H2 V2 BUILD
Ebay link
Will this do? I think the components can be re-arrange to accommodate a volume pot.
I go by the pinch-off voltage, with the Drain attached to +12V, the Gate to ground
and the Source to Ground through a 1 meg resistor. Vp is the voltage across that
resistor. The preferred range is 2.40 to 2.60V, and the Drain voltage setting in the
most recent H2 design is 4.21 times Vp. For example for Vds = 2.5V, the Drain
voltage you want will be about 10.5 volts.
Thanks PaPa. How about Vp range from 2.2 to 2.39 J113?
My Balanced version of the H2v2, unity gain. I'm using it between my Balanced BA2018 preamp and an ALEPH J amplifier. Although the BA2018 preamp gives a very wide soundstage with surprising depth, the H2v2 extends the depth to fill the room.
I had to swap speaker connections when I brought the BA2018 into the main system.
This is my take on the H2 V2 preamp. As you get close to 1V there is also a good portion of 3rd harmonics. At a fraction of a volt it is just 2nd harmonics... but I forgot to take a screenshot. I haven't played with the pots yet. Just set to the Papa's value. 😗
