DIY Sony VFET pt 2 (N-Channel Build)
Joined 2004
No P car in my stable at the moment but I do have another V err 12
Hi, I've replaced the optocoupler and socketed it. No change in measurements or performance. Next to change the MOSFET but they're hard to get so will take a few days.
pics
Official Court Jester
Joined 2003
mosfet - test it first
or place any of IRFP N channel you have around, just slab it somewhere on heatsink with any insulation pad and connect with wires to pads
IRFP150, IRFP 240 will do the job
edit: you can revisit some of these solder joints (trimpot)
especially gray wire from beneath looking fishy, even if from upper side it looks fine; certainly is just ugly but still functional ..... but avoiding ugly in soldering is good practice - leading to higher level of reliability
Joined 2004
I got off Topic with Internal Combustion Engine Banter
VFet N-Channel Update:
I believe I have found my audio nirvana.
Decades of messing around, countless dollars spent,
and a closet full of audio gear, here I am.
The lucky recipient of a "simple" ~10 WPC class A toaster.
My Goodness, this thing is special.
John Lee Hooker with Carlos Santana playing as I type this makes me smile.
