I measure 8.2V across ZD2 (which seems correct looking at the schematics). ZD1 seems odd though, measuring around 1.5V first and steadily dropping to around 3mV. Maybe I got the wrong diode or fried it somehow?
EDIT: That's the one I got
if there is any mistake, blame me ........ or even better - blame Pa
this will help
edit: ignore ZD1-ZD2 designation
as I wrote somewhere, due to mishap with my PC years ago, I unfortunatelly lost consistency between sch and brd Eagle files for this project, so had to wrestle with that even until now, evidently
red written numbers are how zeners needs to be placed
this will help
yup, no relays, no need for parts situated in upper right corner
and yes, input ditto at wiper and gnd beneath
then to AVC of your choice and World is your Oyster
I'm spoiled - once when you properly try inductive attenuator, there is no back to resistive one, doesn't matter how it's made
I went back and read the first twenty or so posts of
Iron Pumpkin(s) and other smaller vegetable animals
the Gain Structure piece and the PSM LS Cookbook
What a wealth of information and what a Pre
My favorite description by Aleksandar
"well - foot-tapping , music is there ..... no thoughts about spectrum dividing , music is simply there"
Following up with the 2016 board, stereo.
I changed my speakers from Pioneer SP-FS-51LR to Polk lsi15. This increased the hum. I cut the ground trace and this resolved the issue.
Still sounds sweet, with babelfish 2j as the amplifier.
Thanks again ZM !
I also built the 2016 boards, and had a similar hum. I forget now without going back in this thread to where I built mine, but later to clear up some other minor deal. I went ahead and also cut those other traces around the relays that ZenMod suggested. Total quiet, no popping between channels, etc. Really love the PS and relay board (I usually use a teabag Inselect here) all on one board.
Hopefully this will be available in the store soon. I believe it is likely my best preamp at this time. It really depends on the mix of other components. The 2018 WLS is very nice. I'm going to build another, board done, and combine it with one of those Muse volume controls. Will make a fine pre I'm sure.
No love lost for the BA3 either, I use two of those! Glad your Iron Pre worked out, you will get much pleasure from that one.
Russellc
Cody, I can't wait to hear what you think. I have my SE Iron Pre staring at me longingly. The balanced is in my system. I may try to outfit the SE with an AVC and give it a try before going with the full Pumpkin. You've inspired me.
I will be watching this one for sure. Will have to wait for another board to be available, (maybe I'll get inspired enough to do this one) hate to not have this pre as is. On other hand, I'm headed to build a SE version of Iron Turtle at some point...
Which AVC are you going to use? The $200.00 dollar one discussed in the other thread, or ZenMods?
Russellc
- What's wrong with the kiss, boy?
