Acoustic Horn Design – The Easy Way (Ath4)
Based on the IR plot it's a resonance around 17 - 18 kHz, it's hardly the waveguide. It comes from the driver, IMHO.
If you correct this with a simple passive RLC (or a DSP biquad, doesn't matter) you should get rid of it to a large degree. (I'm not sure I would bother this high in frequency but you can always test audibility of this easily.)
For the next release of Ath I implemented a new parameter/feature: Slot.Length
It basically adds a flat segment before the actual OS-SE profile, of which the length can be continuously variable (along with all the other parameters). It will be fun watchig what people come up with :)
The wobble is definitely a resonance - stored energy, not a reflection or diffraction. You can recognize resonance by a constant oscillation period in the impulse response. The other effects don't behave like that.
That makes sense as the BMS4550 has a pretty nasty breakup at 18K, there looked to be diffractive ripple in the FR which is what my comment was based on.
Wow! and I agree....I was just swallowing Patricks post and staring at my 2380a lol....I wrote a response and had to delete it cause it finally sank in lol... thinking about the discussions surrounding the 2380a I've had in the past...the idea of its error in technicality (dispersions slots and distortion) combined with the 2382a being used on the Strauss mastering monitor...for home spl levels...maybe there is some potential to combine loading and constant directivity that we have left on the table? Especially after cleaning up the sharp edges.
I envision a focus on slot modelling as a separate discussion from the rest of the horn flair? In that maybe one could take an ideal constant directivity slot and add it to a number if different flare profiles...
One thing to take into account is the idea that with this 2380a the exits area is 3.1416"...an somewhat rough measurement of the slots ending shows the CSA to be ~4.25 (1" wide and 4.25" tall) and with a 4.5inch dept....its sorta like a truncated horn .....that has a very narrow width, thus losing direcivity on the horizontal plane (at HF)...into... another horn/waveguide profile, to help clean things up...at least thats how I see it...
Those minor wobbles indeed correspond to break-up resonances, typical of all 455.. drivers. Nothing to worry about imo.
I bet many people even appreciate the added sparkle, even though it isn't true to the original signal.
Thanks for including this feature.
Over the last 50 years (starting with Abraham Cohen) research has been published regarding diffraction slots. There's specific math involved regarding wavefront propagation along the horn, versus optimal slot length/width/height, versus (eventual) constriction factor in relation to throat and mouth size.
Some clues are given in Keele's horn papers, but there's a lot more available.
Unfortunately, I am currently unable to access the data.
and unless i can't interpret polar charts well how is it that a fifteen degree window across the bandwidth is acceptable....
The nominal beam width is usually given at the -6dB point which on these charts is the outer edge of the orange band, on the Horizontal graph above at 5K the beam width is wider than 90 degrees as the graph is only half the beam width. The slope of the beam as it moves above the on axis rises showing the directivity rising with frequency.
