JFET-only Circlotrons without negative feedback
Why do you keep saying that, but then you don't reply to my requests of showing the test data? Is this just another scam with fake parts?
Hi mbrennwa. Not to de-rail the thread here, but Pras is legit and sells legit parts. Nelson Pass himself has bought many parts from Pras. I also have genuine Tokin THF51 from Pras with more parts on the way. I have no reason to doubt that Pras is trying to help our community get much desired rare parts at a fair price.
I have sent a message to reply to you
I have told you that I am a general measurement method, not a curve test
You asked me to write an email, which I did. I did not receive a reply. Thats why I came back here. Please post the test method and the results here so that we can judge your parts.
Because in the forum, China Network does not support uploading pictures directly
You attached some photos in your earlier post!? Also, I don't care about pictures of your parts. I am interested in the test data.
The second harmonic level depends on the quiescent current of the output transistors. With uj3n065080k3s transistors at a quiescent current of 1A, the level of the second harmonic is -78dB is not so much.
I carried out measurements on a breadboard, the power to the output stage was supplied from a laboratory power supply. Therefore, I did not have the same problem as the jpatay. 🙂
Today I tested the circuit with the inverted power supply of the preliminary part. The diagram shows the transistors that were used. At the output I used transistors IRF150, 2SJ162, 2SK1058. Quiescent current in all cases was 300mA, load 10 Ohm.
IRF150: Vout max=24V, Rout=0.38 Om
2SK1058: Vout max=20V, Rout=2.85 Om
2SK162: Vout max=18V, Rout=2.85 Om
I put transistors IRG4PC40U on the output. Output impedance 0.28 ohm. The maximum output voltage dropped to 13V into a 10 ohm load. When testing the meander, the output transistors went into self-heating. This was not observed with mosfet.
Received my 2SK1530 from Pras1170 today. Used obviously. Nice little board with 5 pairs of 1530 and 2SJ201 in good shape. Maybe some bonus components can be salvaged for tinkering too. 😉 Thanks again Pras!
I finally tamed the JFET SiC UJ3N065080K3S.
The optimal current is 400 mA. For three hours of operation, the current increases from 200 mA to 600 mA. I had to install thermal stabilization from two germanium diodes Д7Б (see circuit).
I am very pleased with the sound. High frequencies cut through. Air and volume appeared in the sound. But I had to make a delay in turning on the UJ3N065080K3S.
Rout - 0.78 Ohm. Frequency response: 5 Hz - 0.6 MHz (0 dB).
Square wave - 60 kHz.
Reactions: savu
