Dartzeel amp schematic - build this?
So disappointed this evening in Copenhagen. With signal -not shorted- as earlier there is huge hum. So have to work with it. Sound is to the dark side. One little speaker only wich I always try before using my expensive Duelund speakers.
One channel with no signal there is no hum. So maybe 4.7 - 10 ohm on the ground inputs.
With the resistors it got worse. Maybe because there is Transformers at output in my PS Audio dac. Will try a buffer between.
Got to take this out again I think.
I would suggest this cabling schema. The only common point point between the two channels is after the ground coupler.
It is intended to be a physical schema, do not move any joint.
With this cabling, I never had hum problems.
I'm in Utah. I opened the distribution box some days ago, without paying too much attention to the cabling, and I think you're right, neutral and ground are connected together. I'm using a 3KVA auto-transformer because, coming from Italy, all my stuff works with 230Vac. I see we have 230Vac also but it is used only for the stove and I don't want to do the job of extending the cabling. So my audio set is working with mixed voltages (all sources work with 115Vac) but I don't see any problem.
That is a very good clue! I didn't know. Thank you!
I'll open the distribution box again to better understand the cabling and, If I can find two outlets, close to the audio set, having different cablig, hopefully thier phases could be inverted. If so, I could disconnect the auto-transformer that, being chinese, runs hot.
