FET vs BJT input phono preamp
www.hifisonix.com
Joined 2003
You can almost guarantee it. DIYaudio is about the only place where people measure phono stages in a sensible manner...and then overkill them a few more dB for good luck :).
Yes. I remember we took John Atkinson to task here for measuring phono stage noise by shorting the inputs.
Problem is he has many measurement reviews going back xpc. 25 yrs so it would be unfair to now start testing with a real world source.
@dreamth
That’s still not a nasty enough source! 1970’s phono stages were crap. Period.
Sorry to be blunt :)
Account Closed
Joined 2010
@dreamth
maybe you can point point out a better solid state design than this 1982 one....yeah, i know it has fet transistors too , but i also know a lot of other things i am not going to fill this topic with...
Account Closed
Joined 2010
Indeed, it uses JFETs as the moving-magnet input stage. Anyway, the 1978 Hoeffelman and Meys circuit will probably outperform it, at least regarding noise.
www.hifisonix.com
Joined 2003
Start with the cartridge and the load (47k // with c. 200pF for a 2 more cable).
That’s the absolute limit of performance and you cannot get better than that. So we can talk about IHF specs, blah blah blah but you can never be better than the Johnson noise of the source plus load.
Plug the data for your cart in here (Download the spread sheet) and set the opamp noise inputs to Zero
So Just How Quiet is Your Phono Stage?
www.hifisonix.com
Joined 2003
The Yamaha circuit has a compromise input stage: the tail current is too low for moving coil and too high for moving magnet. As a result, its equivalent input noise voltage will dominate for moving coil and its equivalent input noise current for moving magnet. With shorted input, the equivalent input noise current has no effect, so you get reasonable numbers for moving coil and way too high numbers for moving magnet.
Account Closed
Joined 2010
I didn't even bother to think of it...i found that example when trying to see what IHF-A means...The only numbers that i am really interested in when i see a new service manual are the input sensitivity and the max input overload margins...For kenwood are double than for yamaha as it's a discrete design supplyed at +-43v...In all the schematics i ever saw , the kenwood one is the best by far.Although it has such high supply rails it has soft clipping at every stage...and that's smart.The only thing that makes a phono preamp shine is his behavior under stress,not its out of this world SNR...
This is the original Hoeffelman and Meys configuration, redrawn to avoid copyright issues. It is just a flat-gain amplifier with a gain of 34 and an electrically cold 47 kohm input resistance. You can turn it into a RIAA amplifier by replacing R2 with a RIAA correction network. You need some kind of buffer after the output, as any load disturbs the input resistance. See the Journal of the Audio Engineering Society December 1978 (original article) and September 1979 (letter from Ernst Nordholt pointing out that R2 could be replaced with a RIAA correction network).
