What's wrong with the kiss, boy?
Thanks to 6L6 I was able to get these balanced boards. I plan to use them with my Serbian Balanced Lightspeed volume control. Also, thank you Zen Mod for this great project!
Just got my parts, time to build them!
Joined 2003
if you think of enabling relay , that's easy - explained earlier in thread , few days ago
14 pins IDC connector : short pins 1 and 3 for input 1
1 to 5 for input 2
1 to 7 for input 3
1 to 9 for input 4
1 to 11 for input 5
I have 2016 boards if that matters, per phone call with Jim, I should connect #2 and#4 to turn on one...however in post above, slightly different #723...add to that I did all this with no coffee (nice dark Sumatra now) combined with professional level ability to destroy anvil with rubber hammer
I got the Gemini shunt sections soldered up and tested with load resistors. I was only able to get a max of +/- 11v regulated out of them. After trouble shooting I realized I got 2.5v lm336’s instead of 5v.
Does anyone think I should order replacements or can I swap out the upper voltage divider resistors R10 and R7 for a higher value, say ~100k?
I am using all the values from this schematic except for U1 and U2 where I used 2.5v instead of 5v ones. With my limited knowledge I was thinking I could up the R10 and R7 values to get voltage division lower?
Thanks for tip on load resistors, I won't bother tacking them on for second board I test! :)
