The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
X, thanks for the reply. Having a hard time visualizing a single rail psu being used for 2 channels. Single rail to me means 1 channel or 1 pcb in the case of ACA. So for 2 ACA pcbs, why not a dual rail. Help with understanding.
MM
@kokanee:
Single rail means single positive voltage output.
Dual rails means positive and negative output.
You could use dual single rails for dual ACA monoblocks. However if ACA is in single chassis, a single rail SLB can easily handle current for both channels as it can do 5 A continuous.
@myl: In the shop, choose the single rail variation. The trim pot gives about only 1v of adjustment. It’s really not needed in retrospect as we should have just set it at about the midpoint with a resistor. It’s to allow adjustment of the output to make sure ripple is minimized. You need an O-scope to do that.
Please note that these are Gen 2 boards and no longer accept the 90 deg Molex Minifit plugs. They are the vertical ones now. This was to make the board lower profile.
Just like to assure people that the vertical Molex sockets work fine on Gen 1 boards. 🙂
That's what I used, as I am mounting my SLB boards vertically - so couldn't have the wires coming off sideways to the boards.
Andy
I don't think I ever posted this, but a while back, I tested out the SLB single rail at 30v and 3.75A using a big 8ohm wirewound dummy load. It showed excellent performance with sub 1mV rms ripple. This is perfect for a single rail Class A amp like the MOFO.
SLB SR fully assembled:
attachment.php
Test setup:
attachment.php
Measured ripple upstream of the ripple eating BJT and after it:
attachment.php
Has anyone had trouble getting the ground Faston tabs soldered properly? I know that they conduct a bit of heat out and it might be hard for solder to fully melt and flow. So if you are having issues, please try to use a bigger (higher wattage) iron, use a big fat chisel tip, use good name brand leaded rosin core solder, set the iron to 400C. Hold the chisel blade so that it touches the flat of the spade terminal and the board solder pads. Slowly add solder so it melts and flows. Hold it for about count of 10.
If this still doesn’t work, preheat the area on the board with a hot air gun.
No, I've not had any problems like that, X. (But I do have a non temp-controlled soldering aron with a 6mm wide chisel tip. 🙂 )
The problem I do keep having 😡 is that, as the PCB is upside down for the soldering, the solder travels down to the end of the spade ... making it hard to get the female connector on. 🙁
Great tip, X! 🙂
I will use my new air soldering gun for this, at the very least! 😀
Andy
