What's wrong with the kiss, boy?
Hi Mighty ZM,
For the input buffer jfets, would higher Idss be preferable (say 10mA vs 6mA in
the BL range)?
Also, how high/low value for the pot is recommended? 100k Alps is available
at mouser and I think 20K and 50K at other stores.
Thanks,
Dennis
higher Idss is OK , just keep an eye od dissipation (say no more than 150mW per JFet, more is making me nervous...if needed ,just increase resistance of source trimpot,, meaning - use first bigger value )
pot value - that's relevant to sources you have in front of pot - more cojones,lower pot value
so ,10Klog to 100K log
oh , btw.......
there is ongoing e-mail correspondence between Flying Jim (6L6) and Patrick A. (sorry, ZM didn't catch Patrick's Nick) and Mighty ZM ..... you can easily grasp how easily ZM is confused with e-mails flying between 3 of us ....... :rofl:
anyway , topic is final development of Iron Pre preamps ( both SE and non-SE) , mostly related to brushing up nomenclature , enabling all bells and whistles,helping with BOMs and preparing of Build Guide , enclosure(s) etc.
my part is finished (sch and pcbs) , so I'll post just teasers -- how final pcbs are going to look
hope I'm not stepping here on their toes ...... 🙂
edit: Diyaudio gave me so much during all these years , this is just a smidgen , me trying to give something back
Iron Pre SE (hope is ) Final
Iron Pre (hope is ) Final
well, ''Pre'' in title is somewhat hinting that ....... 🙂
but , anyway , that's line preamp stage , where you have selector (5inputs) followed with resistive attenuator (volumepot) , then followed by buffer (with reg. psu ) and finally autoformer at output ..... everything on board ;
SE iteration - both channels on one pcb , 3 different brands of autoformers applicable, settable gain 6db or 12db
Bal iteration - one channel- one pcb , 3 different brands of autoformers applicable, gain fixed 6db , arbitrary number of (fixed) SE inputs , rest to 5- Bal inputs, both SE and Bal outputs (active in same time) ; so , functioning as SE in/Bal out and Bal in /SE out converter , and normally as Bal in/Bal out stage
if I forgot something ........ just shoot
