Acoustic Horn Design – The Easy Way (Ath4)
I re-read the Chapter 6 and it makes much, much more sense to me now (even though the math itself is still above my head to a large extend). It's almost an intuitive reading now 🙂
It states (p.145), among other things:
"If instead of driving the throat with a wavefront of constant amplitude we taper this amplitude as shown in Fig. 6-12, then the net effect will be to create adistribution of the velocity at the mouth which has a far more uniform distribu-tion than one fed with a flat throat velocity distribution"
Would it make sense then to try to damp the phase plug exit this way? I'm thinking about putting an open cell foam (the right amount and density) into the exit rings openings. The 18Sound ND4015 seems like a good candidate - laying on my bench right now. It has four slits for a 1,4" throat, reaching the exit of the driver.
Another excerpt (p.148):
"...The only way for this higher order mode creation to not occur would be for there to be a wavefront radius source point which did not move in space, as opposed to one that is changing in each section. It is now readily apparent that any waveguide which has a changing location of the origin for the wavefront radius will require the presence of higher order modes to account for this changing origin."
It seems that this (i.e. the wavefront origin shifting) is exactly what happens for larger throats. For a smaller throat it takes less of the contour to approach a cone, more for the larger.
sorry to butt in but as the math is dumfounding to me, i hope i can ask a few questions to gain some understanding (and hopefully start to make a math to english bridge for myself)
currently these equations are plotting a particular curvature with the intent of doing so with a minimum of problems in the field of interest(i.e. a field defined by the directivity) or am i out to lunch?
I tried the step-tappered throat amplitude but not much of improvement so far. Maybe the exact wavefront profile is much more critical than I anticipated.
(2" throat, 75deg coverage; from left: flat, taperred(1), tappered(2))
hey...thanks...just conjecture on my part but but given modern computing power would it be possible to convert the information obtained in a polar map(visual) into a audible algorithm for auditory evaluation i.e. hear the results of shape changes to horn curvature?
I find that unlikely. What's the radius then?
I agree. That is not what virtually all CDs try to do, so I don't see how or why this would be the case here. It seems to me to be almost impossible to achieve and almost as difficult to prove.
Which brings me to where I think the research should go from here. One of my last project at B&C was to develop a plane wave tube measurement of the exit waveshape. I worked out all the math, but the system was never implemented to my knowledge.
With measurements like this we would know exactly what we have at this interface and may be able to better optimize a waveguide for the actual situation and not an assumed one.
Did you just shade the amplitude? Is there phase shift as well?
I do see some substantial effects even with what you showed. I would not expect a huge effect even best case. We are talking about 2nd order effects here.
One of my last project at B&C was to develop a plane wave tube measurement of the exit waveshape. I worked out all the math, but the system was never implemented...
How did this work? I don't mean the math but what was the measurement set up?
JBL explicitly tout the flat exit wave shape of the D2430K compression driver (used in their M2 reference monitor).
They do show some plots to support the claim but I have never seen any information on how they measured it.
I did wonder if a Microflown had been tried.
Best wishes
David
Put a CD on a plane wave tube with known nonreflective termination. B&C had one of these, they wrote a paper on it. Place N microphones at Xn distances. From the math you can find one mode for each microphone N. Its a matrix problem that is almost certainly unstable and near singular at certain frequencies, but with SVD this could be done, but it would likely add a few mics to get an overspecified matrix.
must be a language thing but to me it's "unfortunate"....dsp..FIR...seems something could do it...it would be invaluable to evaluate the audible results of all the horn math....
I imagined electrodes connected to one's brain to "listen" how the horn would sound in real (and fortunately we are not that far yet)... Otherwise I don't think it's possible to emulate that with electronic filters only.
Just the amplitude. I tried the range 1 -> 0,5-0,8 with various steps. Some was better, some worse. I want to try this on a real driver some day.
