Vacuum Tube SPICE Models
Triode-Connected
Code:
* Generic triode model: D3A_PT_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Dec 24 08:47:57 2013
*                 Plate
*                 | Grid
*                 | | Cathode
.SUBCKT D3A_PT_AN A G K
BGG   GG   0 V=V(G,K)+0.38087015
BM1   M1   0 V=(0.0021582473*(URAMP(V(A,K))+1e-10))**-0.28773641
BM2   M2   0 V=(0.83904987*(URAMP(V(GG)+URAMP(V(A,K))/74.574462)+1e-10))**1.7877364
BP    P    0 V=0.03039942*(URAMP(V(GG)+URAMP(V(A,K))/88.879654)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.018902992*V(M1)*V(M2)
BIG   IG   0 V=0.01519971*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.015714194*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 2.7p
CGK   G    K 7.3p
CAK   A    K 3.1p
.ENDS
Good!
And do not skip this beautiful Ale's triode model.
Btw, my collection of D3A`s.
I'll throw my triode connected model into the ring. Made using Curve Captor from Siemens data sheet.
Code:
* D3a triode connected pentode LTspice model
* Modified Koren model (8 parameters): mean fit error 0.499405mA
* Traced by Wayne Clay on 6/24/2015 using Engauge Digitizer and
* Curve Captor v0.9.1 from Siemens datasheet.
.subckt D3a-t  P G K
    Bp  P K  I=(0.2505628718m)*uramp(V(P,K)*ln(1.0+(-0.1791266922)+exp((4.510443556)+(4.510443556)*((84.18566045)+(-3454.657477m)*V(G,K))*V(G,K)/sqrt((29.60063818)**2+(V(P,K)-(-4.621358765))**2)))/(4.510443556))**(1.176920934)
* Capacitances: G2+P, G3+K
    Cgk G K 8.3p ; 1.0p added (7.3p)
    Cpk P K 4.1p ; 1.0p added (3.1p)
    Cgp G P 2.9p ; 0.2p added (2.7p)
    Rpk P K 1G ; to avoid floating nodes
    d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends D3a-t
Ale to the rescue!
2P29L – Preamp and driver for 4P1L PSE Amp – Bartola(R) Valves
Pentode:
Code:
**** 2P29L DIRECTLY HEATED PENTODE ** Composite DHT with Advanced Grid Current **************
* Bartola Valves | All about electronic valves and hi-fi
* Plate Data source link: Bartola Valves | All about electronic valves and hi-fi
* Plate Curves image file: 2P29L-triode-model.jpg
.SUBCKT 2P29L_AM P G K1 K2 ; 1 2 3 4
+ PARAMS: CCG=6P CGP=8P CCP=4P RFIL=13.5
+ MU=9.1 KG1=2445 KP=140 KVB=21 VCT=-0.46 EX=1.4
+ VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=2
* Vp_MAX=350 Ip_MAX=140 Vg_step=5 Vg_start=10 Vg_count=9
* Rp=4000 Vg_ac=55 P_max=9 Vg_qui=-48
* X_MIN=77 Y_MIN=89 X_SIZE=492 Y_SIZE=526 FSZ_X=1157 FSZ_Y=724 XYGrid=false
RFIL_LEFT 3 31 {RFIL/4}
RFIL_RIGHT 4 41 {RFIL/4}
RFIL_MIDDLE1 31 34 {RFIL/4}
RFIL_MIDDLE2 34 41 {RFIL/4}
E11 32 0 VALUE={V(1,31)/KP*LOG(1+EXP(KP*(1/MU+V(2,31)/SQRT(KVB+V(1,31)*V(1,31)))))}
E12 42 0 VALUE={V(1,41)/KP*LOG(1+EXP(KP*(1/MU+V(2,41)/SQRT(KVB+V(1,41)*V(1,41)))))}
RE11 34 0 1G
G11 1 31 VALUE={(PWR(V(32),EX)+PWRS(V(32),EX))/(2*KG1)}
G12 1 41 VALUE={(PWR(V(42),EX)+PWRS(V(42),EX))/(2*KG1)}
RCP1 1 34 1G
C1 2 34 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 34 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC1 81 0 VALUE={V(2,31)-VGOFF} ; POSITIVE GRID THRESHOLD
GG1 2 31 VALUE={0.5*(IGA+IGB/(IGC+V(1,31)))*(MU/KG1)*(PWR(V(81),IGEX)+PWRS(V(81),IGEX))}
EGC2 82 0 VALUE={V(2,41)-VGOFF} ; POSITIVE GRID THRESHOLD
GG2 2 41 VALUE={0.5*(IGA+IGB/(IGC+V(1,41)))*(MU/KG1)*(PWR(V(82),IGEX)+PWRS(V(82),IGEX))}
.ENDS
Triode-wired:
Code:
** 2P29L TRIODE ************************************************************
* Created on Fri Jun 15 19:29:17 BST 2012 using tube.model.finder.PaintKIT
* model URL:[url=http://www.bartola.co.uk/valves]Bartola® Valves – All about electronic valves and hi-fi[/url]
.SUBCKT 2P29L-T_AM 1 2 3 ; A G K
+ PARAMS: CCG=6P  CGP=8P CCP=4P RGI=2000
+ MU=9.1 EX=1.4 KG1=2445 KP=140 KVB=21 VCT=-0.46 ; Vp_MAX=200.0 Ip_MAX=0.08 Vg_step=2.0
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
6267, EF86 equivalent.
Code:
* Generic pentode model: 6267
* Version 3.10, Generated on Sat Mar  8 22:42:16 2008
*               Plate
*               | Screen Grid
*               | |  Control Grid
*               | |  |  Cathode
.SUBCKT 6267_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.59868749
BM1   M1   0 V=(0.010782364*(LIMIT(V(G2,K),0,1e16)+1e-10))^-0.70765893
BM2   M2   0 V=(0.67945278*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/29.728844),0,1e16)))^2.2076589
BP    P    0 V=0.0013378994*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/43.754099),0,1e16))^1.5
BIK   IK   0 V=STP(V(GG))*V(P)+(1-STP(V(GG)))*0.00078620809*V(M1)*V(M2)
BIG   IG   0 V=0.00066894969*LIMIT(V(G1,K),0,1e16)^1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.83966688*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))^1.5+0.16033312)
BIK3  IK3  0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+7510)/(LIMIT(V(G2,K),0,1e16)+7510)
BIK4  IK4  0 V=V(IK3)-LIMIT(V(IK3)-(0.00071507731*(LIMIT(V(A,K),0,1e16)+LIMIT(LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16),0,1e16))^1.5),0,1e16)
BIP   IP   0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.00071507731*LIMIT(V(A,K),0,1e16)^1.5),0,1e16),0,1e16)
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=LIMIT(V(IK4,IP),0,1e16)
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.05p
CGK   G1  K  2.3p
C12   G1  G2 1.5p
CAK   A   K  5.3p
.ENDS
I'm getting really wacky results in a known working circuit. using LTSPICE VII on mac. Duncan's works. Am I doing something wrong using pentode2.asy? Basically the sim shows -54 dB at 100K and sloping down to 20 Hz
Try this:
Code:
.SUBCKT NU6P1 1 2 3
+params: MU= 18.10 EX= 4.080 KG1=4270851.9 KP=451.94 KVB= 4.2 VCT= 0.00 RGI=330k CCG=9.1P CGP=2.5P CCP=4.3P
E1 7 0 VALUE=
+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
.ENDS
Thanks for providing the Nutube model Jazbo.
Anybody know how I can make this connection marked in red in LTSpice?
