Electrometer tubes
Well, for dealing with electrometer tubes, grid currents are interesting (the most interesting parameter in fact).
Hi stijena1973
FYI:
My triode model is able to mimic the small initial velocity current. But in electrometer tubes, there are also gridcurrents in the sub-nA-range of interest, where further effects play a role. This area is still uncovered by the known spice model approaches...
All the best, Adrian
FYI:
ltspice model
Hi all:
Does anyone have a model of the 6ES8-ecc189 triode? I can't seem to find one anywhere.
Thanks,
Hi all:
Thanks,
Hi all:
Thanks,
Code:
* 6ES8 LTSpice model
* Koren model (5 parameters): mean fit error 0.405269mA
* Traced by Wayne Clay on 01/01/2019 using Engauge Digitizer 5.2
* and Curve Captor v0.9.1 from Sylvania data sheet.
.subckt 6ES8 P G K
Bp P K I=
+ (0.001667389859m)*uramp(V(P,K)*ln(1.0+exp((0.02294225145)+
+ (0.02294225145)*(3057.880457)*V(G,K)/sqrt((0.1158340263k)+
+ (V(P,K))**2)))/(0.02294225145))**(1.268488137)
Cgp G P 2.55p ; 0.7p added (1.85)
Cgk G K 4.0p ; 0.7p added (3.3p)
Cpk P K 0.38p ; 0.2p added (0.18p)
Rpk P K 1G ; to avoid floating nodes
d3 G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 6ES8
Code:
* Generic triode model: ECC189_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Dec 25 13:38:23 2018
* Plate
* | Grid
* | | Cathode
.SUBCKT ECC189_AN A G K
BGG GG 0 V=V(G,K)+0.32201735
BM1 M1 0 V=(0.35943878*(URAMP(V(A,K))+1e-10))**-21.749142
BM2 M2 0 V=(0.06451851*(URAMP(V(GG)+URAMP(V(A,K))/2.602617)+1e-10))**23.249142
BP P 0 V=0.0091825815*(URAMP(V(GG)+URAMP(V(A,K))/40.339075)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*1.6647528e+23*V(M1)*V(M2)
BIG IG 0 V=0.0045912908*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0049348506*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 1.9p
CGK G K 3.5p
CAK A K 1.7p
.ENDS
Hello, I did a search and could not find spice models for tube types RS1003. Anyone know of one for each of these? Thanks.
There is not much on the topic in the internet. The only mention of the component currents I saw is in "Electrometer tubes, part 1" by Dolezalek. But if the curve is known from the datasheet, maybe some kind of a look-up table is possible?Hi stijena1973
FYI:
Yes, that should be possible, with some restrictions:
1) it will not be a genetic approach
2) only valid for a given condition (as described in the datasheet for that specific graph)
6N21B model
Hi guys! In case anyone needs model for Russian 6N21B (6Н21Б) triode, here it is, created by myself using model paint tools:
Code:
.SUBCKT 6N21B 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=2.7P CGP=0.6P CCP=1.4P RGI=2000
+ MU=113.16 KG1=585 KP=276 KVB=225 VCT=0.912 EX=1.526
* Vp_MAX=320 Ip_MAX=14 Vg_step=0.5 Vg_start=0 Vg_count=8
* Rp=4000 Vg_ac=55 P_max=1 Vg_qui=-48 Vp_qui=300
* X_MIN=70 Y_MIN=11 X_SIZE=667 Y_SIZE=593 FSZ_X=2578 FSZ_Y=1458 XYGrid=true
* showLoadLine=y showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=n dissipPlot=n
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Yes, I understand.. I'll make one myself one day (CK5886).
Any suggestions which method /package to use?
Anyone has a ltspice model for the russian heptode-triode 6И1П (ECH81) or the ECH84? Im also quite into radio and Ill use these boys as mixers and oscilators.
The only Heptode model I know is from Derk Reefman. He posted a beta version of the ECH81 (heptode part) in the LTspice google group:Google Groups
I hope that may help you.
Thanks, I do have the EH90 model in my koren tube models collection so someone else had to make models as well.
See Vacuum Tube SPICE ModelsHello, I did a search and could not find spice models for tube types RS1003. Anyone know of one for each of these? Thanks.
- Tubes / Valves
- Vacuum Tube SPICE Models
