Try this:
Code:
.SUBCKT NU6P1 1 2 3
+params: MU= 18.10 EX= 4.080 KG1=4270851.9 KP=451.94 KVB= 4.2 VCT= 0.00 RGI=330k CCG=9.1P CGP=2.5P CCP=4.3P
E1 7 0 VALUE=
+{V(1,3)/KP*LOG(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Hi!
Does any of you have a model for triode strapped 6J1P 7pin Russian mini pentode?
I've got a bunch of them, and would see if it is useful for anything...
Thank you!
Thank you!
6CM8 spice model
Hi at all! Someone have a spice model of 6cm8 triode pentode tube? The triode is very similar a half 12ax7, but the sharp cut off pentode I dont know similar...
Please help me
Please help me
If you can trace the pentode curves for the 6CM8, I can make the SPICE model for you. For the triode, just use the 12AX7 model.
the datasheet have the curve, is enought?
http://www.mif.pg.gda.pl/homepages/frank/sheets/137/6/6CM8.pdf
Vp = 0 to 300V
Pdiss < 2W (probably limit Ip < 30mA)
Vg = 0 to -10V in 1V steps
with G2 directly connected to the plate.
Does anyone have a model for the following dual pentode compactrons or have an opinion on what single pentode models might be close enough?
6AR11
6BV11
6BN11
I'll keep looking on my own but if anyone has one, thanks!!
6AR11
6BV11
6BN11
6BN11 SPICE Model
Code:
* Generic pentode model: 6BN11_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Nov 01 18:19:03 2014
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT 6BN11_AN A G2 G1 K
BGG GG 0 V=V(G1,K)+0.80333486
BM1 M1 0 V=(0.016690499*(URAMP(V(G2,K))+1e-10))**-1.028498
BM2 M2 0 V=(0.59323756*(URAMP(V(GG)+URAMP(V(G2,K))/24.370897)))**2.528498
BP P 0 V=0.0032099434*(URAMP(V(GG)+URAMP(V(G2,K))/41.081176))**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0021774044*V(M1)*V(M2)
BIG IG 0 V=0.0016049717*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.75853563*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.24146437)
BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+3175)/(URAMP(V(G2,K))+3175)
BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.001722887*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.001722887*URAMP(V(A,K))**1.5)))
BIAK A K I=V(IP)+1e-10*V(A,K)
BIG2 G2 K I=URAMP(V(IK4,IP))
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.03p
CGK G1 K 7.2p
C12 G1 G2 4.8p
CAK A K 2.8p
.ENDS
- Tubes / Valves
- Vacuum Tube SPICE Models
