Yeah, but I'm not able to send to him my mail address...
Sorry, I had a few requests and my mail box was full.
So I have placed my email address in my profile details, you can find it there and send me yours.
Best wishes
David
You need those switches because VPSRR as a 1V sinus source is added between 50V power source and V+ from amplifier.
Input needs to be grounded during this test.
BR, Toni
Sir Toni,
Connecting the input to ground I get a blank plot.
I tried switching to different functions at Voltage source (input) i.e. none, Pulse, Sine no response but if I put 1 at the AC amplitude, I get a reading. A little different from my other post, Is this valid?
Input voltage source is set to none. AC amplitude = 1.
Sa muli,
Albert
Hmmm...my plot seems to look like the opamp test
I even replaced all ground symbol to bi-directional PWRGND net label.
SA2015: using vertical mosfets IXTH80N20L and IXTH48P20P - SOA
In post 2155 I showed a dual slope limiter which is designed to protect the amplifier in a worst case condition. The SOA limiter curve are designed to not violate the Tc 75 degree points. Short back EMF pulses are viewable and (hopefully) also within SOA limits. If I lower the bias voltage to fullfill your above needs of about 300mV the SOA limits are clearly and heavily violated. You only have the decision: lowest THD or good SOA protection.
You only can get lowest THD and good SOA protection if you add many many output pairs and oversize your amplifiers power limits.
BR, Toni
My "rule for limiters" is:
All valid output signals must pass to all valid loadings.
BR, Toni
Hmmm...my plot seems to look like the opamp testI even replaced all ground symbol to bi-directional PWRGND net label.
Revert it and remove PWRGND as shown in the simple opamp circuit.
Input signal source must be removed and input short circuit to ground.
This one perhaps? V(n019) is before the zobel.
I remember your post2155, but I could not understand what the plots were trying to show.In post 2155 I showed a dual slope limiter which is designed to protect the amplifier in a worst case condition. The SOA limiter curve are designed to not violate the Tc 75 degree points. Short back EMF pulses are viewable and (hopefully) also within SOA limits. If I lower the bias voltage to fullfill your above needs of about 300mV the SOA limits are clearly and heavily violated. You only have the decision: lowest THD or good SOA protection.
BR, Toni
Good news!Dear Timios,
you may need a heatspreader. Operating the amplifier modules at about 450mA total bias dissipates 38W per side.
The modu heatsinks have 0.5 K/W for your 200x40x120mm sized heatsink parts. So the temperature rise above ambient will be minimum 19 degree. If you don't like up to 60 degree hot heatsinks in summer you can ask a local supplier for 2 pieces 200x80x6mm aluminium parts to build your own heatspreader.
(Will have a look into bin if I can find some suitable parts ... will send you an email soon.)
BR, Toni
I found this 200mmx80mm thickness 10mm.
Sir Toni,
I am attaching the spice files of my amp, I know you are a very busy man but when you find the time please have a look at it.
Thank you!
Voltage sources naming is wrong. "V+" is not the same as "+V"
BR, Toni
BR, Toni
My bad, that was a small detail that I neglected to double check.
Got it this time. Thank you!
The effect of slow down of the current limiter. The short spikes are possible only because of the 22pF caps. If you increase the caps you also increase the time and intensity of SOA violation.I remember your post2155, but I could not understand what the plots were trying to show.
Good news again.
Aluminium received today!!!
Really fast!!!
This is the seller.CNC cutting machines
All screws by modushop will be replaced with inox screws and safety washers.😉
Really fast!!!
Perfect!😉
Best wishes
David
||OT IXYS models||
Dave, I wrote you mail yesterday and I don't have any feedback. Could you reply on my mail please?
Thanks.
As you wish🙂 Which ones do you want?
Thanks! If I would have a wish free for christmas ... 😉
- 2SC3902T and 2SA1507T (onsemi; obsolete, but have tons of it)
- 2SC4027T-H, 2SA1552T-H (onsemi; in production; datasheet values look extremely similar to 2SC3902/2SA1507; maybe SMD variants of them)
P.S.: It's so sad that so many good transistors are no more in production.
P.P.S.: The good news: I have most of the old parts on stock for future projects 🙂
If I make it back to Austria one day then you can buy me a drink😉
The 2SA1552/2SC4027 look OK, a few little kinks on the datasheet that I probably can't reproduce, maybe not real anyway.
I will play around with it, I expect that if you did a few of these then it would be possible to look at the datasheet and just write a model immediately, without conscious calculation.
Best wishes
David
Best wishes
David
Dear Dave,
you will be welcome at any time here in Austria! 🙂
Many thanks in advance!
If you need I could scan some pieces from different lots using my DCA77 pro.
BR, Toni
- 2stageEF high performance class AB power amp / 200W8R / 400W4R
