DAC ES9038 PRO Group Buys
The bottom one is 'current mode'. Instead of a 10K resistor, the coil is connected directly to the ground instead. Each coil (of the LL1684) has a resistance of 41 ohm. Thus the output of the DAC will force current through the coil to the ground. Thus the coil is also acting like a resistor and performs an I-V.
No. The resistance is immaterial for the I/V as it is a DC parameter.
The only consequence of the low resistance value is that the dc level at the dac output is now close to zero volts. There is no i/v conversion as the secondary of the transformer is unloaded.
So, what kind of load does the dac see at audio frequencies then? Not sure about this particular transformer but i have measured a similar Lundahl and the inductance of each primary was around 40-50H. Something like 500k @2kHz?
Again, nothing wrong with the circuit, just don't kid yourself it is somehow resembling current mode as it is not.
Hello Quanghao,
Sorry but because of lack answer on my private emails I must ask you on forum:
Could you inform me about progress with my orders?
23/03/17
Me:"Please confirm my payment for DAC controller and chassis. I'm confused.
Regards"
Quanghao:Yes, next week I will ship to you.
Thanks!"
Hi Quanghao, how would the schematic look like for balanced output? Thank you!
Tuanqv58.
Originally Posted by quanghao View Post
Ok, now. New IV
I have tried to test a lot of IV for ES9038.
And finally I'm very happy with this design, that's my choice,
Combination LL1684 and electronic lights.
Yes, I specifically use Duelund output capacitors!
OHA ! Yes ! And great sound effects!
Thank you Mr. Duelund!
quanghao
Ok, now. New IV
You please take a look at it and test!
thanks
quanghao
Andrea/Quanghao,
I'm definitely interested in the "T-Super I/V" as you described here. I want to wait to see how circuit will be set up for balanced output (no need to switch between balanced and unbalanced). Parts connextion has nice sale on film capacitors, and I want to order some parts. Will the output capacitors remain approximately 1.0 uF? Is there any reason to go any higher such as 2.2uF as you did with your Duelands or was that just because you had them?
Do you have any PCBs for your high voltage and heater power supply as pictured?
Thanks,
Doug
Ok, now. New IV
thanks
quanghao
Andrea/Quanghao,
Thanks,
Doug
Tuanqv58.
Ok, now. New IV
quanghao
Hi QH,
I hope that enjoy and great sound pefect. I wait feedback from you .
Brd,
Tuanqv58 .
"Quanghao,
I'm confused.
xxxxxxxxxxxx
Thanks!
xxxxxxxxxxxx
Any information?
xxxxxxxxxxxx
Im sorry, I sent them to you on this week.
Thanks!"
...and still waiting from March! We paid 70USD just for delivery!
Please give me ANY information about delivery:
- DAC controller- Encorder + 4x20 LCD,
- Chassie.
Hello friends!
I know you are anxious!
We are taking the time to test the iv for 9038pro, we work very hard 12 hours a day.
So I did not go online. Looking forward to sympathy for me.
I have tested 10 different designs, however, we find the design below suitable and have the best sound.
It has a balanced output - directly from LL1684, but the amplifier is small, about once.
The output is not needed by using a large amplifier tube ~ about 3 VRMS
Please wait and pay for the DAC kit, and have fun waiting for the best results, please see the circuit diagram. The circuit diagram has a few points I did not publish.
thanks a lot!
