APEX AA9
Mr. Mile,
I have added rail decoupling near the o/p device and also ground lift.
Is it recommended?
+some reduced the PCB size to 68mmx75mm
reg
Prasi
PS; many revisions, but i want to make it as good as possible.
edit: the black jumper is optional jumper to reduce the trace length from C7 to C of T6.
Mr. Mile,
Is it recommended?
reg
Prasi
Mr. Mile,
Is it recommended?
reg
Prasi
Nice work... you do not need this jumper.
Nice work, did you use loudness switch?
Thanks Mr. Mile.
I made two jumpers instead, but I'm planning to use a proper switch as soon as I connect the TB1 to amp.
Regards.
but difficult to layout😀..
Nice work, you can help to some diyers with Super Gainclone PCB in thread: http://www.diyaudio.com/forums/chip-amps/162099-lm3886-schematics-pcb-45.html
You can't use the output stage diamond buffer in a power amp that way.Simple amp idea.
It's basically two symmetrical SE stages that go to current clipping very fast (if you don't bias it to pure class A) . Simple version from your sch. works for small signals but if you want to make it push-pull you'll have to use a big cap to connect the bases of output transistors. Then it will work but not very good - pair of lateral MOSFETs will do much better job, and then you get old F5-gone-BJT with addition of source follower output stage...
Little improvement.
Hello everyone
Prasi, I finished my PCB (first version) for the AA9. Now I have to solder the components.
Regard's 🙂
That looks as good as the manufactured PCB🙂, nice etching!
regards
Prasi
Hello. Tell me the characteristics, what is the quiescent current and power apex a40? thank you in advance
Hi, here are some measurements. I've corrected the offset by changing the 470R resistors. But I think now the amplifier is underbiased.
Advice are welcome 🙂
But the sound is very, very good. Deep, powerful bass, well balanced mids and transparent beautiful highs.
Regards Olaf
hi i also have made fx12. sounds just as olaf described, and i have vssa to compare. 😀
how do i increase the vas current tho? change out 22k resistors or the 220ohm?
Change 220R in VAS, use 150R or 100R.
thanks mr miles.
i can stop being impressed by this amp. deep and musically satisfying, it's the best amp for me yet, and i've built vssa and aksa clone in the past.
may we have bjt version of fx12, please? 😀
thanks mr miles.
There is EX14
Which is the total power of the amplifier load 8R ? Thanks!
120W/8R, 200W/4R
- 100W Ultimate Fidelity Amplifier
