2stageEF high performance class AB power amp / 200W8R / 400W4R
If you really need 2SC5171 send me an email - have a look at the index at post #1. The design itself has been finally evaluated using 2SC4793 and 2SA1837. (see post #1145 - 1150 and index post #1).
BR, Toni
Thanks, I got the 2SC4793 already. I just wonder anyone still sell 2SC5171 as it's a slightly better transistor with higher fT.
From your experience, How reliable is LTSpice it simulating stability and phase margin?
I finally have the astx running.
It's taken me a long time and it sounds nice.
Operating on ±48Vdc supply rails and biased to 510mA through the 3pair Lateral mosFET output stage.
The transformer is 240:4 * 34.5Vac for two isolated channels.
It will do 105W into 8ohms one channel driven and rises to 178W (-0.7dBW ref 8r) into 4ohms one channel driven.
I have 4 digital cameras and none of them are capable of getting pics into a PC.
At least one of your digital cameras will have either a memory-stick, sd-card or a camera-pc or usb-interface. For memory stick and sd-card you will get ultra cheap universal readers here for example at amazon searching for
"All in One USB Multi Digital Camera / Mobile Phone Picture Memory Card Reader".
For camera-pc or usb-interface you need a special cable and for camera-pc interface also mostly a special software.
OTOH as owner of 4 digital cameras you will have some contacts to local dealers to print your photos - I'm sure they will help you to import or scan and email some photos for free or a small fee...
Modern crap is so unreliable.
You are right!
BR, Toni
SA2016: using lateral mosfets ECW20N20 ECW20P20
Yesterday got new heatspreaders for testing the double die Exicons ECW20N20 and ECW20P20...
BR, Toni
Hopefully Santa will drop a digital camera out of his sleigh for AndrewT. I have my Dad's old Fuji Finepics, still going after 10+years, eats batteries, but does the job. Every time I go to use it the NiMH's are dead, so just use cheap alkaline instead.
Good luck with the exicons/semelab devices, i think they are great devices. They sing in the OPC LME49830 wireamp design, so I am sure they will even be finer with this design.
I'd like to hear AndrewT's or anyone else's assessment vs the OPC wireamp version that I recall AndrewT saying he made as well.
Cheers guys
