No NFB line amp (GainWire mk2)
ok thanks,are those c5,c6 22uf critical?
Can i use 47uf?
j1,j2 ?
Is tl071 ok for servo(just for the test period)?
Those caps are not critical, TL071 should be OK.
J1 and J2 is the position for the jumper(only in one position at a time. CFA or NGNFB).
During the test period i see that tl071 not perform well as offset comparator.
Fitting this tl071,preamplifier output never come to zero d.c volt. This stay to 5mv after 30 seconds.
Fitting the LF411 ,after 30 seconds i see 0V d.c.
I don't know if this is a result of difference inverted and non inverted input for these i.c
I thought that TL071 could be good for a DC servo as it is fet inputs op mp, but never used it for that. Maybe you just used a bad one, try another one.
No Damir, i have use two pairs each from different firm (national semiconductor . and motorola(on semiconductor),same things. 4mV Offset even after 1 hour.
LF411 give 0 mV after 30 seconds.
It's a matter of the part's offset voltage. The 411A is typically as low as 300uV, the 071 as high as 10mV depending on grade.
The 411s are laser trimmed I believe.
Mk2 as it now
