1000W Simple PA Amplifier
  • APEX BA1200 Rev.1.2 Gray.pdf
  • APEX BA1200 Rev.1.2 PCB Mirror.pdf
Balanced input, 30Hz 12dB/oct low cut filter, clip limiter, volume control, signal-power-clip-protect led display and +/-18V regulator all this circuit on single pcb thanks to Willy.
Heres the file's....
  • APEX BA1200 Input & Display Rev1.4 PCB.pdf
  • APEX BA1200 Input & Display Rev.1.4 Silk.pdf
  • APEX BA1200 Input & Display Rev1.4 PCB Mirror.pdf
  • APEX BA1200 Input & Display Rev1.4 Gray.pdf
Ex-Moderator R.I.P.
Joined 2005
tinitus,
What difference does the center tap and and 220nf caps make to the circuit. Will it be more positive as just not to use the center tap ?
just because of available trafos, series connected, thats all ;)
mile shows it like that for the highest power, for the same reason, available trafos
might be ok to use only one 220nf on each trafo
but someone suggested that series connected trafos should better have two 'snubber caps'
I think snubber resistors are still missing
