phasing...good to know, thanks
I thought they were 500VA, but clearly says 6A
but 800VA in series wil be ok
With 2x66Vac voltage 800VA is ok
so far it fits
btw, trafos will be 'immersed' in a sub-chassis below the heatsinks
just hope it wont cause trafo induced hum
Nice heatsink
so far it fits
You can shield your transformer
Nice heatsink
classA heatsinks
300 x 200mm
8x MJL21193, all 526-527mV
8x MJL21194, all 520-522mV
whether such a transformer can be used also for ba1000
80.40 ac ct 40 80
This transformer is very heavy +- 23kg.
160Vx20A=3200VA?
trafo ac 80 ct 80
yes mister,,, can for stereo?,
160Vx20A=3200VA?
Yes, for BA1200 stereo
woow.. nice layout. but still cant find fuse holder. thanks wiljj78.Ok there you go....
Driver BA1200
hi apex,
is this driver board working?
anyone tested or not?
hi apex,
This pcb design is new, not tested.
Apex,
could you get the sch in post181 changed to show the corrected resistor @ 1k?
Ok
sir... R10k very hot to burn at the time played only a few minutes.
2volt bias b to b, and 90vdc supply.
i need your suggestions ? View attachment 351294
10k must be hot (1.5W disipation), you can use 5W resistor.
- 1000W Simple PA Amplifier
