Pictures of your diy Pass amplifier
thx for the intrest about the cooling. In practical terms we would use it to load power supplies during prototype testing. The 1000w would represent the needed load/ohm on a normal dc level . I have seen newer model of this cooling solution loaded with 400w without any issues. My particular one was used with loads of >300watts. i can also add that my colleague has some experience with amlifiers.
Hi Pwrs.
Thanks for the cooling system info. This is the format I want to employ but was going to combine conventional sinks to form a tunnel as had been shown in a post about an F5T buildup. Are these types of sinks commercially available? If so, would you please provide a link or contact info?
Thanks!
My F5 FirstWatt amp effort!!
Here she is, sem-completely. This has been a long and frustrating journey for me at times, solely, because of my own impatience sometimes...
But, I have finally gotten to the 99.5% completion stage..
with no cover..
with a custom logo perspex face plate:
with cover loosely fitted..
Thanx Mr Pass for a great sounding design!!
Congrats brother Prince, and I agree, we owe Papa Pass much!
And since you started it... here's my first pair
...I really like you backlit version. did good job with proportions as well.:up:
Shout of you need the recipe for the LED count and placing? BTW, I used 6mm acrylic sandwiched with 3mm Alu front. Nice balance if I may say so. Total weight was a concern, so everything was designed with that in mind.
Amber light-show was intended at matching my valve pre-amp glow, and it does so perfectly! And the whole thing is a (subtle?) metaphor; F5 being as close as solid state can get to lush and rich valve-sound 😉
....my unfinished amplifier , missing some parts 😀
Alex.
