thx for the intrest about the cooling. In practical terms we would use it to load power supplies during prototype testing. The 1000w would represent the needed load/ohm on a normal dc level . I have seen newer model of this cooling solution loaded with 400w without any issues. My particular one was used with loads of >300watts. i can also add that my colleague has some experience with amlifiers.
Hi Pwrs.
Thanks for the cooling system info. This is the format I want to employ but was going to combine conventional sinks to form a tunnel as had been shown in a post about an F5T buildup. Are these types of sinks commercially available? If so, would you please provide a link or contact info?
Thanks!
Thanks!
My F5 FirstWatt amp effort!!
Here she is, sem-completely. This has been a long and frustrating journey for me at times, solely, because of my own impatience sometimes...
But, I have finally gotten to the 99.5% completion stage..
with no cover..
with a custom logo perspex face plate:
with cover loosely fitted..
Thanx Mr Pass for a great sounding design!!
with no cover..
Congrats brother Prince, and I agree, we owe Papa Pass much!Thanx Mr Pass for a great sounding design!!
And since you started it... here's my first pair
Mind? MIND??Thats awesome Fdlsys. You mind if I copy
I'd be proud! No one copies the ugly stuff!
Shout of you need the recipe for the LED count and placing? BTW, I used 6mm acrylic sandwiched with 3mm Alu front. Nice balance if I may say so. Total weight was a concern, so everything was designed with that in mind....I really like you backlit version. did good job with proportions as well.
Amber light-show was intended at matching my valve pre-amp glow, and it does so perfectly! And the whole thing is a (subtle?) metaphor; F5 being as close as solid state can get to lush and rich valve-sound
any chance you could attach more resolution than 160x91?
Here they are...
....my unfinished amplifier , missing some parts
Alex.
Alex.
terrible solution to the Thermal Dissipation!You are adding a lot of thermal resistance with the stacked cancer (aluminium oxide?) pads.
- Pictures of your diy Pass amplifier
