MOSFET Amplifier IRFP240/IRFP9240
hi apex sir,
now i connect input gnd to psu gnd.
now dc offset showing 105mv. is this ok?
the 15zdiodes reading one is showing 6.6vdc other one 3.3vdc any my mistakes,
the 10ohm 10watt resistor is getting little heat.
what i have to make changes.
I almost earned it when I was in high school.
I removed a big capacitor in the high voltage section of an oscilloscope (without discharging it first). It bit me so hard my arm contracted and threw the cap across the room. I was so stupid I went over, picked it up, and got bit again!
I now work with MUCH higher voltages. No one is allowed to come near me, or to even talk to me, while I am doing a high voltage test.
apex sir,
i supply 70vdc, and the dc offset is showing 145mv dc.
what will be the problem?
little sound is coming out with low volume (volume control i turned to ccw 0 level but little sound is coming through speaker)
Simple Soft-start, DC, Thermal and Overload Protect with NE555. Use single 12vac for suply.
hi apex sir,
the protection board in progress.
is this protection suitable for h900?
hi apex sir,
now i put 10k ntc .
now the protect circuit is working, but when power on , the relay delay time is one second ,because the led indicator only blinking once and after relay connects the led permanently lights on, how can i increase the delay time to 3 or 5 seconds?
hi apex sir,
now i put 10k ntc .
