MOSFET Amplifier IRFP240/IRFP9240
I almost earned it when I was in high school.
I removed a big capacitor in the high voltage section of an oscilloscope (without discharging it first). It bit me so hard my arm contracted and threw the cap across the room. I was so stupid I went over, picked it up, and got bit again!
I now work with MUCH higher voltages. No one is allowed to come near me, or to even talk to me, while I am doing a high voltage test.
apex sir,
i supply 70vdc, and the dc offset is showing 145mv dc.
i connect input gnd to psu gnd.
what will be the problem?
little sound is coming out with low volume (volume control i turned to ccw 0 level but little sound is coming through speaker)
Match input transistors to get under 30mV dc offset. 145mV dc offset and little sound on 0 level is not big problem.
Simple Soft-start, DC, Thermal and Overload Protect with NE555. Use single 12vac for suply.
hi apex sir,
the protection board in progress.
is this protection suitable for h900?
hi apex sir,
now i put 10k ntc .
now the protect circuit is working, but when power on , the relay delay time is one second ,because the led indicator only blinking once and after relay connects the led permanently lights on, how can i increase the delay time to 3 or 5 seconds?
