korg b1 help
hi i need help with korg b1,can any body recommend a 24v power supply for the preamp unfortunately here in the uk we cannot get the triad power supply recommended, i have got it to work with a 24v smps i had from a previous project but had to use a choke and a few rc filters to keep it quiet (not ideal) still a bit of low noise at 0 volume !
also this is gonna sound dumb, it quotes (Remember that the preamp is phase-inverting. In order to get the correct absolute phase coming out of the speaker you must invert the phase after the preamp. The easiest place to do this is at the loudspeaker.) in the pdf, does that mean (+to -)(-to+)at the speaker terminals thanks a layman
Grounding help Circuitbasic LM3886 and Mark Johnson PSU
I just finished building an LM3886 chip amp with the amp boards from circuitbasics.com and Mark Johnson’s PSU board. I thought the amp was fine when I first tested it on my inefficient Minimus 7 test speakers, but when I hooked it up to VERY efficient Cornwall’s I noticed a lot of what I think is ground noise (crunching, whirring, and some radio frequencies) and its pretty loud. I first confirmed 0mv DC offset.
Since I didn’t have the PSU from circuitbasics.com, I thought that I could create a “ground hub” from a plastic terminal block by splitting the ground. The PSU ground, signal ground, speaker ground, and PCB ground all connect to this and I am now realizing this is NOT a good grounding scheme.
I currently have two rca inputs that go into a switch for input 1/2 and then into an Alps Blue pot which has the ground tabs connected and a wire connecting to the ground hub. I did upgrade my wires to shielded cable which helped.
Hoping to get some help on this as i have read multiple forums and looked at a lot of pics and I can’t find a similar wiring to mine.
Thanks!
Have time to desk check my power supply design?
I've been bread boarding this power supply over and over for a month switching things up and I've settled on the design shown here. I used the Quasimodo method to determine the snubber for this Antek transformer.
Would any members have a kind second to desk check it a little?
I do have one specific question though and that is that I chose to establish the virtual ground for the AC filaments using the safety ground, not the audio ground established at Star B or the "dirty" peak voltage raising cap ground established at Star A. Is this ok to reference the filaments to the chassis instead of the audio ground (which is floating from the chassis)? I figured as the filament wires snake around and hug the chassis it was better to have those referenced the same and not get them involved with the establishment of the clean audio ground.
Newbie here.
Question re: transformer for basic bi-polar power supply
I did several searches and was surprised I couldn't find the answer to this, it's pretty basic. The closest I could find was this thread
I'd like to build a basic bi-polar power supply for something similar to a CMoy or Grado RA1 circuit. It's a very simply amp, so I'd rather not spend much money on it. I've attached the circuit I'd like to breadboard, just substitute 115V for the transformer primary.
Regarding transformer selection, I've seen +/- 15V in the wild, but few and far between. Is it acceptable to use a 30V CT, with the center tap at 0V? I was looking at this Hammond unit 166G30: 166G30 Hammond Manufacturing | Mouser
...or this flat pack style transformer:
LP-30-400 Bel Signal Transformer | Mouser
Any input would be much appreciated. Thank you.
Sansui AU-111 fine tuning and balance/FR problem
Hi everyone,
I'm finishing rebuilding a good old Sansui AU-111 from the early 70s, and now that's it has been thoroughly recapped, retubed and biased, i'm fine tuning it, hence I need some help.
Sorry for the long post but I wanted to provide as much information as possible, so the questions are a bit scattered through the post (the questions are in italic)
First thing I've done was to change the more than unbalanced volume pot by a 250K cms commuted one (with center tap), now both channels are exactly the same.
The old 250K pot measured 150K on both channels (IN to GND) and CT at 95k (from IN to CT)
Speaking of this, witch value should really be the center tap? 75K or 125K? (as it's a commuted pot I can choose my CT point).
-I also shielded the power switch zone witch reduced induced hum significantly, still i'm getting audible hum with my efficient Heresy III at listening position.
When disconnecting Preamp stage from the main amp stage, I do not have any hum, perfectly quiet.
Where should I look at to hunt down this 50hz hum (frequency tested on scope)
-Last problem I have is related to the treble pot unbalance pointed by smurfer77 on AK forums. In fact my outputs are unbalanced and frequency response all other the place. All the tests I've done where made with an Analog discovery 2 using both Waveforms and Thatstuffmade audiosuite.
The balance pot was set at the middle position, treble and bass switch to "defeat".
This is the preamp stage where trouble happens.
First thing I've done was to check if my balance pot was balanced by injecting signal directly at the volume pot input.
perfect balance on both channels, phase rotation is probably due to the fact that I'm using both generator outputs (I do not have this phase shift when inject mono signal on both channels)
When injecting from the treble pot center tap here's what I got:
clean
Then when injecting on the Tape monitor input (bypassing the phono stage)
Unbalanced output.
Now comes the frequency response curves:
When injecting from Treble Center tap:
Volume pot at 90°
Volume pot at 180°
Volume pot at 270°
The channels are well balanced, the response is rolled of at the low frequency (I'm bypassing the feedback stage) and changes with volume.
Now when injecting from the Tape monitor input:
Volume pot at 90°
Volume pot at 180°
Volume pot at 270°
Here the frequency response are full but varies with volume and the channels are not balanced anymore.
So my problem lies on the feedback circuit on V2/V3 second triode witch leads to the Treble pot witch sets the feedback loop resistance.
Here are the pot measurements on different points (I made the measurements with the pots in circuit)
I have a significant difference in resistance between the two pots, the left one having more resistance, so I'm assuming I need to add resistance to the right one, but where should I put this resistance?
1. between the pot and the input (from v2/V3 first triode Cathode)
2. between pot Center tap and V2/V3 second triode Grid)
2. between pot and Feedback
I hope someone might help me on those issues.
Matched polystyrene > 8uf capacitors
Two pairs of originally 8.2uf 10% K71-4B polystyrene capacitors.
They are used but not abused. I measure only 0.01uf difference from when I initially measured them some years back (same Fluke 179) so they are quite reliable
pair values:
pair one: 8.54 and 8.61
pair two: 8.84 and 8.90
They are quite big as expected:
Dimensions 85mm X 42mm
SOLD
JLsounds I2S over USB
For sale JLsounds USB board with I2S and SPDIF outputs. It has the NDK NZ2520SD clocks. Full functioning of course, part of 9028 DAC that will on sale, so no use for it now.
Edit: according to current revision numbering, it's a mkII version (mkI being the one with espresso clock I guess), while currently there is mkIII on sale (green silkscreen).
It's firmware is 3.28 (device info) so supports native DSD (as all with firmware 3.06 and above). Of course no problem paying SACD and hirez with 9028
SOLD
GD Parts Class A Single End EL34 Kit
Hi guys,
I'm turning 50 and I have a present to choose 🙂
I have a limited amount of electronics knowledge in so far as, I've successfully built several Seventh Circle Audio pre amp kits for recording, but the instructions were great and if something had gone wrong, I wouldn't really know where to start.
I'm looking for advice on this: Hifi DIY Kits Class A Single End EL34 Tube Integrated Amplifier Vintage Tube AMP | eBay
It's at the top end of my price range and looks easy enough to build. Does anyone here have anything to say about these?
Also, I'm using a Cambridge Audio DacMagic 100 with Tannoy Eclipse 3's and a Sony amp with a dodgy volume knob. I notice the tube amp on ebay is 12w per channel and my speakers are 8w. Would this be a problem?
Thanks in advance for any help.
Alex.
Audio Amplifier left speaker banana plug connector cutting out or shorting
Hi Everyone,
I have a NAD C320BEE Stereo Amp, it's around 15 years old, sounds great and up until the past few weeks has been rock solid. What is happening is the left speaker output (positive terminal I think based on the wiggle test) will intermittently cut out, or sometime slowly fade until it's out. Sometimes, a wiggle of the left positive connector brings it up, other times it does not. Of course I have swapped speaker cables (banana plugs) and speakers and all that logical troubleshooting, same issue.
I am fairly comfortable trying to troubleshoot along the circuit path, maybe, if someone had some idea of where to start, or what I should be looking for. I have access to a scope and meter and all that stuff. I do have the service manual for the amp with circuit diagrams and can share/post them if that's allowed(?)
Thanks for looking and for any help!
Hypex Ncore NC500MP 2x500W Power Amplifier
SOLD!!!
Hello
For sale my test amplifier with two hypex Ncore NC500MP boards installed.
Dual mono a,mplifier in a modest but funcional case.
Peak Output Power is 2x500W @ 4Ω, 2x400W @ 2Ω and 2x270W @ 8Ω.
The power amplifier has been in my testing bench for no more than 50 hours. almost new.
No scratches, no damage.
HICON XLR inputs and standard binding posts outputs. Jantzen silver PTFE wires for audio outputs.
External dimensions 280x250x90mm (WxDxH) Weight 2,5 kg.
SOLD!!!
Re-furbishing Decca Corner Horns
I recently acquired a pair of Decca Corner Horns. The owner had fitted them with Kef B200s and T27s and they sound very nice. However I am toying with the idea of fitting Tannoy dual concentric 8" drivers.
Question - the B200's bottom end is rated at 25Hz and the Tannoy at 40Hz. And Decca's spec for the speakers claims 30Hz. Would the horn loading extend the ability of the Tannoy to reach the lower figure?
Which begs the question - how is the frequency range of a driver determined?
For Sale: ACA amplifier
This is a little used ( about 50 hours) ACA that I don't need anymore.
I'm selling to cover the cost of the parts and materials.
It is built on a Mini Dissipante 3U 250mm All aluminum case. The main transformer is a Hammond and the raw supply filtering comprise of 80mF 35 V Nichicon KG caps (8x10000uF). Biased at 1.6A and works great.
Shipping is from 06851 of about 22lbs.
Asking $450 plus shipping.
SoundDynamics Loudspeaker Crossover upgrade??
Hi All.
Looking for your advice.
I learned that the principal partners at Cerwin Vega had a falling, and, after departing, one of them formed SoundDynamics.
I have a pair of SoundDynamics 2 Way Loudspeakers.
Largish cabinets which feature 10" Woofers and 1" Tweeters fitted with wave guides.
They are very satisfying when it comes to bass reproduction but lack in treble area. Compared to other Speakers I own they are quite flat in the higher frequencies.
I ripped out one of the crossovers this weekend and list the parts as follows:
Resister: Cheap sandcast example marked with the values 7 watt, 2 ohm.
Capacitors: One Intercap 4.7mfd 250v & a smaller Intercap 4.7mfd 100v.
Inductor: Air core, thin copper winding, 35mm diam, 15mm centre hole, & 7 mm high. Scratching the red finished wire winding revealed a shiny copper color.
What do you recommend in terms of upgrading the crossovers?
cheers
Cliff
Whats this capacitor for?
This is an amp that I am currently bread boarding, it is a project suggestion on the Electra Print web site for a SE 6BX7 amp....
My question concerns the 450uf el cap that connects from B+ to the cathode of the 6BX7. Is it possible that this is here by design to inject some of the power supply ripple into the cathode, so that it can cancel out with the ripple on the plate, for better PSRR?
John Broskie does something similar in this article:
But in the Broskie article the value of the capacitor is a carefully chosen ratio of mu, at 1/mu (+ 1 I think). But on the Electra Print schematic they just seem to have jammed in a big capacitor
Parafeed-Amplifier Design
John Broskie does it again in this recent 300B amp:
Two-Tube Single-Ended Amplifier & Speakers (halfway down the article)
All for PSRR benefit?
How to Mod Williamson 1949 for ECC83 & EL34
New to the forum. Been wanting to do some audio DIY for over 15 years, and I'm finally taking time to do it. I've acquired parts over the years, including some nice caps. But, a primary thing I would like to do--besides making a nice-sounding amp--is use my hard-earned tube stash, which consists of some nice ECC82, EEC83, ECC88, EL34, and KT88 variants. (Also have some 6SN7's and 6V6GT's.)
The following schematic link is to a redraw of the Williamson 1949 amp by Keith Snook, who I will thank up front for his work, as clear schematics seem hard to come by. Thanks Keith!
http://www.keith-snook.info/amplifier-hifi-schematics/Williamson amplifier 1949.pdf
My question, of course, is can this circuit be made to use some combo of ECC82's and/or ECC83's with EL34 or KT88 output tubes in lieu of the ECC81's and KT66's? If so, can it be done without sacrificing sound quality? Or, should I be looking at another circuit? I don't have any transformers yet, so...
I'm self taught and can read basic tube specs and get the voltages into spec (I think), but I don't trust my ability to design circuits--yet. Any advice is appreciated.
Best,
Louis
ICEPower ASX series thermal pin/shutdown temp
I have some 50ASX2 SE units and a 125ASX2. The darasheet and designer manual for the 50ASX2 shows the thermal pin and describes its electrical operatiion. However it does not say whether the pin is active before shutdown so that it can be used to enable a fan. I thought I remembered that it operated at 40 degrees C and that shutdown is at 50 degrees C but I cannot now see that in any of the documents.
Does anyone have any experience of using the Thermal Pin in this way?
Harman/Kardon HK6500 - white noise (hiss) in output after recap
recently recapped this entire amp + new output transistors (matched within tolerance of 10).
The amp still hisses in the speakers. It's only audible at max volume. It's very quiet from Tuner/CD outputs, but very loud from phono section (nothing connected).
I heard this could be caused by transistors before the main stage, there are couple of those in the preamp, they run rather toasty (60-70 degrees) and the board is discolored around them.
Anyone has any tips? The Pre-amp transistors are 2SA1124 + 2SC2632. I can replacement ones by On-semi for pretty cheap if needed.
Thanks!
Seas tweeter - terminal broken
I am restoring a prob 18 year old custom built 2 way bookshelfs.
Long story short, there was a long screw in the enclosure that pierced the terminal of the tweeter which is a SEAS 27TFF.
See pics: Imgur: The magic of the Internet
The terminal is supposed to be fixed, and the housing is slightly broken. I can't see where the terminal should hit another piece of metal - the housing looks all plastic to me.
Any ideas on how to repair this? seating it back in looks like it would hold actually, but for how long....
Couple of questions regarding wiring & bridging vs parallel.
I havent bridged my subwoofers before, and looking at new amps has revealed my lack of knowledge to many things
I've been looking for some rather cheap & lightweight amplifiers for bass duty (Not the best combination, I know) to replace my current amps (Pro-line 3000 & Crown XLS 5000) to less weighing ones.
I know I will be getting a bit worse bass than what I have now, but thats a trade-off I am willing to make to reduce my 75kg rack to a 24kg one.
I will be using 1 amplifier to power two Fane Colossus 18XB drivers (8ohm /1000w rms/2000w program/4000w peak) in a reflex cabinet tuned from 40 to 80hz.
So far the T.amp TSA 4000 looks to be the best option (The only options for a new amp really being between T.amp TSA 4000, T.amp TSA 4-1300 & Behringer NX 6000), giving 2x 1000W 8ohm, 2x 1500W 4ohm or 1x 2865W to bridged 8ohm and weighing 12kg.
Wiring: A lot of amplifiers ask for a +1 & +2 connection when bridging. I've only used +1 & -1 cables so far. Do I only need to switch the end of one of my speakon cables (making it a +1 & +2 to a +1 &-1 cable, like in the first picture) for everything to be alright? Or would I have to re-wire the cabinets aswell.
TSA 4000 and bridging; The bridged option says to be 8ohm. My drivers are 8 ohm each, i've placed two speakon sockets on the back of each cabinet to allow for a parallel connection, making them 4ohm each when connected to each other. Will there be problems if I try to connect this 4ohm setup to the 8ohm bridge mode?
Since I want a bit more power than the rated RMS, How would I go about connecting these two cabs to either get a bridged connection or to get the 4ohm per channel to be able to receive 1500w @ 4 ohm per cab?
I am not really sure how to switch between the 8 and 4 ohm options from the amplifier, is it the parallel option?
T.amp TSA 4000
https://www.thomannmusic.com/the_tamp_tsa_4000.htm
Fane Colossus 18XB
Fane Colossus 18XB-8 Ohm – Thomann United States
Many thanks!
Sony TA-3200F: huge output DC offset
Hi all,
'ts been a long time. How's everyone doing?
I'm working on this amp, which I recapped, adjusted, measured (fairly well - enclosed), and played for hours, until there was a POP!, and I lost both channels.
Smelling something too hot for comfort from the speakers protection board (it's an early model), I measured DC voltages coming into the protection board from the outputs and I get 0.85V for one channel and 1.38V for the other. Obviously, humongous. No wonder the protection boards clamps both channels to no output (base of Q110).
Obviously, at the end of my adjustments, the values for bias and offset were pitch perfect.
It seems some sort of failure occurred, but why on both channels, and why so similar a failure?
I am torn between pulling final Qs out (which would be painful, as they're soldered), and investigating the differential input to see if a large unbalance has occurred (but why?). Maybe do some voltage-resistance on all stages, starting at end, against schematic.
Any input welcome!
aR
Nakamichi PA-1 upgrade
Guys, I need your help to modify / upgrade my amps.
I have two Nakamichi PA-1's, 5x100w channel power amps, primarily ment for HT duty. These are like 20 years old and based on Nak's "Harmonic Time Alignment technology" which is probably some derivative of STASIS as it was manufactured after their license term with Threshold.
The Good:
1 - Sound good, parallel 100W per ch, overall solid build.
2 - 910VA R-Core transformer (Kitamura Kiden).
3 - 60,000uF cap
The bad:
1 - Single PCB for all 5-channels+protection, thin Cu layer on PCB prone to failure.
2 - Asymmetric PSU - separate power transformers (546VA + 364VA = 910VA) and filters for 2-ch + 3 ch amps.
I have some experience in circuit and PCB design and frankly i am less than impressed with the skills of Nak designer. There was no need to keep it to a single PCB, could have used fiber instead of thin Bakelite PCBs, too much component cramming, etc.
Few options I have considered:
1 - Re-cap, may be swap some components with premiums. Live with the units until they are beyond repair..
2 - Since I also own a Nak TA-3 (75Wpc, STASIS) and it is the best amp i have ever heard, I thought why not use either Nak TA-4 / PA-5 / PA-7 design to make my own clones. Use the PSU +/- 60Vdc rails of the unit as is, use the schematics from service manuals to design my own PCBs and I will be good to go.
Well, I went through the schematics of all the Nak units, seems like they are too old and many components are not available. Trying to source components that are already obsolete or going into the complexity of figuring out replacements seems too much hassle.
Is it still possible to make 100W STASIS?
3 - Secondly, I went through the Peeter's "X100 back engineered" thread. It seems like a good replacement for papa's STASIS and biased slightly into Class-A like Nak PA-7, it should surpass PA-7.
Basically I want something primarily Class AB with some high-current capability with slight Class-A bias (if possible in the chassis space) primarily meant for HT multi-channel duty.
All DIY Pass designs I have come across focus on Class A. Perhaps because most people into DIY want something really clean sounding for stereo duty.
What do you guys recommend?
PS. Since Mr. Pass is very lenient with DIYers using his designs for personal, non-commercial use, I am hoping I can use one of his old Class AB designs..
PA-1, undressed!
TL494 mini dc converter
เป็นวงจรง่ายฯ ใช้tl494ขับmosfet โดยตรง โดยใช้R DEVIDER ควบคุมไม่ให้ G-Sมีโวลท์มากเกินไป จะทำให้กินกระแสstanby แต่ถ้าvole G-Sน้อยไป เวลามีโหลดก็จะจ่ายกระแสไม่พอ ทำให้ไฟออกตกมาก วงจรที่ทดลองG-Sประมาณ3.3v ทำงานได้ดี
  • MINI DC-DC TL494.pdf
OTL Headphone Amp Topology Question.
Several years ago, before I started meddling with vacuum tubes, I bought a relatively popular Chinese OTL headphone amp, the Little Dot Mk II. It sounded pretty good. In my ham-fisted attempts to "improve" the sound, I swapped out capacitors and such without knowing their function in the circuit. Many lifted pads and bodged wires later, the amp got shelved away.
After seeing the 6AS7 amp that I'd just completed, my kid wants one too, but smaller in size. I remembered the Little Dot, took it off the shelf, cleaned off the layer of dust, and cracked it open. Because the PCB's so jacked-up, I thought I'd build a point-to-point clone using the power transformer. I traced out the circuit:
The front end is easy, a triode strapped pentode. The output section appears to be a White cathode follower. In Merlin's book, he has a voltage divider providing the bias for the upper triode. Here, it looks like the bias is achieved by the 120R resistor between the 2 sections. Are there any improvements that can be made in terms of safety of operation and sound quality?
Thank you.
Hard to drive speakers?
I have a pair of Quasar QS1 speakers. A bit of background on them! They were high-end top of their range Rosewood monitors made in 1974 by Eagle International for export from England to the USA, the deal fell through when the American dealership wanted to assemble them in the USA but Eagle International didn't trust them to do it properly. Anyway, I am driving them with a Sansui AU-11000 but I have the volume at 1 o'clock to drive them at my usual level when other speakers go to only 9 o'clock? They are supposed to be driven with an amplifier with a maximum of 50 WPC? They still had the old electrolytics in the crossovers when I first got them so I changed them out thinking that was the problem but no, it wasn't? They are still hard to drive, they sound great but I'm wondering why they are rated at 50 watts when I have to give them at least 50 watts to get them going? I thought it might have been the HF switch on the back of them getting oxidized but they are both of exactly the same volume! Any ideas anyone?😀
RIAA RCA tube preamp (1968 tube receiving manual)
I'm planning on building the preamp stage from the 1968 edition of the RCA Tube Receiving manual. This circuit appears in many places, even a number of places on this forum:
https://www.diyaudio.com/forums/tubes-valves/213241-help-rca-tube-manual-riaa-phono-stage-3.html
https://www.diyaudio.com/forums/tubes-valves/301088-rca-receiving-tube-manual.html
https://www.diyaudio.com/forums/tubes-valves/156541-own-riaa-tube-preamp.html
https://www.diyaudio.com/forums/tubes-valves/129119-tube-preamp-riaa.html
I've attached the projects BOM (I'm starting completely from scratch, don't have parts hanging around). It comes out to ~$240. I want to use a tube power supply. I'm using the power supply from the RCA manual. It uses a 6X4 tube with a 300-0-300 transformer. The filter I've selected is a pair of capacitors (47 uF) and two 500 ohm resistors. Under a 60 mA load, this should put out the 250 volts I need for B+. How do I estimate the current load for the circuit? It seems under lower load, the output voltage of the power supply will be higher.
I've also added a cathode follower to boost the output from 0.55 volts to (hopefully) something closer to line level (copy-pasted from here: The Valve Wizard -Cathode Follower). I'm using this as input to a preamp that expects a ceramic cartridge output. These carts are 1.5 V RMS if I remember right.
Design goals:
- All tube design, power supply and signal path
- Passive RIAA equalization
- Standalone component from the rest of the system (ie I don't want to reuse power supply voltage from the power amplifier)
- Close RIAA compliance (within 1 dB). I know there are designs that get closer. I want to be as close as possible, but I also want a simple circuit for my first tube project.
- 60's design, this is going in a console from the late 60s, and I like the idea of a contemporary design.
Questions:
- Can I simulate this circuit in KiCAD? I can't for the life of me get reasonable outputs
- Can I save a bit and use 22uF capacitors in place of the 20 uF and the 25 uF capacitors that are not in the RIAA equalization path?
- Have I made any mistakes in the components I've picked out?
- Do I need to tweak any of the values in the cathode follower?
- The cathode follower calls for a 280V B+, I'll be using 250 V, is that OK?
Circuit schematic and BOM attached.
  • BOM.zip
    BOM.zip
can a use an 811A in this guitar amp circuit?
can i use a 811A in this guitar amp circuit?
https://www.tedweber.com/media/kits/lauren_schem.jpg
PT specs
680V/150ma
6.3V/5A
solid state rec used.
OT specs
25watt SE
5000k primary
2/4/8/16 secondaries
i wanted to build a guitar amp that was a bit unusual ish so i found this weber Lauren amp kit and loved the cool 807 tube it uses. i never messed with 807s before but after doing some closer spec checking on the transformers this kit comes with, i realized i could be runing a more powerful output tube.
then i heard about the 811A and got curious lol
but i want an opinion from people with more XP with these tubes. if an 811A is just a bad idea with these transformers & circuit design, what other tube could i use in place of the 807 in this schematic to really get some umph?
thanks!
PC speaker with MarkAudio CHR-70
While in my long quarantine during this Covid-19 crisis, I have so much time so I decided to built a desktop speakers for my PC. After reading numerous thread and positive comments, I plan to use MarkAudio CHR-70.3 as it fits my budget.
I know there are a lot of proven cabinet design with the CHR-70 but they are just too big to fit my desktop. So I plan to built one that have small footprint but tall like a mini tower. I'm thinking of using the design below:
So I came up with a design that is 16x16x33(w,d,h). Basically its a tall square tower.
The volume excluding the port is 4.56L and I got the box tune at 42hz and gives a 1cmx42cm port at the bottom.
I am not sure if i have done everything correctly. Is a square tower a good for speaker box? The goal is to built a good sounding desktop speaker with good bass output. I know it's impossible to achieve punchy bass with a 4" fullrange driver but at least it should not sound thin without bass at all. Or are there better driver for this task beside the CHR-70?
Woofers comparison
I'm looking for a 8-10 inch woofer that will be working in active separate bass module crossed between 200-600 hz depending on swappable mid-high modules and go down to at least f3 40 hz.
The goal is to achieve fast,musical bass that is dynamic at the lowest listening levels. I guess im looking for a driver that has high Qms , low Qts and low Mms ?
So far i've found following drivers for bass reflex enclosure :
SB Acoustics SB23NRXS45-8 ( paper cone)
SB Acoustics SB23NbACS45-8 = SB23NACS45-8 ( alu cone )
SB Acoustics 8” SB20PFCR30-8 = SB20PFC30-8 ( paper cone )
wavecor WF223BD01/02
SEAS PRESTIGE H1252-08 L22RNX/P
SEAS CA22RNY
SEAS CA22RNX
SEAS L22RN4X/P
Seas CD22RN4X
Dayton Audio RS225P-8
Dayton Audio RS225-8
for sealed enclosure :
SEAS CA26RFX
L26RFX/P
SB_Acoustics 12" SB34NRX75-6
SB_Acoustics 12" SB34NRXL75-8
Peerless SLS 10
DAYTON AUDIO RS270-8 10
Could someone that has exerience with these drivers make a brief comparison between them and tell me which one would be the best ? Im especilly interested in SB23 paper vs aluminum. Also will a bigger and heavier
driver in sealed enclosure have better and faster bass at low volume than lightweight driver in BR enclosure provided they have same f3 ?
Some people say SBA woofers are fast and some say the opposite. Which is true ?
Lexicon omega problem
I have had my omega for quite a few years now and I used to record a lot but now I mainly use it to listen to music or play music through my studio speakers to play guitar along with.
After a while I started getting a bad hum through my speakers and yesterday when I tried to record the hum was in the recording.
Also when I turn the monitor mix and mainly the output level I get horrible cracking through my speakers and then one or the other speaker will quit playing until I find a sweet spot that gets both speakers playing.
I thought about taking the case off and at least spraying everything down with canned air and maybe get dust out and see if that will work. I'm just worried that if I mess it up I won't be able to use it to listen to music. I have a picture that shows that even with everything unplugged the levels are up 2 bars.
Does anyone have any ideas that might help?
Sent from my SM-N950U using Tapatalk
Cheap Chinese 24 position attenuator
OK, I didn't have $250 for a gold point stereo 24 position 100K attenuator. So, I bought a couple of cheap Chinese ones off of ebay, see attached photos. I know, I know, let the moans and groans begin. Anyway, I spent about an hour with my DMM and for the life of me can't find the terminal that correspond to in, out and ground. Anyone have experience with these? Thanks in advance for you help.
In
><---- Out
Ground
Castle Microtower build
Micro Towers - I can't exactly remember which one I came across first - the plans on Planet 10 website http://homepage.mac.com/tlinespeakers/FAL/downloads/microTower-maps-150909.pdf, or this thread by Dave: http://www.diyaudio.com/forums/full-range/148901-microtower-bipolar-ml-tl-chr-70-el70-2.html. Either way, I loved the intro... a bit of nostalgia, a bit of reviving a joy of the past... and the build looked simple, the finished speakers cute. Compact dimesions = (usually) Higher WAF 🙂, especially given that my first FR build was the BIB (pretty massive); then the plan was to build a Pensil 12 which became a Super Pensil 12 (pretty massive too).
I was also looking for speakers which could produce good bass and became very excited about FAST. After discussing FAST with Dave I had initially planned to order a pair of Alp 7 or CHR70.2En from Dave as FAST FR units. Dave's CHR70.2Ens were on sale at that time, so just decided to pick up 2 pairs... a pair for FAST and a pair for other experiments.
And then it hit me - why don't I do a Micro Tower build? According to Dave and ChrisB the MTs give plenty of bass... also the MT dimensions looked a perfect fit to me for using my left over pieces of ply board.
And so it was decided - let's go and build this! The picture below is not my buidl, but a concept build by Dave and Chrisb taken from the plans. If you take look at the illustration (taken from P10 plans), you will see how compact the speakers are (and the variations that can be made).
-Zia
When does something qualify as a front chamber?
I found some Adire Audio 12" Brahmas in excellent condition that somebody was selling on Craigslist for $125 for the pair. I bought them not really knowing too much, but after some research it appears that these are quite legendary. Very capable SPL and SQ, so I am excited at the prospect of being able to build some high-end subs. I am looking to build a ported enclosure with one of them for use in the home. Problem...I have very limited floor space and a wife who understandably does not want any more taken up.
I was looking into building an enclosure beneath my house. I have seen bandpass designs where just the port fires into the room, and I guess I could go that route. But I was really hoping to build a vented system. My question is, if I build a ported enclosure and both the woofer and port fired into a "chamber" that goes to the room, then is this just a bandpass? For instance let's assume the front baffle of the enclosure is 18x14 and fires into a "chamber" that is 18x14x6 such that the 14x6 dimension is a hole in my floor covered with a vent to make it look like a heating vent.
I am thinking all speakers fire into a "front enclosure" that is your room, but at some point that enclosure is so large that it does not affect design. But I don't know how large that area needs to be. It made me think of car audio...is a sealed sub in a car with a window partially rolled down now considered a bandpass enclosure to those outside the car?
Filtering the ground line
I get a nasty (high freq) buzz on the ground line. When I lift the ground connection, the system is quiet. This is on my pre amp. However any other source component that is grounded immediately introduces this buzz again -- as soon as I plug it in.
Also, this nasty buzz usually instantaneously goes away later at night, around midnight. Nothing in my house, as far as I can tell.
So can I install some type of a ground line filter? Is there such a thing? Recommendations?
thanks.
Herman
soldering a TO-3 transistor technique ? (problem for me)
haha, i'm currently soldering some circuit and it involve a TO-3 package transistor (MJ15003).
Well.... this is the second time i try to solder such package, but both are difficult, as they are hard to wet with my solder (its my solder problem ?) They cannot 'bond' to the surface of it, which easily came off if use a small force (shaking also will do).
The problem of base and emitter terminal are not so much problem (as pad let us do easy job, but they still hard to solder than typical TO-264 or similar (which standing, not flydisk shape)
The collector (entire casing and 2 holes) surface is the most difficult, like spending most of the time doing that and FAIL !
So any guys have nice and brilliant idea or experience to share with me ? in order faster and easier to solder these TOUGH 'guy'.
v.divider+v.follower or v.regulator
hello. i have a question about pairing voltage with application.
i have a source of 12V and i need to work with a fuzz face pedal distorsion with germanium transtistors and the the pedal should get 9v.
what is the best solution for this?
i thought about a voltage regulator or a voltage divider + opamp as voltage follower.
the best solution would be the voltage divider but i'm considering a walkaround. any pro/cons?cheers
d&b audiotechnik Anyone knows which driver brand they use?
I would like to know if any on you you know which component brand does d&b audiotechnik use in their systems, particularly:
-. the 12" neodymiun woofer in their J12 system; and
-. the 1.3" exit HF compression drivers with titanium diaphragm in their C3 system.
Sorry i post this here, but I know there are many users from europe in this forum.
thank you in advance.
Sowter 9335 as input - hard noise when switching
My recent build is a SRPP pre-amp which has too much gain for me so I will probably rebuild it into something like this Muchedumbre Buffer Preamp – wauwatosa tube factory
But I think with two halves of the 6sn7 I am using in the SRPP
Now my question is as follows:
- I use Sowter 9335 as volume control
- Switching is by relays kit from Dantimax, this works fine
- However there is a lot of hard noise while switching, really annoying. Is this because of the high gain? Or because of the relays?
- Also do I still need a grid resistor after the Sowter?
BHSE cannot adjust bias
For my BHSE, I have changed the original Mullard EL34 tubes to another brand. But the sound of my left side became a bit, how should I say, veiled. The higher the volume and the higher the pitch, the more obvious, like playing songs by soprano.
This still happens after I have changed back to the original Mullard tubes. Has anyone experienced this before or know the reason?
I have discovered that the bias the bottom left tube (left offset) cannot be adjusted. Has anyone experienced this before? Or does anyone know how to fix the problem?
Thanks a lot
Carvin SX-15 Preamp
Hi everybody,
I am attempting to build a bass amp head utilizing a Carvin SX-15 Preamp and a DBX 1 Compressor/Limiter 262. I am looking at a 210 watt per channel (420 watt Bridged) power amp board. Typical bridged configurations only use one of the input channels. I want to retain use of both channels while in mono but I am concerned about combining right and left outputs from the SX-15 using a common ground. Will this damage the preamp? I would also like to maintain the versatility of switching between stereo and mono. Anybody have any input?
Single rail 36V about 200W power supply for TPA or TAS3251 amp
Hello,
I have designed a class D amplifier board based on a TAS3251 chip (TPA3251 + DAC+ DSP in the same chip).
I now need to buy the power supply. My initial intention is to go to a Meanwell LRS-350-36 (MEAN WELL LRS-350-36 Switching Power Supply SMPS 36V 9.7A 350W - Audiophonics). I have read several good recommendations for those.
However, I'm a bit bothered by the fact that those power supplies are not optimized for Audio. They can deliver a steady 350W, while I will normally have much lower needs, but need a to be able to cope with short peaks. TI has some suitable reference designs with 200W nominal and 600W peak (from memory).
I understand that DIY is not easy in that area because of specific transformers and coils (and voltage). Drmord proposed an interesting desgin, but from the Google translate of the article (Russian), making the transformer looks like art :-(
CONNEX modules are more significantly more expensive that Meanwell. Hypex even much more.
At the bottopm end of the cost spectrum, some cheap modules like Nouveau Module d'alimentation 36V 5A AC DC Module d'alimentation a decoupage carte ca 100V 240V a DC 36V alimentation a decoupage|Alimentation a decoupage| - AliExpress
What are they worth ?
Other interesting products to consider ?
And to increase my knowledge: what should I look at for those type of power supplies. What are the interesting features / performances ? What to stay away from ?
Help welcomed,
JMF
SB Acoustics SB12MNRX25-4 as a fullrange
Has anyone tried to run this driver fullrange ?
It looks fairly flat up to 10 khz on manufacturer`s graphs , with -5 db drop up to 16 khz . I was thinking about running it fullrange with aid from my amp's treble knob that starts regulating from 10 khz so this would be ideal , or maybe with help of a tweeter playing from 10-11 khz with only a cap and resistor in series.
How would it stack against the specialised fullranges ?
Help sourcing a inductors summing amp
HI Guys,
I have a question regarding a summing amp that I am about to build.
I am posting the schematics and a picture of the original card.
could you help me sourcing this inductors and from what type it is exactly ?
We talk about L9 and L10 here.
the value is 15 uH.
thanks a lot !! 🙂🙂🙂
P
newbie DIY PA open baffle + H cab sub?
I am putting together a PA system for piano-organ-voice and harmonica playing usually in a relatively small practice space. I don't need huge volume potential but want to get a full and natural sound.
I have done lots of projects and built electric and acoustic guitars, but the only experience I have building audio speakers is years ago when I put a pair of vintage Western Electric 755a speakers in and open baffle. I loved the simplicity of that form and want to create something similar at a larger scale for practice and performance.
I am using some new parts and some items I have been using with my current setup... re-used will be a Mackie 8 channel mixer for input. New is a B-52 Matrix-1500 BBE 3-Ch Plate Amplifier (1200W w/sub crossover), two Eminence Beta-12CX 12" Coaxial Driver with PRV Audio D280Ti-S 1" Titanium Horn Drivers and LaVoce SAF184.01 18" Subwoofer.
I'm thinking of putting the 12's in an open baffle and the sub in an open "H" cab.
is that a stupid idea? and how much math do I need to learn to figure out the dimensions of the baffle and sub cab?
Amp Howls
I have a subwoofer amp I built from an Electronics Now (remember that?) magazine article around 1992 or so. Recently it started making whoosh/thunder noises, now it just howls. I have the schematic and can trace down the parts, but was wondering if I should focus on a bad cap or something or do I have to check everything (IF I want to keep it)? Thanks for any help.
Help with finding new drivers for existing enclosures
Hello people of diyaudio.
I am looking to reuse an old set of fairly well build enclosures for a new project. The enclosures have cutouts for two 10" drivers on the front panel and a removable rear panel, as shown in the attached picture.
I currently don't have the capability to make new enclosures from scratch, but i should be able to build new rear panels plus what other small changes/fixes would be needed.
The enclosures have an internal volume of about 95 liters, but i would like to use a pair of hypex fusion plate amps so i expect the volume to be closer to 85-90 liters with their box included.
I have already tried modeling the enclosure in bassbox 6 pro with a single peerles XXLS-P835016 per box and a bending bassreflex tube of 100mm radius by 452mm length that's flared in both ends. This seems to be an ok option with an F3 of under 24hz, though i am unsure if a peak vent air velocity of 18.4m/s is ok.
My goal is to get a frequency response from around 20hz to 200-300hz. I hope you guys can help me with ideas for drives suited for this enclosure 🙂
How to remove lettering from chassis
Hi there, I bought a chassis with some lettering on the front panel I would like remove so its generic. I have tried Isopropyl and nail polish remover with no success.
I thought I saw a thread on this but can't seem to find it now. I know there is one on how to put lettering on a chassis but I want to get rid of a manufactureres name on mine.
Thx in advance
Neville
Is this a new topology?
attachment.php
By giving a hand to zintolo with his GU50 projects I came upon this circuit. The bootstrapped pentodes provide a gain of 75db ,yielding 40 ohms plate to plate output impedance for 6k load by plate to cathode feedback. The input inverter comes from Audio Research D70 , It can function without by parafeed mode but oscillates on saturation. Using Ayumi models the amp exhibits 80w with 0.03% Dtot.
Audio Note UK Model Soro SE Integrated - audio playback distorted
I have an issue with my Audio Note UK Model Soro SE Integrated recently.
My Soro SE is the model with ECC82, 6SL7 and 6L6/5881 tube.
The audio playback will begin to be distorted, especially obvious with mid range like vocal after power up for around 35 mins to 40 mins. The duration the audio playback begins to distort is always similar each time. This problem seemed to be related to heat, maybe some component is not working properly when heats built up.
if you have a similar experience and can advice what is the likely cause of this issue. Do also share with me if you have the schematic of this amp.
Thanks.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,433
Members
7,918,987
Messages
Filter
Forum Statistics
Threads
407,742
Messages
7,918,987
Members
508,433
Latest member
Kriswanagiyata
