SSHV2 Sink for Q3
As per SSHV2 Guide:
Q3 dissipates Watt power of what spare current you allowed times the B+ voltage. Calculate C/W sink spec for no more than 60C sink temperature in worse ambient conditions. Look for sinking guides on the web if never done it. 1.5C/W spec sink should cover most applications for SSHV2 range though.
As per SSHV2 Guide:
Thanks for the reply! Yes, I read that from the build guide and have difficulty finding documentation to calculate 1.5C/W size heatsink. What have you use in your build? Can you post a pic? I am thinking of using the chassis as the sink. Thanks!
Abe
Mine advice is not use the chassis for HV reg.
Attached pic with the heat sink I use 12cmx10cmx3.8cm
Thank you guys!
Merlin, that is huge! What is your H+ going into the SSHV? I have about 210V, with B+ at 150V.
I thought the write up says spare I x B+ = Watts. Did I miscalculated it? 20 mA x 150V = 3W?
Abe
