Adcom 5802 Bias Adjustment
Hello,
I've done a lot of digging here and elsewhere but my flavor on this common question remains unclear.
Based on the Adcom 5802 Service Manual I have adjusted the voltage across R88 on both left and right channels to 33 mV.
Do I stop there? I do not 'think' so.
I want to confirm I have step 4 right ... setting R88 to 33mV raises the voltage on some of the other source resistors (R96-R114) to as much as 45mV.
Because the correction states that no source resistor should be above 33mV, once R88 is set to 33mV do I then find the highest reading on the others and readjust R61 so the high source resistor is 33mV even if that drops R88 to as low as 20mV.
Is this ok that R88 is so low?
Thank you
MTM Double vs single rear port and placement?
Hi folks,
Are there an advantages of using double ports instead of single, assuming they are both tuned at the same frequency and air flow? Especially in a MTM configuration?
If double port would be better, how should they be placed? Side by side vertically, horizontally facing the rear of the tweeter, or at the far vertical ends, facing the mid woofers?
Drop In replacement for seas woofer
Hi everyone!.
I want to replace a seas p21rf and I already own a p21rex pair (new old stock, never used before) so I am tempted to change the 20 years old drivers for the new one.
Crossover wise, will the new driver work with old crossover? They share many similar specs and Seas states that p21rf is a further development of the p21rex but with 2inch voice coil, also I like the sound of p21rex, it is more sensitive speaker so it works better for me
HELP PLEASE : Toroïdal PSU for Classe A Pass A3 board
Hi amigos,
Just got this Pass A3 modules. I want to build a double Mono board.
But looking for the appropriate Toroïdal PSU.
Recommend PSU is : AC20V-0-AC20V
I am pretty lost with those Toroïdal stuff... I have one 300VA with 2x17V secondary but I guess it is nor the right one....
TTS300/D230/17-17V BREVE TUFVASSONS - Transformateur: toroidal | 300VA; 230VAC; 17V; 17V; 8,82A; 8,82A | TME - Composants electroniques)
The AC input board has 3 faston inputs, any idea ?
Can someone give any appropriate Link (Europe would be better) :
I found this but I don't want to buy via Aliexpress...
Transformateur toroide en tissu noir GZLOZONE 500VA pour passe A3 amp 19V 0 19V 19V 0 19V L3 26 | AliExpress
FS : Mark Audio Alpair 6m
One cone slightly dinged. With tags for soldering. Only used full range for a couple of months then spent the rest of their life high-passed at 100hz.
Shipped in original box.
£20 includes delivery in the UK.
Enable 12V trigger with audio signal
I would like to trigger the power-on of a SMPS based amplifier (Hypex SMPS+UCd) using the audio signal. I have seen that it is possible to swith on the SMPS module by applying a 3-12 V DC. Searching the forum I found only references to external 12 signals which could be used to power on the SMPS module.
But is there a simple way, or commercial module, which takes the audio signal (coming from a preamp with possibly low voltage at low listening volume) and when detecting a signal, provides the necessary max 12 V and, after some time without input, allows to switch off the SMPS?
(PS: I enjoyed this features on some commercial amps I used for central/surround channels in an AV system, only turning them on when using actual surround)
Thanks in advance
AC loadline and max output
I am thinking about the loadline of 300B and there is a website which provide handy calculation on loadline on various tubes.
But there is a question I don't understanding, is that the maximum plate voltage limited to the HT provided? For example, if the HT is only 500v than the 300B would only reach 500v plate voltage at max swing?
6SL7 driver clipping
I recently discovered this website: Triode / Pentode Loadline Simulator v.1.0 (20161216 www.trioda.com), and started playing with a 6SL7 driver tube for a single ended 6V6 amp.
Here's the schematic:
attachment.php
And here's the load lines for the 6SL7:
attachment.php
The red line is the DC load line, the blue is the AC load line for a 100k load, which is what I have. The green is for a 470k load, thrown in just for comparison.
The 6SL7 starts to clip with an input sine wave at 1.2V P-P scoped just after the 0.47uF coupling capacitor. It's just the top half. With the cathode at ~1.5V, I figured it should take a lot more than 1.2V P-P to clip the tube. The 6SL7 tube is a NOS RCA, well balanced and strong. I tried other tubes and the clipping remained the same. What am I missing? Am I misunderstanding something?
Oh, this is without NFB hooked up.
Steinberg Audio Interface UR242 Repair
Hi all, newbie here.
I have an audio interface outputting to two speakers. Several years ago, my house experienced a power surge and we needed to reset the breaker. Since then, I've been getting terrible feedback from the speakers on-and-off. I've replaced the 1/4" cables and noticed the problem persisted. The issue occurs on both output channels and both speakers, which leads me to believe the issue is with the audio interface itself. As it is expensive to replace an interface, I wanted to see if anyone with more experience might have some advice. Is there any test I can do to determine with certainty the source of the problem? I don't have any other devices that can output to the speakers in question.
Thank you
Any Sony technician Online ? Sony STR-DE495 Volume issue
HI
I own this amp and found out perhaps I've been listening to a faulty amp since I've bought it..
One of these days I built a RPI network player & was connecting it to my amp and listening via headphones.
The amp has been sitting in my bedroom disconnected for some time because I've been listening to the TV via a Sound-bar offered by my brother 2 years ago by Christmas time.
As You know this amp has a DSP and no volume pot but an encoder.
The volume goes from 1 to 73 on the display and above 60 sound gradually shifts to the left channel as if You were turning the balance pot to the left.
Happens both on speakers & headphones. First I've thought it was a cable or PI issue bur narrowed to the amp after experimenting other sources & cables. It happens on all inputs
This only happens with DSP sound-fields say Jazz, Concert, CEXT Cinema modes. If I leave it in 2 CH mode all is OK.
Another issue is even in 2 CH mode if I tinker with the Bass or Treble settings the same happens. I believe at 0 position the DSP isn't used perhaps.
Even if You go into the Balance settings & increase balance for the right channel, You can't compensate.
I've performed a Initial setup reset, but didn't help.
Is this meant to be like this ? I mean to compensate for a poor supply or for clipping notification / prevention ?
It's rated 5* 80W but has 4700uF supply capacitors. My old 2* 40W Pioneer amp has 8000uF.
Has someone dealt with the same situation ?
Was this addressed by a firmware upgrade & how can I obtain and flash It ?
Thank You for Your attention
AliExpress Power Supply boards
Problem with a Dayton SA1000 Sub Amp
Hi all,
I tried searching the net but could not find anything on this.
Also I'm sorry if I've posted this in the wrong section. Feel free to move it to the correct section.
I have an issue with a Dayton SA 1000 Sub amplifier.
Link here: Dayton Audio SA1000 Subwoofer Amplifier Rack Mountable 300-811
I'll try to explain it as best as I can but its a weird issue.
Basically, when turned up to a moderate volume (no where near flat out) I hear a squeak sound from the sub woofer driver on the decay of a bass thump.
It only lasts a fraction of a second and follows the bass note/thump decay (this squeak is above the normal sub freq range, sounds like about the 1khz-5khz region so i assume its being produced after the low level crossover section as the sub bass is only operating below 100hz or so)
If it helps, this amp has what they call a patented tracking down-converter power supply.
After a bit of searching on this site, I found this thread: http://www.diyaudio.com/forums/solid-state/5298-carvers-tracking-downconverter-thoughts.html
Also, another clue to this issue could be that when the amp is just idling, on the main amplifier board I can just hear, very faintly a mild buzzing noise, like something is resonating. Its very soft but its there.
Then when playing bass notes (at any volume, even quite softly) the buzzing noise from the amplifier board seems to get a little louder and change in sympathy with the bass notes produce by the subwoofer driver. Maybe that's not an issue but I think its worth mentioning anyway.
But then when I turn it up enough to cause the issue mentioned at the beginning of my post, that same sounding squeak seems to come from the amplifier board, in sympathy with the subwoofer driver.
As its got one of those fancy power supplies, I'm thinking the fault must lie there somewhere?
I know for a fact its not a faulty sub driver making the squeaky noise as I've tried more than one type of driver with this amplifier, and also both those drivers are fine when driven by another amplifier.
For the record, both drivers I've tried are 8 ohms, so I'm not even using a 4 ohm load which it should handle.
Any help will be appreciated.
Thanks.
Help me choose a tube amp kit!
I’m interested in a tube amp kit to pair with some full range drivers. Currently using a little TubeCube 7 and looking to upgrade but staying under $1k. Here are the amps I’ve looked at:
-Tubelab SSE (most work/room for error)
-Dynakit ST-35 (old school design, would need to modify, out of stock until at least December)
-Oddwatt DMB (looks nice but only 5W)
- Buying a built UL amp from Audio Nirvana (no build needed)
Any others I’m missing?
Could someone confirm than my multiple bulb Dim Bulb Tester schematic is correct?
I am building a DBT in connection with my first Pass build (Aleph J). Unfortunately, in California it seems impossible to obtain an incandescent bulb larger than 40 watts. So I am thinking of using 3 bulbs in the tester to add their wattage (two 40 watt bulbs and a 25 watt bulb). I believe I need to have the 3 bulbs in parallel and the combination of bulbs in series with the device being tested. Am I correct in that? I have attached a proposed schematic. I would appreciate it if someone could take a look and let me know if I am doing this correctly.
Thank you.
Jazzzman
Korg B1 completion kit pioneer batch feedback
This thread is exclusively for feedback about the "pioneer" batch of Korg B1 completion kits and chassis.
We are doing things a little differently this time by soft-launching the first batch of kits to builders most active in the Korg B1 thread. We will gather feedback and make any needed adjustments to the kit, chassis and instructions before opening up a pre-order for the full kit to the public.
There shouldn't be too many issues, but you never know until people starting building.
To be eligible to grab one of these kits previous experience is not required (a wide range of skill levels would be ideal). However as the purpose of the exercise is to gather solid feedback from real builders we do kindly ask that you:
  • Either be in the US, or if international choose an express shipping method
  • Be ready to start building immediately and give feedback within days (the sooner you give feedback, the sooner we can offer this kit to everyone else)
  • Be prepared to resolve any minor problems yourself
The pioneer batch of chassis and completion kits can be purchased from this store location which is not accessible via the main store navigation:
Korg Nutube B1 – diyAudio Store
Once the final production run has started, this thread will be closed and locked.
FS minidsp 2x4 Balanced and MiniDIGI
Everything was sold.
Hello.
This is clearance time for my active system:
2x minidsp balanced 2x4 boxed. 60€ each. ALL SOLD
2x minidsp balanced 2x4 unboxed. 50€ each. ALL SOLD
2x minidsp miniDIGI optical and coaxial in/out. 50€ each. AVAILABLE
Everything in perfect cosmetic and working condition.
Minidsp boards will be supplied with the following plugins:
2 way 1.02
2 way advanced 1.10
4 way advanced 1.09
Prices + 4% PayPal fees if apply + shipping.
Shipping to most EU countries varies from 15 to 20€.
Send me your zip for an accurate quotation.
Help with tube buffer
I'm building a class-D amp using the Purifi 1ET400A module and would like to add a little tube magic. I need to create a input buffer with a little bit of gain.
The requirements are differential input and output with about 10db of gain. I'd like to have an input impedance of 30K to 50K per leg, and the Purifi module has an input impedance of 2.2K per leg.
I've never designed with tubes before, and my circuit design skills in general are pretty rusty to say the least. It's been about 40 years since I did any serious analog design, so I could use a lot of help.
I'd like to be able to use the power supplies I already have to support the Purifi module and other circuits. These include +/- 65V unregulated, but heavily cap filtered from a linear supply (lots of current available), +/- 12V regulated with very low noise and ripple (~500mA available), +12V regulated to drive ancillary circuits (~300mA available), +15V regulated referenced to the -65V rail (~300mA available), and +5V regulated for driving digital logic (~50mA available). I could use a linear regulator on the buffer board tapping one of these to create another voltage if necessary.
Ideally, I'd like to avoid coupling caps, but I'm not sure this is practical (or possible). I was thinking of using a differential triode stage feeding an op-amp driver (like an OPA1632), but as I said I'm a total tube neophyte so not sure if this is the right approach, particularly if my goal is to add a little tube magic.
Any help or pointers would be much appreciated.
ALSA pcm hw_params hook (Loopback Notify Kludge)
In case it's useful to anyone I thought I'd mention an alsa pcm hook I wrote to essentially do what the loopback pcm_notify event would do if it actually worked.
Basically you wrap the loopback device in this hook in an asoundrc file and the hook will execute the command of your choice when the hw_params are changed on the pcm device. This allows the capture end to release and reattach to the pcm device at the right times such that the playback end is free to set the hw_params of its choosing.
I've tested it with camilladsp using unmodified versions of mpd and squeezelite on a raspberry pi 4 running moOde audio. I switch between mpd and squeezelite using the standard moOde / LMS GUI options. In terms of audio files I have switched between 44100 and 48000 Hz sample rates and S16_LE and S24_LE formats.
In my setup it calls a pair of python scripts. One tells camilladsp to stop and close the loopback device. The other tells camilladsp to open the loopback device with the right sample rate and format and load the matching sample rate FIR filter for DRC.
Maybe this could also be helpful for people using brutefir and possibly other DSP programs I'm not aware of who don't wish to use an alsa plug device to do resampling and format conversion.
The hook is available on github.
GitHub - scripple/alsa_hook_hwparams: Run commands when an an ALSA pcm device is about to have it hw_params set or released. Useful for loopback.
The python scripts are not part of the package. They're too ugly to share.
I have no intention of adding any additional functionality to this hook. As I said just putting it out there in case it's useful to anyone.
Ground Question ???
Don't know where else to post this and I do know that Demian knows about this stuff.
I'm readying a concrete slab for a storage shed and I'll end up with something
at least 7' x 7' by 6". From what I've read I can make a 6-inch circle of
copper tubing with in it and it's supposed to make the almost perfect ground.
It will be located about 20' away from the house foundation.
Foundation sites recommend using a heavy plastic sheet vapor barrier base between the earth and layer of gravel, then concrete with rebar reinforcement rod. Guessing this won't be a proper ground any longer.
I assume that somewhere I need to drive a copper stake into the earth somewhere? Assume not to pierce the plastic vapor barrier.
where to drive it into the ground:
Between the house and the ring/shed?
On the far side of the house, ring/shed?
Then, I run a ground from the house to the copper ring in the slab?
Another question, does the copper ring in the shed's concrete slab
make it more of a lightening path then the house? That is having this
ring under the storage shed make it more susceptible to lightening strikes?
If I knew I wouldn't ask.
Thanks for any suggestions.
Segmented stator construction
Hello,
I have been following the various threads about constructing segmented wire stators. All that I can recall use a series arrangement of resistors between the segments. However, one of the early threads also diagrammed a parallel resistor arrangement between stator segments. Can someone discuss the advantages of one technique vs the other or is it purely a cost of parts issue?
Using this 220v SMPS in US, or help finding similar one
500W 600W Amplifier Switching Power Supply Dual Voltage Power +-40V +-46V +-58V +-71V Digital Power Board H121|Amplifier| - AliExpress
600W Class D Digital Amplifier Switching Power Supply Board Auto DC+-58V | eBay
600w, +/- 58v planned to use with a pair of L20.5 amps, just realized it's 220v ONLY and i live in the US (basically copying @saarmichel )
whats nice about this one, is it has overcurrent and speaker protect modules built in
does anyone have any recommended SMPS that have similar capabilities? or should i just get a different SMPS with aux and run a separate delay/softstart/protection module (not even sure if all of those are in the same circuit)
@saarmichel L20.5 build for reference: https://www.diyaudio.com/forums/vendor-s-bazaar/180625-ljm-audio-post6169008.html
Extra Long Binding Posts for Scan Speak 32W/4878T box?
Scan-Speak Revelator 32W/4878T, 2 ea. sealed enclosures
I am building a pair of Scan-Speak 32W/4878T’s in 1.5 cubic foot sealed enclosure’s and with the rear wall made out of a Baltic Birch/MDF laminate and finished with ¼ inch red oak, I would need binding posts with a shaft at least 2 inches long, 2 ½ or longer would be even better.
Does such a thing exist? North Creek Music used to sell “Big Posts”, or a name close to that but George Short has closed shop many years ago.
I assume I will need to use SpeakON Chassis mount connectors which isn’t a problem, I would just prefer standard binding posts; would make it easier to move subs around without having to wire SpeakON ends on the speaker wire every time I move them, especially with all the in-wall speaker cable already in place.
Thanks.
The first enclosure is glued and getting cleaned up before I finish the sides, top and bottom in 1/4 in. x 6 in. Red Oak boards and a front fascia made out of 1 in. x 4 in. Red Oak boards.The inside is covered in sawdust for now.
Baffle step when the baffle is nearly completely absorptive
Any ideas as to what would happen with the radiation pattern, and on-axis sensitivity, of a driver that happens to be on a baffle completely covered with a thick layer of felt? I'm talking enough dense, real wool felt to absorb >90% (or for the sake of argument, 100%) of the sound energy in the frequency band of interest.
If the size of the baffle dictated that the radiation normally be into half-space, what would this absorption do? Would the driver start behaving as some sort of mix of half-space and full-space? Would it still radiate into half-space, with no effect on on-axis sensitivity, with the only effect being some reduced baffle diffraction?
Lowther neodymium magnet
Hello,
I'm so sad to start a thread like this. I'm a truly Lowther lover, I like so much the way this speakers represent the detail and dynamic of real instruments, even if I know very well how much work you have to do on them to make them sound more "musical" and linear.
These are a marvelous mix of engineering and handcraft objects, but the neodymium series... let's talk about it.
I find them a great improvement compared to the ferrite ones (sorry, I never put my hands on a alnico one), more smooth and detailed, more frequency extesion, less peaks to tame.
After about 8 years one of them started to make strange noise and scratches, so I thought "ok, the same old story, I have to center it". You know what I mean, Lowther are quite delicate units, I centered them quite a lot of times, especially the unit with high weight magnet.
So I opened them, but I saw strange brilliant piece of metal inside the gap. Strange, I give a lot of attention to avoid dust to go inside he gap, especially considering that is open to air due to the mechanical structure of the speaker.
In the same time, I noticed the presence of a particular type of dust, not easy to pull out. I didn't have the courage to believe to my eyes, but there was no doubts: the neodymium magnet was starting to loose its nickel covering, and the neodymium powder was starting to go everywhere in the magnet unit.
I wrote to Lowther to report this serious issue, they answered me with a standard price list of refurbishment tasks. Practically, they treated me as I caused the damage of the speaker.
I think it's a real shame that a such high reputation and historic company accept the fact that theyr recent enginnering design present such a serious fault. One can love or hate Lowther, but they are bringing music from almost a century (the first Voigt design was released around 1930) and a Lowther made in the '60/'70 years can still sings well in our days.
So, they managed to reach the impossible: build a throwaway speaker. Sure, it's a great improvement in terms of business, you have to pay a 1300/8 years tax to own a pair of DX (and EX, I think) series Lowther. How a honest thing it can be, we can speak about it...
I expected a so different reaction from Lowther company: apologize for the engineering design fault, a public action against the neodymium magnet supplier, a quasi-gratis exchange program of the magnet unit... nothing of this, I have to accept the idea that the Lowther neodymiom magnet show the building quality of a Chinese low-cost gadget.
I NEVER buy a DX or EX series again, and I invite audio friends to take in serious consideration the opportunity to run other ways.
So sad to say, but I have to share it, at least to give respect to the great engineers that made great the Lowther name in the past. I'm sure that they're not happy with this particular Lowther's turning point and behavior.
Massimo
p.s.: from that point, other 2 speakers started to scratch... embarrasing.
SAR ADC for high performance audio ADC project [LTC2380-24]
Hello all,
As many DIYers here and from my own experience in building ADC's,
we can seen that no obvious improvement was done from much years in ADC IC available.
The AK5394A designed 12 years ago still the better audio ADC available on the market.
I really think that the main reason come from the lack of market for a really better performance.
In all my investigations, i seen nowadays that SAR ADC market mainly used for instrumentation
have reached a performance level that become comparable to the better sigma/delta audio ADC.
LT has released some months ago a new SAR ADC, the LTC2380-24.
It is an high resolution 24bits 2Msps ADC that integrate a digital averaging filter to improve SNR.
After many hesitation, i had decided to purchase the evaluation board of this IC.
The eval board is intended to be connected to a DSP board (from LT also) for data collecting
to a PC and analysis with the LT software ( PScope).
I don't want to buy the DSP board because it's pretty expensive(300€) and my target
is to use the EVM with all my favourite audio software for sound-card.
The EVM board include an FPGA (EPM570) that is used to sent data to DSP board.
The ADC use a serial link (as SPI) to enable conversion and read serial data.
So, i wrote a complete new software in the FPGA to read the ADC at 1.536 MSPS,
and average 4,8,16 or 32 samples to give an output at standard audio rate of 384kHz, 192kHz, 96kHz and 48kHz.
Then, the data rate is transformed to fit in directly in SPDIF format,
so CPLD outputs drive a pulse transformer to get a coax SPDIF out.
At rear, 3 positions toggle switch allow to change sampling rate or perform a DC calibration
(the ADC do not have HPF has many audio ADC have).
The EVM need also an external clock, that must be low noise and high frequency
to get maximum sampling rate and minimum jitter.
So,i add a 98.304MHz ultra low phase noise oscillator(Abracon ABLNO)
powered with low noise 3v3 regulator.
The original input front-end of the EVM is very simple, with only followers.
The ADC have differential inputs with Vref/2 offset, so the inputs must have this offset (not friendly).
Because i want to use inputs in single-ended or differential mode, i designed another
front-end including a little low-pass filter to limit aliasing and out of band noise.
After some investigations and tests, I designed a front-end using the MAX44206
fully differential amplifier. The buffer has unity gain and allow 10Vpp full scale input (3.5Vrms).
After all of this done, i was very curious to know what we can really expect from this type of ADC...
First , you will find below some pictures of the setups with the EVM becomed
an audio ADC.
Then, some measurements done today with it.
Front view with differential input and on/off switch
-1dB 10kHz THD test with EOSC10KV3 oscillator
Top view, EVM PCB with oscillator and front-end buffer
Now, some measurements results.
1/ 192kHz mode noise floor, 50 Ohms on each input (orange trace).
Green trace is the noise floor of AK5394A ADC to compare them.
We can see here that despite the lack of noise shaping and only
low oversampling ratio of LTC2380-24, the noise floor level is very near
what we get with AK5394A (-111dB).
The floor of LTC2380-24 is also extremely flat over bandwidth.
2/ 1kHz THD at -6dBFS 192kHz, single-ended.
Generator is EOSC10KV3 1kHz version, output level set to 3.15Vrms (8.9Vpp)
3/ 10kHz THD at -1dBFS 192kHZ, single-ended.
Generator is EOSC10KV3 10kHz version, output level set to 3.15Vrms (8.9Vpp)
4/ 10kHz THD at -21dBFS 192kHZ, single-ended.
Same measurements as previously, but -20dB passive attenuator added
between generator and ADC input.
5/ 10kHz THD at -41dBFS 192kHZ, single-ended.
Same measurements as previously, but -40dB passive attenuator added
As we can show, measurement results are very far to be ridiculous !
When can see exceptionally clean spectrum with THD level excellent at any levels,
even near to full scale. So, these results confirm me that modern SAR ADC IC
can be a very good choice to build a high performance audio ADC.
There is also many others advantages that is :
High DC accuracy (could be usable as high resolution voltmeter).
Easy to get 384,768 and event 1536 kHz sampling rate ! (if supported by sound-card).
DNR can reach 145dB using sample averaging (low rate).
I will continue to investigate in this direction, and i will also probably try the EVM
with the LTC2378-20 (pin compatible) that claim a better THD figure than the LTC2380-24...
Frex
Pure tube phono preamp kit
I'm looking to supplement my new build with a phono preamp as the next step, specifically for RIAA adjustments. I wouldn't mind building a kit, but so many of the ones I run into use op amps or mosfets in the signal line. Merlin sells a PCB on his site:
The Valve Wizard
Has anyone tried this or have any strong opinions about it?
I'm in the US if that makes a difference as far as sourcing.
FS A ton of random (nice quality) drivers for DIY
I am selling off my "stash." As requested by the mods, I have consolidated to one thread. I hope this is satisfactory. (For what it's worth, I am not a commercial business. Like most of you, I am just a hobbyist with an obsession and hoarding mentality. 😎 )
I also solemnly swear that I will not "bump" this thread, but I will update it periodically as new things are dug out of the speaker hoarding dungeon I call "my workshop." Every mad scientist needs a lab or a workshop.
Thank you all! I truly appreciate all of the folks who keep this buying and selling forum up and running, friendly, and productive.
Cheers!
baco99
Revisited YAHA amp
Hi all,
I have 3 pcb board left of a hybrid amplifier project, based on a revisitation I made from the YAHA headphone amplifier.
The main difference from it is that I preferred not to use the grid leak bias (tending to the positive region of Vg) but the classical cathode bias running tha amp at 24Vdc, through a simple LM7824 on B+ of the ECC82. The tube filaments too are fed with Vdc, from a CRC filter. The transformer is a toroidal one 12VAC and at least 20VA, I found this one doesn't offer magnetic coupling (and then zero hum) respect to a EI core transformer, that takes more space too. The PSU is made up of two units, one of which is double the other with a FW rectifier going to ECC82 plates.
A mention is deserved to the opamp, it should be able to bear >60/70mA of output current: so I deem the choice can be NJM4556, NJM4580 or NJM2114. The latter I have to say is very good (though with lesser current of the prevoius ones) but good soundstage and dynamics.
If someone's interested to the boards otherwise I appreciate some opinion about the circuit. As little implementation I also thought to use as alternative to Ra a CCS based on a constant current J-fet or LM334...I know it's a simple project, but for the overal cost of components is a fine sounding little amp.
DSpeaker Dual Core 2.0 – Test Bench Report
This is PART 1 of my report (see other parts below).
I understand that this article may not be 100% fit for DIY Audio, but it is too technical for other forums like AVSForum, where I also a member. And I do compare commercial product with result of my DIY work. That is why I decided to publish my findings here.
Modern computing technology made significant progress in the last 15-20 years. It made cost of processing audio low enough, so it became common even in low cost devices. But most implementation are dedicated to multichannel audio for movies sound track, built into AVRs and surround processors. For some time there were efforts to expand digital audio processing to stereo systems designed to play music. But most hobbyists in hi-fi (or rather high-end) audio are very conservative in anything that is added to audio chain and violates rule “less is more” very popular among that crowd. But in recent years several vendors tried to convince owners of high quality music playing systems that they should add digital processing that compensates for speaker-room interaction and thus improve sound on top of passive room treatment. Thus we saw products from MiniDSP, DEQX and DSpeaker. I myself believed in having playback chain short (even as I do use and like Audyssey XT in my surround system ).
One of the main drawbacks of using signal processor is a fact that it has to be placed right before power amplifier and thus process analog rather than digital signal. As a result it adds additional A/D and D/A conversion, since all processing is done in digital domain. If music system uses only digital sources, this conversion can be avoided by placing digital processor before DAC (or using D/A convertor in it as DAC for the whole system). But with analog sources (vinyl media is still alive and kicking), this is not an option. As a result users have to trust that additional conversion stages do not alter sound to a degree when it can be heard. That is why ( despite actually working on device of that kind – see my report here http://www.diyaudio.com/forums/digital-line-level/282346-ultimate-behringer-mod-50-deq2496-1-a.html ) I didn’t try up to today any digital audio processing in my dedicated music system, using only passive room treatment to improve sound. But in my room I could go only so far.
And finally I decided to try one of digital processors which was for few years promoted in several magazines and web sites dedicated to high-end audio. Last trigger was a promotion letter that promised 40% discount on DSpeaker Anti-mode Dual Core. That device was called product of the year by Absolute Sound and received Class A recommendation from Stereophile (though neither published measurements confirming their rating). Considering offered discount, it was no brainer to place and order – I would not loose much if I do not like it and have to sell in near mint condition.
So I placed an order and soon box from California arrived at my door steps. My approach to anything new I get for audio is: put it on test bench before fist use. It allows me to avoid wasting my time on trying something that is broken (accidentally or by design). That was my approach to tube audio (you may find my reports about two tube amplifiers on that site http://www.diyaudio.com/forums/tubes-valves/208987-yaqin-mc-100b-powerful-advertised-value.html http://www.diyaudio.com/forums/tubes-valves/255409-lian-845-set-kit-commercial-product.html ) and I wanted to follow the same rule with my new digital processor – first confirm that it works as advertised. Thus this small black box went to my home lab for a proper testing.
Here are main parameters advertised by manufacturer:
[FONT=Arial, serif]
Interfaces:
[/FONT]
• [FONT=Arial, serif]2 x RCA inputs or alternatively 2 x XLR inputs[/FONT]
• [FONT=Arial, serif]2 x RCA outputs and 2 x XLR outputs[/FONT]
• [FONT=Arial, serif]Toslink S/PDIF digital input (2-channel PCM only, maximum rate 96 kHz)[/FONT]
• [FONT=Arial, serif]Toslink S/PDIF digital output (48 kHz)[/FONT]
• [FONT=Arial, serif]USB Audio (USB used also for measurement export and software update)[/FONT]
[FONT=Arial, serif]Analog Specifications:[/FONT]
• [FONT=Arial, serif]Dynamic Range: > 108dB[/FONT]
• [FONT=Arial, serif]Total Harmonic Distortion (analog in, analog out, typical): 0.003%[/FONT]
I planned to use it between my preamplifier and power amplifier, both of which have balanced interfaces, that matched well to DSpeaker offering balanced analog connections. Thus limitation of digital inputs in it was not an issue (and I do play high-resolution PCM and DSD content using my DAC).
As you can see dynamic range and distortion numbers are good enough on paper for practical use even with high quality systems like mine (Accuphase pre- and Bryston power amplifiers, B&W 802D speakers). But if DSpeaker lives up to specs – that is what I was planning to find.
For measurements in that case I use computer with RMAA Pro ( RightMark Audio Analyzer. Products. Audio Rightmark ) software tool that does measure main audio quality parameters and allows easy side by side comparison. My venerable EMU 0404USB is the A/D and D/A interface used along with it. This is not the latest signal processor, but it is well known to have exceptionally low noise and distortion which allows reasonably accurate measurements of most modern audio gear.
Thus I built a test system where I used balanced cables between EMU and DSpeaker units. I also used Toslink cables for SPDIF interface measurements (DSpeaker only has optical input and output). I did measurements with my laptop running from battery, but I didn’t notice any difference from using external power. Before measurements, I did factory reset of DSpeaker to make sure that there were no leftover configuration settings that affected the performance. Volume control and input trim settings in DSpeaker were set to 0 dB. In all measurements other than pure digital I used EMU in 24 bit and 96kHz sampling mode. In digital only measurement I had to use 24 bit 48 kHz sampling (see explanation below).
First test was for high level frequency response. And here is what I saw: Fig 1 (see attachments below).
Oops… I easily came to three conclusions:
  1. Low frequencies response is limited by -3.5 dB loss at 20Hz. This hardly can be called transparent when makers of DSpeaker declare one of their device uses as subwoofer equalizer. What kind of subwoofer they are talking here – one that comes with tiny satellites as HT-In-The-Box?
  2. Response in top three octaves has visible ripple. This usually points to poor implementation of reconstruction filter when there is not enough processing power for that.
  3. High frequencies are limited to just above 20 kHz with sharp rolloff above that point. This simply means that this DSpeaker is useless in a system where high-resolution content is played (this actually includes vinyl – it has some content in low ultrasonic range, and people value it for that). This means that if someone uses DSpeaker he will not have value from high resolution music sources. This also causes phase and timing smear associated with low sampling rate. Based on my measurements I concluded that it is likely that input audio sampling and internal processing is done at 48 kHz rate. Considering that digital processing was routinely done at 96 kHz rate even a decade ago, there is little excuse not to have it in device targeting high quality audio market.
Next test was to find out what is the real dynamic range of DSpeaker. In that test 1 kHz tone with level -60 dB is applied to the device input. Here is what I found at the output: Fig 2
As you can see output signal is reaching exactly -60 dB, which means that DSpeaker has a unity gain. But (Oops.. again) the noise floor is at -120 dB at middle and raises to -110 dB at low frequencies. Overall measured dynamic range according to RightMark tool is 88 dB which is way below advertised 108 dB. Of cause we do not know what adjustment curve was used by manufacturer to specify the value. RighMark tool does not use any correction (A, C etc.) and noise level is calculated over full frequency range. A can imagine that magic 108 dB number can be achieved when using A weighting. But from what we see it is clear that DSpeaker offers at best 16 bits of resolution, exactly what CD gives us – say bye-bye any advantage from high-resolution digital sources. Modern DACs offer from 18 (entry level), to 19-20 (mainstream), to 21 (state of the art) bits of resolution. Again there is no excuse not to have at least 18 effective bits of dynamic range in any modern device. Considering that when used in pure analog mode DSpeaker should never see 0 dB signal at its input (otherwise ADC will clip) practical dynamic range is even lower by at least one bit. Thus dynamic range of DSpeaker is LOWER that recording on CD.
Now let’s see how much of harmonic distortions DSpeaker adds to the signal. For that I used full range 1 kHz input signal: Fig 3
Here we see that harmonics are quite low, with third is the highest at – 97 dB. All other are below -100 dB and thus are not really an issue. Though you can see a lot of high frequency hash, even beyond 20 kHz pass band limit. Overall THD is 0.0028%, which is within manufacturer’s specification. But you can see that overall noise level raises few dB up from -120 baseline, which may point to rounding errors in processing.
Now let’s look at IMD. For that two tones (19 kHz and 20 kHz) at -7 dB level were sent to DSpeaker input: Fig 4.
Result is not bad at all (if ignore already known issue with limited dynamic range). 1 kHz difference tone is just above -90 dB. Third order IMD components and aliases at 30 and 40 kHz are all below -100 dB. Overall it results in IMD at 0.013%. This is not exceptional, but not bad either.
As a summary of DSpeaker performance in analog chain, I can say that it can be used only if the music source is CD and owner of the system does not try to squeeze last drop of sound quality. But would people like this even bother with adding another device to their music system?
(Story continues below...)
Thinking to build a plug-in circuit
I’m interested to build a universal variable loudness to use with any amplifiers. The idea is to put it in between pre-out and main-in link of any integrated amplifiers. I had the schematics of Nakamichi 410 preamplifier as attached. Could anyone help to educate me whether I can build this circuit with or without any modifications, please? I'm not an electrical engineer but have some soldering skills. Thank you in advance
Guyatone Flip 500
A friend brought this amp to me, saying that the amp is breaking up at low volume levels. With the master volume at 50%, he said he could only go up to 50% on the clean channel before break up. I cannot get the schematic or any technical info about this amp. I remember seeing somewhere on the net that this amp is rated 15watts with an 8in 8 ohms speaker. It has a single 12AX7 and 2 6L6GC tubes. The preamp is solid state. There is a pot on the amp for bias. Upon checking the bias, I get 39.44mA on one tube and 33.90mA on the other at 427V plate voltage. So one tube is dissipating16.84 watts and the other 14.48 watts, with a total of 31.32watts. This is double the rated power and can this be the reason for the early breakup. Is this bias setup safe and acceptable for this amp. Please assist.
Yamaha EMX5000-20: Not sure what I did wrong..
I have a Yamaha EMX5000-20 powered mixing board that my band has used for several years for live gigs and practice both. This past year i have taken it upon myself to learn how to cean and maintain it, because it really is a nice unit. Well, a few of the knobs were scratchy, as well as some faders. After a good cleaning, the faders were still the same. So i read up, and watched videos on how to rejuvenate the faders and thought i would give it a try as music is something that will never be over for me.
So i got copies of the service and user manuals, and disassembled it as the service manual instructed. I desoldered the faders (ch17/18, and ch19/20 from the circuit board and cleaned them up as the videos instructed. I was also under the impression that the Aux Send jacks were not operational. So i also desoldered those, and 2 from ch 17/18, and swapped them with each other, soldering them back into place. All seemed to be ok, until i got it put back together, and now my right side main is not working. I did all of the elimination steps, and it is definitely in the mixer somewhere. Both speakers and cables work when hooked up to a different mixer. Also, the right side LED meter does not show any movement while the left does.
I am certainly capable of repairing it, i just need a little guidance on where to start. I checked over the inside of the mixer really well, and all my solder points and things i changed, and i just dont see anything that looks out of place, broken, fried, etc. All fuses appear to be intact as well. Thanks so much in advance for any help that anyone can provide.
Dyavox vr70 high bios voltage.
I'm new to DIY audio forum, so I hope I've posted my post in the right category. I have a lot of vintage hifi but no valve gear, so after reading how good valve amplifiers are, I decided to take the plunge and buy one. I bought a Dyavox VR70 of a famous auction site ( no names) big mistake!!
After receiving the amp I coupled it up to my mint warfedale e70s speakers and noticed the right channel was a lot lower than the left, I'm no electronic expert but had read how to bios the amp. I conected my Multimeter and set it to 2000m and connected to the valve bios test points and was shocked at the reading, 750m and counting down. The valves are a quad matched set and have a number in felt pen written on top of the el34 valves 305m. I've tried trimming the voltage down but the voltage is so unstable, I've given up. The voltage does come down after say a hour to around 150m. I removed the amp bottom cover to reveal the electronics, it's a real mess, a bodger has been inside and changed the circuit. Pictures enclosed. Sorry for the long posting.
HH Scott 299C
My first tube amp and new to them and have a couple questions. HH Scott 299C and Klipsch Forte II speakers with Crites crossovers.
First, I see a high and low for magnetic cartridge for phono connection. I will be using a Shure V15 Type III and from what I researched is 3.5 ms and would be considered low after reading that 6ms is where one decides low or high.
Is that correct?
Secondly I read here that Scott amps are not compatible with modern tape decks. Modern being my question. The post stated that it was due to line input impedance not below 100k?
I have a Nakamichi 600 cassette tape deck and can not find any reference to "line input impedance" for it.
Compatible or is it not as the deck is circa 1975 so not too much modern for the 1961/64 ish 299C?
Thanks and anyone with Forte II and a 299C please chime in on how do you like?
Analogue active x-over delays
Can some help me here, in layman's terms!
I currently run my system controlled with a digital dsp enabling me to set delays for minimum phase/time alignment easily, with the help of arta.
Thought I would dabble with analogue again and purchased a Rane 23s. The manual has a chart for "rough" delay settings by crossover frequency and voice coil offset.
My question...why is the amount of delay required different at different frequencies for the same driver offset, which in my case is around 9" as I use a horn and cone mid set up..
Thanks.....
Sony CDP-XA5SE Problem
Sony CDP-XA5ES Problem
Hello,
I ask for help with my XA5ES player, suddenly it doesn't work anymore.
This is what happen:
- the tray open
- then the disc-holding spindle moves gently outwards
- at the end of the movement returns unexpectedly back
- However, I can place the disc and close the tray but the disc is not recognised
- I hear mechanically noise and I see that the laser lens shake
I tried to power off/on with the disc inserted, clean the laser lens, changed various disc but no result.
Has anything similar happened to anyone?
Please help me, this reader is really a nice product that I wouldn't want to throw.
  • XA5ES.mp4
    3.4 MB
NAD C300 Output is barely audible HELP!
My NAD C300 Amplifier has just lost the Ghost. Output is barely audible on either channel even when the volume is set to maximum. You can just hear the music when you get close to the speakers.
The question is rather open ended but any suggestions on where to start would really help.
I am no expert but thanks to this forum, I managed to repair my old NAD 304 with just a £3 soldering gun and a 10p resistor. I could have gone round in circles but a similar fault had been diagnosed on here.
What would be the "ideal" compensation method?
Looking at all these threads on audio compensation, I can see that significant improvements in distortion can be made by combining local and global feedback and adding poles and zeros at particular places.
For the sake of argument, lets assume an amplifier is a linear device in the sense that the superposition principle applies: if the sum of two signals are applied to the input of an amplifier, the output should be the sum of the two signals that would be output from the amplifier from each of the two signals alone. This is of course not true due to distortion which is the whole point of such compensation schemes. But small-signal analysis is used to inform stability analysis which determines whether a given compensation scheme is likely to be stable and therefore a necessary (but not sufficient) condition for an amplifier to be useful for reducing distortion.
Many of these distortion compensation methods rely on taking the output and then applying a linear function of that output to various stages in the circuit. This could be modeled where the output voltage is scaled by a transfer function transconductance with amplitude/phase as function of frequency so that currents are injected into various points into the previous stages as to provide a feedback mechanism.
So I now pose the following problem. Let's say we start with a given amplifier circuit comprising and input and output with a single current source where the feedback is to be injected at a stage, and therefore with zero transconductance is nominally an open circuit and produces no modification to the amplifier output. Furthermore, lets say for this circuit we can expand the output voltage as a polynomial in the input voltage, so that at least for relatively low audio frequencies, the polynomial terms corresponding to the second-order distortion, third-order distortion, etc. can be identified.
Given, say, one wishes to minimize a particular distortion term, say third-order distortion, is there an ideal transconductance that achieves that? This would be finding the amplitude and phase of the transconductance transfer function that would minimize the distortion, for example, the third-order distortion. The transconductance would not necessarily be limited to what could be easily achieved by a few passive components, but for example, could be applied by using a DSP to calculate the feedback current from the output voltage using some FIR filter.
One could then, for example, describe an amplifier linear transfer function with the output being dependent on the input voltage and feedback current (from the transconductance) and therefore optimize the FIR filter and find the "ideal" compensation filter.
The idea then would be to extract the transfer function from a SPICE model, perform this optimization, and then include the filter in the SPICE model to see what improvement might result.
This may be overkill but it seems to me that there should be some optimal feedback filter in the sense of control theory.
Finally got 1200AS2
I had hard time finding 1200AS2 in the US so bought an assembled unit. I received 2x 1200AS2 modules in case with 8x Furutech FT-807, 4x Neutrik XLR, VanDen Hul CS-16 wiring and on/off switch. It is pretty but has problems: heat sinks have no conducting area attached to module plates, switch (speced as Shaffner EMI/RFI filter) was on/off toggle with 10amp fuse and 14/3 power cord, amps are thermal isolated in closed box and go into clipping when driven hard. These are 150watt amps with 6db headroom that is not much heat. The amps seem to be designed for European power and would benefit from higher voltage. I will replace 10 amp fuse with 20amp (maybe with 30amp Filtered Entry Module someday), make 12/3 power cord with high temp C-15 connector and run 20amp, install 2-Noctua-NF-A8-5V fans and wire to 5v auxiliary on boards and rewire power LED’s to clipping pins on boards. Final thought: these modules would benefit from direct mounting to heat sinks with pull through cooling, I am glad they did not include EMI filter as speced as I can use different value fuse, heat sinks that are not mated to base plate are useless.
Modules
Bottom
Side
Back
Threshold CAS 2 Amplifier SL 10 Preamp Help
Hi, I am new to the forum here but have been collecting vintage audio for many years. I purchased a Threshold CAS 2 power amp and SL10 preamp at a garage sale this weekend. I am not sure the last time either of these were used and I was concerned to power up the amp. I do own a variac but have never used it. It is basic and just has a dial to adjust the voltage. Should I power the amp up with the variac or not. If yes, can someone advise how to go about it. I ordered a preowned power supply for the preamp as it was missing so I will wait to ask about that. I have some skill but do not want to damage the amp as I have read this is a beautiful setup. Also, if anyone has schematics for either of these, that would be great as well. Thanks in advance.
Line Level output - Alientek D8
Hello all! Lurking hare for a while, bear with me:
I´m interested in getting an Alientek D8. I wish it had a similar feature as the SMSL AD18 that has a subwoofer line level output in the coax connector, but the D8 seems not providing this. I´m limited by budget as the AD18 would be my pick. (With lemons we make ...)
If by chance any of you master modders/engineers/wizards here has derived a line level output from the D8, as well other options to get a subwoofer output to feed an external mono amp, I´d love your advice.
Cheers! 🙂
DC Audio 9.0K
Hi, working on a DC Audio 9.0K. Same as the Ampere audio and several others. Easy question so far. The power supply driver transisters, KTA1275 and KTC3228s, have a diode that has shorted. Is this just a signal diode like 1N4148? If not, anybody know the number? Thanks.
Rel sub amp troubleshooting help.
Hello,
I am looking for little help with REL Britannia B3 sub amp troubleshooting.
My skill level: electronics engineering background - however have not worked in industry for 20 years or so - so I am I guess less than novice.
Symptoms: - hum with static static "pops", regardless of inputs (or lack off).
Initial diagnosis (my own - very likely wrong): considering subwoofer is 15 yo, very likely PS or amp section caps.
However, upon opening the unit I found the following:
1. Capacitors do not really show signs of "leak" or top lid buldge. (see last two pictures below)
2. I found the signs of component overheating on the - if I understand it correctly - the Power Supply board. (circled in red in first picture). The board on the other side - almost directly under the resistor (is it 1.2k or 12k?) is slightly darkened.
3. I think it is a mosfet - however I would appreciate any suggestion in identification it says DH S48:
3. The caps appear to be in good shape - however I will change them. Only few I can easily source in that range are "snap in" (Nichicon KG or ELNA), the solder one is Mundorf - are they any good?
So, besides questions above - what should I replace first - capacitors or the mosfet? or both?
Can someone confirm what that mosfet is ( or transistor)?
Should I change the resistor in pictures - is it 2 watts one?
I appreciate all help I can get.
Bez
FS: Pair of Fostex T90A with Fostex Lpad-1.5uF Attenuator box
I am selling a pair of Fostex T90A super tweeters and a pair of attenuators. The Attenuators are built in a alum chassis using Fostex R80B 100W L-pad and 1.5uF Mundorf Supreme Silver oil caps.
Everything is in excellent shape and used for 300 hours. Total retail value is about $650.
I am asking $300 shipped to the USCON.
WTB BC32740BU and BC33740BU
To build the Paradise Phono Stage and I am in need of BC327 and BC337 preferrably matched for hfe around 500 to 550 mA, Fairchild.
I know that there is a lot of people building or have already built this phono stage so I suspect that there are a lot of those BC327 and BC337 out there already matched and ready. I need 36 of each if matched and ready to go or.... unmatched I need 150 of each. Please come with a fair offer.
Need advice from JFET expert
I am designing a VCA compressor (mostly for the bass guitar) based on a THAT4301 chip and am presently on the sidechain attack decay circuit. The design started with a circuit from a THAT comp pedal design, but quickly went elsewhere (I wanted adjustable time constants, which is turning out to be the tricky part).There design uses 2 BJT current sources feed a cap, one for attack the other for decay. The problem is that if the decay is adjusted to fast it changes the slower attack times. The decay ccs is draining enough current from the attack ccs to change the attack times. So I found a way to turn the ccs's on and off but still had its problems. Ended up using FETS to switch the currents instead. The hard part is getting the large ranges. Attacks can be between .01ms and 300ms and decays form .02s to 3s. getting these broad ranges (6 orders of magnitude) from 1 timing cap aint easy. The present circuit uses the FETs as dynamic resistances to help the pots change the currents.
Now the question. How much will these dynamic resistances (the FET properties) change with individual FETs (one J113 to the next ). Seems that different Vp of the same FET will change the timing current. Does this spec vary a lot ? How close to reality is this sim?
Thanks in advance.
100W subwoofer drive choices?
I've got a pair of small ported "bookshelf" type speakers in a well insulated garage - they use decent drivers (Vifa XT25 treble, Seas W11 4.5" midbass). The sound quality is good, but obviously they don't play that low.
I've just picked up a mini 2.1 amp with a crossover for a sub output (adjustable between 50-200Hz), with the sub output delivering up to 100W.
I'd like to add a sub to the system; mostly to take the low end load from the small speakers. The intended use is music only, and (within reason) bass quality over quantity.
100W isn't a lot for a sub driver, and so far I was looking at the JL Audio 8W1v3-4 (8W1v3-4 - Car Audio - Subwoofer Drivers - W1v3 - JL Audio) from a combination of "not too expensive", "doesn't need too much power", and "JL Audio stuff is usually pretty decent".
Are there any other options I should be considering? Size (of the driver or enclosure) isn't really critical as I have space. The only issue is that it's got to be available in the UK. There are lots of options from US vendors, but obviously the shipping would be prohibitive.
JC-80 eBay PCBs & Power Train
Welcome to part two of the thread initially titled "JC-80 eBay PCBs". The goals of that thread had been totally fulfilled and, toward the end an incident of rudeness / trolling brought it to a close. Do not post to this thread anything that is in violation of the rules. If you have not read the rules, please do so NOW.
Near the beginning of part one John Curl offered his assistance in selecting components for the JC-80 pcbs available on eBay. Some of those components are rare (the originals specified by JC being totally unobtainable), others difficult to match, and nearly the entirety of the power train left unspecified. With John's help and supporting comments from many others, particularly ticknpop, a power train schematic was laid out that, in John's words
. . .is neither JC-80 or Blowtorch. It is a mixture of the two, better than the JC-80, and somewhat less than the Blowtorch. It should work just fine.
The rationale for most of it can be found in part one but reading part one of the Blowtorch thread is recommended for the serious student. The power train is split across three pcbs and housed in two separate enclosures. It is modular for two reasons. First, a minimal version might include one transformer, one rectifier pcb, one regulator, and a pair of JC-80 preamps. I have not tested that configuration and the current load would max out the Kubota but it could be done. Second, the regulators are subject to heated opinion and can be easily exchanged without much disruption.
Toward the end of part one I discovered a source for the rectifier pcb. That allowed me to specify a BOM for the power train that could be duplicated by any interested reader. In addition, pinnocchio is keeping me honest by building a replica and we will exchange thoughts in this thread. His JC-80s have been operational for some time but he is incorporating the ideas from part one into his power train.
There are many interesting tidbits in the first part such as the following "It requires a good same device match, but the complementary match is more forgiving." Builders are encouraged to follow the BOM delivered with their pcb for the JC-80 and possibly the Kubota (if purchased as a kit). No efforts will be made in this part to elaborate on (or disclose) those BOMs.
Despite John's admonition
Don't 'cheap out' too much. It is pointless to invest your time, if you are not going to make a sonically 'successful' product. Cheap bypass caps, resistors, etc will only compromise an otherwise 'elegant' design.
I have made every effort to minimize costs and offer strategies for sourcing caddocks and matched pairs of jfets. In the end builders will spend at least $300 and likely more than $400 to build two channels of JC-80s with full power trains. Some will spend much more! Keep in mind that John will sell you an assembled Blowtorch for only $2000.
Advent 300 Receiver Question
Hi folks,
Working on this receiver and notice that the output offset on one channel is what I believe to be too high (50mv) versus the other channel's 5mv.
Schematic here:
https://davidreaton.com/wp-content/uploads/2016/08/Advent-300-newer-Amplifier-schematic.pdf
Notice that it uses a number of differential pairs in the inputs and was wondering if I should remove a few of them, and try to match the gains of transistors in input of the "offending" output section channel to lower the offset - or could you suggest another way to lower this.
And while we're at it - can you suggest any other tweaks
THANKS
Charles
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,781
Members
7,888,170
Messages
Filter
Forum Statistics
Threads
406,224
Messages
7,888,170
Members
507,781
Latest member
Ronny2001
