MSP Alnicos - a blast from the past
Just thought I'd give these a try, they've been sitting on my shelf for years. MSP were an Aus manufacturer during 50s-70s
These are their 8TAX/15 Alnico full rangers, 8", 15 ohm, Fs 50 Hz, Qts .84 power 8 watts.
Plonked them in a pair of 30 L test boxes, well stuffed.
How do they sound? - Low end, a bit recessed, but not bad; Mids- low treble pretty good, full & well balanced, but no high highs to speak of, sound OK with a couple of piezo supertweeters. Saxaphones sound glorious on these.
If anyone in Western Sydney wants to try Alnico Full-range nostalgia, come & get 'em, they're surplus to requirements here & need a good home
My Orion 1400.1D blew up. New to this whole thing hoping someone can assist in repairing.
Good evening,
I have a Orion XTR1400.1D.
It was in use for maybe a year. I bought it new but not in the box or at least told it was new.
The batteries on my truck died and I assume they killed the amp when it was boosted.
I have been reading as much as possible to figure out what to test.
It’s very obvious that the transistors blew up. Smoke/smell/burn marks. I had no output but the amp had the light on but not the protection light. No fuses blew it has 4 30 amp fuses on the amp.
I attempted to replace and they simply blew up again.
I am going to order more but would like to not run in circles replacing random parts. It’s obvious they were defective.
I have another amp that functioned torn apart to replace one of the potentiometers on it and am trying to use it to compare readings.
I think I have a dead short in the amp somewhere as I have continuity between positive and negative terminals and my other test amp is not like this.
None of the capacitors are swollen. I have tried checking the transformer for shorts and can’t seem to find anything wrong.
I have a soldering iron, soldering pump, I just ordered an oscilloscope should be in the next couple days.
I have a multimeter as well.
I’ll post a picture of the blown up internals tomorrow when I get a second.
I would appreciate any help
Adcom GFA-5802 right channel dead (((
Hello all
Need some help here...
Got this amp last week, good cosmetics, it worked ok. I decided to check bias and DC offset. DC offset in left channel was 8 but it responded well to the pot correction. Right channel was 20, and with pot all the way counterclockwise it went to 10, and that was it. I have to match and replace input transistors I know. I ordered them.
Bias was 16.5 mv at R88 both channels. I adjusted it to specified 33, but other mosfets were all over the place, from 18 to 45, so I turned it down to about 25. Same in left channel. It worked like this for a couple of days, and then - kaboom! Blew both 10A fuses in right channel, and thermal protection LED came on. I found four shorted output IRF244s: Q99, Q92, Q13, Q2. I have no idea what happened...
So, a few questions:
1) I was using outboard turn-on strip, with amp's power switch in ON position - could that do it? Worked fine on all my other amps over the years;
2) Does this amp have a turn-on/turn-off disconnect relay? Because in my case sound comes on as soon as turn it on, and continues for a few seconds after I turn it off;
3) I have located IRF244 mosfets, albeit not cheap. What else should I check for before I plug them in, put the amp on my variac, and pray?
Thank you
Mark
10" subwoofer recommendation please
Hello all,
I made some years ago a tower speaker with a side woofer. The woofer (SAL SRP2530 - Kevlar membrane ) is working more like a subwoofer an is cut at ~140Hz.
The tweeter is BS26ADC-C000-4 and for the mid I use Alpha-6A. Crossover frequency are 140Hz and 1600Hz. It is a ported box and I measured -6db@45Hz and -10db@37Hz. The woofer box is ~37L without speaker.
There is a better woofer/subwoofer to work in this box and to not be expensive? Preferable to be available in Europe.
TDA7396 power output far lower than expected
Hi guys,
I've been working on a small boombox based on TD7396 chip.
using 4 Ohm dayton ND140 for lows-mid in parallel with 8 Ohm dayton DC28F-8 for highs.
The system sounds quite good but not as loud as i expected ( and intended, it's a boombox after all)
I checked consumption with a bench power supply, and it draws 640mA @ 14.1V so around 9 watts for a steady 100Hz sinewave
The chip datasheet says that for 14V power is 20W for 4Ohms or 32W for 2Ohms.
As my load is about 2.66Ohms : 1/(1/8+1/4), i would assume to be in the 27ishW. Instead of that, i'm not even at the rated power for 4Ohm !
Chips were buy from farnell, a reliable electronic retailer, i don't think those are fake
What am i missing ? Do someone has any ideas ?
For Sale in Los Angeles: Dynaudio studio subwoofer w/ dead 8 ohm driver, nice sealed 12" w/ dead driver, more
Hello,
Been collecting subwoofers, and the time has come to uncollect them. For pickup only in Los Angeles because they're bulky and heavy, so shipping is a no-go. Photos included are not mine but are representative (except I don't know where the grille is for the Dynaudio subwoofer).
Have a Dynaudio BX30 12" ported studio subwoofer. As far as I know, the amplifier is fine and the driver is not. It's one of the fancy 4" coil Dynaudio drivers, but it looks like the spider gave out, as it's the floppiest thing I've seen this side of [delicious] silken tofu. Big 76 liter cabinet with a large port, 140 watts RMS output @ 8 ohms amplifier (because of the large cabinet, doesn't need much power). $93 firm, pickup in Los Angeles. PDF attached or at: https://usermanual.wiki/Dynaudio/BX30.1158802585/html
Sonance 12-250 home subwoofer. Very nicely finished in piano black. Dead driver, open coil. Otherwise nice, aluminum cone, woven lead wires, big magnet. Really nice - front mounted controls, but behind the grille so they're invisible. Would be great with any nice 6 - 8 ohm driver (low Qts probably better to take advantage of the cabinet volume). $67 firm, pickup in Los Angeles. https://www.sonance.com/product-archive/92365
Exodus Audio PR18 18" passive radiator, cast frame, super well made, with mass kit: $40 firm. PDF attached of specifications.
Squeezebox Boom - very cool Squeezebox-based digital audio streamer with stereo biamplified speakers with a sliding dynamic EQ. $63, this one can be shipped.
Tal
  • Exodus PR18 radiator.pdf
  • Dynaudio BX30.pdf
    Dynaudio BX30.pdf
For Sale B1 with Korg triode, cap multiplier
SOLD Working board fully populated with standard kit parts, including Korg tube and additional capacitance multiplier board (allo.com serial number SBC01-027-001, which could be easily disconnected). No power supply or connectors or volume control. $66 plus shipping ($10?) to USA only.
SOLD
IcePower amp Input buffer question
I have a 50ASx2se I have built into a ghent audio case and I wanted to know if this board here that I received by accident can be used with this as a Buffer. Its aOp-Amp pre amp board. It only has one Op Amp. DO I need a buffer with dual opamp? I am running the icepower single ended RCA and plan on going just output of my Dac to the icepower. If I can use this do I go from RCA input to the input on the board and then from audio out to the 7 pin connector input on the icepower?
TPQWR for a 10" driver (Circlomanen?)
Hi so I've got a number of 10" drivers available to me at the moment and I'm trying to decide on the best boxes to build for them. The intended purpose is to replace the current reflex subs I'm using for my function band (Thomann Pyrit 12A - 96 litres) with something a little more efficient and just because I'm interested in building some subs with the drivers that I have and seeing what you can get out of a small box with a small driver. So really the criteria is as small as possible and as efficient as possible. 50Hz-160Hz ish. 40Hz is probably unattainable without an excessively large box and I can always build some THAM15 or ROAR/Paraflex for some 15s I have lying around if I need something bigger. The portability and weight factor is a fairly big thing because I need to transport in a Vauxhall/Opel Zafira Tourer the entire PA plus my keyboard rig.
My initial thoughts were for something like double THAM 10s which seem quite driver flexible and are around 120 litres. However after seeing the ROAR designs and in particular something Circlomanen designed on Martinsson's website I'm keen to get some more information about it and similar projects. I've posted the file here, I gather it hasn't been built but I know Circlomanen has built other similar boxes. Have posted the drawing for clarity.
Any assistance welcomed.
How To Use Bose Lifestyle 135 Speakers With Other Receivers
My project for the winter is to find assistance or start the hunt for a new speaker. I use to own a complete working set for a bose lifestyle 135 home theater set, but unfortunately after a recent superbowl party the receiver got wet and no longer works. I was wondering if it would be possible to still use the soundbar without the bose 135 receiver and use another non bose receiver? The soundbar inputs consists of a 9 pin input, a headphone jack input, and a subwoofer input. Any ideas, or forms that could assist?
Thank you!
(Pictures below)
Horn sub built into a stage
Hi All! I am looking for advice on a project that I have coming up. I am setting up and building out a DJ and live music venue, and being a fan of horn loudspeakers, got to thinking about building a really big horn sub (or two) into the stage as part of the build. I will need to build the stage and support it anyway, and thought that I could build the supports in a way that would configure the interior walls of the horn. The stage will be 30" tall, and will be 20' across and 11' deep. I would like to have the frequency response be at least -3DB at 20 HZ, but lower would be nice, and I am hoping to cross over to horn based mains at around 60 HZ. The available space will be 2.5' X 11' X 20'. This should be enough room to build two, with the openings being on the 20' front of the stage towards the outsides where the main L and R speakers will be placed. I was thinking I could use DSP on the the horn subs to time align them with the mains. I have a couple of 18 inch subs pulled from a pair of Energy ES-18XL subwoofers on hand, but am willing to buy something else if these won't do. The venue is around 2400 square feet with 11.5' ceilings. Is this crazy? I have been looking online for examples of this but haven't found any yet. Any advice on how best to do this, and opinions on its feasibility would be much appreciated.
Hello from Northern Ireland
Hello DIYers. I am just about to begin my great adventures into DIY audio. Ive been browsing through these forums for many years now and wanting to build my own system for the same length of time.
I am finally going to take the jump and throw all my hard earned cash into something which will hopefully be a great success!
I have reasonable skills with soldering etc, and a basic understanding of electronics, being an electrician for over 20years, but thats big wires and AC voltages, not the the tiny electronics side of things I am about to dive into. The general understanding of how the inners of amplifers, pre amps actally function will be a steep and enjoyable learning curve.
My starting point will be putting together an F4 amp. This may sound like a poor option with the ACA being a simpler beginners project. But why not, the best way to learn is to jump in feet first.
I already have a lot of very simple and maybee stupid questions and advice to ask.. So be prepared 🙂
Reactions: Ray Lough
zobsky builds a SLOB
I've observed a few of SLOB projects come to life on here . A few carried to completion , and some caught in the web of "analysis-paralysis", and yet others hamstrung by unobtanium drivers (result of supply chain ripples)
Why did I build this:
  1. To utilize the random scraps of cheap poor quality COVID era ply and other wood in my garage
  2. To provide a simple to build , cheap, good sounding example.
  3. Use readily available woofers with fairly common T/S specs that can easily be substituted in case of future non-availability .
  4. 2 way design with easy to work with drivers .
Drivers used per speaker :
mid-woofer: 8 x 6.5 poly cone woofers https://www.parts-express.com/6-1-2-Poly-Cone-Woofer-4-Ohm-299-609?quantity=1
mid-tweeter: GRS 8" planar https://www.parts-express.com/GRS-PT6825-8-8-Planar-Mid-Tweeter-8-Ohm-272-126?quantity=1
The planar makes this design what it is ... it can run as low as 200 Hz (heck .. I ran it full range at low volume and it worked) and has reasonably flat response .
The bass response is good to 50 something Hz with usable response down to between 40 and 50 Hz depending on positioning . Once again, I haven't set up my measurement rig yet .
While this design doesn't hit the lowest octave, it s strengths are that it
1. gets the bass fundamental and mid bass correct , allowing easy subwoofer integration.
2.is crossover friendly .. shouldn't be hard to crossover . This is essentially a Full range - woofer assisted design aka FAST
I haven't got my measurement setup working so for now, I've rigged up a 2 way crossovers at 500 Hz . I've tried various slopes and a bone stock 2nd order (or even a first order) Butterworth slope driver at that frequency sounds pretty good.
Tested with a run of the mill Yamaha receiver (cleaner + less bass) and also a pair of stock aiyima A07 mini amps that I haven't yet had a chance to tweak for more performance (more bass than the Yamaha but a tad less clear)
More to come . I may have to rebuild this with better materials and more attention to baffle dimensions and shape, wing design, rear wave treatment etc .
If anyone is interested in building a SLOb, this is a fairly cheap way to do it .. and not too bad sounding .
Reactions: DorinD
Phase inverter Hum
New Build
This will be the third time I have built this amp section so I know it works fine, and is normally very quiet.
I normally don't use a choke but did this time.
But if I ground R1 the amp hums/Buzz very loud along with some whooshy noise.
I tried grounding C2 directly like I have seen done and the amp hums exponentially louder until shut off.
The amp works without this grounded at all as long as the negative feedback is connected.
Test I have done:
All preamp tubes removed, No change.
Preamp section disconnected from amp section no change.
Phase inverter tube removed, hum & buzz gone. Just a normal low hiss
Changed Inverter tube to one I know works, no change.
Grounds test (several points) show less than 1 ohm all the way to the power outlet.
I don't have a scope, but my meter shows less than 2 volts of AC at the power caps. B+ 473
Plugged another amp with the same amp circuit to the same power outlet, with no issue.
Other symptoms:
When turned off the speaker takes a bit to stop making sound (can't remember if that's normal)
The power caps instantly drain almost completely at shutoff. Normally it takes a couple of minutes with a drain resistor attached.
Exceeding Cone Excursion
I have been designing.my 2way bass reflex speakers and now they are complete, Proud moment for me 🙂😉, I have checked the frequency response which seems to be ok, however removing all these biases I like them when they play music.
I am stuck at one point here on my winISD model, where it shows me Cone Excursion exceeds limits from 59Hz to 145Hz over full signal power of my amplifier @40Watt. I am paranoid on this as I fear that may damage my dayton speakers at this level. The cone excursion starts to exceed from 10watts of power.
I am attaching the graphs from winISD and need your inputs and opinion how to limit the excursion as I am stuck in the situation. Also I will appreciate any other design inputs good or bad on improving the design.
Thanks folks and look to have your support, help are welcome.!!!!!!
coupling capacitor question .
Suppose one constructing one integrated amplifier to keep it understandable lets say one P3A and one DOZ preamp
Integrated amplifier no one is messing up between amplifier and preamplifier
so there is one coupling capacitor / DC blocking capacitor in the output of the DOZ and one more in the input of the P3A
can we remove one capacitor ?
only one capcitor between the two devices should be enough
any ideas ?
Reactions: clpk
Aragon 8008 clone
Anybody ever tried cloning this amplifier? I am planning to make a PCB.
Is the schematic correct?
Will it work perfectly after implementation or do I have to change anything? Also, will it make any trouble if I eliminate the servo circuit from the amp?
Due to unavailability of some transistors, I want use 2SC2073/2SA940 pairs throughout the whole design and 2SC5200/2SA1943 for the output pairs.
Waiting for expert's suggestion. Thnx in advance!!
TDA7293 Parallel kit from ebay (modular/slave style, no lossy emitter resistors)
The easy little kit
This chip has Fet output built in, so it doesn't need lossy resistors at the output for paralleling.
279672d1335671579-tda7293-parallel-kit-ebay-modular-slave-style-no-lossy-emitter-resistors-tda7293parallelkit.jpg
Making two chips as easy as one.
This is documented in the TDA7293 datasheet as a modular approach.​
Notes-------------------------------------
Ebay link:
(link 1) Two board *stereo* kit TDA7293 Parallel from HappyShop
(link 2) Two board *stereo* kit TDA7293 Parallel from Min9988
(link 3) One board mono TDA7293 Parallel from Happyshop
(link 4) One board mono TDA7293 Parallel from Fly-XY
Power circuit:
Fortunately, the kit came with 220uF power caps for the amp board, which is perfect for clear sound and cool running of TDA7293. This setup with 220uF (or 330uF) power caps assumes that there will be larger power supply capacitance (a real power supply board).
Voltage:
If you push for quality, the Antek AN-3222 transformer is low priced, drops only 2v @13a and has ideal specs for use with TDA7293. If you push for power instead, AN-4228 is about max. However, 25+25vac dual secondaries transformer is typical and that's what I'm using.
Cap values:
I'm changing the 47uF bootstrap cap to 100uF to assist low bass (valid range 68uF to 100uF).
I will omit the 10uF Mute cap (location is right side of the board, near speaker jack) for zero delay.
A highly effective power circuit upgrade is shown at post#30.
Instead of the 22uF FB-shunt cap (which is far too small), I'm using a 680uF 16v cap paralleled with a 0.47uF electrolytic cap for good treble. I'm also using a 1n4007 antiparallel pair as safety clipper to restrict this big cap's discharge to 0.65v. Photo is at post#29
The 105, 1uF box cap is your input cap, but there's other fun options to use, such as 4.7uF (or smaller) Elna Cerafine paralleled with a tiny polyester (to DIY your own low cost blackgate), etc. . . Try some variety and choose which you like.
Resistor values:
The leftmost 22K resistor is Input Load. Valid range is from 15k to 28k. A difference in value can alter the midrange loudness. If you don't need the adjustable feature shown in the schematic with 100kVR||39k, then just use a simple 22k or 25k resistor for input load.
The gain divider is the factory standard 22K/680R and although this will work, I disagree with bad performance that generic values cause. Instead, I would like to use 27K/730R for great quality. If you want quality results, the feedback resistor and the feedback-shunt resistor(s), MUST be placed underneath the board, close to the FB-Shunt cap. The feedback resistor is installed from pin14 to pin2. The feedback shunt resistor(s) are installed from pin2 to FB-shunt cap. It fits easily and shown at post#24.
349465d1368903275-tda7293-parallel-kit-ebay-modular-slave-style-no-lossy-emitter-resistors-tda7293.gif
The above is new text and new schematic. Previously, there had been some problem getting sufficient gain; however, a just-right gain divider setting with resistors direct (not inserted to pcb), and a power circuit update was the combination that got this little amp up to high fidelity.
See assembly photos starting at post#24
It does use a power board:
Due to the power circuit mods for power filtering at the amp board (in the photo attachments at Post#30) we didn't need a CRC type power board, so here's a simpler edition.
429934d1406261198-tda7293-parallel-kit-ebay-modular-slave-style-no-lossy-emitter-resistors-7x2200-simple.jpg
(5x3300u caps per rail and a pair of prefab bridge rectifiers is similar but easier.)
See also Bob's power supply
Yes, new content that uses the schematic (above) starts at post#24--previous discussion might not be applicable to the new schematic, so you will probably want to skip ahead to post 24.
Is This Class-A BJT Amplifier Schematic Worth A Tryout?
Intended to learn simulation, this amplifier schematic comes up. Yes, it's a modification from some schematic around internet. I did use Micro Cap 12 to simulate. The simulation result looks like output power = 21.1W (RMS) and THD is about 0.02% when D1/D2 being 1N4749. The quiescent current for each output transistor is about 975mA, if my simulation is not so wrong.
There is a significant question to be asked here: is this safe to use +/- 19VDC or even +/- 21VDC for NE5532A for listening? because according to NE5532A specification from TI, its absolute power supply is +/- 19VDC.
Is this Class-A BJT amplifier schematic worth a tryout? Do you think there is a better schematic to try? Under consideration of utilizing NE5532A for voltage gain and DC servo, and SC5200/SA1943 as output transistors. BTW, for learning purpose I already used KiCAD 6 to get a PCB layout and routed, about 2.5"x7", not send out for PCB sample manufacturing yet. I know there are so many DIY experienced people around here, that's the reason I am asking. Don't laugh at me.
Wood too expensive for your next speaker project? Think about re using furniture
Wood has gotten ridiculously expensive if you are forced to buy at end user stores. At the same time the quality you get has gone down. At least where I live. Ply wood has large chunks missing in the surface that have been fixed and hollow spots. Noting you can put wax on or clear coat. Fiber board is rough as sand paper, in the past at least one side was fine sanded from the factory. MDF is often so bend, you have to re shape it for weeks until you can use it.
I have an alternative, that may be interesting for some DIYS guys here.
Since I have a low priced circular saw with a long guide rail for cutting perfectly straight lines, I have started to use old furniture and panels from all kinds of sources for my builds. I collect clean, usable material, cut of the unusable excess and store it.
Lately for example I got 12 doors from an old living room closet wall in different sizes, veneered in wonderful cocobolo. With some careful planing how to cut, I will build a large subwoofer from it.
If you ask, there are always people which are happy to get old furniture or left over building material picked up, as they may have to pay otherwise for it.
Recently I bought a table saw in a close out for 105€, which is perfect for smaller cut's which are more complicated with the guide rail.
It has paid for it self in short time, as I do not have to drive to the hardware store that often anymore.
There is one problem I want to address: Used panels may have screws or nails hidden, which can ruin a saw blade. If you are in DIYS you probably have an electronic line finder. I use it in the metal setting to check before I cut.
LCD conundrum.
I have some equipment with a bog standard LCD 16x2.
I built one system up and noticed in one part of the software the display corrupts.
So I checked solder joints etc and it seemed fine.
So removed display and fitted a new one which worked fine.
So bad display ?
I wanted to see if it was software timing problem so soldered bad display into a new pcb.
Now it works fine in the new pcb !
So had a serious look at my software timings and they are all above what spec suggests.
Not sure where to go next ? unless it was a bad solder joint that looked ok ?
Harman Kardon TC400q replace?
A year ago i bought this amp as defective on one channel.
I repaired it and then it has been on my shelf for a while.
Now i will need an amp to drive 2 fronts and 2 rear speakers in my RV (camper)
i will probably use a portable sub together with my setup.
My idea is something like 2 pairs of infinity kappa and a tube sub.
I will not destroy my interior with a big subwoofer.
Question sell the Harman and buy something newer and better sounding or keep it?
Pelle
Pink Triangle THE PIP
Hi folks!
Does anybody have the schematic of Pink Triangle's THE PIP or the PIP 2 ?
I remember listening to the PIP2 a long time ago and found it very good - a phantastic battery powered amplifier with a very unusual look.
I also remember a HifiNews article rewieing this item vaguely ( it consists a transconductance amplifier and passive riaa).
It seems for what reason ever PT discarded the product early, it was no great succes (which does not say anything about sound quality).
Any deeper knowledge ?
greetings
Klaus
Complimentary ramblings AKA another Sony TA-5650 V-Fet thread
Hi all
Some hesitation on adding to the pile of Sony V-Fet threads. So this is aimed at logging MY refurbishment of a Sony TA-5650.
(My TA-4650 thread is https://www.diyaudio.com/forums/solid-state/376634-sony-ta-4650-fet-thread.html that didn't actually go so well)
First of all lets get some resources out of the way (just in case)
Service manual: best copy by far I've found is at hifiengine although others exist they are resolutely monochrome 🙁
Service bulletins: yes! most important is the 'dutch' one as it details mods to bias and component changes made to enhance longevity (Has ANYONE seen that in English?)
Circuit operation: see "Sony TA-4650 new circuit operation" for a how it works document that broadly applies
Other links:
https://www.diyaudio.com/forums/solid-state/311612-sony-ta-5650-restoration-doc-breaths-life.html
What I hope this thread will mimic 🙂
So here goes, as usual I haven't finished this project yet so its not a tale of, "this is how you" it's recorded live 😀
I find it very useful to step away from the project and document it.
I have *TWO* Sony TA-5650 amps and one set of working power transistors
Serial 601467 - marked as 601518 internally
Serial 602370 - marked as 300378 internally
602370 has Grey Elna Caps fitted rather than blue Nichicon ones, as a side note, it is also missing a positive power rail, at least without Vfets :apathic:
To me it looks like 602370 went back at some point and got a new serial (?!?) Unless someone knows what the internal numbers actually mean anyway...
601467 is cleaner, as both of these are 'pre-loved' maybe it's been serviced, I couldn't tell you. Anyway I'm going with 601467 from here in. A decision that would have been best made BEFORE I robbed the output board for the TA-4650 project. :headshot:
Can I just say I hate wire wrapping. I really hate wire wrapping.
Andy
Question about Project Phono Box
Hello everyone. I found a Project Phono Box mm/mc phono preamplifier at a garage sale, the model that is powered by an external 16v AC source.
Since I already have an IFI ZEN Phono, I want to experiment with modifying the Project towards the Actidamp II, just to see how it sounds.
I have found the thread of said modification, but when I look at the circuit board I see that as IC it has TL 071 CP.
I have searched for information and I see that this integrated is not dual.
How could they use it as a dual IC? Or is there a dual version of the TL 071?
Since I haven't bought the transformer yet, I haven't been able to test it, I don't know if it's working.
Another question. Is it convenient to spend time in the modification towards the Actidamp?
According to what I have read, it would be the original scheme of the designer.
Greetings.
  • phonobox.doc.pdf
    phonobox.doc.pdf
Radian Audio LM8K
I’ve never seen such a big ribbon driver before, nor one with such an extended frequency response. On paper it looks like and option of something close to a FAST system. Of course, there are no THD measurements and I can’t find anyone using them (the pdf is marked preliminary). Are there obvious trade offs with ribbons tweeters trying to go this low?
LM8K - Wide Band Planar Ribbon Transducer - Radian Audio
Brian
For Sale O-Core Transformers
Hi all,
I have two potted (epoxy filled) and shielded (Iron can) O-Core Transformers for sale. Both are brand new, and unused.
Originally purchased from James Transformer for a project that never happened....such is the way it goes sometimes.
Transformer Spec:
VA: 50
Pri: 240v
Sec1: 0-18v
Sec2: 0-18v
Sec3: 0-18v
Sec4: 0-18v
Premium quality transformers. Both tested and working.
£65 ea, or £115 the pair. Inc postage in the UK.
WEET Pure Alu Film &Foil Caps
Hi all,
I bought a minimum order of these caps but don't need them all. I have 3 of each value and once they are gone, they are gone.
WEET WMH Pure Aluminum Foil and Film caps were chosen to replace some metalized PP caps in my speakers.
These are genuine alternatives to Jantzen Alumen-Z but at a lower cost.
All items are genuine imports from the factory.
Caps:
WMH Aluminum Foil and Polypropylene Film 6.8uF 100V +/-3% 23x85 Axial RoHS
£55 EACH
WMH Aluminum Foil and Polypropylene Film 8.2uF 100V +/-3% 25x85 Axial RoHS
£60 EACH
Price includes postage within the UK.
Will ship anywhere, but please ask for a postage quote.
https://ibb.co/445WddQ
NAD 514 CD Player - two different Versions (KSS-210A and KSS-212A)
A friend of me have problems with read in TOC. His version uses a KSS-212A.
In the present service-manual is mentioned the KSS-210A - go to
https://elektrotanya.com/nad_514.pdf/download.html
Is the version with KSS-212A a later series and exist therefore a second service manual resp. an additional supplement ?
On the web I don't find any information.
Under
http://vasiltech.narod.ru/CD-Player-DAC-Transport.htm
both types listed.
Thanks for an advice.
Crunch class D
This amp has no output.There is no rail to rail oscillation on the output FETs.I see a square wave on the output of the Lm211 and pin one of the IRS chip.
Using the ground tap of the 7812 regulator vcc voltage looks ok for the chip.I install a new on but no change.
Any suggestions?
Cyrus Pre HA7L Jiddery Volume?
I've been running one of the original Cyrus 'pre' amps for many years. Today I found that when the volume level was adjusted one of the motorised pots inside would not settle. It just keeps jittering the motor, like it's constantly seeking a value but can't reach it.
I tried swapping the pots on the PCB for each channel, but the problem channel remained the same, so I do not think the pot itself is the problem, rather the driver circuit.
Does anyone have a schematic? Or know how the volume pot system works?
It seems to me each is a dual pot used for balanced signals. When the level is adjusted I think the circuit seeks a set value on the pots becasue I can see them overshoot slightly and move back again. Or maybe one of the wipers on each dual pot if used for position feedback and the other for the signal?
Volume up, you can hear the pot constantly jittering even when the other one stops at position. Shared album - Simon A - Google Photos
EL504 output stage conversion
I've been eyeing a pair of old Davoli-Krundaal guitar amplifiers from 1964 (schematic attached). This particular auction is selling a pair, missing 2 out of 4 EL504 and both ELL80 phase splitters.
Since these tubes are rather hard to find nowadays I'm thinking of changing the output section in some way.
These are the ideas I'm pondering, in order of preference:
  1. (Hopefully) convert these into a pair of monoblocks for music reproduction. This is the only way I could get some use out of them. My main fear is that the OPTs will have a ugly response outside of the guitar frequency range. Then again, they are rated for 60W so they may behave well at lower wattages (I don't need more than 8W of power).
  2. Do a proper restoration: try to keep them as stock as possible and only fix what is missing/broken.I may end up replacing just the the ELL80 as it's the hardest tube to find. In the end I'd then have to sell them as I don't play guitar and certainly don't need two of them.
  3. Change the output section, keeping them guitar amps. Again, I'd have to sell these later.
Hopefully you guys have some experience with these or similar amplifiers and can advise me on the OPT quality.
Either way, I'll probably have to swap out the EL504s and the ELL80s, so what tubes do you recommend as a replacement? As stated I don't really mind changing the sockets/circuitry.
Bonus points if the suggestion includes Russian sweep tubes that can be had cheaply and in abundance (I always like to buy extra for replacements).
85V rails at Lme49830 IRFP240/IRFP9240 amp
I would like some advice please with my current amp project.
I am building a power amp with the chip LME49830 as driver stage for IRFP240/IRFP9240 mosfet quads, it's going to be used for bi-amping to drive the woofers of my speakers, each speaker has a pair of 9" woofers whose impedance @20-300Hz ranges from 3.5 to 6.0 Ohm
I already have a 1.4KVA transformer with a pair of 0-60VAC secondaries that I would like to use and it will give me rails of approx +-85VDC.
I know that in theory it is OK to feed the LME chip and the mosfets with that high voltage but I am not sure if -even with a very good but passive cooling- it will be safe with the load I intend to drive.
Please advice!
Schematic of the amp
Firstwatt F1 with Powered Subwoofer?
I've mostly been a reader only on the diyAudio forums up to this point, but I'm starting to diving into some more audio projects now and need to get more actively involved in discussion and questions. One of the projects on my to-do list relates to a pair speakers and amplifier that I found at a local estate sale. The speakers are "The Great Horned Heil" from the Horn Shoppe. This is a rear-loaded horn speaker with a ESS Heil Air Motion Transformer (AMT) on top. There is an external set of crossovers which were presumably designed to work with this pairing. The speakers also came with a First Watt F1 amplifier and "The Truth" Preamp. (I've found mixed reviews about The Truth preamp, so I'm going to ignore that component for now.)
Everything seems to work and I'm liking the sound I'm getting from the setup so far. (Although, I'm detecting a small amount of distortion from of the Heil AMT drivers on some recordings... The diaphragm may need to be replaced) I'm still experimenting with speaker placement and which room to put them in.
I understand that the First Watt F1 amplifier is an effective choice for efficient full-range speakers due to its transconductance (current drive) design. While this encourages better bass out of the speakers, I'm still interested in incorporating a powered-subwoofer to see if I can improve the overall performance.
Normally I would start by connecting the amplifier speaker outputs to the "speaker" inputs of the powered subwoofer. I'm worried about doing this with the First Watt F1 amplifier, however. Will the fact that it is a current source design create problems if I attempt to connect a sub in this way? I had found a short statement in a old forum post (via Google search) in which someone suggested that you should never connect this type of amp to a powered subwoofer. There was not enough detail in the post to fully understand the reasons. Could anyone advise me to what my options might be for incorporating a powered subwoofer for this system? Will I be limited to tapping off a line level signal back up the signal chain to a pre-amplifier?
Thanks!
Am using Philips DSP 2500 multimedia speaker. I want to hack and combine all 5 satellite speakers into one box
Hello, am using Philips DSP 2500 multimedia speakers. These are 5.1 speakers. I.e . 5 satelite speaker & 1 sub woofer bass reflex.
I am going to create holes in the main enclosure & put all satelite speakers into one place at diff
Can i do this. Wil there be interference or any issues.
This is how the satelite speaker looks.
This is how I want to drill holes & put all 5 speakers in the same enclosure. Will there be problem !
Choke loaded THF-51 with iSCG front end
Hi
About two years ago I bought a set THF-51 like so many others on this forum (I think we all know who to blame…).
To start with I needed to figure out what to build wit them. Single ended class A was a given, and based on Ben’s excellent builds I decided to make a common drain choke loaded amp. This out put stage does of course not offer any voltage gain but Rahul’s SCG could be used as a front end for the THF-51 out put stage. But I would also need some way to bias the THF-51 and I would like a low impedance bias supply (seen from the THF-51) to prevent any (high) gate current from messing with the set points. I achieved this by inverting the SCG.
I have not done any simulations on this circuit other than ohms law on a calculator. And measurements are limited to DC work points only. So, you have to make due with a hand drawn schematic. The reason is that I have been on a tight schedule to finish the amplifiers for a DIY loudspeaker event yesterday in Viborg Denmark.
The bias is adjusted by a small DC voltage applied at the bottom end of the 1M input resistor.
And here is a photo of the two amplifiers ready for yesterdays DIY event:
Best regards
Simon
Mcintosh MC2500 Amp board
Greetings. I have a Mc2500. The amplifier board was badly repaired a long time ago and now has become unusable. I do not know if I'll
be able to salvage the op amps. The rest of the amplifier is however still in good shape. I am making a new amp board myself for both channels
with new components as there aren't any stock available in the company and the used boards on online auction sites, look dubious. I need to
know however, what brand/type of resistors and capacitors did the manufacturer use in those Mc2500 amplifiers. I need to purchase new
components to make the new board but do not want to end up spoiling the original tone of the amp. Also, if I can't salvage the op amp on the board,
what is the best substitute for the original op amp? If someone knows, kindly advise me on this issue. This means a lot. Thank you.
Board-to-board PCB connector on NAD amplifier - how to detach?
I am taking apart a NAD T750 and it has a vertical volume circuit board that connects directly to the (horizontal) main circuit board. There are two board-to-board connectors to detach and one of these easily pulls up without any manipulation but the other one does not budge. On another forum it was suggested that I tried pulling on what looks like latches on the sides while I pull the board up, but that part of the connector does not seem to move at all. If anyone has come across this type of connector I would appreciate any advice!
Hiraga 30Watt build… can't get it right (help!)
Hi Guys,
Im doing my first build of a Hiraga 30 Watt class a . I put all components right and checked them all, but appearently my powerstage does not go 1,5 amps current.
I did some measurements, maybe you can give me some direction where to look / what might be wrong?
There is no load, input shortend, and it does amplifie, all be it crooked class B with a lot of distortion. Im puzzled !
Effect of resistor in parallel on amp output ?
I have bought a Beresford TC-7210 speaker/amp switch, described here http://www.beresford.me/downloads/TC-7210 speaker selector REV3.pdf
I've been misleaded reading this sentence : " Load Protection circuit design safeguards your amplifier when it is not connected to the speakers" so I figured out that the circuit was designed to insert a resistor between amp's hot and negative binding posts when an amp was not in use. As I'm a curious guy, I cracked the box open only to discover that a 100R/10W wirewound resistor is soldered between hot and neg of each input terminal, thus being connected in parallel to amp outputs permanently...
What would be the effects of such configuration on amp's and speaker's operation ?
XLS 2500
After 12 years of use one of my crown xls2500 start some problem.when i push the power button amp starts all relays click but no sound on speakers.after about 20 seconds all the bar leds start blinking for 3-4 seconds and relay click ones.then i have sound on speakers and the amp going on for hours without problems.can someone give me advice what causes that?or someone have the same experience with this very popular amp?i have all ready do some troubleshooting desolder all relays and checked then check all relay diodes all ok.capacitors is all new change 2 years a go.thanks for any help.
Guess current draw for a portable headphone amp?
I built this Tangent Pimeta2 over decade ago:
https://tangentsoft.com/audio/pimeta2/
It has worked fine for years, even surviving many daily road trips and errand runs. Sound quality is first rate!
BATTERY POWER, IEMs and CURRENT DRAW :
I have been using an external battery pack comprised of 10 AA 1.25v NiMH batts. So I have about 13-14 v of power for my PIMETA2. The charge lasts about 7 hours (I built a multi-hue battery health LED ckt for the front of the PIMETA2; this provides very good insight about how the PIMETA2 uses batts).
As an experiment , I recently switched to two 9v alkaline in series (18v).
Music played as normal, perhaps a bit more beefy and dynamic given the extra voltage.
HOWEVER...
My PIMETA2 drained two new Ray-o-Vac 9v alkalines in less than two hours. I noticed this symptom rather quickly: music went from sounding ok to very distorted over the span of only, maybe, two minutes. This is when I checked the batt. LED: Indeed, the PIMETA2's batt indicator was almost not visible anymore (it was beyond hue change--- very dim).
I switched the PIMETA2 off for about a min. Turned it on. Same batts inside. All LEDs green again, but same battery-draining thing happened -- only now after perhaps 5 min of use. Seems as if the 9v battery chemistry was beyond recovery!
All these years of uneventful use, I never wondered/guessed how much current the PIMETA2 draws (idle or playing music thru IEMs) until the two 9v alkaline in series incident.
I measured PIMETA2's current draw at batt terminal with my Fluke 87.
Idle (no input or IEMs plugged in): ____ mA.
Music, normal volume, with JVC IEMs: ___ mA.
I assume this ____ mA is draw NORMAL given that I opted for buffers. (I did bias into class A; my L, R and G channel opamps: all AD825). And I also use this completely passive xfeed board. Modified Linkwitz Crossfeed https://tangentsoft.com/audio/mlxfeed.html
I only use IEMs with this and all my portable headphone amps. I have a 2006 Go-Vibe portable amp that uses a single 9v batt. The GoVibe also has an op-amp ground channel. It draws: only 6-7 mA (idle or with music into IEMs)
Try to guess " ___ mA" based on the info provided above, as well as links to the device -- theory of oper., topology, schematics, BOM, etc -- on the original Tangent website.
Reason for asking: believe it or not, the original designer has no clue about his own creations' specs. And he seems to avoid all queries about such topics. The whole PIMETA project was group-forum effort on the orig Headwize site, so Tangent may genuinely be clueless about many specs.
Power cable for Kentiger Hifi Power Amp & Pyle horn speaker setup
I have all the electronics savvy of your average Amish kindergartner, so bear with me please LOL I'm putting together a homebuilt E-Caller rig to take the place of my 30 year old Johnny Stewart cassette deck outfit (25 pounds & clunky as all getout). It involves a 12 volt 7.2 amp hour battery - inline buss fuse -- Kentiger lHifi Power Amplifier - standard AC wall outlet - connecting to 65W Pyle horn speakers, using 12 gauge speaker wire.
I have the stuff to build the E-caller EXCEPT a power cord from the battery to the Kentiger amplifier. No power cable was supplied with the amp.
Now, I tried a really thin wimpy wire recharging cable from my old Johnny Stewart E-caller, since it had the proper connector to fit the male plug in the amp. So I cut the AC wall outlet prongs off and put the positive and negative alligator clips on the raw end, added the in-line glass fuse, and hooked the whole thing up to the battery. Within 3 seconds the thin wire sizzled and melted from the alligator clips to the fuse housing and would have burst into flames if I hadn't disconnected the clips from the battery. WOW -- SCIENCE!
So... apparently the wire that re-charged my Johnny Stewart tape deck battery was TOO WIMPY?? to do the job?? The glass automotive fuse DID NOT blow, by the way. The amp itself, and the wire from the fuse fitting to the amp itself, were not affected.
I looked online and Kentiger only offers 1 power cable ... it has an AC wall plug - to - 1/8th" female connector. This cable has a circuit breaker built into the cable. Is this what I need to get, and cut off the AC household wall plug and replace it with the red and black alligator clips?
CAN I MAKE MY OWN POWER CABLE (Alligator clips to fuse holder to amp) out of the 12 gauge speaker wire
Or what do you suggest? (besides give up DIY electronics projects; too late for that now, I'm hooked on the smell of ozone and plastic insulation smoke in the morning). THANKS in advance Gordo
Affordable PDC-2.6p alternative?
Hello digital active speaker friends,
my DEQX PDC-2.6p seazed cooperation a while ago. Repair of this old unit seems to either be impossible to do by myself (no documetation anywhere) or prohibitively expensive by DEQX. Buying a new unit looks out of the question budget wise and buying a used unit would again be old technology.
So I have come to the conclusion to buy a new, more modern xover/DSP.
Features wantes/needed :
Analog Input for phono
Digital Input AES, SPDIF, Toslink, USB (optional), not bluetooth
Streaming and MQA support not necessary
Control by PC over USB port
IIR and FIR filtering
4-Way xover
Internal processing and AD conversion with min. 24Bit/96kHz
Output balanced (preferred) or unbalanced
Budget up to 1,000 €uros incl. taxes and shipping
The above list may not be complete... 😉
One product attracted my interest is the new miniDSP Flex Eight, but this one is missing the ADC and I'd like to have the ADC clocked by the DSP internal DAC clock.
Maybe someone here can recommend a product (with justification please) which meets my needs.
Thanks a lot and kind regards,
Winfried
Best PSU for TPA3055 at high output power
I am experimenting since quite a time with TPA3055 modules at supply-voltages of 30 Volts and up .
Tired of moifying the power-supply every time for different tests and after several ups and downs I found
that a combination of cheap chinese units gives me a good result for my own purposes of Voltages and
currents with an ample margin for both values :
a 24 or 36V switched PSU with 10 to 20 Amp-rating ( of the type see picture ) is one :
and a boost-converter of 20 amps input current ( again see picture ) is the other.
Both together come to 50 dollars or less and allow for any output voltage and current one might want
to try for ones amp . Lowest voltage is 24 or 36 volts , depending on chosen PSU , and current is limited
by maximum input current of the booster or less if so adjusted on the booster unit. Set both in screened
box to keep radiation locked in and taking power out through a small choke and an equally small
capacitor ( 470uF/100V los esr-type )and you have a stabilized PSU which adapts to whatever you want
at a very low cost , weight and safe to operate as any failure can only result in lower voltages.
Choke and capacitor placed next to the outside wall of screen-box.
Gives 8 to 15 amps depending on freely adjusted output voltage up to 50 volts
As it happens it makes a good low cost PSU to use in a definite amp as well .
Opinions ?
Reactions: maxolini
For Sale Woden Design Stinger w/ Mark Audio Alpair 6.2
These are "The Stinger" as described in the PDF attached to this thread:
https://www.diyaudio.com/community/threads/woden-design-3-box-designs-babylabs-more.247904/
I purchased these from Dave (aka planet10), and I believe they were built by Chris.
They are made from Baltic Birch in a very nice Rosewood veneer.
Cosmetically very nice except some minor damage to one of the back top corners (can be observed in the photos)
Drivers are Mark Audio Alpair 6.2M.
Asking $300 includes shipping and fees in the US.
In addition,
SINGLE Mark Audio alpair6.2PeN (the driver with EnABL treatment). I believe these were originally around $65/ea, so asking $50 incl. shipping in US.
Help requested: DAC I>V conversion, filter, balanced buffer
Hello DAC experts (which I'm not!),
the motivation for this project comes from the fact that I want to drive my active Speakers' balanced inputs with a balanced Preamp Signal.
The Preamp involved is an old, but well working, DSP DAC PreAmp with 3-Way digital x-overs and equalization capability, working with 24Bit/96kHz resolution, on digital and analog inputs. The standard outputs are cinch connections.
A closer look at the main board shows 18 x OP2134 between the AD1853 DAC Outputs and System's cinch Outputs: The first stages do I>V, filtering and unbalancing, next is analog volume control (PGA2310 based, jumpered "off" because I use digital volume), a jumpered 4 level coarse output control (which I won't need), then a buffer stage for an add-on board (which I don't use) and finally buffers for the cinch outputs (which I won't use an longer...).
So I came to the conclusion (maybe naively?) that I could switch off all circuits the above, cut and derive the signals at the DAC chip outputs and feed them into an own I>V, filtering and balanced output stage made up of just two OPA1632 (fully differential OpAmps) per signal. This would reduce the number of OPAs the signal is fed through to just 2 (one I>V & filter, one as balanced buffer) and have the (just perceived?) advantage to keep signals balanced from the DAC chips' outputs to the balanced Speaker inputs without unbalancing and rebalancing on the way...
After reading AD1853 & OPA1632 vendor application documents and looking at other available I>V/Buffering solutions, I have basically merged two app note schematics into one circuit concept which (I think!) does what's needed.
Here is the AD1853 application from the datasheet:
This is "my" circuit adaptation with OPA1632:
Now I would be very grateful for feedback and input on this, especially on the values chosen for I>V, filtering and buffering, no matter if that's all OK or not OK 😉
Thanks a lot for reading all this.
Best Regards,
Winfried
again on 6-24 cross
Hello, everyone,
I'd like to know if anyone has used the 6-24 crossover pass to enter with a stereo signal and exit with frequencies above 100 Hz still with a stereo signal and with frequencies below 100 Hz with a mono signal going to the subwoofer amp. Use the 6-24 to sum the left and right channels and output in mono without losing audio quality.
Thanks in advance to everyone for any suggestions.
Cheers
Giubos
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,468
Members
7,920,953
Messages
Filter
Forum Statistics
Threads
407,832
Messages
7,920,953
Members
508,468
Latest member
Wheelman
