Hodgepodge
Identical post on ASR ( https://www.audiosciencereview.com/forum/index.php?threads/hodgepodge.61979/ )
Quick story: Went to my storage unit and found some parts I never used for an old project I canned. A pair of KEF SP1632 drivers and a few dayton 5 1/2" Epique drivers. So I was playing around in CAD to see if I can make something relatively compact. I think I may have stumbled into a cardioid design. Here's what I got:
This would be an active design. I found this a little while ago ( https://www.tinyosshop.com/index.php?route=product/product&path=158_193&product_id=1233 ) which should allow me to even out the response between the KEF and the daytons. I would like to put something in the port chambers in order to create small group delay, enough to drag the signal 90 degrees out of phase, but I'm not sure what I could use. DSP would take care of the rest. I still have a lot of little details to work out, but that's the gist of the design. Would love to hear from the community on what I can do to make this work. If it won't work it won't break my heart, but I figure this could be a good learning experience either way🙂
Help with HF horn combing/lobing
So I prototyped a single Minimalist MEH (Minmeh) using Faital HF108/2x4" and passively filtered the response quite flat 160hz-12khz. Sounded A+ until I swayed my head laterally -- just a couple inches -- then it became noticeably dull/flat -- and a couple inches further -- lively sound came back -- and so on and on. Classic comb-filtering?
This was with a single speaker at 3m. To explore further, I disconnected the mids and listened from ~0.5m keeping one ear constant-30°-angled toward the throat for maximum acuity, as I adjusted head position laterally. Well, obvious combing or multi-petal lobing on test tones 4-12khz; 10khz sounded like pulse-pulse-pulse as I shifted. Then I flipped my body/neck/head 90° pretending the horn was narrow rather than wide, and moved accordingly (with some difficulty). Same result, qualitatively. Again, this is a single horn with just the HF108 playing.
I searched but could not find this issue mentioned. Help, please.
Minmeh HornFaital described here:
Cayn Vacuum Tube CD Player CDT-17A repair and new Project
These days I started restoring an old purchase, a Cayin CDT-17A CD player that I bought years ago for a modest price, $200. The CD player had various problems, someone had tampered with the PCB to the point that it no longer worked. I managed to "resurrect" the CD player, I asked myself the question, leave it like this or redo everything, and, how to proceed? In the absence of an electrical diagram and taking advantage of my passion for PCBs, I redesigned everything, separating the various stages, Control, Power Supply, DAC and finally the Tube power supply and audio and the digital audio outputs. The result is this. Now, is it possible to improve on the original design? Does anyone have any ideas?
On the net you can find something, but nothing of that!
ORIGINAL
NEW POJECT
Harman gets bigger ...
… ucking up Bowers & Wilkins, Denon, Polk Audio, Marantz, Definitive Technology, Classé, and Boston Acoustics
https://stereonet.com/news/breaking-masimo-finds-buyer-for-consumer-audio-business
https://www.whathifi.com/hi-fi/harm...s-as-masimo-sells-its-consumer-audio-business
Samsung-owned Harman porfolio includes audio brands JBL, Harman/Kardon, AKG, Infinity, Mark Levinson, Arcam, Austere, Crown, DBC, Lexicon, Martin, Revel, and Soundcraft. If the new deal goes ahead, Harman will add Bowers & Wilkins, Denon, Marantz, Polk, Definitive Technology, Classe, HEOS, and Boston Acoustics, making it the largest audio company in the world
dave
Markaudio MS vs MAOP
I'm wonder about buying a pair of either MAOP 7.2 or MAOP 11.2 or 11MS.
I've had the Pluvia 7.2 HD which I didn't particularily like (needed quite a bit of BSC and sounded off).
I'm running pair of 7MS today that I'm very happy with but they need some correction in the 2-4 KHz area which they are a little bit hot, and I'd like a little more SPL capability in the bass (hence looking at the 11.2 and 11MS).
Does anyone have experiences with these drivers and can tell me a little bit about how they compare?
Little Class AB Amplifier Hiss
I have this cheap little class AB amplifier. I am getting a hiss through any speaker I connect it to. Both channels. I'm thinking bad transformer but I will run through my troubleshooting steps. It is HIGHLY likely it is a just a bad design and there is noise between signal and power on these boards, however, many have used this amplifier without this issue. BOTH channels hiss.
I do not have the schematic
Findings:
1. When it is whole and you power it up you can hear the power supply transformer hum. The soft start relays kick on once the caps are charged and then you start to hear the hiss. The sound from the transformer isn't that different from the sound through the speakers which is why this is suspect #1. The transformer makes no noise unless it is hooked up to one of the boards. I know class AB is always on and pulling some power even at rest so this makes sense.
2. The hiss seems less noisy with the 120V input ground disconnected which is strange. If you scratch the 120V input ground on the chassis you can hear the scratching come through the speakers. This seems to point to a grounding issue in the design. This ground only goes to the chassis. This is suspect #2
3. There is a 3 pin volume pot for each channel. If I spin the volume pot with my head up to the speaker I can hear the sound of the pot turning coming through the speaker. I do not know how to bypass a 3 lead volume pot. I have disconnected the pot from the boards which seems to default it to the lowest volume level. The hiss is still present.
Things I have tried:
1. Disconnecting the volume pot - no difference
2. Separating the boards and moving them far from the transformer - no difference
3. Attaching the incoming 120V ground straight to the chassis and then to the building's conduit. I know the buildings conduit is a good ground as we have had to test this for other things we have built in the shop.
4. I soaked the transformer in polyurethane. I was hoping to quiet the actual mechanical noise of the transfomer. This also did not help.
5. I took a pencil and started tapping all of the components while it was powered and I could hear the hiss. Touching the components had zero effect on the hiss. I was hoping it might have been a badly seated/soldered component but that does not seem to be the case.
I open to try any suggestions at all. I have hooked this up in both my shop and my house and I get the same noise. I don't think its DC on the AC line since I have another class A amplifier that uses a toroidal transformer and I hear zero hiss coming out of that one. That one is about half the power but it has abosolutely no hiss at all.
The transformer is outputting 12v as well as two 35V leads to the board. Right now I am thinking its the transformer. Could be a bad batch of these cheap filter caps. I really do not have enough experience with class AB amplifiers to give any type of informed guess. Thoughts?
The Nightmare Before Labor Day
The acoustics in my new home are horrendous and I have to figure out a way to deal with that, or else find a new hobby.
This is my old place, in San Diego. The main room is really wide and deep and the ceiling is a standard height.
Four years ago, I lived in a tiny condo, and one of my top requirements when I bought a house was a big living room. I had to sell my Gedlee Summas in 2016 because my old condo was way too small for such a big speaker.
The living room in my new place is about as large as the old place, but the ceiling is nearly 30' high. When I bought the place, I had daydreams of a space where there would basically be no 'ceiling bounce' and I thought this room would image like a dream.
Instead: it's an acoustical nightmare.
So many issues with his space:
1) Due to the fact that there's absolute nothing between the speakers and upstairs, you can play music in the living room and it's about as loud upstairs as it is downstairs.
2) Due to the fact that there's nothing between the kitchen and the living room, anything that's going on in the kitchen interferes with the living room. Last night we had guests over and I had to put my chair a meter away from the TV, just so I could watch a show.
3) Every surface in the house is flat and reflective. It's like putting speakers in a warehouse.
So I gotta come up with some way to tame this space, acoustically.
My initial idea was a CBT of Unity horns. The idea that I had, was that you could array a vertical series of Unity horns and get a beamwith that's 30 degrees or less. The idea was that I could listen to music or watch a movie without bugging everyone else in the house. After discussing this on the Facebook group, I came to the conclusion that an array probably isn't ideal. The problem with an array, is that it doesn't control directivity to a low frequency. For instance, an array that is one meter tall will control directivity to about 340hz. But nearly all of the issues that I'm having in this space are at low frequency and ultra low frequency.
For instance, on Monday I was trying to watch "Heat." In the movie, the action sequences are about 20dB louder than the dialog. This creates a catch-22:
* if I lower the volume to accomodate the action sequences, the dialog is completely unintelligible
* if I play the movie at a decent volume level, the action sequences irritate everyone in the house, particularly if people are sleeping. My wife's complained about this, and I've even had guests complain about it. (My guest room is on the opposite side of the house, about as far from the speakers as you can get.)
The obvious solution would be a dedicated home theater in the basement. Which would be great if I lived where homes have a basement. In Nevada, there's exactly one house with a basement, and it's built to withstand a nuclear bomb:
Las Vegas House With Doomsday Bunker for Sale
Although I'll admit that buying a fallout shelter and installing Unity horns in it would be a very Patrick Bateman thing to do, I don't particularly like their decorating choices.
So I have to come up with a plan for this space...
Scott's Jaguars Sounding Great!
Just about done with a pair of Scott’s Jaguars with Mark Audio A10.2 drivers. They’re still in my garage/shop; thus, the background. The supra-baffle is walnut and wenge. I’m enjoying them as I’m typing this. No doubt, they’ll get a lot more use. Great for many types of music, but acoustic guitar sounds really great. Female voices are great too: Karen Carpenter sounds angelic. Wreck of the Edmund Fitzgerald by Gordon Lightfoot is playing right now and sounds darn good, too.
I was looking for something other than a typical box, so these fit the bill. I’ve done a pair of CHR-70 Mar-Ken’s and these were a simpler build. I’ve got the parts and plans for the A12PW/A7P, so those are next.
I really like the “challenge “ of something different. I did a pair of Frugalhorns with A7s, so I might try a Frugalhorn Lites down the road.
Any suggestions on what type of amp works best with the A10s? I’m using an old Onkyo now, but I’d like to see if I hear any difference with other amps. Also, are these best away from a wall?
Speaker simulator for a distortion analyzer
I want to build a load to test amplifier distortion and possible instability into something resembling my Seas A26 two-ways. I don't know what I'm doing, but I came up with this circuit. The impedance plots kinda match, right? Should I be concerned about all the swings in phase?
NAD T753 Fan Circuit / "Ground loop" hum
Greetings all.
I've been restoring a NAD T753 as another learning project. Initially, I had a power issue regarding the relays. There was a diode that was covered in the RTV/Hot glue stuff they were using at the time which was getting shorted to adjacent components that I fixed. After this, I noticed an intermittent hum/buzz reminiscent of a ground loop hum, which is independent of volume changes. I changed the cable to a non-grounded one and removed all peripherals, but the hum still persisted. Eventually I got the idea to disconnect one of the four fans underneath the heatsink. The hum stopped. I tried disconnecting a different fan, it stopped again. so it seems disconnecting any one of the four will cause the hum to reappear. As i'm still learning, i'd like some input as to how to hunt the cause. I'm thinking either the capacitors 875/874 would be something to check first, though I doubt both would be bad at the same time and there are no visible signs. Next, considering the fans are always on, I don't think this should be and maybe the thermistor is causing an issue. Normally these thermistors would only cause fan activation as temperature increases, but would this component being faulty cause the hum? Somehow I don't see this happening as if it was just locked in the on position, it would have a higher resistance to ground and not be able to cause a loop between two ground points. What are your thoughts on where to look next? I will be disassembling again to check the thermistor anyway to see why the fans are always running, but other than that i'm unsure how to test.
All SIT 50W+ Single Ended Amp (beta)
While pursuing Firstwatt's Articles and Mr. Rothacher's threads for years, I've always wanted to build an all SIT amp. I finally started testing one on my workbench, and it seems the amp is working well so far. This amp is similar to Michael's LuminAria + Mofo (L'amp) with some additional ideas.
Feedbacks, critics, ideas and suggestions are very welcome. 🙂
- All SIT. No other active components sans 2xPSUs.
- Sony 2SJ28 gain + Tokin 2SK182ES follower.
- Minimal signal path. Simple but heavy and hot.
- 600:600 transformer is used for testing.
- Water cooling (will be tested soon).
- Gain: 20dB
- Bias current: Sony 95mA / Tokin 4.2A (updated v1.2)
- Max: 50W+ @8ohm
- Power Consumption: 220W (updated v1.2)
Updated (V1.2):
Updated Schematics and measurement (V1.2)
Threshold CAS1 unequal rail voltage
Hi all. I bought this CAS1 recently and after replacing an arching power switch noticed an unequal rail voltage . All rails measure approx 33 volts till you get to that blue cap. 50 volts. I have never run into this before. But, I have never had just 1 cap replaced. Both ac inputs to the bridge react run 76 volts. Meter is rms reading
I probably will replace these caps and the tantalum’s too but thought this wierd.
Thank you, Rick
Threshold 4000 - difference between output boards PC0S3 and PC0S1a
I have several Threshold 4000 amps. Most have the PC0S1a output boards with the pcFE1B front end board.
I have one with a PC0S3 output board and the pcCFE 379 front end board.
The output boards are similar using the same A6 and A8 output devices. The FEB are entirely different.
The PC0S3 output board uses 4 wires to connect to the pcCFE 379 unlike the others that use 5 wires.
Anyone know anything about the PC0S3 and pcCFE 379? The serial of the amp is # F7908513. I'm guessing they are a newer design? Maybe?
Any schematics available, especially for the FEB pcCFE 379? I've got the output board figured out but both FEBs need work or rebuild.
Thanks,
Eric M.
For Sale Topping E50 DAC
Awesome little device. As good as you'll ever need, I just don't have a use for it at the moment. Has variable and fixed output. Upgraded metal remote and power supply from Ifi. $175 shipped CONUS price is firm thanks!
Behringer F1320D Replacement Power Supply
Hi Guys,
Looking for a replacement power supply module for this active monitor. The PCB board is a self contained SMPS dual output, which I am hoping can be replaced with a suitable equivalent, but I can't really tell (even from the schematic) what the rail voltages are.
I'm thinking 300W capability, with +- 30v (approx) rails? Any suggestions please?
Help with Onkyo Integra A8067, protection mode
Hello, I recently purchased an Onkyo integra A8067 integrated amplifier from a garage sale.
I am looking for some direction of how to diagnose /troubleshoot the unit.
The unit powers up but it appears to be in protect mode. When the power button is pushed the unit will power up however I do not hear the relay clicking. There are red lights illuminating on some of the boards (see pictures). Not sure where to start. Thank you for any assistance.
New to Electronics
I'm new to electronics, but have been a music fan my whole life. Let's just say that has been a LONG time. LOL! 😀 I have recently gotten back into music after a long hiatus. It's a long story that I won't get into, but I'm happy to be back. I love 2-channel audio and prefer speakers. My return to audio was initially spurred by my getting into personal audio. My wife works at night, so I use headphones so as to not disturb her. I use IEMs when I'm out, as I prefer not to have big headphone when I'm out and about. I'm even into car audio, and sold car stereos for a few years at a local shop in MD. I was even into home theater for a while. I think that learning something about electronics will help me in my journey and I'm looking forward to it.
My question to the diyAudio community is, what is the best way to learn electronics? I know almost nothing.
Anyway, it's great to be part of the group. I look forward to the interaction.
Oppo new UDP series players - 203/205 - Discussions, upgrades, modifications
As known, Oppo have already issued on market the new series UHD models, starting with a lite and cheaper edition - Oppo UDP 203. It will follow quite soon the next full edition model 205 (expected with the new DAC chip ESS9038 inside).
I may come soon with my considerations about this new model, based on the available pictures. I also hope to have quite soon the opportunity to improve this new model.
I think to open this new thread dedicated to these new Oppo products. Please feel free to come here with your opinions, appreciations, mods and/or improvements in this field.
L-Adapter
- We many times wonder what if that SMPS brick that feeds the Raspberry Pi or the mini PC or the MiniDSP or the Squeezebox or the DAC or the desktop Class-D amp etc. was a linear PSU? How such wonder boxes would perform without switching noise polluting their rail and most crucially their many times interconnected ground?
- What if we had a simple and strong linear PSU instead of fixed SMPS brick adapters that it could cover the voltage range for such applications by only setting it up with a jumper?
- Enter the L-Adapter. A versatile Sziklai pair stabilizer / capacitance multiplier based on LED voltage reference.
- Its output voltage is how many LED + trimmer minus one Vbe. Roughly 1.5V to 20V range. Move the jumper, trim Vout, ready. Connect the load.
- Is it any good? Yes its good. Not noisy at all and stable. For 1.5V input ripple it produces 1.5mV thick DC line. For 3 Ampere load it measures 0.02Ω output impedance. Which is flat and extended in frequency. When you pulse it the recovery is clean of ringing. Because there is no feedback between the output and the voltage reference. We want a general purpose PSU staying insensitive to random gear loading peculiarities.
- The recipe isn't anything new but the details are well researched. Low noise unity gain reference, but adjustable too. Which LED bar with which CCS experimentally chosen between many styles for very good Vref stability, what pair of transistors, the layout. Various ways to sink it, accepts quality TO-220 bridge diodes, two reservoir capacitors, fused like a Π filter. The board is 136mm x 63mm.
- What about its output current ability? Well, it uses a 15A audio amp grade TO-3P pass transistor. But that alone says nothing much. Its also the transformer the diodes the reservoirs the sinking the load's average consumption. Say up to 7.5A average can be catered for.
- For any light or heavy current application it takes that the chosen Tx the bridge diodes and the reservoir caps won't lose the plot for a target Vout. That's about rectification and filtering basics. It does not like less than 2.5V input-output voltage difference. That's the DC difference between C4 and the output. Can probe that between the fuse and V+ out. Or across D11. Although it keeps working on smaller differences it gets progressively goofy. If you see the LEDs dimming a bit its tell tale you crossed the raw DC section's losses good limit.
- Here is a schematic with typical reservoir caps values and some pictures. That soldering iron pulled 55W peak from the mains through the PSU to boot and idled at 12W. The scope pic displays Vin ripple on C4 vs Vout status captured at a point when the iron was still pulling hard to heat up started from room temperature cold state.
The Fluke reads C4's raw DC level in another picture. Started at 27V idle with worst loss of 4V during the soldering iron's boot cycle (trafo, diodes, rippleV). At 23V raw DC for 18V output to the iron, that trafo and reservoir caps passed the 2.5V Vin-Vout criterion by double margin. Other type & quality trafo or diodes could lose more or less steam of course. Higher value reservoir caps would achieve less ripple voltage but would also make the diodes work harder. Since the worst raw DC level sufficed, better not increase the caps value in this case.
The example has 4xMUR860 & 2x4700uF/35V B41231 EPCOS/TDK. Also a 38mm tall Q2's sink. Which sufficed due to the irregular current pull of the micro controlled soldering iron. Can it do an RPi3? Yes I tested it with Wi-Fi and streaming vids on the Raspbian OS. Can it do a 12V Windows 10 Cherry Trail mini PC? Yes I tested it. Watched a whole movie stored in a mechanical 2.5 inch USB Hard Disk attached to it. The PC was at the same time charging an OnePlus X phone from a spare USB output so I pushed it further. I now used lower voltage and smaller size transformers than that R-Core. EI or toroidal of average quality. They and the sinks sufficed again because of the irregular current pull of computers with idling gap periods. 45C on the 38mm 35C on the 25mm ones for the diodes. Minimal RPi use shouldn't need diode sinks at all.
- In the final black & gold boards there are correct Q1 Q2 designations. On the green prototype first photo you may spot Q3 Q4 relic prints, please ignore. PCB size is 136mmX63mmX2mm. Its mounting holes diameter is 3.6mm. Their horizontal center to center distance is 127mm. Their vertical center to center distance is 54mm.
- I will be editing & enhancing post #1 in later installments.
- 25/6/2019 Build guide added (includes circuit description & BOM) - attachments rearranged
  • L-Adapter Guide.pdf
    L-Adapter Guide.pdf
Reactions: starcat
HF driver diagram failure, defect or too much power
Guys,
Last Friday gig one of my tops just go dull, so I noticed and when in front of the cabinet, I immediately knew what happened, I lost the HF driver.
The tops are :
Yammy DSR112, the plate amp have all the DSP and limiting , so why the driver fail?
Metal fatigue, too low XO point (too much LF power), or just too much power.
Factory DSP suppose to prevent any harm to the drivers!
I saw pics on the net where the diaphragm shattered like this or more.
See the pic
Like 8 months ago the original driver died, at that time it you can see the glue of the coil bubbled and more dark suggesting power failure.
But why? I have seen people who play them with the limiter light stuck on ,
And nothing blow.
Do I have a bad plate amp that is outputting DC or not limiting right?
I'm puzzled.
Power Amplifier using Split Feedback Loops
The amplifier has 2 stages: voltage amplifier and current amplifier with each stage having a separate feedback loop. The motivation for removing the overall feedback loop is to reduce the overload of the input stage due to crossover distortion on the voltage amplifier, implemented using IRFP240/IRFP9240 vertical power mosfets biased at relatively low current (100mA). The crossover distortion occurs each time a power transistor turns on. and pushes the gain of the power stage down to cero (close to). When cascaded with the voltage gain stage, the gain is still cero. Independent of the amplifier bandwidth, feedback cannot correct the crossover distortion if the gain is cero. It is difficult to predict the output waveform because the circuit is time-varying. But single inspection indicates that the error signal produced at the input of the amplifier is very large. The resulting transient response at the crossover point shows a large overshoot and ringing that last a longer time than the charge time of the gate capacitance, that means, the time required to have the gain reestablished. By splitting the feedback into two separate loops simulations indicate that transient distortion at the crossover point is reduced both in amplitude and duration. Overall distortion is higher, as circuit theory predicts, but tests show to be below 0.1% at any frequency for this particular circuit. The voltage amplifier is composed of a cascade of a common base input stage and a folded cascode. The power stage, composed of a complementary pair in compound (quasi Darlington?) configuration with single loop feedback (common base - common source), achieves the required unity voltage gain.
The two monoblocs are build using chassis and power transformer from old PA amplifiers, includes additional capacitors (4 x 4700uF each) on the supply rail, and semi-translucent acrylic front panel for esthetics. Would like to discuss described feedback topology.
Reactions: m0rten and abstract
Audio to I2S for DAC Testing.
For testing my various diy dacs I have used CD test discs in the past.
Ideally an audio to I2S interface would bypass this and allow direct audio from a sig gen to the dacs I2S (PCM)
i found this one:-
https://www.audiophonics.fr/en/devi...onverter-wm8782-i2s-24bit-192khz-p-13351.html
or this one maybe a better choice:
https://www.audiophonics.fr/en/devi...dc-board-wm8782-i2s-24bit-192khz-p-14897.html
Any views?
Hello DIY community
Hello fellow audiophiles. My name is Weston. I'm an iOS engineer by day, and spend nights gaming, doing tech related side gigs, etc. I'm interested in learning more about audio hardware and software. My knowledge is quite basic but my experience in tech helps a bit. Currently working on a project using RasPi and Moode Audio Player OS to stream audio. Also enjoy learning about car audio setups, which is how I first learned about speakers and amplifiers when I was 17. Hope to learn more here.
Stoked to be here!
- Weston
DIY crossover for replica JBL 4345 horn and tweeter
Hello,
I've a pair of replica JBL 4345 which I've been 4-way actively bi-amping with the DEQX Pre-8.
I'd like to add 2 subwoofers to the mix, and that means I'll have to free up 2 of the 8 channels from the Pre-8.
My idea is to make a passive crossover for the horn (JBL LE 85, 8 Ohm) and tweeter (JBL 077, 8 Ohm), and then run them off of 1 amplifier.
Trouble is I don't have any experience with such activities, so I hope someone here can teach me a thing or two to get started.
What I think I know so far is as follows:
From the JBL 4345 manual they state that the crossover frequency from the horn to the tweeter is at 10kHz, 18dB per octave.
I understand that there are different types of crossovers from 1st to 6th order? They have different names along the way?
After reading around a bit I gather that my crossover needs to be a 3rd order (Due to the 18dB?)
Then I used the link below to calculate what I think is correct:
https://www.diyaudioandvideo.com/Calculator/SpeakerCrossover/
And the result is as follows:
In the calculator I had 2 options for a 3rd order, Butterworth and Bessel, what are the differences between these? Which would suit my case the best?
Am I on the right track here? Or is there something I should know about?
How important are the values? Is it okay to be a bit over or under, in case I can't find a capacitor or inductor with the exact value stated?
I hope someone will enlighten me a bit and maybe give some tips if possible.
Best regards,
NavnFugl
Heybrook HB2: Polydax tweeters need new impregnation / coating : Liquid used by Polydax / Audax ?
I have two pairs of Heybrook HB2:s, on which the coating /impregnation on all Polydax tweeters have aged and disappeared, so that more than 50% of their surface area lacks impregnation, which is very visible looking through the domes with bright light behind them. An open, sparse silk mesh is all what is left, so not even close to air tight.
I read a thread by diyiggy from 2020, "Poor man silk soft dome liquid impregnation" , where he stated that Audax did use "aqua solvant acrylic coating", and he also considered Polyisobutylene as dope/coating for his silk dome tweeters.
Have anyone found an impregnation fluid that actually works as well as the original, "forever tacky ones" ?
I am desperately searching for one, since the "drop-in" Audax tweeter replacements sold by Falcon Acoustics do not sound even close as good as the original ones.
Best regards,
Magnus, Gothenburg , Sweden
New "Oldie" here :-P
Hey,
i just revived my home-studio, it was sleeping the last 13 years in containers -.-
I made a lot of electronic music, soundtracks etc, back in the 90ìes^^
I have some old, analog Roland gear, like TB-303, MC-202, TR-606, TR-909,m Alpha Juno 2, Wavestation A/D, etc pp..^^
So i love the warm, fine analog sound, i swear on vinyls, DAT-Tapes, Tube Amps and even Compact Cassettes 🙂
Now, i am on the search for something tube-styled outdoor gear, and th`s the reason, why i am landed in here.
I am in the mid-fifties, but still feel like an never grown Peter-Pan :-D
I love my dogs, motor-sports, and not to forget - Music, Music was my first love, and it would be my last <3
Hope to meet here open minded, helpful people, same as i am!
cheers and hello to all in here :violin::wave::note::Piano::hphones::cheers:,
Mario (Germany)I
Hello diyAudio members and community, people, folks, fans
It kept popping up wich people used the 'hi, hello dyAudio so I figured to included as many community words I could find. Hi!
Im 54 y old male from small, cold northern europe country. Wasnt my choice! married, happily, dog, 2 cats a nice house and car. Background in legal and government. Also sometime DJ back in the 80s and 90s. Ive only rediscovered my love for audio some time ago.
At this moment because of nostalgia I keep drawn on Quad amps. Especially the Quad 34 pre amp wich so easy to use for tone controls. I also like the 606 power amp. They are both well maintained (not by me).
I use pc mainly as audio source, with a dragonfly USB out. A Minidsp takes care out the 34 output and my main speakers atm are Revel F208. They are quite rare in europe and I only haven them for a few weeks now. I added an SVS sub 2 years ago but because I like some more scope in varied and loud SPL moments, decided to go into better subs and went for diy kit from parts express. At the moment 2 15" Dayton ultimaxes. After a good half year I find the integration fascinating and always wanting. Spent many hours learning MSO and now it kind of works good enough. I am contemplating on upgrading on the ultimax subwoofers since im lacking a bit between 70 and 100hz. That said I might get the Revels to work better there. Not sure. crossover is now at 73 for one preset, and 100 at the other. English isnt my first language so bear with me. Thank you!
Strong local feedback + light global or the opposite?
I would like to know what is the general point of view on this topic.
Is it preferred to have a stronger local feedback to drive the OPT with a lower impedance, then apply a small amount of feedback across the output transformer to iron last harmonics, or drive the output transformer with a higher impedance and then apply a stronger feedback across the output transformer?
The first option should be more permissive on the choice of the output transformer, and should recover faster from overloads.
Any other pro and cons of the two choices?
Thanks in advance
Roberto
Excited new member here !!!
Hello everyone:
My name is Dan and I'm happy to have finally joined the forum. I have recently gotten into the vintage electronics repair space and I enjoy it very much, I am by no means a pro or expert, I just enjoy tinkering and fixing things, it gives me a certain satisfaction to take something old and broken and breathe new life into it. I'm an enthusiast that would like to broaden my electrical "know how" which is not my strongest skill. I have recently gotten into fixing vintage pioneer car radios and 8 tracks, growing up my father was a manager at Radio Shack and over the years he amassed a huge collection of old pioneer car radios and 8 tracks which he has recently given me. I have been going through the radios one by one assessing their condition and level of repair needed and then trying to fix them. I have much to learn about vintage electronics and I'm excited to go on the journey, I have many radios to repair and even more questions regarding them, but I will save that for another post. Thanks
Reactions: 6L6
Modding JBL Bar 500
I'm no so satisfied with the sound of my JBL 500 Bar and wanted to see if I can do things about it, like building a larger cabinet for the bass. So first I tried to measure the TS parameters of the subwoofer and the dimensions of the original box to model that in WinISD.
The JBL speaker has markings : S260C3C 3Ohms but it's a special reference for that subwoofer
The method I used to calculate the TS Parameters is here : https://sbacoustics.com/wp-content/uploads/2021/01/Measuring-Thiele-Small-parameters.pdf
The method I used to calculate the impedence is here : https://www.tek.com/en/documents/ho...ement-lab-measuring-impedance-and-capacitance
The results are here :
So first I'd like to know what people think of these parameters, did I made any obvious mistake or is someone willing to measure his speaker for comparaison ?
Then I went ahead to measure the enclosure. It's made of 30mm MDF at the bottom and 18mm MDF on the sides. Three faces are covered with damper. The "panel to panel" measurements are: 267mm x 267mm x 350 mm for a volume of 24.95 Liters (without removing the volume of the daming)
1744520846868-png.1448085
The vent is tricky to measure as it's an oval, and conical : The vent section Outside is like this with a section of 4475,2 mm²
The vent section inside is like that with a section of 3191,1 mm² :
As the vent has a 90° angle in the piping, I measured the longest length to be 40 cm
and the short length to be 20 cm.
To summurize :
Vent port outside : 4475,2 mm²
Vent port inside : 3191,1 mm²
Vent long length : 40 cm
Vent short length : 20 cm
It's probably very wrong but if we assume the means, the vent average size is 3833mm² and 30 cm in length
Then in WinISD I entered the following parameters :
I do not know what are Vcd and Dvol or how important (used) they are in the software
When creating an WinISD project I entered the volume of the box : 24.95 Liters, then the vent diameter to get the same average area
Then I played with the tuning frequency in order to have WinISD calculate the vent length that is about the same size as mine : 30 cm
I'm very surprised with the results :
Did JBL really tuned a subwoofer like this and applies heavy DSP filtering ? Is that part of why I feel the JBL Bar 500 sound "Boomy" and not punchy or tight ?
Do you think I can build a larger box to make things a little better ?
Next I'll measure the frequency response of the amplifier within the subwoofer.
EDIT : I wired a 5 Ohms resistor at the output of the subwoofer amplifier module and measured amplitudes with my scope. The soundtrack generates sinusoidal tones with the sample amplitude and is played over bluetooth to the bar.
By measuring the voltage across the resistor I have an image of the gain for the whole system applied to that subwoofer
First observation: When no sound is applied there is a 385kHz sinewave with an amplitude of 1V at the terminals of the amplifier output:
This is probably the operating frequency of the D class H bridge used in this amplifier.
When I play my soundtrack overbluetooth I can plot the amplitude response of the amplifier only on it's resistor load :
We see a huge gain arround 30Hz and a band cut between 44 and 50 Hz.
Frequencies below 25 Hz are rejected by the amplifier DSP
There is a very smooth cutout frequency above 100Hz but the slope is too "weak" in my opinion and could be steeper.
This does not match exactly the spike of amplitude modeled with WinISD but I probably have many errors in my WinISD model.
Now with all these considerations, it seems that if I can build a box with the same speaker, a volume about 100L and a tuning frequency of 15Hz I can have a better low frequency response, and less of a bump at 70Hz. In red is the response with 100L box and a 15Hz tuning
The vent air speed seems to reach crasy high speeds at low frequency, however below 20Hz the JBL amplifier has a large attenuations and the speaker would never have the same excusion at these frequencies. So it might work because these air speeds are never going to be obtained in real world
I could of course make the vent larger, however the 1st port resonance would be too low...
What are your thoughs on my reasoning before I cut any piece of wood please ?
EDIT :
Link1 : https://www.diyaudio.com/community/threads/hack-for-jbl-wireless-subwoofer.413330/
Someone having issues with the amplifier and tries to add a new input to the subwoofer
Link2 : https://www.diyaudio.com/community/threads/jbl-bar-500-sub-no-power.421103/
Somone having issues with the subwoofer power supply
Aino gradient - a collaborative speaker project
Ok folks, inspired by the discussions of room acoustics, sound perception and boundary reflections here at diyaudio.com, I hereby start a new thread for a collaboratory speaker project named
Aino gradient
The inspiration to this project is the legendary and revolutionary home stereo speaker by designer Jorma Salmi, the Gradient 1.0 and it's siblings.
History
We will discuss it's design principles and we try to reconstruct and perhaps even go beyond it's performance and sound quality in contemporary domestic room environment.
This is not a commercial project and if we break some patented or otherwise protected things/issues, it is not intential.
The name of the project combines the very popular finnish first name for women (also wife of composer Jean Sibelius) and the concept of sound pressure gradient Sound speed gradient - Wikipedia, the free encyclopedia
The guidelines for development are as follows:
- to create a pair of stereo speakers that makes use of laws of physics, specially room acoustics to:
- minimize the early reflections from boundaries and to
- utilize the floor boundary gain by
- combining controlled directivity and controlled reflections
The means to achieve this are guidelined by the innovative pioneering work of Jorma Salmi, and they are mainly these:
- the bass utilizes a down-firing driver
- the mid is a large dipole tilted upwards
- the tweeter has controlled and quite narrow directivity (cascaded line array), perhaps dipole/bipole radiation
Ladies and gentlemen, start your engines!
Juhazi
EDIT - status Feb. 2025
Minidsp 4x10HD broke 2021, now two 2x4HD units with latest iteration of settings. LR2 acoustic xo
ainogneo83 2x4 conf37-tile.jpg ainogneo83 vx out 40ms 112 norm Directivity(hor).png
Hybrid Tube / Class D amp. Just a gimmick?
I have caught the Class D amp bug lately. I see many hybrid tube / TPX3xxx amps advertised (ex. Douk). Is the tube input stage just a gimmick?
My first radio in the 70's was an AM tube radio... it definitely had a warm sound that was great. My fathers stereo had a Scott integrated tube amp. I don't remember the tube colorations / too young to know a difference / don't think his speakers had the resolution to tell much of a difference.. I get tubes have their own unique sound. Do the tubes in the input stage just add tube coloring / warmth to the audio? I am pretty darned impressed with the "sterile" sound of the TPA3126 and TPA3255 boards I have been playing with. To me adding a tube input section will just alter the more pure sound to a warmer more colored sound?
"Back in the day" I had a Counterpoint SA100 class A/B amp with a triode tube input stage. I ditched it when I bought my used Threshold 400a Class A amp. There was a huge night and day difference between the two amps... but I doubt the difference was in the triode tube input stage. More just Class A (Nelson Pass) vs Class A/B amp. HiFi vs MidFi.
I am interesting in peoples thoughts on this?
Discrete FPGA DAC project
Recently I finished a prototype of the FPGA based DAC with following features:
  1. Singe optical (TOSLINK) input, accepting 44.1, 48, 88.2, 96, 176.4 and 192k sample rate.
  2. Stereo outputs L/R 1.06Vrms 0dB
  3. Digital volume control 64 steps of 1.16dB.
  4. PCBA 160x140mm, 4 layers
  5. Dual frequency SI552 VCXO clock oscillator 33.868MHz/36.864MHz
  6. Jitter suppression -100dB at 10Hz, using digital PLL with 0.03Hz bandwidth
  7. FPGA - XC6SLX9 LQFP144
  8. Power supply unit - USB-C PD input 15V 5W, isolation 5kV 18pF.
  9. There is no DAC IC, the audio output implemented as a 16-tap differential FIRDAC + 6-order analog reconstruction Low Pass Filter
    The parameters:
    ENOB - 17.2 bits
    SNR - 104dB
    THD - 0.000004%, almost unmeasurable at least -142dB to carrier at 0dB.
    SFDR - 140dB minimum.
    See attached spectrum of 1KHz sinewave of 1.05Vrms (0dB level).
    -30dB notch filter followed by amplification of +36dB was used,
    so THD was 32 times better than measured, noise floor and harmonics were -30dB lower.
Power Supply Optimization for Bluetooth Audio System
I want to build a bluetooth audio system with an ESP32 + DAC + Class D amplifier. This is the first draft of the project and I would like to discuss it with you before starting real tests, in order to optimize the schematics.
What I would like to discuss in particular is the power supply. The entire assembly will be powered from a 12V voltage source, obviously an SMPS. This voltage goes directly into the power amplifier. Then, the ESP32 module and the DAC must also be powered from the main 12V. And here's the interesting part. I started the power supply chain through a bidirectional LC filter, which must filter in particular the ripple generated by the 5V DC converter on the input, so that it doesn't go into the amplifier. On the converter side, I added dumping with an RC snubber for stability, and on the amplifier side, the dumping is introduced by the amplifier's filter capacitors that have an ESR of 2 x 260mR. The converter drops the voltage from 12V to 4.5V. Then comes another LC filter cell similar to the one on the input, with dumping included. This attenuates by 48 dB at 400kHz (the coverter frequency). From here, it goes into an LDO that powers the ESP32 with 3.3V... And it also goes to the DAC, through an RC filter (since we have low consumption), which increases the attenuation to 83dB, and through a 3.3V LDO that further increases the attenuation to 123 dB ! This is my first attempt at designing LC filters and DC converters, so I need to check it with someone who really knows about this...
What do yoy think ? Is this enough to have a quiet amplifier, without switching interference in the audio band ?
TDA1541A reducing DNL
DNL = Differential Nonlinearity, best explained here:
https://www.mvaudiolabs.com/digital/tda1541a-dynamic-element-matching-slowed-down/
Especially interesting is the TDA1541 DAC conceptual schematics.
It is possible to influence the upper bit currents by adding or subtracting a small amount of "leakage" current that compensates for the deviation from the theoretically correct bit current. This addition/substraction can be comfortably done at the DEM decoupling capacitors pins.
If a bit current deviates from the ideal, it causes DNL. The TDA1541A is specified for < 1 LSB DNL. Since the LSB is 61 nA, about half of this is the maximum current we have to inject at the DEM decoupling pins in or out. This tiny current can be generated by a 3 V source and a 10 MΩ resistor at each pins. The voltage is related to the default voltages at the DEM pins (that you can't measure with a DMM of 10 MΩ input resistance BTW bacause it causes a "leakage" current).
Previous work:
https://www.diyaudio.com/community/threads/dac-linearity-test-cd.113620/
https://www.diyaudio.com/community/threads/static-measurement-of-dac-linearity-possible.406689/
https://www.diyaudio.com/community/threads/16-bit-dac-at-60db.406935/page-5#post-7712941
Differential nonlinearity is the deviation when the bit current step is not exactly equal to with 1 LSB. Examples:
0000 0000 0000 0000 -> 0000 0000 0000 0001
0000 0000 0000 0001 -> 0000 0000 0000 0010 <- here 1 LSB change at bit #1
0000 0000 0000 0010 -> 0000 0000 0000 0011
etc.
Here and in the following I count the bits as LSB = bit #0, MSB = bit #15.
We are interested in the bit transitions of the upper 7 or 6 bits (more on it later), that is:
0111 1111 1111 1111 -> 1000 0000 0000 0000 (MSB, bit #15)
0011 1111 1111 1111 -> 0100 0000 0000 0000 (bit #14)
0001 1111 1111 1111 -> 0010 0000 0000 0000 (bit #13)
0000 1111 1111 1111 -> 0001 0000 0000 0000 (bit #12)
0000 0111 1111 1111 -> 0000 1000 0000 0000 (bit #11)
0000 0011 1111 1111 -> 0000 0100 0000 0000 (bit #10)
0000 0001 1111 1111 -> 0000 0010 0000 0000 (bit #9) - we will not use any correction here
Now we just need to measure the THD around each bit transition, and inject a correction current in the DEM pins for reducing the THD.
Sensitive ears?
Over the last 5 months, I have been building a budget stereo system (Akitika GT 102 amp w/volume control [pre-built], Thorens TD 165 turntable, CSS Citron 1-TD speaker, Rotel 855 CD player, no money for preamp yet). The irony is that the more that I improve the system, the worse the CD player and turntable sound. But the cheap 12 foot cable with RCA to 1/8 inch plug inserted into my cell phone to listen to YouTube classical music videos sounds better and better - the worst source!
I believe that I have very sensitive ears - speakers with strong high-frequency presentation hurt my ears - especially Klipsch. So do high powered Wi-Fi routers.
It recently found out that YouTube cuts off frequencies over 15 kilohertz. So a possible simple solution to my stereo problem would be a low pass filter at 15 kilohertz.
I know almost nothing about electronics. But is it possible to build / purchase a 15 kilohertz low pass filter? And should that filter be inserted between the amplifier and the speakers? Or someplace else, such as the interconnect cables?
(BTW, I have a friend that could help me build the low pass filter, given a schematic and a list of recommended quality components).
Many thanks from this music loving electronics noob.
Single Ended KT66 / KT88 6550 Triode Strapped & Ultra Linear
This project was inspired by the now obsolete AirTight M101 Kitset Single Ended KT88 that used Tamura Output transformers , my findings may differ from your take on it or even the parameters I am using , as always safety is paramount with amplifies like this with lethal voltages involved .
The AirTight M101 kit was discontinued back in the 90's when Tamura stopped making many Transformers , fortunately Tamura have re - issued a F915 with UL tap I used in this trial.
https://positive-feedback.com/nos/acoustic-masterpiece-m-101-amplifier/#:~:text=The midbass impact was very,could have a killer system.
First output transformers tried were the Muse Coils I have, 4.6K / 70mA max , %40 UL or Triode mode , other taps are 3.3K /2.25K triode .
20Hz -50Khz -1dB !!! I am very happy with its 2kg mass / chassis footprint 65Wx90Dx120H mm and performance ideal for this Amplifier circuit with a KT66 .
This transformer is perfect with the KT66 in triode and ultralinear the best I have listened to with for many years , triode mode is very similar to a 2A3 this confirms the KT66 matches the PX25 performance in triode mode .
The entire spectrum of audio is well balanced and plenty of bass . https://musecoils.com/?bot_test=1
The bog standard chassis from Hammond I used was the Mouser Part Number ,1444-12123 chassis and 2 x 1434-1212 bottom plates used , only problem is the Hammond aluminium chassis are only 1mm thick and had to order two bottom plates , cut one bottom plate in half ,file to size and glue the extra piece under the chassis using a decent glue ie Loctite 480 Instant Adhesive , then 4 x steel brackets bolted in each corner underneath and one each side midway for strength to hold transformer weight , a messy and slow process . Note only the rear half of the chassis was strengthened to 2mm in total for support .
Will likely get a local sheet metal shop to fold a 2mm aluminium chassis and have drop through holes for a Hammond 290LX power transformer , tube sockets holes and IEC rear punched out in future .
The wooden surround to fit around the Hammond Chassis is Tasmanian Blackwood and Oak for the rear , so stamped speaker / RCA/Power lettering is clearly visible , there is more work to do with further miter cuts to curve corners and flat sections will also be curved inwards .
Once the wooden surround is bolted to the Hammond chassis it will also strengthen the sides considerably .
A cutout for the volume control knob at the front will be made for the 100K PEC Carbon Precision series KK/2RV7 potentiometer ,
the best I could find , much more natural sound than plastic film in the signal path IMHO .
https://www.digikey.com.au/en/produ...4m3MbB8DDerkn2rs4tywuTUwLPRRIB-j3JuTna9Tw5iNw
A KT66 will first fitted a tried , drawing below in triode mode , followed by the KT88/6550.
Biasing the KT66 ( B+ 385v ) and KT88/6550 ( B+ 400v ) will take a bit of trial and error as each set of tubes often don't operate near enough to published curves , again a 10 ohm resistor in series with the tubes cathode resistor to get it spot on and output transformers soak up a few more volts than others depending on current required
This project is being shared as a personnel build not a DIY guide as your own designs may well be better .
I saw a number of pictures on the net including under the Chassis of the M101 , quite a simple affair of 12AX7 plates strapped together 1.1mA approx and a KT88 biased with a 600ohm cathode resistor 70mA ? starting with the premise of a B+ rail close to 400v DC .
It looked as though the 12AX7 input tube with plates / grids and cathodes strapped together looked to be biased near 1.1mA , mine is now 1.4mA on latest amended version 3 drawing on post below , please ignore drawing on post 5 and bias @ 2mA is incorrect , trouble trying to reverse engineer from old photos , lesson learned always check current with 10 ohm resistor in series . The main dropper from B+ to the 12AX7/12AD7 is 68K !! not 6.8K typo on the KT88/6550 so ignore drawing on post 5 & 8 please .
Now I have installed a GE KT88 / 6550 although labelled GE KT88 it looks certainly to be a 6550 which is a highly regarded NOS GE tube .
With 400v B+ my take on the M101 with 12AX7 driver circuit enclosed but remember tube current on the KT88 /6550 can often vary to published curves so always put a 10 ohm 2 watt resistor in series with the cathode resistor to ground and measure volts to ground V = IR you should see 0.7v ( 70mA ) on the lowest setting on your volt meter , somewhat abbreviated . So often the cathode resistor will need too trimmed a little for the desired current .
With the latest Muse Coils ( Model MinotauR OTSE - 060NHY-046 @ 15Hz -52Khz -1dB ) 1.6T @ 25Hz custom design for me a primary of 4.6K 70ma / 3.3K /2.25K / - 4 / 9 and 16 Ohms with %40 Ultra Linear tap for the 4.6K worked well with the 6550 limited to 70mA mA
The Muse Coil Sound with the 6550 in UL was excellent and very smooth over the entire range , bass had plenty of snap and leading edge ,slightly darker tone and rather sumptuous in triode , excellent high frequency extension , The F915 is also an excellent performer and probably more true to the original M101 sound 25Hz - 65 KHz which is very good for a 5K load , same slightly darker tones of the Muse Coils with excellent frequency extension , in this circuit much less distortion than a SE300B and able to work with speakers 90dB/1 watt and above , in fact drove a pair of Sonus Fabers 86 dB/1watt quite well ! BASS in a real winner here tight and controlled .
( edited after much more running in was needed )
The Sound of this transformer in my take on the M101 is excellent and would endorse the positive - feedback review .
I have used this F915 with a SE300B at 8 watts output very nice indeed very detailed but never bright and excellent bass compared to the Hashimoto H-20-3,5U SE300B which was very musical but more energy in the upper mids ..
The 12AD7 I used , same 12AX7 with tighter specs also needed to be trimmed for cathode resistor value , using a 10 ohm resistor to check current .
The sound of the SE6550 in Ultra Linear was very nice indeed , the synergy between the 12AX7 and 6550 produced excellent bass and high frequency extension and the midrange was surprisingly smooth and sweet , I have introduced about 3dB of CFB as this seems the break point where the sound stage closes in a bit , with a Mundorf Silver Supreme capacitor detail was excellent but sound stage pushed forward .
This amplifier has far less distortion than a SE300B at 6-8 watts I have previously built with more dynamics and bass impact , I suspect the SS Hexfreds power supply can attribute a little to this phenomenon
A Toshin DUCT paper VitaQ oil was installed and the soundstage moved further back between my speakers , it has a very warm sound good bass impact , very full midrange and HF is good , the Mundorf Silver Supreme is more revealing being an oil impregnated metallised silver polypropylene dielectric capacitor .
The Problem with the now Vintage AT- M101 kit set is the old carbon resistors and electrolytic's will need swapping out now for longer term reliability , quite a bit of work !
The 12AX7 I decided to use was a NOS Japanese Toshiba 12AD7 the very low noise closely matched version the the 12AX7 with very close matched plates suitable for strapping together .
All my signal wiring is point to point copper foil at present and resistors I have chosen are mainly Amtram AMRG & AMRT carbon resistors and capacitors from mainly Vishay Sprague ATOM and a full bridge rectifier using HEXFREDs bypassed with 0.01 uf 1200v ceramic capacitors .
The LM317HV has been replaced with wire wound resistors .
NOW are few pictures of the chassis and woodwork ( almost finished ) to be fitted and Muse Coil Transformer Plots 15Hz - 52Khz -1dB 1K driving impedance.
F915 25Hz -65KHz -3dB
Warning​
This information is for general interest only and you would need to come up with your own designs for any build and be suitably qualified in what ever country or State you live in to embark on building these projects as inlet power supply involving AC mains voltage and DC voltages in this post can be lethal if not used safely .
  • SE K88 UL : 12AX7 version 3.png
Emotiva XPA-2 Gen1 schematic needed
Hi Guys,
Scored an Emotiva XPA-2 gen 1 power amp today for not much $
Issue is that it tries to turn on but goes straight into protection mode. So like any curious DIYer, off with the lid !
Jeebuz 😳 what a beast !! This thing weighs in at 35kg, has a 1200VA toroid and 12 x 15000/50V electro in the main pwr supply.
Rated at 300wpc these appear to be quite well regarded.
Anyways, I've pulled the DC power supply board but can't find anything that stands out as failed.
This thing has a soft start board that can auto select 120v or 240v and is also tied in with the protection circuit to open the mains relays if a fault is detected.
It is powered by its own 10va transformer.
Anyways, looks like it tries to power on, lights come on and relays click, then after 2 seconds, it shuts down.
This one is going to be tricky !
I've emailed Emotiva service but they have decided not to respond.
Does anyone have schematics for it they can send my way ??
D'Agostino Factory Tour
Here you go:
Login to view embedded media
The aesthetic is definitely not to my taste BTW - I am posting this for academic interest. There are a few aspects shown in the video that I find interesting. One of the comments remarks about the lack of ESD straps, but if you are working in a strictly bipolar world, is that a big deal? (personally, I use a strap even when handling jellybean BJT-based parts, but I am ESD-paranoid). Methinks that the most expensive components shown are the CNC-milled enclosures and level control. The exposed moving coil movements, sitting on egg cartons, are curious.. You can't use compressed air on them, so how do they prevent fluff from getting into the meter? (that would upset me on an amp that cost 6 figures - I'd be expecting Rolex levels of dust hygiene).
Reactions: hpavictor
QUAD II mono amp/control unit/tuner (old model-1960)
Hi everyone,
I have an old-model (1960?) Quad II mono-amp with control unit and MW/SW/LW tuner, which was working fine about 20 years ago, including the green cat´s eye tuning monitor. It went into "safe" storage for a number of years, next to the garage, but a rainstorm 2 years ago caused a leak in the roof, with water dripping heavily onto the set. I only discovered that long after it had dried out.
When I tried it out recently, all the valve filaments did light up very nicely, but the set didn´t work. The volume control crackles loudly and amp output is very noisy, even with all possible filters set. Each time, the set only works for a short while until it stops. The tuner only receives one AM station (v. faintly) and the green cat´s eye won´t work either.
Then I tried it out only the amp and the control unit, connecting the earphone plug of an old cassette player to one of the AUX inputs, but output is noisy with very faint signal.
Opening the three modules to look inside, I didn´t really see anything I could understand - I don´t really know what to look for, although I do have all the documentation, manuals and electronics schematics.
I wonder if it will be possible to try and save this set, or if it will be worth the trouble, and would appreciate any possible comments to this respect.
I´ve seen some threads here related to Quad II repair, but I can´t tell if the repair-work done there would apply to my case.
At the moment, I´m trying to get a video and a photo out of my mobile phone to attach to this message as illustration for the previous paragraph.
Cheers for now, and thanks in advance!
Aleatorylamp
Making a Variac more optimal
G'day Guys,
I managed to find a 2KW single phase variac for 100 kiwibucks a wee while back.
https://www.aliexpress.com/item/100...OCdnqQdW&utparam-url=scene:search|query_from:
One of these but without the fuse holder which is problem #1
Problem #2 is the analog meter is pretty poopy. At 230Vac output according to my DMM the analog meter reads 220Vac.
Problem #3 is the connections. Having to wire things in ever time will be a pain in the buttocks.
So my evil plan is to graft a large plastic jiffy box on the front so that I can mount the extra bits to make it more usefull:
Here's the block diagram.
So far I have tested the variac to make sure it works as intended: check.
I checked the accuracy on the built in analog meter as per above. 10Vac out at 230Vac
I also checked the function of the digital meter: much better. 2Vac out at 230Vac
Next up is to start cutting into the jiffy box to mount the goodies.
After that I will need to figure out how to mount the jiffy box to the front of the Variac chassis. Probably rivet nuts.
Reactions: Mainframe
  • Locked
For Sale PCM63P-K chips + DAC board + IV board
**Sales is now withdrawn.
I would use the chips.**
A good buddy of mine here has decided not to proceed with his PCM63P-K project, hence selling the following package:
1. A pair of brand new unused PCM63P-K chips
2. Miro PCM63 board ( no parts installed, as pictured )
Information can be found here : PCM63 board
3. Pedja Rogic OPA861 I/V stage. Board with all parts soldered on but have not been tested yet. You will need to power it up, test, debug (if required)
Information available here : https://www.audialonline.com/blog/opa861-zero-feedback-output-stage-of-aya-ii/
All these for US$195 or preferably Singdollars 252, shipped.
Paypal FF only please.
For Sale 12x TPA3116/8 PBTL bare pcb + IC soldered from Dug's GB
Hello, I have 12x PBTL amplifier boards for sale with TPA3116/8 IC soldered and tested. These are from Dug's GB a while ago. I will include 2x 10uH inductors with each PCB (Sumida CDEP147NP-100MC-125).
The boards are packed already 4 pcs. each, so I would like to keep them that way and would sell 4 boards (incl. 8 inductors) for 45 EUROs plus shipping from Germany.
These have been out of another never finished project.
Please let me know if you have any questions.
Best regards,
Klaus
JFET-only Circlotrons without negative feedback
There is a desire to make a powerful amplifier exclusively on JFET.
Without negative feedback.
Tested circuit at low power is already available.
There is now a powerful MOSFET output scheme.
The next step - a powerful circuit Si-C JFET.
Related topic:
JFET-only Headphone Amp "Circlotron КП903B".
Vintage Receiver score - Sony STR-6036A
Woot, I just scored an old receiver! It's a Sony STR-6036A. Not for the main system, but the vintage look is kinda cool for somewhere else in the house. My wife spotted it on FB buy-nothing group locally, what an enabler!
Here are some pics, attached.
I'm in the process of doing simple external cleanup. I'm going to have to fix the broken slats on the vent on top. I bought some oak 1/4 in. by 1 to cut down to the right size, and tried to choose a stain that looked like the right color. Info I could find online called the finish 'light walnut' but Home Depot only had much darker walnut. I hope I can match the finish, but fear I won't be able to.
Knobs and switches are all dirty. I saw some guy spraying Deoxit in them on youtube and figure I'll do the same. But I do have this question: one source said don't use anything that leaves a residue to clean the tuning capacitor (use what, then?), another guy said use Deoxit, just spray it out with compressed air afterword. What does the vintage restoration brain trust say? I have Deoxit and an air compressor, that part's NP.
Otherwise, it seems to work. I played a bit of FM through it, but haven't done more than that, I'll have to finish going through it. This is ~ 1972 vintage, so part of me says all the electrolytics should be replaced. Another part of me says that if it ain't busted, don't risk making it busted. I'm mostly here for the speakers, I know a bit about the electronics but I'm probably not going too deep into the guts here.
Chime in if you have experience with one of these units, or know what I should be doing with mine!
Fourier Transform Speaker
I don't know if this guy's speaker will ever be marketable but he's got a playing prototype, and I've not seen anything like it before.
If I'm understanding the concept correctly; a typical digital audio setup recreates a music signal as a mixture of pure sine waves that mix and interact via the Fourier transform principle, and the mixing occurs within a digital processor, upstream of the power amp(s) and speakers.
In contrast; in this guy's setup the mixing of the component sine waves occurs at the speaker itself. That is; driving each speaker are twenty separate signal processors feeding pure component sine waves into twenty amp channels-- discretely driving twenty drivers in each speaker. As such, the Fourier transform occurs at the speaker itself, as the separate driver outputs blend together in front of the speaker.
That's a lot of digital processors and amp channels so even if this guy succeeds in taming all the gremlins, it's a complicated and expensive setup.
Enjoy!
Thermal measurements for Modushop Galaxy 1GX388 2U chassis
I am planning to use a Modushop Galaxy 1GX388 2U 330 mm by 280 mm by 80 mm chassis for a pair of Zenductor 2 amplifiers. To find out whether the 10 mm thick corrugated sidewall profiles are sufficient as heatsinks for 15 W to 25 W dissipated power per side, I did thermal measurements with a DC power supply, a 100 W 8 Ohm power resistor, and a thermal camera built into my cell phone.
The answer is that the chassis should work as is, i.e. without replacing the side walls with real heatsinks.
I attached the power resistor with a pair of spare M3 screws and nuts (supplied with the chassis) to the center region of the flat middle section of the 2-channel side of the Galaxy sidewall profile, and ran tests at about 18 W and 39 W, both with the wall free standing and as part of the assembled chassis (with the rear panel partially slid in, to leave an opening for the resistor power cables, and the remaining opening mostly blocked against air movement).
Temperatures stabilized after 20-30 minutes, and were lower than expected. From the measured temperature rises, and correcting for the heat loss directly from the resistor body to ambient, I compute a thermal resistance of about 1.4 K/W or °C/W.
Graph of four measurements (two power levels, freestanding and chassis-integrated heatsink):
Ambient temperature (the zero level of the graph above) was about 22°C. Interestingly, the equilibrium temperatures for the heatsink (corrugated 10 mm sidewall) were lower in the chassis than free standing. The increase in effective convection surface, from bolting on the other four panels of the chassis) must outweigh the shielding effect of the case.
Between the second and third measurement series, I installed (slid, with the screws and nuts already in place) the sidewall into the chassis.
Also interesting (to me) is that radiation losses are not negligible. A sidewall (448 cm^2, counting both surfaces, but not the corrugations) at 40°C radiates about 5 W more power into a 22°C room than it absorbs. I chose NOT to correct for radiation, since the effect will be of similar magnitude in the real application of the chassis.
As mentioned, I did correct for the direct convective losses from the power resistor, by measuring the resistor equilibrium temperature of 120 °C (!) at 9.68 W, with convection shielded from the resistor mounting surface (sitting on an insulating surface), giving a thermal resistance of 10.2 K/W.
The thermal resistance from the resistor case to the heatsink computed as about 0.5 K/W, which should be similar to achievable case-to-heatsink resistances for transistors. No thermal compound was used.
Example of a thermal image (equilibrium image for 18 W power, resistor mounted to side wall inside the chassis):
The resistor mounting position 'shines through' to the outside surface; I used the maximum, center temperature as heatsink temperature for my calculations. This choice should give correct results for the estimated case temperature of the device to be cooled. The average heatsink (side wall) temperature will be lower than computed from the effective thermal resistance of 1.4 K/W.
Resistor mounting position:
Reactions: Dave Zan
Hello DIY Audio
I've been messing with audio and electronics since I was a teen. Made more than my share of smoke. But some successes too. I have most of my luck with turntables and tape decks. But I did once get a Dynaco ST120 working on my own. Took two tries, though. I learned to ask why that transistor failed before just replacing it. I am digging out some of my old audio gear and checking it out. I figured having this forum as a resource would be helpful. I've visited occasionally over the past couple of years and I find the content very interesting. Even when it goes over my head.
Chassis Discussion
This thread is for discussions about any of the chassis. For more information on this product, please see the product page below.
Threads on diyAudio or elsewhere on the internet that show off what can be done with these chassis or give creative ideas:
Low Rp tube for line stage - ideas?
What would be a good sounding low Rp triode for a line stage? Requirements - Rp under 2K and low gain, like under mu=10.
Possibilities include:
7233 - 230 ohms
A2293 - 380 ohms
6S19 - 420 ohms
12B4 - 1K
6CK4 - 1.2K
6AH4 - 1.8K
6BX7 - 1.3K (double triode)
4P1L - 1.5K (in triode) DHT (needs 25mA or more)
71A - 1.7K DHT (getting rarer and more expensive)
There are also all the 6AS7/6080 type tubes and bigger DHTs like 2a3/6B4G/6C4C but that would be overkill.
Hello diyAudio members from an audio enthusiast in Ohio, USA
Hello,
I am a collector of audio equipment from the 70s through 90's, with an emphasis on the 80s. I've been actively collecting for about 5 yrs, gathering all the bits and pieces I wasn't allowed to touch or couldn't afford when I was younger. I have a particular interest in the odd and rare.
This forum has been a goto for me. Thanks for all the help. Hopefully, I'll be able to contribute in the future.
MnM
NAD C390DD (C 390DD) does not power on failure with fix
I was repairing a NAD C390DD for my friend and tough I'll post the solution here too as this type of problem is likely to happen on other units and I did not find it documented in web prior to this.
Symptoms before fix
A) When powering on from back panel power button the orange 'sleep LED' comes on
B) After push of the on/standby button on front panel 1 click of a relay can be heard and the orange led turns blue ... display will so no sign of life. Not other relay clicks follow. The unit does not switch on.
Problem appeared to be in secondary PSU which supplies the +5V and after switch on the +12.5V.
The +12.5V power line showed only +4.5V after the step B. So clearly something wrong. Anyhow, longish troubleshooting later it turned out to be a fault in following capacitors.
Hope this helps someone in future.
For Sale Antek transformers
I have used Antek transformers for sale. Revised price and shipping cost
AS-4220 opens box but never wired up. Asking $40.00 plus actual shipping cost to lower 48 states. SOLD
AS-4432 limited use once then removed. Asking $40.00 plus actual shipping cost to lower 48 states.
AN-5220 used, asking $45.00 plus plus actual shipping cost to 48 lower states
AS-3218 used pull from dual mono amp. Asking $30 each plus actual shipping cost to lower 48 states. Sold
Reactions: birdbox
Need help understanding bode plot phase shift
Hey guys! I have been trying to design my own simple small signal circuits for using in my condenser microphone. I am pretty new to this, but I was able to get some designs that perform well in regards to THD and Bandwidth. However, when I perform an AC analysis, the bode plot that is displayed also shows the phase relationship within a range of frequencies. When I do a search to understand how much phase shift (or what kind of phase shift) I should see, I can't find an answer. There are tons of videos and blogs that show how to measure the phase shift, but none really saying "how much" I should allow in my design. I saw one guy on reddit saying he allows no more than 10 degree shift from zero. So how much phase shift should be allowed in a well designed circuit? Also, will I be able to hear this as long as the shift is distributed evenly throughout the whole "audible" frequency range? I will post some pics of my bode plot from qspice, and maybe somebody can give some feedback on it.
Here is one where the shift seems to be even up to around 25Khz
Question 1 - is this amount of phase shift considered acceptable in (hifi standards)? Or at least professional standards?
Question 2 - is this going to be audible?
Here is another plot with a more complicated situation going on (180 degrees)
This one has some corner frequencies from some inconvienient bypass caps I had to use.
Question - this shift in the low frequencies, is it normal? Will this cause the low end to be cancelled out or distorted?
Thats it, thanks for reading, any feedback would be really helpful.
Hello, from Athabasca, Canada
I'm currently getting into voiceover recordings for Librivox, and looking forward to polishing down down some over-produced demos (davenoel.bandcamp.com). I'm currently building a collection of cheap mic bodies and ordering new capsules and preamp boards to swap in. I wish the BM800s out of china weren't so varied in builds, at least they use the same case for easy pcb replacement.
Spending time obsessing over schematics is a great way to avoid actual work!
I'm also building a mastering quick speaker preview array with mono sum and difference switches and various car and home speaker sets built into a large speaker array. The idea is if it can sound not as bad as anything else on various shitty 6x9's and 2" computer speakers, hopefully it will sound good elsewhere.
How to build a S/PDIF coax input selector
Hey everyone
I've got a few digital sources hooked up to my system and I'm frequently comparing DACs. I'm looking for a better way to switch between them. Right now, I'm using a cheap external switch box, but it's not ideal and adds another cable going to the DAC.
What I'd really like is a professionally made switch built right into my DAC's case, so I don't need any extra cables. What's the best approach for switching coaxial and S/PDIF inputs?
I'm thinking a basic rotary switch probably isn't the right way to go, am I right?
YH11068A 10-32V to 45-390V dc/dc - guess the control ICs
You may have seen this neat dc/dc available recently, especially given the wide variable B+ setting capability, and quite high power rating, and ability to run off 12VDC.
For low power valve amps (eg. up to 6V6 push-pull) they should make it very convenient to power just from a 12VDC 4-5A plug-pack.
The initial intrigue is what control IC's are used, as the 8-pin packages are defaced.
To help the guessing game, the attached doc has my first pass at a schematic drawing. No doubt I've misinterpreted a few parts, and the IC pin numbers are based on what I think are the pin 1 dimples that haven't been defaced completely.
Some strong power saving pulse skipping is going on, which appears as low frequency ripple at times, and at other times it is just pulse skipping at 70kHz ripple. The FET drain waveform is pretty clean and fast, given the simple pcb and parts. The current sense filter cap ground and IC ground seem a compromise of layout. The turn-on appears to be trying to occur close to a zero-voltage dip. No load loss is pretty good.
http://dalmura.com.au/projects/YH11068A.pdf
Ciao, Tim
Warp-1 Amp
The LSA Warp-1 amp based on my TPA3255 reference design amp has been getting some good reviews. I think it is time for it to have a dedicated thread.
The reviews so far include:
ttp://v2.stereotimes.com/post/lsa-warp-1-power-stereo-amplifier-by-greg-voth/
https://www.tonepublications.com/review/review-the-lsa-warp-1-power-amplifier/
https://www.superbestaudiofriends.o...warp-one-class-d-power-amp-impressions.11451/
We also have reviews from SBAF loaner tour here:
A new review on YouTube by Thomas and Stereo just came out:
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,471
Members
7,921,101
Messages
Filter
Forum Statistics
Threads
407,839
Messages
7,921,101
Members
508,471
Latest member
Delrtm
