Older kicker kx1200.1 Powers on but doesn't get loud with pictures
Like I said I have a kicker KX 1200.1 I just purchased to strap to my other kicker 1200.1. I tried bench testing it before installing it in the car and it does power up with no protection light coming on but it has very low output. On taking the heat sink top cover off the amplifier I found this. Would this cause that problem?
LRDDMC Loudspeaker Resistor Drive Distortion Measurement Challenge
Nobody wants to know if you hear distortion.
But
Do you measure distortion?
I thought about what a measurement experiment could look like so that the person measuring can directly experience what they are currently doing and achieving.
Do you have a speaker? Good!
Have you ever measured the frequency response of your speaker? Good!
Can you connect a line directly to a transducer in it (leave out the crossover)? Good!
Find a resistor with 20R! Don't worry about the power performance of this resistor! Just keep explosives, your beautiful toddler, your cat... away! 10 Watts is what i use. That's plenty and certainly a lot more than my speaker can handle.
Complete your usual measurement setup.
Carry out a measurement at a very moderate volume. Only the transducer in the box, directly connected to the amplifier. [1]
Save this measurement to overlay. [1]
Then insert the 20R resistor. In series to the transducer. Carry out a second measurement. Increase the volume to approximately the same sound pressure level. [3]
This is all about distortion. So RTFM until you have two distortion charts.
[4] One connected directly and one with the 20R in series.
If you do not see a difference in D3 ask here for help.
This was done at 0,5 Volts at the transducer:
No need to blast your speaker!
[1] yellow is the fundamental directly connected (0R)
[2] Same setup, just disconnected speaker. Noise...
[3]
green is with 20R in series.
yellow is directly connected (from [1])
[4]
D3o (white) is directly connected (0R)
D3 (red) is with 20R in series
20240108 Edit 1:
I am extremely disappointed by the fact that no one is taking measurements here on diyAudio. There are only theoretical heroes here who type more or less gross nonsense with their keyboard.
20240108 Edit 2:
User >OllBoll< on diyAudio was the first measuring "it".
https://www.diyaudio.com/community/threads/hypex-ncore.190434/page-384#post-4095122
He was cited on a German forum on
12.09.2023, 16:47
9 years (nine years !) later, because there was nobody on the whole internet measuring "it". Now that
Tenson< joined,
https://www.diyaudio.com/community/...ortion-measurement.402566/page-9#post-7558653
we are 3. Please be the 4th ;-)
20240110 Edit 3:
tmuikku< joined (#40), we are 4. please be the 5th ;-)
  • Thank You
Reactions: tktran303 and jayme
Stepping down speaker level to line level with audio transformer to feed into power amplifier - does it cause too low impedance issue?
Many Denon AVRs have speaker level outputs for passive speaker connections (mostly around 90W for Dolby Atmos surround systems) and I think I can step down the speaker level to line level to run RCA/XLR cables to speakers with each having their monoblock amplifiers. But the problem is, these Denon AVRs have 4/8ohm output impedances from their speaker outputs and if I use an audio transformer to step down with 1:10 ratio, speaker level impedance being already being either 4/8 ohm, impedance gets even lower to 1/100 ratio of 0.08/0.04ohm. ChatGPT suggests that feeding too low impedance line level signal to power amplifiers can damage the amplifiers. Is that correct?
As far as I understand if I step down speaker level signal voltage with a 1/10 audio transformer, input being 8ohm, I get 0.08ohm (1/100 ratio) impedance. Would this harm a mono power amplifier if I feed this line level 0.8 ohm signal to it?
Not: My aim was to have more gain than Denon provides with separate amps and since power amps I see on internet have line level inputs, I thought of stepping down the speaker level to line level as a solution but not sure if this is a good idea.
Ah revisit of my curved planar magnetic tweeter ! BINAURAL RECORDING, use headphones
Ah revisit of my curved planar magnetic tweeter (bit to much curve though)
Well i replaced the foil since i dont like Kapton, and i forgot i used Kapton.. see if i can raise the top end a little since thats in this case because of the curve the first to go 🙂 and give it another try. Please keep in mind this is recorded with in ear mics so use a headphones for correct spatial sounds etc.
At least this project is not dead.
I play one tune Anette Askvik - Liberty go here if you want to skip the rambling 🙂 TUNE
Login to view embedded media
ELEKIT TU-8800 SET AMP
Available Now....
TU-8800 $1185 (stock version)
TU-8800 $1,785 (Lundahl Version)
Takman REX50G 2% Carbon Resistor (85 PCS) $65.00
Mundorf Supreme Silver Gold 0.01 X 2 + 0.1 X 2 $150
Gold Lion - Matched Pair KT88 X 2 + 12AT7/B739 X 2 $185
TKD 2CP601S $65
The Lundhal + PCB + HV + Hardware is $645
https://www.diyaudio.com/forums/elekit/353407-inexpensive-tube-set-tu-8800-a.html#post6177418
● Rated output: 12.5W + 12.5W (KT88-HIGH mode / UL connection THD 10%)
● Rated input: 360mV
● Residual noise: 90μV (IHF-A)
● Frequency characteristics: 12Hz to 55kHz (-3dB)
● Input impedance: 50kΩ
● Output impedance: 4 to 6.3Ω, 8 to 16Ω (switched by the switch on the back)
● Input terminal: LINE x 2 (LINE1, LINE2): RCA jack 3.5mm stereo mini jack (uses both LINE2 and cuts LINE2 when plugged in)
● Output terminal: Speaker output terminal: Gold-plated screw terminal (banana plug can be used) Headphone terminal: 6.3mm headphone jack
● Power supply voltage: AC120 / 200V 50 / 60Hz (3P inlet)
● Power consumption: 95W
● Body dimensions: W350 x H204 x D324mm (including protrusions)
● Body weight: approx. 12kg (without power cord)
IT SHOULD BE 7581 (NOT 7591)
OPTION: Lundahl OPT
Adcom 5400, Chinese 1998 manufactured, question on the power supply caps
Just got an Adcom 5400, Chinese manufactured 1998, and I opened it up to make sure none of the fuses was blown, and looked at the power supply caps. I see some dark brown at the edges of the caps and it's been noted in other posts that that was a mastic to hold the caps to the board but all of them are loose to light pressure. Should I assume it's the mastic? The tops of the caps are slightly convex. Should I therefore assume they're bad and leaking? No caps I've seen with suspected leakage ever turned out to be bad when I removed them. If it works ok without hum, should I assume it's just mastic goo?
Online Calculator or Freeware Program for Power Supply Design?
Referencing the attachment, it is a power supply I hijacked off the internet and plugged in my own parts values, using plain guesswork. I have no training in this and don't want to keep spending money buying parts and wasting time on my own hairbrain plans. What I want is about 230-235 volts of clean DC with 100 milliamps of B+ available. Note also that there is an "unknown resistor" I put in. There's got to be a better way than this trial and error tinkering. Certainly there must be an online calculator or freeware program where I can just enter parts values and get a reasonably usable expectation. Thank you.
Amplifier for piezoelectric sensors
This is an amplifier especially designed for piezoelectric sensors.
It is a differential charge amplifier but a two pin piezoelectric sensor can be connected to the (+) and (-) input.
The amplifier includes three gain setting (0 - 10 - 20 dBs) and high pass filters (3 Hz- 16Hz - 160Hz).
I have some PCBs available (without any components), if someone is interested to build one.
The dimensions of the PCB are 84mm × 101mm.
The price is 28 Euros (shipping is included).
in my situation which FR could you be married?
Hello All
I have made a first project with the mark Audio CHR70.3, it sound good, i like them really. I have listen the Pluvia 7.2HD it’s better for not so much. (i have little regret, i have listen them after) For my deskroom wich is small really near it’s enough.
Now for my new project i want to make a 55 sqm listening room…. 2 CHR70.3/ 7,2HD it’s not enough. I will be between 2,50 to 4 m at the listening point, the room is 5,5 m large. I want a depth in the sound image. the more realistic as possible, not boring really dynamic, nearest the of top of the line.
I listen mainly alternative rock,pop, piano, guitar classic and electric, vocal
I have not the possiblity to listen other Mark Audio driver, near me no one have them, in fact really few people use full range/coaxial as main listening system.
There is specialized shop but they want sell finished system… not drivers…
i know the driver don’t make all…it depend of what there is before,for the momment i have :
2 diy 12 inch sub wich can help theses future beauties
i have amp NAD 356BEE (it could be changed, a lamp or preamp can be studyed)
a DCX 2496 for filtration/correction
a DAC
i have read on this forum that there very few very good FR and that the price is not the best indicator, good news i have not the budget for the cube audio unfortunatly, even a lowther.
For this project I see bigger, stronger, better…and go to best as possible,due to budget i will be maried with it for minimum 10 years. And you with wich drivers could you get married the rest of your life in theses conditions?
Martin Logan Ethos 2024 Active (DIY)
Just finished a small project adding a Hypex NC500MP under each speaker to make them active. Also had the cabinets spray painted in satin gray polyurethane furniture paint. I think it looks more up to date 2024-ish. By the way, the hypex does quite good driving the ESL load. I had a dialogue wiht Hypex (nice people!), and they confirmed that it would not be a problem with the ESL load. This is a point where Hypex differs from Icepower. Icepower would probably have a challenge with the capacitive load. Anyway, now my Ethos are fully active with hypex driving the esl's and icepower for the subs. Works nice 😉
What do you think?
Manual Request
Hi everyone,
I'm a tape deck lover from Hongkong, I recently bought a AIWA XK009. I want to know everything about it, but I couldn't find user manual anywhere but hifiengine. Sevice manual is everywhere but not user manual. And hifiengine do not accept any new members. I am in a dead end.
So someone kindly enough plz help me download the user manual from hifiengine and send it to me? I would be most grateful.
https://www.hifiengine.com/manual_library/aiwa/excelia-xk-009.shtml
My e-mail: xyhtony@hotmail.com
Shawn
Discussion: The relationship between the Fosgate PR-250 and the Pioneer AD-360
I recently acquired a Pioneer AD-360 from the late Jim Fosgates estate. At first, I was hopeful that he threw some secret sauce in this one and i'd get to be the only one to enjoy that. Turns out he didn't. In fact, it didn't even work. So my next guess was a friend left it with him for repair because 'My buddy Jim knows amps' is probably how the rationale went.
So I went looking for a schematic. But I was too cheap to buy the service manual. Then I started looking up part numbers. The part numbers led to a thread here
The drawing note on the PR-250 schematic led me down a rabbit hole as not only was I able to use the PR-250 schematic to service my amp, it bears the 'GM160' stamp!
The drawing note:
The board stamp on my AD-360:
At this point i'm just MADE of questions. Both of these amplifiers were released around the same time. It's sitting in Jim's house. One board is referenced in another's drawing. They're both 'Made in the USA' which is not common for Pioneer electronics of the era.
What was the relationship between Jim Fosgate and this product?
Did Jim OEM the AD-360 for Pioneer?
Did Pioneer License the design from Fosgate?
Did Pioneer OEM the PR-250 for Jim and Jim added the processing in house?
Was the 'GM160' a build house design both Pioneer and Fosgate custom tailored for their models?
Another interesting note: I have 2 of these amplifiers. Jim's model has no solder mask and the unit bears no serial number or warranty sticker but my other model does!
Reactions: BIGDOGBRODAVE
State of the Art for Tracker/Down Converter?
I have started to look at switch mode power supplies that track the audio, a la Bob Carver amps, and later Lab.Gruppen and others.
The use is a home theatre system with tri- and bi-amped speakers, so there's a dozen or so power supplies to build, hence a simple IC based solution is attractive.
What is the current state of the art in circuits, ICs and power semiconductors for this?
The trend in industrial SMPS seems to be towards Zero Volt Switched circuits.
My first impression is that it seems attractive for Audio too, but I see there are some tricks and traps with this technique.
Standard MOSFET or bipolar power semiconductors still look cost effective for < 600 V but perhaps there are new SiC or fancy semiconductors that I should consider.
Any comments appreciated, except that I should just use Class D amps - different discussion!
David
For Sale PCB mount Novar tube sockets
Contracted manufacturer to install 1.0mm pin sockets in Magnoval bases. Tested on 12GT5 Novar tubes.
Money back guarantee if not satisfied with fit. Background link below.
$2.50 each + ship to US, Canada.
Thanks,
Jim
https://www.diyaudio.com/community/threads/real-novar-sockets-inside.397358/#post-7304388
Proac 2.5 clone cabinet problem
Recently I both drivers (Scan Speak 18w8535-00 + 9500). First I make Troels Gravesen cabinet http://www.troelsgravesen.dk/download/2.5_Clone.pdf. I tried many types of crossovers but withouth result. Sound was muddy, undertone without expanse in middlem, bass was deep but without attack (energy). I think the cause of this was small volumen of the cabinet. After nearly a week of work I quit of this cabinet.
Next solution was Event http://www.audiocomponents.nl/speakers/scanspeak/classic/tekening/event_1.htm. Results was better then previous but sound was bad though. I have opossite sound from previous. Middle was wide but without warming and definition, bass was deep but without definision. I worked on dumping but without visible results. There is last solutin. Close cabinet. I searched internet but without results. I wish to build BR or TL but I'm in the dead end. I have not equipment to mesure T/S parameters and work further.
I'm count on you people 😉
Any hint will be highly woth.
best regards
For Sale Wavecore SW259WA02 10" aluminium cone woofers (2x pairs)
Hi all,
I have for sale my final four of these excellent subwoofers. Superbly engineered and often overlooked drivers from Wavecore. The 4 ohm version was recently reviewed in Voice Coil magazine.
I have 4x available and would like to sell them in pairs please. £400 per pair inc. UK shipping.
Will ship worldwide at cost.
Specs can be found here: http://www.wavecor.com/html/sw259wa01_02.html
Thanks for looking!
Drivers FS
Brand
Model
Qty
Condition
Asking price (sold in pairs only)
ETON​
4-200/A8​
2​
New​
$80​
ETON​
5-200/A8​
2​
New​
$80​
Vifa​
P13WH-00-08​
2​
New​
$100​
Scan-Speak​
P13WH-00-08​
4​
New​
$100​
Scan-Speak​
21W8555-00​
2​
New​
$100​
Wavecor​
TW022WA09​
2​
New​
$60​
Wavecor​
TW030WA14​
2​
New​
$60​
Scan-Speak​
D3004/602200​
2​
New​
$100​
For Sale PCB LYNX Amplifier and LM4870
I have one stereo set of PCBs for the Jan Dupont Lynx amplifier. As a fringe I will throw in one pair of OPA627 (used, desoldered) with the PCBs.
OPs are tested before. Asking price is 10 Euros + postage.
For more info: https://www.diyaudio.com/community/threads/official-lynx-power-amp-builders-thread.118469/
I also have 4 pcs of LM4780. Asking price is 7 € a piece + postage.
Postage as you see fit is added. I accept Paypal and direct banktransfer.
I am EU based (Sweden) for info.
Edit:LM4780s sold.
DH-220C project - power up...smoke!
I've been working on rebuilding my Hafler DH-220 into the DH-220C input circuit - the Bob Cordell designed circuit that's sold by delta9electronics on eBay and I believe is a member here.
Anyway...on power-up, (the rail-to-rail voltage is about 120V or just under +/-60V) and it more or less immediately fried R53, the 22 ohm resistor at the positive rail, along with both R13 and R25 the 180 ohm resistor that power Q1 and Q2.
This was only one the right channel - the left channel seems to have survived.
Questions:
I haven't pulled the transistors, but is it safe to assume they're also toast, or is there a chance they're ok.
What would have caused R13 and R25 to burn.
I presume that R53 blew because of overcurrent at R13 and R25...
Where should I be looking for the root cause?
Bessel vs Critically Damped Enclosure
Does anyone have experience listening to the difference between critically damped (Qtc 0.5) and Bessel (Qtc 0.577) sealed enclosures?
The 'tightness' and 'speed' are noticeably better with lower Qtc enclosures, with systems over Qtc 1.0 not that uncommon, but sound like mud to me.
Will a Qtc 0.577 sound just as tight as Qtc 0.5? If Group Delay is the reason for the muddiness, 0.577 might even sound better.
With a high qts subwoofer, this makes a huge difference in enclosure size. e.g. with the Wavecor SW312WA03, speakerboxlite calculates 236 liters for Critically Damped and 85 liters for Bessel. This is using the 'unbroken in' manufacture numbers, I'd expect qts to drop, and even if VAS goes up, box size comes down. But this is just an example of how big a difference there can be between them for enclosure size.
Obviously extension is also an issue, but I don't want to go into that in this thread.
SET Friendly MTM, Seas ER18RNX and 27TDFC
I built this in 2007, with a lot of help here from Jay and Zaph particularly with the crossover. I thank these guys most sincerely!
Design was constrained by WAF to about 8.5 inches wide, about 12 inches deep and 1 metre high, also by the amp, my 45 parallel SET giving 3.5 watts (note the decimal point). Don't query the amp unless you've heard a 45 SET, if you have you will understand. Room is 18ft x 14ft.
The speaker is about 42 litres, bass reflex to give good sensitivity.
The Q of the bass driver was calculated allowing for amp Zout, giving Qts 0.51 quite high. This made bass alignment a bit of a problem; the ideal volume for a standard alignment became massive. But it was overcome with use of WINisd. With my volume it was not possible to avoid a hump in the bass, but tuning the port to 30Hz got the hump to below 1dB. Group delay was under 10mS at 40Hz (Zaph's criterion), and if I remember, the peak in group delay was moved to quite a low frequency and was not too massive. In fact this is very much Zaph's 'lean and low' tuning; low is obvious, and lean I take to mean removing or minimising the hump at roughly 80 to 100Hz.
Crossover was very similar to Zaph's one for his MTM with Vifa woofers and 27TDFC, virtually as Jay's suggestion; very simple:
Woofers 1.35mH, 40uF
Tweeter 1.9 ohm series R, 12uF, 0.39mH
The L on the woofers adjusted by ear for BSC, starting value 1.4mH was very good.
Tweeter C was adjusted after SPL measurement to reduce a slight dip in the upper crossover region.
The result?
Superb.
Bass is very good, adequate quantity, reasonable depth, very good quality; nothing boomy; tight, tuneful, fast. I had expected to want to try different port lengths, or straws or damping, but once I heard it I told myself, do not mess with anything! (I've messed electronics up in the past and never got back to the best).
Overall, sound is tuneful, fine tonality, good rhythms, excellent leading edges (says a critical friend who loves leading edges and dynamics); superb vocals. Highly musical. Just seems to do lots of things right in a way that you don't notice them, they disappear.
I like the combination of amp and speakers a whole lot, and I'd put it this way.
In hifi, you might have decent hifi sound.
Go a level higher, and it sounds like better hifi, you notice the hifi things more.
But at a higher level still, I find it sounds less like hifi; I don't notice the hifi things, they go away, leaving a very natural presentation.
These speakers are getting close to doing that.
Liked a lot by hifi addict friends; a Naim addict dynamics freak says they have some dynamics and rhythms (and he's critical, blunt with it, like Craig Revel Horwood, for my own good, and he knows his stuff).
The system does not sound underpowered in any way; for one thing the amp sounds more powerful than my 300B SETs of twice the power. Definitely all the volume I want, without stress.
Anyway, I can recommend this design to anyone who wants to build speakers for a SET amp and is constrained by WAF.
You will soon understand why I'm posting about these speakers many years after the event.
The system is pretty good.
Sources:
Teres turntable (acrylic/lead platter), Moerch DP8 arm, Zyx 4D, far better than previous LP12; good valve phono stage.
Marantz CD65 II (TDA1541A dac chip), lots of caps upgrades, NOS converted, lampizated; superb tonality, great sound.
Valve preamp with 27 triode
45 parallel single ended amp, separate PSUs for the two stages, massive PSUs, both 2 pi with chokes, film caps, tuned for fast clean transient response.
Which Markaudio drivers for integrated home streamer?
Hi, first time poster so thanks for all the useful info and expert advice on the forum. I'm building a small cabinet for a stand-alone, wifi/bluetooth home streaming music centre. Movable to any room in the house, compact, easy to use with good quality sound. The cabinet will be approx 600mm W x 200mm H x 300mm D (but can be varied to a limited extent) to house a Fosi MC 101 Class D amp, Wiim Mini streamer (aux out to aux in on the amp) and two small full-range drivers. Each driver will be in enclosed boxes at either end with the amp mounted through the baffle in the middle with Wiim behind, both in a separate central (vented) box. The cabinet ends will be kerfed to create a soft, rounded look which may have some acoustic benefits? Front baffle will be an Australian hardwood called Tasmanian blackwood (19mm) with the case in 15mm veneered ply. Rear ports. A mockup image is below.
I'd like to use Mark Audio drivers for this project and would like to ask which ones you would recommend? The driver units can be 5-7cm and ideally would be gold to match the amp and timber. Volume of each speaker cabinet can be 4-6 litres but I could stretch to 9 litres each by extending height and depth if justified in terms of improvement in sound.
In a prototype I used Dayton Audio PS95-8s in 3.7 litre boxes with a DA KAB amp which sounded good but lacked some bass. I understand bass will be limited in such a small system but am hoping MA drivers would offer some improvement at the low end. This is not a boom box, so it's not just about the bass, I would like to have good mid and upper range too. Most important is to get good, clear sound stage from two drivers close together in near field/small room listening setups for all types of music. Also where on the front baffle would you place the drivers - at the far ends next to the curve or further in towards the middle? Do you see any issues in matching MA drivers with the Fosi (one review on the MA site suggests MA drivers and Class D amps are not a good match)? Any issues achieving the required box volume by departing from the online MA speaker plans by increasing depth and decreasing the other dimensions?
Experiences with Infinity products
I'm just curious if others have had the same sad experience, or if the unit I received was in the wrong hands before it ended up with me.
I got an Infinity Modulus subwoofer into the workshop and now I've been working on it for 4-5 weeks on/off. The fuses were blown, the output transistors were shorted (TIP35C/TIP36C), and some of the soldering around the PCB looks like something done in the dark by someone who is only used to industrial welding. My previous experiences with Infinity products are already not good, but can this really be the standard for Infinity products? Just the fact that the unit from factory use TIP35C/TIP36C output transistors (original according to the diagram/parts list) with 100 Volt Vceo for an output amplifier with a supply voltage of +/- 47-48 (= 96 Volts P-P)......??
Am I just unlucky or has anyone else had the same overall bad experience with Infinity?
Using a large, distant TV as a PC monitor?
I spend a lot of time using a 27" monitor - for forums such as this, surfing the internet and streaming music and youtube. I like it much better than using a laptop sized screen, but I'm starting to get tired of sitting at a desk all the time. So I'm thinking of getting a big TV (say 65" or so) to use as a monitor, and mounting it across the room from my armchair, which would be about ten feet or 3m viewing distance.
My keyboard and mouse are already wireless, so it would be simple enough to do. However I'm concerned about the legibility of text and that kind of thing, with it being a TV rather than monitor (and probably not an expensive one, either). Has anyone got or used a setup like this, and if so how did you get along with it?
Thanks,
Kev
EAR834p clone with hum. Would appreciate some help
Hi everyone!
I have built an EAR 834p clone but have a hum problem. I have followed the grounding scheme (see picture) from the Lenco Heaven forum (and also implemented the mods) but is seems like the amp is picking up noise from the inputs. I am a novice and I am starting to feel that I perhaps took on a project to complicated for me. It is a good sounding phono stage and also some money invested so I would be thankful if someone more knowledgeable would like to help me sort this out so that I can keep this.
I have a Rega P6 turntable with a MC cartridge. I bought it second hand but from a reputable HIFI dealer that had checked it. I have not tested it with anything else than my DIY 834p build. I have not owned a TT since the eighties so I know very little about TT grounding.
After a lot of testing I have been able to pin down a few things regarding the hum. I have built an input switch for MM and MC so that I can easily switch to MM in the future if I like. I have hum even if nothing in connected to either input so I know the hum is from the 834p.
If I switch to MM input, and then ground the switch with a wire, hum is pretty much gone. It disappears completely if I put my hand over the MM inputs (from the back of the amp), I do not even need to touch them, just cover them. Same thing if I hold a piece of metal in front of them. So it seem like the inputs and the switch act like an antenna picking up hum from somewhere. I used an app on my phone and measured the hum. I have a loud 50hz peak, and also a 100hz peak thas is not as loud.
When I plug in my TT to the MM input, there is a faint hum, and it no longer makes any difference if I ground the switch with a wire or not. It's a Rega P6 so it has no separate ground cable. Ground in Rega TTs is in the left channel cable. Don't know if that has anything to do with it.
If I switch to MC, with nothing connected to the input, which goes from inputs trough a pair of Lundahl LL1931 SUTs and the to the switch, I still have hum even with the switch grounded. A tiny bit little less when grounded, but not much. I have tried different grounding schemes for the Lundahls and this is the most quiet one, but still way too loud. I only have a MC cartridge, so if I want to listen to vinyl, hum will be present if I do not solve this.
In my build I have made it so that the switch switches both + and -. Is that a bad idea?
I have changed all the unshielded input wires on the picture to shielded, no difference.
Also there is a problem with hum with the Rega P6. I get a really loud hum when I touch the tonearm and sometimes it stays after I let go of it, sometimes not. If I move around the input cables from the Rega this loud hum can also start. When I get this hum, I can cancel it by putting a wire from Right input - (shield) to amp chassis (not the Left channel that supposedly has the TT ground), but if I leave this wire permanently in place I still get hum if I touch the tonearm and to cancel the hum I now need to remove the wire.
All of this is so weird to me.
So, what can I do now as the next step? Do I need to ground my inputs in another manner perhaps? I have seen that some people connect all input - to each other and some don't. I am at loss at this point.
Reactions: Mildslight
Help for Micro CaP
Hello,
this post can be closed. I did mistakes in shorting some wires in components, error found 🙂
Hello,
is there someone working with Micro Cap? I am beginner with spice and i want to simulate a schematic that is from a book and it works in real very nice.
It is a booster from 12 to 200V with 555 and FET. In Simulation i only get 23V on the output, but it should be over 180V.
Maybe i have an error in there, but i cant find. It would be nice if someone is using Micro Cab and would load the circuit to check.
Thanks,
Andreas
First project
Hello 👋 beautiful people.i am 15years and a ugandan. I've been saving for this boom box project and now I have the money. Can some one help me in the plan . I am going to use a hifi stereo amp with 100w per channel to power drivers of 2*65w 4.5inch 4ohm that's sub , 2* 25w 2.5inch 4ohm midrange and 2* 20w 1.5inch 4ohm. And please does the pre amp increase sound clarity because I want a quality sound build . Am using wood as the enclosure and 2 passive jbl 3rd gen radiators thank you
Reactions: njswede
Speaker gasket sealing tape
Hello,
I can access places like Element14 (Newark USA, and known as Farnell in UK) or Digikey.
The tweeter as you can see has a fine tape - more to maybe hold the copper dome down. The woofer the foam has long gone, or never was used. The speakers are Celestion SL-6. I fixed the corrosion issue in another thread back in December, with Rust Oleumn 5in1 paint
https://au.element14.com/pro-power/hsht-roll-0-8x25mmx5m/tape-pe-foam-5m-x-25mm/dp/7224825
tweeter and maybe woofer
for the woofer maybe
https://au.element14.com/multicomp-pro/ppc116/sealing-tape-pvc-25m-x-6mm/dp/176068601
HV B+ linear shunt regulator ringing
Hello,
I am testing a design of mine for tube amp B+ supplies, both for input and output stages. Currently setup for the lower current input stage, running at the top of its adjustable range, 170V/75mA, with the shunt mosfet (IRF820) run in linear region (of course) dumping 40mA current. This is a stress test to check for thermal stability and worst-case scenario performance - the shunt will dump a bit less power in normal operation (25-30 mA at 150V). Looks that will make for a decent space heater if anything 😎
I am satisfied with line regulation (about 150mV pk-pk), but there is a great deal of ringing (see scope shots). First one is blurred but only there to show the main ripple voltage with the ringing around it as light green, next two pics are close-ups. Sorry with the bad shots, I have only an old scope and I'm not that good working with it. I have measured around 100mV pk-pk ringing at about 50 KHz. Is that to be expected? Note that these preliminary tests were done into a 5K dummy load, without "speed-up" capacitor C1 and output capacitor C3.
50mV/div, 0.50mS/div
20mV/div, 50uS/div
20mV/div, 20uS/div
A few more circuit details: The top device M1 is an IXYS IXCP10M45S current source; The shunt mosfet M3 has a 100 ohm stopper resistor soldered close to the gate (see board pic below). It is a dual mono board with all TO-220 devices on the same heatsink with ceramic insulating pads. In the actual builds the heatsinks will be mechanically connected to the grounded metallic chassis. This test setup doesn't use the heatsink that will be used in actual project but uses the actual adapter bracket (the aluminium flat bar the tabs screw into) and heatsinks are left floating. I will check with grounded heatsinks tomorrow.
I have measured a substantial capacitance of 50-100 nF between the TO-220 tabs (drains) and the heatsink - That can't be good, I fear HF coupling between devices and channels... I have tested only a channel at a time so far. I am not very experienced with parasitics management and would appreciate any advice on how to tame the ringing. I have often seen ferrite beads used in SPMS designs, presumably on the gate lead. Can it help here?
Thanks in advance.
- Joris
Leak Sandwich (original) rebuild and TH parameters
While I'm waiting for my MA drivers to arrive to put together with a KEF B139 I thought I'd get on with a refurbishment project.
I picked up a pair of Leak Sandwich 15 Ohm speakers recently and have finally resolved to rebuild them into larger cabinets - with a separate section for the mid/tweeter and importing a foreign tweeter. Barlow, who designed the drive units always wanted to add a tweeter considering that asking his smaller sandwich unit to handle 900-16,000 Hz was a tad of a tall order... and then the cabinet is too small for the 13" bass drivers.
I got around to figuring out on my learning curve how to measure the TS parameters using REW and a soundcard - as a precursor to a new sealed cabinet. I tested each driver 3 times and got pretty consistent results for each - but there are major differences between the drivers leading to huge differences in cabinet size.
I'm placing them below - partly because they may be helpful to someone else but also I'd be interested in why such large differences in VAS of 166 and 274 litres? I'll add the measurements of the mid-tweeter (if anyone is interested) in a separate post to save space.
(EDIT)
For comparison Leak tested the free-air resonance at 19Hz, in cabinet (I think at 58Hz) with a cabinet size of approx 65/70 litres.
Speaker A
TS Parameters file
Room EQ V5.30.5
Dated: 03-Feb-2024 12:20:35
From measurement L Feb 3
Zmin 11.76 ohm
fmin 153 Hz
f3 878 Hz
Le(f3) 1.513 mH
Motional impedance parameters
R0 25.23 ohm
CMES 423.4 uF
L0 49.122 mH
beta 0.3437
omega0 291.5
Blocked impedance parameters
RDC 10.60 ohm
dR 0.23 ohm
Re 10.83 ohm
Leb 216.7 uH
Le 3.845 mH
Rss 100000.0 ohm
Ke 0.1665 S-H
Thiele-Small parameters
fs 30.6 Hz
Qms 1.301
Qes 0.882
Qts 0.526
Fts 58.2
Mms 87.59 g
Cms 0.309 mm/N
Rms 12.942 kg/s
Vas 166.10 litres
Bl 14.383 Tm
Eta 0.55 %
Lp (1W/1m) 89.62 dB
Dd 28.00 cm
Sd 615.8 cm^2
Speaker B
TS Parameters file
Room EQ V5.30.5
Dated: 03-Feb-2024 14:08:12
Zmin 11.59 ohm
fmin 150 Hz
f3 861 Hz
Le(f3) 1.521 mH
R0 29.83 ohm
CMES 388.5 uF
L0 88.961 mH
beta 0.1273
omega0 248.0
RDC 10.70 ohm
dR 0.18 ohm
Re 10.88 ohm
Leb 194.6 uH
Le 3.377 mH
Rss 99372.6 ohm
Ke 0.1847 S-H
fs 25.9 Hz
Qms 1.546
Qes 0.688
Qts 0.476
Fts 54.4
Mms 73.85 g
Cms 0.511 mm/N
Rms 7.778 kg/s
Vas 274.67 litres
Bl 13.786 Tm
Eta 0.71 %
Lp (1W/1m) 90.72 dB
Dd 28.00 cm
Sd 615.8 cm^2
Reactions: indianajo
For Sale I have 10 brand-new LM3886-based composite amp boards for sale cheap
I just built 20 high quality composite chipamp (class AB) amplifier boards but only really need 10 and would like to sell the extras. These are my version 5 (sigh) but they're finally pretty good and what with high fixed-costs I decided to build more than I need.
Contents: completed and tested amplifier board(s)
Not included: power supply ; heatsinks; case
Price: $50 each (minimum of two). Free shipping CONUS.
Options: with a small ballast resistor they can run in parallel or bridged for higher power or lower impedance or better heat dissipation
SPECS: balanced inputs, up to about 40WRMS@8 or 60WRMS@4 ohms depending on power supply. At higher power the distortion specs don't change much other than better S/N.
POWER REQUIREMENTS: +-22 up to +-40V. Higher voltages are 8 ohm only unless paralleled amps. The amp voltage swing is a bit less than the power supply. The measurements are remarkably consistent between samples and very good but not guaranteed identical. Higher voltages generate a lot more heat. At +-25VDC it's a 40W@4 amp.
Here's the first sample's 5W@4 ohms. Here I'm powering it with 2 bridged Meanwell LRS-150-24 power supplies @25VDC. A linear supply would be slightly quieter. This was unbalanced input and the output choke hasn't been glued together yet 🙂 ->
I'll add more detail if requested. Warranty: it's tough to warranty something you can destroy by powering backwards or ... but I guarantee I will test/validate them before ship and include a printout of 5W@4 result for the board itself that should look much like this.
I've attached the REW file with my first tests. Note that the dynamic range of the amps is more than my test equipment so I have to test higher powers (>5 Watts) with a voltage divider which adds noise. I mark those as -6 or -10 (6db or 10db dividers).
My personal opinion is that these sound better than any amplifier I've ever owned. I listen to music at moderate sound levels on fairly efficient speakers. I use 4 of these amplifiers per channel (two in parallel for 4ohm woofer, one mid, one tweeter) in a DSP amplifier setup (so 8 total for stereo) - hence the need for 10.
Mark
1Spot CS 12 with half of the outputs not working.
Hey y'all.
Got a half-broken Truetone 1 Spot CS 12 pro that I intend on fixing. The first six outputs aren't working (2X 18v 100ma and 4X 9v 100ma) and the rest work just fine. The broken ones output around 1V DC with 300mV AC ripple. I find online that when cs 12's fail, this is often the failure mode. People generally just recommend sending it back to Truetone for repair, which makes sense, as messing with an SMPS can be deadly if you don't know what you're doing. This one isn't too dangerous, as I measured any potential voltage hotspots and they seem to drain pretty quickly.
I was wondering if anyone knows where I should look to find the failure mode on these? The back of the board is pretty dense with SMD stuff. I doubt there are schematics (I couldn't find any), but if someone knew where to source them that would be great!
Any help would be greatly appreciated!
CHP-90 bookshelf design question
I want to build something new. After some sucessful builds of planet10´s CGR for CHP-70 and Woden Design´s for CHN-50 I want to build something with a bigger driver but still for a smallish place, aproximately 20sqm.
I am quite fond of the looks from the classic golden ratios. The CGR for CHP-70 shall be the model dimension/ratio wise.
http://frugal-phile.com/boxlib/P10free/CGR-dKal-El703-301113.pdf
My idea is to take the general alignment from the "compact vented" one from the Markaudio site. I think its from Scott and fit a slot port on the side.
https://www.markaudio.com/wp-content/uploads/2022/05/CHP90-compact-vented.png
F6=46Hz and FB=46Hz according to plans.
The Volume is Vbox=12,47l and the 40mm round port is A=12,57cm l=12,3cm. I put the data into hornresp and got a frequency graph like this.
F6 is roughly 48Hz and FB 42,1Hz. I have double checked my data but this is what I got in HR.
My slot port should be 14cm wide and 15mm high. To reach the same FB=42,1 it has to be l=20,8cm. This is with a Vbox=13,11l. I had to increase the volume slightly because I upsacaled the CGR ratio by 15% and I want to stay on even numbers. The graphs are not the same but very similar from my point of view.
This is my first time designing a box. There might be stuff I missed or just dont know 🙂
Now my masterquestion. Can I do the box like this? Should this work or is this too far off from the original design?
I know, when using a slot port its adding R to the vent and pushing it more towards aperiodic while decreasing port output.
I attached my hornresp records in case somebody wants to have a look.
What comes to mind that I might change the port ouput which might had helped to fill baffle step losses? Also by placing the driver off centre. But this is just a guess which I can just assume.
Need help building open baffle/bass reflex hybrid
Hi all,
I am attempting to do my first build and am not very tech savvy so bear with me. My general idea is to mimic the Nola Brio speaker. It is a hybrid speaker consisting of two identical full range 3.5 " drivers. The configuration is a ported box housing on the bottom driver and an open baffle housing the top driver. I need advice and direction on all aspects. Here are my initial questions:
1. Should I wire the drivers in parallel or series configuration?
2. I don't want to blow the driver's up with my 250w/channel amp and so need direction on power handling (i assume this plays into how I choose to wire the speakers abnd how I choose the drivers)
3. Advice on drivers- I would like to use very low weight paper drivers to get a very quick and detailed sounding speaker (any recommendations would be great.. TangBand makes some very pretty looking ones)
4. Given that they will be identical full range drivers do I need a crossover? would there be advantages of filtering out bass frequencies in the upper driver ?(this is what the maker of the Nolas does.. He says he uses one simple capacitor in each speaker)?
Thanks in advance for any direction you could give me.
Procedure to determine unknown transformer rating?
What is the good procedure to determine the power / ma rating of an unknown transformer? I know that when I apply 120v to the primary I get approx 200v unloaded on the secondary. But I have no clue of what the rating of this transformer is, I salvaged it years ago, no part numbers. Intuitively I think I need to apply a varying load while measuring the secondary current and voltage drop. Maybe plot that graph at different loads? But at what point would I determine if it is considered to be a 200ma transformer, a 300ma, a 100ma, etc? Maybe when I see the voltage drop by maybe 10%, 15% then maybe call it that current rating at that point?
RCA sound system needing to utilize Bluetooth
Here is the link to thread I started back in Dec.'2023 in the Windows 11 Forum: https://forums.tomshardware.com/threads/no-audio-output.3831037/
The pic above is the Logitech Z-2200 2.1 speaker system that I bought in 2004. In 2007, I moved, and had to leave the bass, but kept the satellites.
In 2008, I bought Logitech's Z-2300 2.1 speaker system.
Which now made it a 4.1 system. Sound was fine, until the audio output driver somehow went bad(PC is from Best Buy in 2019). I tried to re-install the driver, multiple times. But with no success. The speakers are RCA connection.
I had a local PC tech come by over the weekend. He came to the conclusion I was dreading. He said I would have to start using the Bluetooth capability. So, I am trying to figure out. How to enable using the Bluetooth capability on my PC. While still being able to use my external speakers.
RSVP ASAP TIA
Linn Classik K/230 – Spring come out of CD player tray somewhere!
Hi!
I was fitting a replacement CD laser unit to my friend Mike Smith's Linn Classik K/230 when a small flat metal strip spring, about 20 mm (¾" !) long with two right–angle bends @ each end about 3 mm long, fell out of somewhere round about the left hand side of the CD tray somewhere and I can't work out where it fell out from!
. . .Does anybody have any pictures of a Linn CD tray that I can refer to that shows where this little flat bent spring went, or an exploded diagram please ?
Chris Williams
Meet GSL - Gunillas Song Box
(swe: Låda (box))
I found my sister Gunilla singing via a floor standing guitar amp at rehearsals etc… not ideal. I offered to build her a transportable PA for song and she accepted.
So it needed to be based on a sack carrier and a small lightweight loudspeaker. Me wanted to give it some proper performance in terms of fidelity as well as good wide coverage. Concerts are given but typically to smaller crowds - say a max of 50 persons in a couple of 100 sqm. Very simple operation is desired.
I came up with this concept sketch:
Its based on:
  • Sica 10” (10 C 2 CP 8Ω) bass prepared for coaxial tweeter
  • Lavoce 1” CD (DF10.10L-8)
  • Mic amplifier 2-channel but used as balanced
  • t.track DSP 4x4 pro for XO, EQ and compression/gate
  • 2x80W class-D TI based amp
BW: 150-10k
XO: 2,3kHz, 4th.
BOM: 750€ / 30 hours.
Dimensions:
It can be configured to play 5 different positions:
  • staying in transport box for quick sessions… (not ideal but usable)
  • sitting on top of transport box
  • mounted on sack carrier handle - handle in low position
  • mounted on sack carrier handle - handle in extended position
  • sitting on table etc. within 3m from transport box which is max extension for the spiral cord used
All electronics are mounted to a separating wall in the carrying box which in turn is mounted to the sack carrier. Loudspeaker is completely passive - spiral cord between amp and loudspeaker has 3 leads.
Operation entails:
  • Take out power cable(s)
  • Lift out speaker
  • Connect to mains
  • Adjust volume
  • Choose “mode” - three different (EQ, compression) settings for different sound characteristics - thats it.
  • Nock-em’out with some pop-jazz….
  • Write autographs
It’s very near completion - I’m waiting for a new selector for the “Mode” switch as I got a BBM but a MBB was required.
Next up is meeting up with the artist to do sound check and personalised tuning. But before that some standard measurement here at home. Home is a small, one room, flat which has made the build not so easy - a very small kitchen is not an ultimate workshop ;-D
Favorite Threads and Posts in "Musical Instruments"
Favorite Threads and Posts in this Forum
This permanent thread is a place for links to threads or posts in this particular forum that are useful and/or exemplify the best of DIY Audio.
This is so others- especially newer members can find them. Feel free to post with these links and a brief comment on what the thread discusses. Occasionally the moderators will consolidate them into fewer posts.
PA System for outdoors electronic music
Hi all, and thank you all for this forum.
First of all I'd like to tell a bit of why I'm here and what are our goals.
We've formed a non-profit society that has a goal of advancing the electronic music culture in our city. I joined to read and learn (and ask) since I want to build a sound system for the society (and for myself to learn).
I know a bit about woodworking, 3D modeling on solidworks and have access to a 3D printer and possibly a wood CNC machine.
I've been producing, recording and playing shows so I know the basics of music.
We would at the beginning host dancefloors of about 50-150 people, indoors and outdoors and I've still to decide which cabinets we'll go for.
Music we will play through the PA will be Psytrance, Techno, Tech House, Hard Techno, Drum & Bass, almost whatever you can imagine.
Priority will be clear sound, precise & pumping bass that can be felt and the possibility to build more to expand the soundsystem as we get things rolling.
Our transportation will in most cases be one european, regular sized van and 2-3 people in the crew (ourselves). So we would need something 2 people can haul.
Current idea is to build 2-4 15'' or 1-2 18'' subwoofers, depending on the cost of the drivers, wood is not that much of an issue.
Midrange and up would be point source, possibly a pair SynTripPs or something similar.
The 18'' option would be the Keystone since I'm assured that there is a massive wealth of knowledge and testing behind the design and read a lot of good about them.
For 15's, I've been looking at SS15 or THAM15, but I'm a bit worried about the low end extension in those cabs. SS15 so easy and cheap to build and very transportable. I
also read about the XoC1 optimised SS15 with the extension. Would that possibly be our answer? If we go with the SS15 would it fare good as a kick bin if we later build the Keystones?
Any other suggestions, I'm open for them. Best would be of course experience based but if someone can point me to a direction that would be helpful too.
My best regards
-Dougal
Amp enclosure
I'm going to be ordering a class d amp board from Aiyima to power a passive subwoofer I have. How would you guys go about putting this in an enclosure? I've built and bought diy enclosures before for small class d modules, but not for an amp where heat can be a big issue. I'm looking for ideas and/or tips on putting something like this board into an enclosure. Thanks
3 way Bluetooth speaker (component check)
So im designing a 3 way bluetooth speaker but im not completly sure what components to use..
Here is a list of what i currently have in mind:
Subwoofers 40 - 1k Hz: 2x (Tang Band: W3-1876S)
Midrange: 1k - 4k Hz: 1x (Dayton Audio: ND65-8)
Tweeter: 4k - 20k Hz: 1x (ND20FB-4)
Amplifier: KABD 430
My question is are speakers good, do they compliment each other, is it a suitable amp or are there better alternatives to this. Keep in mind im trying to make somethin as small as possible.
WTB McIntosh MC225 output transformer. . . or a parts MC225 with a good transformer. I know that I am wishing on a star here but thought I would try.
I need a McIntosh MC225 output transformer. . . or a parts MC225 with a good transformer. I know that I am wishing on a star here but thought I would try. I have tried so many outlets, including McIntosh labs, all of their recommendations, transformer re-winders and makers. This is a family heirloom and would very much like to get it operational again. Thanks, Tom L.
ICEpower 200AS2 volume/tone controls
I am trying to build a guitar amplifier similar to this, which uses and icepower 700 watt
https://www.seymourduncan.com/single-product/powerstage-700
I want to use this prebuilt setup or something similar, how could I add a bass, treble, mid, volume control to it?
https://www.aliexpress.us/item/3256805632323437.html
Would I just need to get something like this and drill holes for the pots then attach a cable to the Icepower?
https://www.aliexpress.us/item/2255....0.0.2cbf7a9dYKhBzD&mp=1&gatewayAdapt=glo2usa
I was also thinking of possibly buying this instead then getting the icepower with cable kit and some speakon / XLR connectors for the inputs and outputs
https://www.aliexpress.us/item/3256....0.0.f09e3064HILPil&mp=1&gatewayAdapt=glo2usa
Thanks for any help
Chip amp + MOSFET composite
Why to enhance a chip amp?
The trouble with these amps they are designed as opamps for stability and easy for use. The downside is very low NFB at high frequencies. In modern amps with two pole OLG, one can get over 50db NFB@20khz, while chip amps hardly reaches 30db. This results in low resolution amplifier with bad reproduction of complex vocals or large orchestras.
A simple way to correct, is to add a MOSFET to pump extra gain at OLG. The chip amp is used as its highest possible IV converting gain and the MOSFET converts the error voltage into current.
The universal circuit is shown bellow using LM3886 as simulation model compared to its application circuit. The Loop gain curves show how the initial 25db NFB@20khz leaps to 60db with MOSFET. The distortion is not implemented but the noise is. Comparing the output noise at 1khz, the 41.7uv of the initial circuit gets reduced to 0.7uv with MOSFET, this is 58 times lower which I estimate the distortion of the chip alone gets also reduced by the same factor.
I tried this circuit on Chinese TDA2050-LM1875, TDA7294 and LM3886. The best sounding I got is with 7294. Besides getting very smooth high frequencies, it has a wide, generous midrange that reminds me 45rpm records. With 3886, every time I tried this chip in composit, the voices goes back stage, with MOSFET, I got the worst ever of such type of sound. If I don't like it, many consider it better as they call it 3D sound or holographic.
The 7293 has 0.005%THD 1khz 5W, it gets reduced to 0.0001% to add the THD of 2N7000 of 0.0005% it should result less than 0.0006% in total.
The power supply will be a semi floating type for better bass using conventional psu, with SMPS, the positive input of the chip needs to be referenced to a virtual ground(2x10k resistors from rails).
I will design a PCB for 7293.
What to do with KEF B139s and T15s? A TL?
Hello all... there's a lot of experience and knowledge out there that I'm hoping to tap into. I've built the odd speaker before, (but have more experience with building/repairing wooden acoustic instruments than working with mdf and the like) - and I'm at the 'ideas' stage at the moment.
This is a medium-term idea with a lot of cogitation needed before commencing work in maybe 6-8 months time. If anyones got any bright ideas or comments it'd be much appreciated.
I've got 2x KEF 139 Mk2 SP6171 (the 'Racetrack' I think?) and two T15 tweeters - both from a Celeste Mk2. I inherited the speakers and the cabinets have suffered badly from damp. I grew up with this very pair of speakers, the cabinets are not really worth the work given the overall sound of the speakers - the box is too small for a B139 and it needs a mid-range.
So, call me a sentimental old fool ("you sentimental old fool!") but I'd like to use both the B139s AND and the T15s (if possible) in a TL. If the T15s are not a good idea I'll use them in something else down the line - a few people regard them with some favour I think.
The room is about 21' by 18' and 11' high. Size of cabinet is largely not relevant given the room size - the WAF measurement indicates that taller is better than broader and Black Ash is very definitely out. For these (and other not definable reasons) I like cabinet iii) the KEF B139 Triangulated TL from @planet10
I think I've narrowed down the box to one of the following (not an exhaustive list):
Variant a)
i) Atkinson SOTA (with a B110? in the mini-box inside or something else other than the B110). Matched B110s are £270 from Falcon :-(. T15 in the main box. Disadvantage - the woodwork required is crazy.
The woodwork on the following should be easier.
ii) Bailey triangle - with closed back mid? T15 in the triangle - or maybe in a separate box together with a mid?
or
iii) KEF B139 Triangulated TL @planet10. The B139 seems to be about ear-height so where's a tweeter to go with a 1300mm tall cabinet?
or iv) any other ideas
OR...
Variant b)
Cabinets as above with a single range driver (such as Alpair 5.2/3) in the Woden Babylabs 'Bloodhound' or 'Skyflash' (MA CHN70). A separate box though would rule out iii) KEF B139 Triangulated TL because of the height I suspect?
Quasimodo V4 & JFET IDSS jigs - FREE
EDIT: All gone!
I have 3 extra PCBs of each Quasimodo test-jig V4 and A slightly safer JFET I_dss measurement jig.
You only pay 100g non traceable international shipping with padded envelope: 5 EUR
Note, that if you only need one of the two PCB, you better make an order yourself. See in the screenshot below how much I paid for 5 pieces at JLCPCB, including shipping.
To reach 100g total weight, I will add 3 versions of the ground loop breaker circuit by Rod Elliott (Figure 5 at this page) that I made to teach me how to PCB.
Thank Mark and prasi, not me.
  • Thank You
Reactions: Dennis Hui
Hello from Groningen, the Netherlands.
Hello everyone,
My name is Jente (try pronouncing it 😉 ). During the daytime i act as a mechanical engineer, during the night i feel more like an electronics engineer. The reason for this is is that my passion for building speakers has grown into searching for ways to improve the electronics of my builds.
I really enjoy trying new designs and variations while learning through your comments and books from sources like Douglass Self.
i hope i can learn from and in the future teach the like-minded people of DIY audio. im looking forward to the journey and your company.
yours sincerely,
Jente a.k.a. ImpatientIcecream
Reactions: stv
JFET with matched JFET current sink for linearising
I came up with this basic configuration while digging into ways of emulating triode like behaviour with depletion FETs. Maybe broaching this topic is like beating a dead horse and no one wants to hear about it at this point, but I found it a bit curious that I have never come across this method.
Bare bones scetch:
Simulation in Falstad (perhaps questionable in accuracy from what i know about falstads transistor simulations):
(Left plot is the input waveform and right plot is the output.)
To give a bit of context. What I am really after is nice saturation characteristics in amplification stages that can be affected by power sag. I read (I forget where) that one major drawback of resistive NFB, as a method for achieving triode like transfer characteristics, is that triode tubes display something roughly equivalent to nonlinear internal NFB. And people usually emulate this by the use of diodes. My hypothesis is that using a matched JFET as a current drain in this configuration can open up the possibility to really dial in the NFB and make the transfer characteristics as linnear and symmetrical as you would like.
This is in itself not very different from using the well known "solid state cascode" configuration, but I primarily found that this was way easier to get biased properly in simulation. As you can see I only used one drain resistor and "cathode bypass" with nice results. (To retain more asymmetry, a resistor can be placed in parallel with the bottom JFET). Aditionally, it should work as I intend by using matched (or dual) transistors, while I have read that cascodes often require "complementary" transistors to work properly (??).
Would love to hear what you all have to say about the general idea, possible drawbacks or complications etc. Have you seen it before? Does it have a name?
My next step will be to implement it in LTSpice to hopefully verify the performance with a bit more reliability, take more "proper" meassurements, and examine how it behaves under different loads.
PS. This is my first post after years of spying on many great conversations. I'm very impressed by this community's knowleadability and generally friendly demeanour. Please be kind if I break any rules or some such, it's just lack of knowledge 😀
Cheers!
First Neurochrome Preamp Build
Cross-posted from Neurochrome forums, please delete if not allowed.
Hi All,
I'm looking to start my first neurochrome preamp build. I don't have a lot of experience, I tried and failed to build a B1 buffer years ago but I'm ready to jump back in. Here is what I would like to have:
  • Active
  • 2x RCA inputs (on DPDT switch)
  • XLR and RCA outs
  • Volume control with remote
  • 12v trigger out for amp
  • Plexiglass/Acrylic case 10" wide
Based on what I've read on the site I am planning on buying the following:
  • Neurochrome Preamp power supply (12v for the buffer and 5v for the volume control, 12v trigger)
  • Neurochrome Universal buffer
  • Khozmo 64 step ladder attenuator with remote
  • everything else (RCA jacks, chassis, etc)
Am I missing anything? Is 10"x10"x2" big enough to fit everything? Is there anything wrong with using plexi for the case? I'm assuming I'll need to drill some vent holes.
Crossover analysis and baffle diffraction
I found two loudspeakers that are three-way configuration have the same drivers except woofers and enclosures: ADS L980/2 and L1590/2. Despite the same mids and tweeters, their crossovers on mids and tweeters are different.
However, there exists similar situation in the previous series: ADS L810 and L1230. The L810 and L1230 have exactly the same ALL drivers and crossovers, and only EXCEPT the cabinets.
Back to the L980/2 and L1590/2, the crossovers are simply second-order on both high-pass and low-pass section.
The component values are different as follows:
L980/2: C1 = 4.7uF, L1 = 0.3mH, C2 = 13.6uF, L2 = 0.6mH
L1590/2: C1 = 6.8uF, L1 = 0.2mH, C2 = 15uF, L2 = 0.4mH
I’ve already put these values into simulation software, VituixCAD2, to see their filter’s characteristics. It showed the L1590/2 has peaky SPL response at the crossover region, whereas the L980/2 has smaller peak there.
I wonder why they were designed different mid-to-high crossovers, unlike the other case mentioned above—L810 and L1230. Is it because the baffle diffraction theory? AFAIK, the baffle diffraction would affect in the low frequency region, i.e., the woofer and cabinet interaction. So, they might be able to use the same crossovers (for mid-to-high), weren’t they?
PS. JBL L112 and L96 also use the same crossovers despite the different components including drivers, cabinet dimension and baffle size.
Pairing SMPS with a CRC filter
Hi There,
I've purchased a Nelson Pass F4 amp kit and just recieved it.
I went ahead and purchased 2 X 24V+- 350w SMPS units online. my question is, can i filter the SMPS DC output using a CRC power filter board like the one below (bypass the AC to DC conversion). and is it worth it?
Also, I've read somewhere that CRC filter configuration is supirior than just using filter capacitors, can someone help me understand why.
Thanks in advance. 🙂
Community Blender Horns
Below is a ball that I've got rolling but I hope to involve others. I desire to design basic Waveguides/Horns but I want to do so in a Wysiwyg fashion. So far, just from starting a thread on the blender forums, I see the potential for something easy, free and accessible to the community. The Geometry Node section of Blender is modulistic, in a good way. It also has a learning curve. I think with the superpower of community effort, we could cover ground pretty quickly. Lets share ideas and developments here and use the Blender Forum thread, linked in the pictures, to work with the Blender Wizards there to further our efforts. This has been a goal of mine, and as I make progress I will share it here. I know with community involvement it will be much better and quicker developing, its just a matter of, the community taking interest. So far I can create the shapes of various Round, Elliptical, Square/Rectangle, and soon Squircle mouthed waveguides, with expansion profiles that can be designed visually. The goal would be to develop a Geometry Node set up, to the point of producing simple printable models within a short amount of time. Anything that I have is downloadable in the thread linked. Good Luck 😉
Reactions: freddi
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,638
Members
7,881,959
Messages
Filter
Forum Statistics
Threads
405,935
Messages
7,881,959
Members
507,638
Latest member
Sheikh Jobayed ahmed
