Questions about IEC inlet filters, again...
Hello,
I was looking at some commercial IEC filters with an intention to clone them. My understanding is that even if the schematics are available, the lay out and actuall construction might be critical for performance so this would be a good reason to buy the ready products. But my little research left me with more questions about how to choose them. In particular, among the models for different current consumption, the only thing that change is the inductor's value: as the current goes up inductance goes down. I suppose it has to do with inductor's saturation but anyway how do we choose the proper filter for a given device? If, for example, the current consumption is at 1A then filters rated at 3A and 10A would perform differently?
I also found datasheets stating inductance at a certain frequency. What would that mean? Does inductance change with frequency?
impact of frequency response humps and nulls
I read somewhere that a hump around 600 hz will sound boxy and that more stuffing can help with that or a rise around 3000 may sound strident and needs a resistor what are some other freqency response deviations and the effect and solution. Just curious and I spent quite a bit of time looking for this information and really cannot find much. I have a average 5 db dip between 100 and 200 at the listening position not sure what this causes or how to fix it.
Sony CDP-557ESD Clock Help
Hello, I need some advice regarding an old battleship Sony CD player I recently purchased. At some point in its life, it had a Trichord clock upgrade but this has been removed. I'd like to return it to stock but it's missing the original crystal oscillator. I know the frequency I need (16.9244M), but I don't know if essentially any crystal will do the job? A quick web search throws up a ton of results for oscillators, are they pretty much all the same?
I'll have to replace the components around the original crystal as they've just been snipped and left in place, other option is to try to get another external clock and pick up a DC supply from somewhere in the player.
Any advice would be greatly appreciated!
For Sale ACA MJ Racam pair UK
For sale a pair of ACA MJ Racam built these on a wim and have collected dust since first test, please see photos.
R1/R2 on one board arnt raised above the board so could probably do with replacement and the washers holding down the fets could do with being replaced but everything else is good.
I would recommend setting up again before use.
UK mainland only
£90 ono This will include Postage to mainland UK
Reactions: arteom
Vintage console enthusiast here with a strange transistor project
Hey everyone.
Iam a big fan of the old transistor based consoles especially Neve 80 series consoles and the sound of them, I have nerded out on designing my own modules and now I want to take it a little further and use some of my old 1:12 transformers, to make a mic preamp. but with a transistor amp.
Iam looking for transistor based schematics for mic preamp that can use a 1:12 winding input transformer. If it has ever been made.
I know a 1:12 ratio winding would be made for tube amps. But I wonder if anyone back in the days 60’S/70’S made any mic pres in consoles for that type of transformer, that was transistor based.
Or also someone nowadays who made it would be of interest.
Let me hear if you heard about such thing or what your thoughts are on the idea.
Kind regards Bob
Need help to identify an amplifier
can anyone identify this tube amp , i want to restore it and i need a schematic , i think it was used in some type of tone cabinet , there is no markings on it other then 2222 printed on the front of it . power tubes are supposed to be 6l6gc , other tubes are 6c8 , 6c5 , 6h6 , 5u4 rectifier ,
the power transformer is branded STANDARD RADIO PRODUCTS OF KITCHENER ONTARIO CANADA .
Please let me know if you know what it is.
8" Woofer/Subwoofer Intermodulation Distortion Testing
I have found that low Intermodulation Distortion is a good indicator of sound quality. The last couple of years I have been measuring 10-12" subwoofers and 6-7" midwoofers in IMD, I will now share some testing in 8" drivers.
The test enclosure is a .5 cu ft (14 liter) sealed box with the bottom lip of the speaker just 2 inches above the floor. The microphone is on a stand 49"high with the base of the microphone 33" from the driver. A distance of about 1.5m from the speaker to the microphone. As I'm not measuring in an anechoic chamber my measurements are not comparable to anyone else's but comparisons can be made between the drivers I test.
Feel free to make suggestions on what drivers you want to see tested.
Behringer A500 _ one question about the schematic
Hi i have one Behringer a500 unused on which i would like to replace all the electrolytics with better parts The stock ones are scaring
The nice things of this unit are balanced inputs and a decently sized toroid (i know nothing about its actual quality)
i am attaching the schematic
I read of some distortion issues for different position of the input attenuators
Looking at the part of the circuit
i see a strange R71 and surprisingly a pot value bigger than the input impedance at the opamp
I always thought that the pot value should be lower of the following stage input impedance
Can i eliminate R71 at least ? i dont like it at all
Thanks a lot
Feedforward Error Canceling with Blameless Topology
Feedforward Error Canceling, in theory, could cancel most of the distortion. You could get 0.002% THD figure without much efforts with this technique, at least in simulation. A good example is the famous Current Dumping. If you don't know how Current Dumping works, I highly recommend you jump to this thread to learn how it works and what it can achieve. Current Dumping with OPAMP
Besides Current Dumping, the same technique, Feedforward Error Canceling, can also be implemented to other topology. Here I use a Blameless style amp for example.
See the example below, the Blameless style with EF2, with an average loop gain. Pretty common setup. Please ignore C1 and R7 for now. They will be used later. The idle bias is at 136ma. 10KHz 20Vp into 8 Ohm is about -72 dB THD.
To implement Feedforward Error Canceling, you need pull a resistor from Miller cap VAS side to the inductor speaker side. However, the VAS doesn't have the capability to drive the feedforward resistor directly. The work around is to create TMC (Transitional Miller Compensation) around the driver stage, and use driver stage to drive the feedforward resistor. See updated circuit below. R13, R4, C1 create a transitional network for the Miller compensation.
From the simulation, you can see all the distortion is gone!!.
The optimal value of R7 depends on the inductor value and also the loop gain bandwidth of the amp. The loop gain bandwidth of the example below is about 600KHz. Thus, the optimal value of R7 should be 2 * pi * Bandwidth * L = 2 * 3.14 * 600,000 * 4.7e-6 = 18 Ohm. If you still don't know what is going on, please search Current Dumpling and learn it. This technique is highly effective but also overlooked.
[EDIT]
PS: In the example above, there are 2 things going on. One is TMC, the other is the feedforward error canceling. They both contribute to lower the THD. The TMC may cause other stability issue. I recommend to check the final version that is without the TMC.
Some turntable suspension measurements
I’m playing around with a suspension for my new plinth and did some rough measurements of the two options that others might find interesting. In the plots below Z is up and down X& Y are horizontal. “springs” are a set of metal springs from a VPI HW19 “With Damping” means with the original VPI foam inserts in the springs. “Foam” is mixed cell polyurethane designed for building or machine foundation isolation. “Constrained” means that I built a solid wrap in the XY dimensions from plywood about 80% of the height of the foam blocks. I calculated the size of the foam blocks from the manufactures literature and should be getting a resonance close to what I get with the springs but I think the manufacturer’s data is based on wide thin sheets and the shape I am using (essentially a cube) is changing things a bit. One thing you can’t see in the roughly 1 second of data I posted for each is that the undamped springs rang for an incredibly long time, minutes in fact. The vpi foam inserts while they did raise resonance a bit cut the ringing time considerably.
DIY Fostex Laboratory inspired project questions
Hi all, first post on this forum!
I am embarking on on a new project with a friend who is a skilled cabinet maker with access to cnc etc to build some speakers inspired by Fostex lab studio monitor series.
https://www.preservationsound.com/2013/09/fostex-laboratory-series-pro-audio-monitors-c-1980/
The plan is to use the plans for the h400 horn available here: Here is construction plans for Fostex Type of H400 wooden horns - Techtalk Speaker Building, Audio, Video Discussion Forum make out of Sapele and match with a modern 1 inch comp that is suitable (any suggestions welcomed - thinking BMS 4550 or B&C 250)
and build a LF box inspired by this matching cab from the 80s:
https://www.fostexinternational.com/docs/speaker_components/pdf/recom_enclose/w300aII_encl.pdf
but modify for B&C 12NDL76 rather than the original Fostex driver, which I have done here = Subwoofer Box B&C Speakers 12NDL76 | Ported Box | Slot .
Planning to run as low as possible and cross at 800hz as per the original design - to the horn then run a super tweeter from 7k up, (Fostex FT17H?). Does my design look suitable for this?
Not confident in crossover design but have used lots of DSP in live sound scenarios, but would rather run passive from one amp rather than active with DSP on 3 amps so need to work that out. The original crossover plans for the H400/Wa3002 combo are available, how much would it cost to get give someone a list of the drivers I am using and the old crossover plans and get them to make a passive crossover? Thinking Crown macro tech amp(s).
Thanks in advance!
  • Thank You
Reactions: GM and wchang
For Sale Various Jantzen/Mundorf/others capacitors and coils
Most components are new or used for tests. See photos for details:
Jantzen Air core coils:
1.2mH, 1.6mm, 0.27 ohm, 30x60 mm, 550g, SOLD
NEW: Nihicon KW 2200uF 63V capacitors, new, bought from Mouser, 15 EUR/set of 8 x1
Send PM for details. Price is per piece + post costs, Payment via Paypal.
new member
Hi, I'm Henk from the Netherlands. A long time ago, I was probably 12 years old, I started building amplifiers. I used the DIY kits from Philips for that, I built preamplifiers, a complete 8-channel mixing console and power amplifiers. In that period I also started building speakers.
When I was 18, all that building was a bit over, I was too busy with my studies and work. I was already working in security at the time and built the central units myself for various large projects.
Now a few years ago, before my retirement, I started building speakers again, for example the Klipsch Cornwall (Klonwall). About 2 years ago I started building Horn speakers from Western Electric complete with separate crossovers. These are now finished and I am very happy with the sound that comes out of them. I also bought a tube amplifier (so not built) during that period, the Willsenton R8 and I was very happy with it until I saw a video from Stephe (Skunkie Design) about modifying this amplifier. I did most of the modifications then. A few days ago I had some problems with the amplifier and then I sent Stephe a message which she promptly answered and of course was able to solve my problem, through Stephe I also came into contact with DiyAudio. I hope I can learn more about building audio equipment here.
Noise measurements for LiFePo4 and supercapacitors?
Hi all,
I've been searching around without any joy for evidence of noise measurements of modern batteries or supercapacitors when used as power supplies for digital circuits.
I can see older references and measurements for lead acid and nicad batteries in various articles and in threads like this Battery-powered supplies - diyAudio
But I can't see anything similar for supercapacitors or for example LiFePo4 batteries.
I've heard very good reports from people using lifepo4 with a float charger to power their dacs, but I'd like to understand some of the theory and benefits.
Is anyone aware of any publicly available results comparing lifepo4 to other methods of low noise power supply?
Thanks,
James
  • Locked
New Members... please read this before posting
Welcome new member,
Start a thread here and introduce yourself to activate your forum posting privileges. Please save your technical questions for another post. The Moderation Team will approve your introduction, if you would kindly allow us a little time for this to happen we would appreciate it.
Please note, we are an English speaking forum. Posting in the forum's legitimate sales area is restricted until new members have built up a small count of quality posts elsewhere on the forum. This is done for the protection of both new and established members.
We're looking forward to learning about your journey and how we can help you.
diyAudio
Moderation Team
* Threads other than introductions created here, and other non-complying posts may be removed or other such action at the discretion of moderation.
looking for schematic for prewar Gibson EH150
I am looking for a schematic for a 1935-36 Gibson EH150 1st Generation second series amp. I've been asked to bring it back to stock but it came with a 5U4 rectifier, 5V6 and 6V6 power tubes, and a 6A6 preamp tube. I know the 5V6 and 6V6 can't be right and the 5U4 rectifier is a question mark. It looks like the amp was recapped in the 60's and the tech who did it splattered solder all over and did a really bad job. Does anyone know where I could find a schematic? This is a very early amp with no volume control or any pots at all. There is a resistor on the one input jack and a cathode resistor but that is all. There is a choke, a field coil speaker, and a lot of dust. Any help on a schematic would be fantastic!
Can anyone identify these output transformers?
I bought these cheap off ebay. Seller said 10K ohm-4,8 Single End Transformer. Quite Large and heavy. I would guess Chinese.
Just thought someone here might recognise these. 200 for the pair so the impulse kicked in LOL. He mentions Yaqin but I'm not sure
about that. Thanks
Endgame WMTMW open baffle woofer options
I am still not finished building my monster OB line array speakers but am already looking ahead for a next build
My next build will run also use a ESS Heil tweeter >3khz
The mids will be two alpair 12p's
For the woofers I am eying the 21" Lii Song OB drivers. Problem is there are 2 versions from 2 different Lii Songs.....
Version A
Version B
Version A has higher QTS and QMS and dual voice coil.
Version B has vented pole piece, higher VAS and thicker plates and looks a little more premium to me, even though it is slightly cheaper.
Which one would you pick and why?
W5-876SE for MTM
I purchased six Tang Band W5-876SE 16 ohm woofers on closeout from Parts Express several years ago and never got around to doing anything with them. I'm thinking about using them for MTM speakers. I've searched around quite a bit and have found many posts that mention that they can be used for MTM but no specific info on how to best go about it. Where should they be crossed and what type of tweeter would be work with them? Are there any existing designs? I'd also consider some kind of TL enclosure if that would sound substantially better. They'll mostly be used for music.
On the search for cheap mods to my setup
Hi there,
I registered here, because it seems the only place where people are discussing multiuple things from my current setup.
I want to give and get some feedback about minor modifications that I have planned.
the speakers: https://www.diyaudio.com/community/threads/panasonic-sb-pm28-active-crossover-help.301156/
and the crossover: https://www.diyaudio.com/community/...uit-diagram-for-a-weah-d222-crossover.406079/
for this setup I use a SMSL AD18 Amp.
Best regards
For Sale 2021 DIY Sony VFET - VFET N Channel (pt 2)
So I was one of the lucky ones to be able to build and own one of a few hundred 2021 DIY Sony VFET amplifiers as pre built (OS) and tested by mr. Pass.
Now, due to significant downsizing, basically losing a hobby/listening room due to family expansion, I put this amplifier up for sale.
The amplifier is the N-channel version, see link to build thread. I have built it fully as stock and the Meanwell SMPS is included. In the past two years I have had the amp playing compression drivers on Yuichi Horns from 600hz and up. The sound, well this forum will back up it's qualities 🙂
Please send me your best offer + shipping and paypal fees from The Netherlands. I'd rather have this amp making someone happy than it being not in use at my place but if it does not meet my price, I will keep it as the collectors item it is. 🙂
RIAA preamps versus real loads
On another thread I proposed several sophisticated RIAA preamps, adding LTSpice simulations for all or most of them.
One of the main problems in simulating RIAA preamps in any program is that you have to add a load that includes both the anti-RIAA and the cartridge.
The one I found the most interesting one was an opamp representation of an idea Erno Borbely had proposed years ago in The Audio Amateur magazine, in a discrete preamp design e introduced there.
The RIAA part of the preamp was split in two preamps: the first one being passive and the second being active.
So with the help of some DIYAudio friends, which I hope show themselves here, it was arrived to working preamps with excellent simulation specs.
To start showing models and sims, I will start by what I consider a brilliant development by Hans Polak to the original proposal by EB.
It is to be noted that also MarcelvrdG contributed to this design.
Cable Management.
I've seen a lot of kit on many forums, but often it comes with a lot of visible cables.
This may be quite acceptable to those contributors, but it's quite easy to hide most of them if you choose.
I'm a tidy person, so I don't like to see them. They can also be a trip hazard, more of a problem, if something expensive then gets dragged off a stand when it happens.
I use plastic trunking. it's dirt cheap, easy and quick to fix, either with a few small screws or just the adhesive that is on the back.
Mine sits on top the skirting boards and is hardly noticeable. Of course, any change of equipment can be accommodated as the tops just clip on and is easily removed and replaced.
Now I know this won't interest many, but perhaps it will some.
Cables from one double socket feed the TV and everything under it to the left and the wall unit lighting and all my audio equipment to the right.
[IMG]
[IMG]
This feeds my electric piano, its amplifier and the music stand lamp.
[IMG]
There are two pairs of cables to each of these jukebox wall boxes, which have quick release connectors behind them. The cables pass down inside the trunking below the shelf, then along more trunking on top of the skirting board, then disappear behind the wall unit.
[IMG]
This trunking comes in different widths and lengths, here in the UK, usually in 3mtr lengths for just a few pounds. Easily cut with a small saw. You can get "elbows" for them but they aren't really necessary.
[IMG]
Reactions: Miller-8
AlmaAtaKZ just joined, Hoping to build my first pair of speakers
Hi, all!
Just joining. Starting with saying thank you to user DannerD3H for making a guide for Hypex HFD newbies. Really appreciated!
Have just started building a pair of active speakers using FA253 and having no prior experience of any design or build.
Anyone wants to coach me through this project?
Denis
London
Simulating and modifying the UDP3
G'day Guys,
I've been playing around with Mark Johnson's UDP3 in LTspice.
Firstly to understand what its doing and secondly to modify it to my purpose.
I don't understand the 2nd stage clamped capacitance multiplier entirely and I can't find a model for the AZ431AZ so that I can simulate it.
From what I can figure out the purpose of this subcircuit is to set the output voltage at 19v (aside from the reduction in ripple).
I would like to be able to use the UDP3 for input voltages other than the specified 22vac and output voltages other than 19vdc.
With this goal in mind it seems like the clamped capacitance multiplier subcircuit should be modified or dropped to allow the extra flexibilty.
I've whipped up a sim in LTspice however I am very new to simulation so please forgive me if things are not done well.
I have omited everything up to and including the rectifiers as unimportant for the work at hand.
I have also omited the ferrite beads as I can't figure out how to sim them properly. I don't think these are very important for the sim anyway.
I couldn't get a model for the TIP122 to work so I am using the model for the TIP142 as close enough for my purpose.
So starting with the first capmx stage, here's what I have come up with.
For 25vdc in, I am getting 3v drop which seems reasonable.
With a 0.35Vrms input ripple. I am getting 3.4mVrms out.
40db reduction in ripple according to my calculation.
Adding a 2nd stage the same as the first drops another 3v and gives me ripple so low I can't see any in the sim even with the scale set to pV.
So a couple of questions to get the ball rolling.
1)Are my assumptions reasonable so far?
2) Is 350mVrms a reasonable ripple voltage for something like a 150mA load
3) Is there a way to figure out what the ripple is in the sim when it is so low the line is flat on a 1pv scale?
I would like to figure out what improvement in ripple reduction would be from adding a second stage.
My main use case for this circuit will be as a 'pre-regulator' before a VRDN style denoisered LM317/337 in place of a CRC filter.
So the ultimate question is:
If one was to simply chop off the clamped capacitance multiplier and put it in front of a denoiser, is there much benefit to adding a 2nd capmx stage?
DSP Three-way open baffle
Hi there - I was kicking around the idea of making a Pure Audio Project (PAP) clone using an 8" full range with 2 15" woofers...but the x-over had me ruffled. I've never built a speaker or cross over and wasn't sure I wanted to tackle it. Plus I'm not completely convinced a FR will give me the top end I want so I was thinking of adding a tweeter/super tweeter of some kind. I was also thinking about trying to add Dirac room correction to my system. Then recently I've been reading about how far class D amps have come, and maybe thinking of trying something in that vein. Enter miniDSP's new FlexHTX; eight channel dsp with Dirac built in--talk about flexibility. So, and bear with me here....consider an active three way PAP clone using the FlexHTX as the cross over. Drivers would be two Bianco 15" drivers, a Tang Band W8 full range driver in the middle, and some sort of AMT or Ribbon tweeter mounted next to the full range, NEO 3 for example or Mundorf ($$). Amplification would come from two three channel Purifi based class D amps like Buckeye or one of the other similar ones out there. I'd run the woofers up to 400hz, the tang band from 400-8k or so and the tweeter from 8k up. With the functionality of the Flex I can do all the x-over work digitally, time alignment etc and room correction. I'd still have two channels in the x-over left over for subs if needed. I'm confident I can build the open baffle.
What do you all think of this idea? I don't love being bound to using the miniDSP's DACs...but to be honest DACs are all getting pretty damn good and the idea of getting the cross over "right" plus the in-room correction probably makes up for whatever shortcomings the onboard DACs might have.
What am I looking for? Big, open sound, excellent imagine, dynamics, clarity. Music is a wide range but mostly country rock (Grateful Dead, Bill Strings) and 80s rock and small group be-bop jazz. Really looking for that big immersive soundstage I hear people describe from open baffles without giving up the dynamic impact of high sensitivity speakers.
I'd have to liquidate most of the existing rig to fund something like this, and I don't love putting pre/dac/x-over all in one box but maybe that's the ludite in me. I keep reading/hearing great things about the clarity and transparency of these class D amps and seriously considering taking the plunge in this direction. Tell me what you think!
LDR Pre MkII - LDR volume control and I/O switching
The list of differences between LDR Pre MkII and original VxD LDR volume controller is so long that I thought it might require a new thread, even though LDR Pre MkII is actually a spin-off of amazing VxD from Vincent:
Arduino based LDR volume and source selection controller
1) Instead of Arduino Nano which runs on Atmega328P, LDR Pre is driven by Atmega328PB which can be found on some Chinese Arduino Nano clones. To utilise however the full power of "PB" which has three native 16 bit timers instead of one, Nano clone boards require hardware modification to expose additional pins on "PB", as well as new bootloader which uses serial1 instead of serial0.
2) LDR Pre has native 16-bit "DAC" capability, instead of 8-bit DAC in VxD. This allows smooth volume changes without impedance range switching which was causing volume bumps due to time constants in RC filters at PWM outputs.
3) LDR Pre supports only OLED with SSD1306/SSD1311, no LCDs any more. OLEDs from Aliexpress running on SSD1309 are not supported - I was not able to make them work over I2C.
4) LDR Pre has firmware which stores all the parameters in EEPROM.
5) LDR Pre fw has ability to change all the parameters from user interface, including: load and nominal impedance, screen brightness, screen saver timeout, welcome message, I/O names and LDR min values, max saved volume level, measured 5V voltage, etc.
6) Entire user interface is accessible by a remote or encoder. You can use only one of them or both to access all functions.
7) Backlight pin is now used to control power amp relay
8) Entire board runs on 5V. Built in Nano 5v regulator is not used any more, so less heat on the controller board. OLED now draws current from power supply directly instead from Nano.
9) Power supply is now delivering 4X5V instead of 2X12+8V.
10) There is no feedback code to maintain constant current in LDRs. I found this routine to cause more instability in impedance than environment temp, so I removed it. This allowed more room for additional functions.
11) Since all the parameters are stored in the EEPROM, it's possible to deliver unified, one-size-fits-all precompiled firmware updates without involving Arduino IDE and all the hassles it carries. There is no need to have IDE installed at all to update firmware or change parameters.
12) Calibration routine has been changed and optimized to accommodate 16-bit timers.
13) There is an option in the menu to reset all parameters and names to default values.
14) Firmware is power amp friendly - it can be configured not to save volumes above max value stored in EEPROM. By default this value is 10 (out of 50).
15) Firmware boots into standby mode. Pressing play button on remote for 3 seconds turns on the device and powers up the power amp (if connected). Pressing it again for three seconds puts the device in standby mode again and turns off the power amp stage.
16) Pressing center button on (Apple) remote or encoder for 3 seconds enters the setup menu.
17) There is now a child lock in the firmware, which allows to disable encoder and operate with remote only.
XKi - X's ab initio Karlson 6th Order Bandpass
Update (5/21/2020): My Plans for XKi W5-2143 here.
Update (4/17/2019): xrk971's W5-2143 XKi (more info here):
750221d1555471376-xki-xs-ab-initio-karlson-6th-bandpass-xki-w5-2143-p08-jpg
Videos here: https://www.diyaudio.com/forums/ful...tio-karlson-6th-bandpass-127.html#post6689070
XKi W5-2143 basic design here.. It is very important to follow all the instructions in previous link showing internal build details regarding use of melamine foam damping pads and felt and foamcore on the backside of the aperture.
143 here.
Update (3/23/16): Srednivashtar's wonderful dual PA130-8 XKi
What's the deal with a Karlson aperture in front of the driver? Won't that mess up the polar dispersion? That's a great question, and no. The aperture actually improves the uniformity of the polar response compared to the bare faced driver:
461843d1422331652-xki-xs-ab-initio-karlson-6th-order-bandpass-xki-rs100-4-tape-neweq-polar.png
This thread found its beginnings here: A Speaker that Kicks Butt in Large Spaces - Page 66 - diyAudio. The finding was interesting enough that I decided to put it on its own here.
I will recap:
Properly scaling the Karlson K15 cabinet to work with smaller drivers has been an elusive goal for over 50 years. If you are at all familiar with the K15, you know that the moment it is scaled below a 12/15 scale, the bass extension suffers. The cabinet excels at efficiently controlling cone motion and channeling what little motion there is into high SPL levels, albeit, with some warts in the way of the famous Karlson "W" dips and peaks in the mid-bass region. Nonetheless, the speaker sounds very good and has a devoted following.
I recently have been working on developing 6th order bandpass subwoofers over in the subwoofer forum, especially slot-loaded push-pull bandpass subs. This alignment is very good at controlling cone motion and in many ways reminded me of the topology of a K15. So I got to thinking that I could develop a K15 style cabinet for any size driver, if they satisfy some basic T/S parameters needed for a 6th order bandpass box (moderate to low Qts, low Vas, strong motor, high sensitivity, etc.). I would design the new box from the ground up, or as they say, "from the beginning". The "i" is for ab initio, or from the beginning. I have figured out how to design a new type of "K" box with deep bass, good cone control, for any size driver with appropriate T/S parameters. There is no scaling of the K15 design involved, and it begins with the design of a 6th order bandpass alignment optimized for bass extension, flat response, and good control of cone motion, all properties that a 6th order bandpass alignment is known for. The difference is that the output port is simply a Karlson aperture of appropriate cross sectional area, and the chambers are designed with angles to avoid rectangular volumes that may have resonance modes.
As a test case, I designed a box that can reach 50Hz using a nominal 3.5in driver - the Dayton RS100P-4 (paper cone). This driver has a suitable moderate Qts to allow fb to set below fs and has good xmax of 4mm and a relatively powerful motor. The 6th order bandpass design was a 4.0 liter rear chamber and 1.0 liter front chamber with a 0.5in x 5.0in x 9.0in long vent, and a front chamber vent consisting of a 5in dia aperture.
I converted these volumes and vent dimensions into a box that has internal dimensions of 5in wide x 9.0in tall x 7.5in deep which then provides the correct volumes once the vent volume and driver volumes are subtracted. The front K-aperture is sized to have the same cross sectional area as a 5in dia hole, which was approximated by the area of a triangle that is 5in wide x 7in high, accounting for the curvature and offsets near the bottom.
The box design looks like this:
Here is a photo of the inside during construction showing the bracing and folded vent arrangement leading to the top of the front chamber (although not ahown, there is a piece of open cell foam on the bottom and I put a wad of pink fiberglass in the main large volume to damp the HF's from reflecting back onto the rear side of the cone):
Here is the completed speaker - still retains the look of a very small K15:
And here is the measured frequency response about 0.5m away along the axis of the driver centerline - it has the characteristic Karlson "W" dips and a falloff near the bandpass followed by the direct radiator output which lets it reach up to the HF limit of the driver (about 14kHz in this case). The measured f3 is 51Hz! An amazing concept for anyone who has ever tried to scale a K15 down will realize. Predicted max SPL at 4mm xmax is 98dB in 2pi space:
How does it sound? Very nice - sound clips attached below. Dispersion was very good as evidenced by the polar data showing very little variation in the response from 0 deg to 45 deg (or 90 deg full cone, and even out to 60 deg the variations are quite small). This is one of the biggest advantages of the Karlson aperture is a uniform polar response:
The transients are also clean as you can see from the measured impulse response. Furthermore, because the polar response is so uniform, the impulse response is also uniform along different angles. Many open face speakers will exhibit vastly different impulse responses because they have beaming or cone breakup modes that are angle dependent.
Here are the IR's for 0 deg to 45 deg (note the similarities from 0 deg to 45 deg):
461171d1422071148-xki-xs-ab-initio-karlson-6th-order-bandpass-xki-rs100p-ir-0-deg.png
461172d1422071148-xki-xs-ab-initio-karlson-6th-order-bandpass-xki-rs100p-ir-15-deg.png
461173d1422071148-xki-xs-ab-initio-karlson-6th-order-bandpass-xki-rs100p-ir-30-deg.png
461174d1422071148-xki-xs-ab-initio-karlson-6th-order-bandpass-xki-rs100p-ir-45-deg.png
This is a tiny speaker with a tiny driver, but it sounds quite big. Now, the neat thing about this methodology is that if a 3.5in driver can hit 51Hz, a 6.5in or 8in can probably do 40Hz. This can also be used for a sub woofer with a good pro audio 12in driver like the Faital Pro 12HP1030 and achieve 120dB SPL and mid 30Hz...
I applied a -24dB/oct high pass filter at 47 Hz to reduce cone excursion and some EQ to see if we can't make the response less bumpy. Here is the result of the HPF and EQ:
461175d1422071148-xki-xs-ab-initio-karlson-6th-order-bandpass-xki-rs100p-effect-hpf-eq.png
Here is the impulse response after the EQ has been applied - a little cleaner:
Here is the harmonic distortion - a lot of this is the result of the foam core cabinet vibrating. CLD can knock this down quite a bit but I have not done that yet:
If you are interested in this speaker and would like to design a box around your favorite driver, follow along and I will detail the process and methodology for designing the XKi for your driver.
Briefly, the process starts with a design of a quasi 6th order band pass box with your favorite driver, but with these guidelines:
1. Set the rear chamber volume to front chamber volume ratio at 4:1
2. Set the output vent to have a cross sectional area equal to at least 2x Sd if you plan on using full range drivers
3. Using a quasi 6th order bandpass simulation program (Akabak, Bassbox, etc) adjust the vent length and chamber total volume to provide the optimum balance of bass extension, SPL output, and flat response.
Akabak script for 6th order band pass is available here: XKi - X's ab initio Karlson 6th Order Bandpass - Page 16 - diyAudio
4. Convert the volumes and vent length to a box with a total volume equal to 5x the front chamber volume PLUS the driver magnet/basket/cone volume and the vent volume
5. Set the width of the cabinet based on driver bezel width plus an inch or so of margin, set the height at an aesthetically pleasing ratio (golden ratio is good), Fibonacci, etc.
6. Calculate the depth based on known volume and height and width
7. Calculate the front chamber volume using the area of a triangle - this calculates the setback of the angled V in the front chamber.
8. Make the vent a channel vent leading from the top to the back and wrapping down. Note that the final build tends to have a deeper tuning than predicted due to the additional losses in the narrow aspect vent walls, so you may want to reduce the vent length by about 15% or so in the build.
Edit Jan 25, 2015: effects of EQ, high pass filter, and aluminum vs paper cone - aluminum cone seems to have more bass.
461443d1422174486-xki-xs-ab-initio-karlson-6th-order-bandpass-effect-paper-alum-eq-boost.png
Edit Feb 19, 2019: Plans for XKI with PA130-8 by Thermcul
717369d1542949252-xki-xs-ab-initio-karlson-6th-bandpass-pa130-8-xki-box-drawing-png
xrk971's As-Built XKi for W5-2143:
846117d1590078184-xki-xs-ab-initio-karlson-6th-bandpass-xki-w5-2143-plans-xrk971-21-2020-jpg
  • XKi-RS100P-4-RP-01.zip
  • XKi-RS100P-4-ZB-02.zip
WTB WTT for SONY K82
I find myself in possession of most of the parts for a 2016 SONY VFET amplifier.
I picked up PCBs here that were populated originally for use with K60/J18 devices…of which I have a few.
However, in searching for a pair of the special mounting brackets used with this amp project I also acquired a pair of J28 KF33 VFETs here in the swap meet.
They were originally from
CircuitDIY Acronman according to the seller.
Not curve traced. No Vgs written on them. I’d have to figure out the testing procedure to determine Vgs.
Still, I’d like the opportunity to assemble the amp as NP originally designed it.
To my knowledge NP never curve traced the VFETs. My understanding is he measured the Vgs of the devices and then I suppose he tried to put together pairs of the K82/J28 that would avoid any serious operational problems in the circuit.
I’m looking for a pair of K82 that would work with the J28 KF33 I have properly in the circuit.
I’d be willing to buy them outright or would consider other options such as trading for some of the K60/J18 devices I have which are perfect for the SONY VFET Part 3 OS project.
I would also consider buying K82/J28 pairs if there is someone who has them from a reputable source that never got to building with them.
Again, I don’t feel obligated to have curve traced matched pairs.
In the event that someone does have some special curve traced matched pairs of K82/J28 and they are interested in a trade then I might consider offering some Semisouth R100 curve traced matched pairs that I have hoarded in exchange.
Dynaco ST80 clone - Speaker wobble on start up
I have cloned a Dynaco ST80. The only circuit changes are 6800uf filter cap and output caps. My issue is that there is 3v of speaker cone deflection on start up and I can’t shake it. 3v DC measured across the outputs for a split second. Have added a 100nf x cap to the live and neutral. This actually helped a little bit as the deflection is now silent. Any ideas? I have an original ST80 and it behaves the same way. Would still like to fix it. Would an NTC thermistor help?
Filter choke critical inductance
For a good design in power supply filtering for audio (tubes) I read that one must take into into account several parameters, including the Lc that is the critical value of the input inductance. This is true when using an LC filter, where Lc>Rl/6*pi*f, but the same can be neglected with a pi-filter, CLC. Since I'd like to use a relatively small filter choke, someone could explain this rule (and the role of the input C)? Thanks.
Trying to see FFT of a typical tube gain stage
Hi
Everyone says that triode tubes have more 2nd harmonic THD than anything else and I wanted to see this in LTspice. I made a CC gain stage with typical values and ran it with a low-level sine input. The output was generally clean looking and THD was pretty typical from what I've read.
The FFT of the output showed odd and even harmonics with the 3rd not being much lower than the 2nd. A few higher harmonics were present in both FFTs. I know the curve for a triode follows a 2/3 exponent, which maybe does produce both even and odd harmonics?
I wondered what the input signal looked like and its FFT was similar AND its THD baseline was only a little below the baseline for the output FFT. This made me wonder if the tube was simply amplifying the dirty oscillator harmonics?
I went to a different file for a super-low-THD solid-state amp and checked its input and output FFT. In this case, the baseline for the output FFT was around -180dB and 10dB lower for the input.
So, it seems like LTspice scales the THD of the sine generator depending on the range of THD the circuit under test generates?
Does this seem normal?
Full range cardioid
Full range cardioid, need advice on next prototype
Currently i'm working on a new speaker build, aiming for a cardioid radiation pattern from 50Hz on up. I have made a prototype consisting of a top cabinet which has a A&D R1030 10" woofer in a damped Uframe, and a Hypex PSC 2 400 plate amp (2 ch amp + dsp). I experimented with the opening of the Uframe, adding slots and especially the placement and quantity of damping material. See attached files for the optimal polar pattern. For high frequencies, I have a B&C DE250 on a Dayton 10” waveguide. I modified the waveguide slightly to accept the bolt on compression driver and remove any irregularities in the transition to the waveguide.
For the sub cabinet, I have 2 Peerless XLS10 woofers and a Hypex PSC 2 400. In order to achieve cardioid radiation, I have combined a sealed and dipole enclosure. The dipole is high passed at 50Hz using a 4th order filter in order to limit cone excursion and to have the advantages of a pressure source <50Hz. Free field measurements showed a polar resembling cardioid from 63Hz on up.
However, there are some points for improvement for which I would like your advice!
1. In order to achieve maximum suppression of LF at rear, I had to delay the monopole sub by 1,9ms. This resulted in less than optimal summation of the two drivers at the front. The dipole woofer is actually positioned 20cm behind the woofer in the sealed enclosure.
2. The polar has a maximum which is about 20degrees of center, caused by asymmetric construction of the dipole. I think I will make a new version using a regular H frame.
3. I’m considering adding passive radiators to increase output of the monopole <50Hz for LFE use. I’m a bit concerned this will complicate achieving cardioid radiation in the 50-150Hz region.
RK-Auto200W Amplifer
RK-AutoBias200 Amplifier
Here's a schematic I've been developing for a couple of months, now. I have not laid out the PCB yet, let alone built one.
[The schematic shown in post #92 is the most recent iteration so far.]
The design goal is a 200W amp with distortion below 0.001% up to 20 kHz. VCCP/VEEP looks like they're going to be +/- 63V unregulated. VCC/VEE will be +/- 70V regulated.
Generated rails from the shunt and series-pass regulators will be
VCCP-5V
VEEP+5V
+15V
-15V
I've made an attempt at EF-triple stabilization, with a thread here: Removing MJE1503x in an Output Triple
but I don't think the final answer to that can be found in sims. I have not drawn the feedback yet, nor the final compensation. In IC op amps, a cap from the top of R8 to GND is sufficient, but a T-miller arrangement here will further linearize the output stage.
OL Gain is very high, and the pole from the output stage will between 10 and 20 MHz.
Output transistor biasing will be adapted from William Chater's bias control circuit from 1988. That's what's in the yellow box. I've detailed my adaptation here:
William Chater's "Bias control for power amplifiers," Revisited
Added, 10 Mar 2020:
My plan is to finish this design, documenting my progress and performance on diyaudio. When the design is complete, and the PCBs are laid out, I will make PCBs available. Gerber files, too. Then I will try to stick around to give advice on building and mods.
I still have some expectation that simulated performance, up to 20 kHz can be as low as 0.001%. We will see if my PCB layout skills can get a real circuit to approach that performance.
At this point in my life, I have 35 years experience as a designer of audio circuits, including 12 years where I designed discrete transistor power amplifiers for car audio. After that, I designed class-B and class-D audio amplifier ICs for 10 years. Now, I am a research engineer designing analog to digital converters for 200 GS/s SERDES in silicon processes that are not yet released for production.
I'm hope this design ends up being as good as the best of what's out there, both commercially and DIY.
Outline of the thread, so far:
  1. Addition of cascode below Q5. Discussion of TL431 and replacing with quieter infra-red LEDs--posts #8 - #15
  2. First documentation of performance--posts #15 - #28
  3. Simulated amplifier with clipping. Quasi-sat of KSA1220 driver caused instability exiting clipping. Replaced drivers with 4 each of KSC3503 and KSA1381. This let me increase UGBW to 5 Mhz from 3 Mhz, and increased SR to 94 V/us from 58 V/us. Posts #39 - #45.
  4. Documentation of simulated performance, post revision, Posts #46 - #50.
  5. Discussion with BesPav about my design decisions, Posts #62 - #65.
  6. Addition of SOA limiting, single-slope, dual slope, and eliminating distortion caused by SOA circuit, posts #66 - #78.
  7. Schematic of SOA limit and bias servo offloaded to daughter PCB, post #80.
  8. Replaced LM334 with "ring of two" current source, post #85.
  9. Find sources of distortion and optimize. TPIIC considered. Posts #92 - ...
keywords: [special=power amplifier]%[/special], [special=design ]%[/special], [special=folded cascode]%[/special], [special=triple EF]%[/special], [special=LTspice]%[/special], [special=low THD]%[/special], [special=low noise]%[/special], [special=self bias]%[/special]
SA9123 USB to SPDIF optical I2S output 24BIT 192K SA9227 32BIT 384K AC3 DTS DSD256
It may be the cheapest in the world. And the excellent performance of 24 BIT 192K
USB TO digital platform. SA9123
SA9123 USB TO SPDIF ,optical , I2S 。
The SA9123L is a high performance up to 24bit,
192KHz PCM streaming USB High-Speed compliant
audio steaming controller. It features one IEC60958
S/PDIF transmit streaming output. The SA9123L is
ideal for both one stereo-in and one stereo-out
professional digital audio interface applications
The SA9123L is high-performance, up to 24 bits,
192KHz PCM Streaming USB High Speed Compatibility
Audio USB controller. It has an IEC60958
S/PDIF transport stream output. SA9123L Yes
Perfect for one stereo input and one stereo output
Professional digital audio interface application
Supported specifications:
Independent sample rates for each
pair
44.1/ 48/ 88.2/ 96/ 176.4/ 192 KHz sampling rates
16/24 bit resolution
It may be the cheapest in the world. And the 32BIT 384K DSD256 with excellent performance
USB TO digital platform. SA9227
And supports AC3 DTS and DSD256
Cancelling out room Eigentones with a sub & DSP-LF
I have an annoying boomy resonance in my listening room at about 68Hz. I don't want to insert any filters into the signal path to my amp (Q909).
My speakers are Magneplanar MG1.6 and go low enough but can't be relocated to a position which doesn't excite the eigentonesso much.
So I was pondering on placing an unused sub near my listening position driven with a Dayton Audio DSP-LF and spare amp. In this case, adjusting the response to cancel out the boom rather than boosting the low frequencies.
Doable?
Car stereo subwoofer? With this amp?
Hello everyone!
First, I want to apologize if the translation is bad, being French I use a translation site to put everything in English, if things are mistranslated or incomprehensible, let me know 🙂
So I will explain my situation, I always wanted to have a subwoofer in my car, so I went deep into the search.
At first I wanted a closed subwoofer of 300/350W RMS, except that in the end, given the prices for such power in closed box, I preferred to go on bass-reflex or other because it is much cheaper.
Except that I realized that the dual subwoofer drivers were not so much more expensive than single sub driver. So I decided to start with that.
Then came the choice of an active or passive housing. I found some nice active sub (price/power level), but when I looked a little more closely, I saw that the integrated amps were not necessarily ideal (example: barely 2x50W RMS for a 2x300W RMS sub driver), so I have a first question: Why is it so different? Can we trust the active sub?
Sub in question: Edge Car Audio DB EDB12TA-E0 (2x 300W RMS)
Integrated amp in question: ED7300
Personally, I concluded that it was not, so I started looking at the passive sub.
That’s when I thought: since I plan to take dual subwoofers, it is better to put them on stereo, so I have a second question: Is it really worth it? I read that we perceive very badly the stereo with bass and most of the time, they were mixed in mono, except that I want to dream!
I have always been very sensitive to the pan (left/right variation) on instruments, and as far as to make as much have the best sound possible! (I really want to believe that the stereo is worth it, but if not, so be it ...)
Finally, to return to the sub, I found one that interests me strongly in view of its price, but especially that in the manual there is an instruction (screenshot support) to connect it in stereo (which I did not find in the manual of its lower version the B1 210):
Sub in question: GAS Mad B2 210
It is therefore a 600W RMS, or 2x300W RMS.
Looking at the 300W RMS dual channel amps in 4 ohm, I came across amps at 300 € minimum! In any case, too expensive for me.
Then I went to a second-hand amp and came across this one:
Amp: TN4 900D
Only 40€! With 4 channels 2 ohm and 2 channels bridged 4 ohm to 450W RMS. My main question being: can I make a stereo installation by connecting the 2 sub drivers with 1 pair of channels bridged 4 ohm 450W RMS each?
I read somewhere that it is not possible stereo in bridge because the 2 signals (stereo right side and stereo left side, I do not know how to describe this) add up to form a mono signal at the end. Talking with an AI (GPT chat) I may have learned that actually the 4 channels of this amp (and probably for all amps if it’s real) are in fact separate on the stereo right side and stereo left side.
Then I wondered if there are 2 right and 2 left channels, so why not make two pairs of the same side (right + right and left + left) instead of making two pairs with 1 different side (left + right x2)? And then make a stereo installation?
Does it make sense? I don’t know much about it, it may be lunar for connoisseurs. Thank you for enlightening me!
If something is misexplained/mistranslated, I apologize and will do everything to clarify it 🙂
PS: at the base I was going to take 2 used amps at about 300/350W RMS in 4 ohm rather than a multicanals amp but since I came across this really cheap amp I wonder what is best. And if it is possible, is 450W RMS per subwoofer driver not too much for 300 W RMS?
So you want to design your own speaker from scratch!
You have been doing this DIY speaker thing for a while, probably built a couple of proven designs from people like Zaph , Troels Gravesen, Paul Carmody or any number of other successful designers.
Perhaps you started out like me, cobbling together random drivers with off the shelf or textbook crossovers, but never quite worked out why they didn’t work out as well as you imagined. You bought books like David Weems' “Designing Building and testing your own speaker system” and Vance Dickasons "Loudspeaker Design Cookbook" and have decided it is time to design something from scratch.
Alternately you may have followed AllenB’s excellent tutorial "Designing Crossovers Without Measurements" but have decided to take it to the next level and do measurements in which case Joseph D'Appolito's book "Testing Loudspeakers" and his article "Testing Loudspeakers, Which Measurements Matter" will be useful.
If you haven’t done any of the above you may want to have a look at Paul Carmody’s excellent FAQ "Proven Designs" first, which covers why you should build a proven design as your first project .
If you have got this far and are still game then read on 😉
Note that I am not an expert, I am just a guy who has been playing with speakers for the better part of 30 years, I’ve learnt quite a lot just by experimenting, a lot from reading and I’ve probably forgotten at least half of what I at one point knew or understood (or thought I understood!!).
As I don’t have expertise in all areas (some might claim in any!) I’m thinking that I will put in a number of placeholder posts, with the idea that members with more experience in those areas can write a post and I (or another Moderator) can paste the content into the relevant placeholder post. I’m also happy for this to be more of a live thread with suggestions for corrections or additions to the core posts taken on board and potentially amended.
There are many different design philosophies, and it is not my intent to try and cover them all, though where appropriate different directions may be suggested. I’m not interested in starting any religious wars on design choices 😉
The intent of this thread is to give someone a starting point and things to think about rather than a prescription on how to do it. I am an advocate of simulation as part of the design process so later posts will feature this, but even if you don't want to simulate hopefully you will still find the thread useful.
So lets get started!
Lets keep this thread uncluttered, A separate Designing your own speaker from scratch discussion thread has been created.
Please use that thread for questions and discussions or suggestions and we will try and add just relevant content to this thread 🙂 non complying posts may be mercilessly moved to the other thread 😉
Reactions: fabio323ti
For Sale Marantz CD-273 for sale
Asking price: 165 € + postage, EU buyer preferred due to customs.
Working condition. With the legendary Philips TDA1541 DAC inside.
6EM7 dissimilar triode model
Using a 6EM7 dissimilar triode model
I am experiences difficulty getting this model to work.
Any ideas?
Thanks in advance, HD
.SUBCKT 6EM7_P1 1 2 3 ; P G C
  • PARAMS: MU=65.12 EX=1.14 KG1=554.18 KP=1228.6 KVB=4674.43
  • RGI=2000
  • CCG=2.2P CGP=4.8P CCP=.6P
E1 7 0 VALUE={V(1,3)/KP*LN(1+EXP(KP*(1/MU+V(2,3)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/(2*KG1)}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE GRID
C2 2 1 {CGP} ; GRID-PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
.SUBCKT 6EM7_P2 1 2 3
  • PARAMS: MU=7.288 EX=1.16 KG1=124.11 KP=25.418 KVB=1856.1
  • RGI=2000
  • CCG=7.0P CGP=10.0P CCP=1.8P
RE1 7 0 1G
G1 1 3 VALUE={ (PWR(V(7),EX)+PWRS(V(7), EX))/(2*KG1) }
.ENDS
For Sale House keeping amp boards
I have the following amp boards fully built and used for sometime. Moved on to other amps so these need to move, so offers are welcome and shipping to local CONUS only.
All of the boards have genuine parts and some expensive caps all per suggestion of original builds. They have been fully tested and used for 20-30 hrs with my Klipsch Forte speakers with perfect bias and offset as per the recommendation of the amp build guides. Parts have been sourced from either members part of the group buy and Mouser/Digikey/Newark, so rest assured very good parts especially on the Aleph J I have used all the PRP resistors.
1. Lu1014D cascade amp -- SOLD
2. Zdmini LH Quam member -- SOLD
3. Aleph J by RainfallSky member -- SOLD
Interested in Bottlehead Crack - Anything to know before ordering kit?
I am preparing to upgrade my HD600's to HD800S and my LittleDot MkII to a Bottlehead Crack.
First question: I know the Crack pairs well with the HD600, is it similarly good with the 800?
Second question: Are there mods I should consider, parts I should order separately, or generally ways to augment the kit?
Thanks!
For Sale Normundss Input and Switch boards v2.3 for Soekris DAM1021 + DimDim ArDAM lite for Soekris DAM1021
Hello,
Up for sale are two items related to the Soekris DAM1021.
First up is the Normundss Input and Switch boards. Complete set with connectors and most necessary parts already soldered. This set is just missing Coax and Optical parts that can be procured from Mouser/Digikey. The set includes input board, switch board, and RaspberryPi adapter board.
Price: $OLD
Next up is DimDim ArDAM lite assembled board with separate IR receiver. This board allows for an OLED display to be hooked up, which indicates input information, sample rate, etc. This also includes Arduino Uno board, which is pre-flashed with ArDAM firmware. Finally small OLED display is included as well.
Price: $60 shipped CONUS.
Will ship internationally. Add $20.
For Sale Various PSUs - Kits - Salas BiB v1.1, Salas L-Adapter, Salas Reflektor-D, DIYinHK 5V 1uV
I've got these PSUs for sale:
2 sets of Salas BiB v1.1 with IRF+, IRF-, BJT+. 1 board set includes remaining PSU +/- parts not included in IRF/BJT kits. One board set 3rd + power rail has been split off.
Set with just IRF and BJT is $50 shipped. Set with full PSU parts is $80 shipped.
1 set of Salas L-Adapter 5V - full kit. Missing Q1. $60 shipped.
1 Reflektor-D - full kit. $60 shipped.
1 DIYinHK 5V 1.0uV 800mA kit. $50 shipped.
Prices are CONUS.
I will ship internationally, however the price is $20 more.
Introduction
Just a quick intro here, hopefully more about myself will emerge from future posts.
Found this site looking up info on tube amplifiers after diving in head first and acquiring a couple of very interesting old things in various stages of neglect. Still working on them and looking forward to actually hear them sing.
See you in the tube section.
Yuichi A290, TAD TH-4001, Yamamoto F350, Crowe ES290: Horn in Your 2 or 3-way Speakers?
The specifics of horn design in speakers utilizing compression drivers determines numerous aspects of sound quality. And of course, the ultimate test of any well designed and built speaker is in the listening. Therefore, I’m hoping that I might be invited to hear speakers using any of these horns. Having these actual listening experiences will best enable me to decide between these horns for building my speakers.
I have my short list of drivers for a two or three way design: Radian 745 or 951neoBe, Yamaha JA6681B, SB Audience 65CDNT, B&C DCM50.
These are my Altec midwoofers. https://josephcrowe.com/blogs/news/altec-416-8b-in-100l-sealed
My subs. https://www.rythmikaudio.com/F12.html The Altec and Rythmik sealed cabinets were built by Jim Salk.
https://www.salksound.com/model.php?model=Rythmik+12+Subwoofer
I would only need for your system to include a nice DAC with a USB input. That way I can play via my laptop uncompressed WAV files
of CD track rips and what I believe are high quality Youtube files of live concerts.
I’m in New York and can travel a respectable distance by rail within the US.
Thank you.
Reactions: camrector
Liberty Praxis resurfaces as "PraxisFREE"
During my MEMs microphone project this year, I needed some specialized measurement features for calibration of reference microphones and of the MEMS microphones themselves. Since I could do get under the hood in Praxis code and (when I could remember!) knew how it worked inside, I went in and removed the necessity for the AudPod hardware and modified as needed. Since then, in some spare time, I've been cleaning up the user interface and making a calibration scheme that didn't depend on AudPod, and am posting it online as "PraxisFREE". Feel free to download it and play if you want, it's at
Liberty Praxis, from about 20 years ago, was kind of a swiss army knife for audio measurements with computer "soundcards" (nowadays known as audio interfaces). It was like a big matrix of very configurable measurement stimuli and signal acquisition types along with a bunch of math processes for time domain and frequency domain data. It can't do everything that modern systems like ARTA or REW can do, but maybe can do a few obscure things that others don't (?).
The Praxis scripting had to be dropped (the correct tools for that weren't found on any of my old backups) and a large number of measurement types had to be deleted or disabled due to their dependence on functions of the Audpod or their just being too much work to resurrect again. But PraxisFREE now supports sample rates up to 384k (or even 768k, if Windows ever supports that natively), and the FFT and IFFT processes, as well as curve smoothing are now much faster than they were.
And a disclaimer: Since this is no longer commercial and just free use hobby stuff now, please don't expect a lot of support or ongoing bugfixes. I couldn't check all the possible operating scenarios, so I expect some of them may not work right. Non-buyer beware!
Have fun,
Bill
Parametric EQ project - not sure where to start - Kits? From scratch?
I want to make a multi-band analog domain parametric EQ to use for correcting headphone response. I have a few questions:
1. Should I try to find a kit, or start from scratch?
The kits I've found are all for guitar pedals, and I'm not sure how applicable they would be. The circuits don't seem that complicated, perhaps building from scratch is simpler?
2. PCB vs. point-to-point
I've never designed and printed a PCB before. I know there are services that make it easy. At the same time, if I can build this point to point, so much the better. Is this the sort of thing it would make much more sense to learn how to make a PCB for?
I guess that's only two questions. But it'll get on for now. I see several directions I could jump at, but I want to get some feedback from those more experienced before I go to Mouser....
Reactions: Rewind
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,551
Members
7,876,523
Messages
Filter
Forum Statistics
Threads
405,702
Messages
7,876,523
Members
507,551
Latest member
mbwiest
