SA9123 USB to SPDIF optical I2S output 24BIT 192K SA9227 32BIT 384K AC3 DTS DSD256
It may be the cheapest in the world. And the excellent performance of 24 BIT 192K
USB TO digital platform. SA9123
SA9123 USB TO SPDIF ,optical , I2S 。
The SA9123L is a high performance up to 24bit,
192KHz PCM streaming USB High-Speed compliant
audio steaming controller. It features one IEC60958
S/PDIF transmit streaming output. The SA9123L is
ideal for both one stereo-in and one stereo-out
professional digital audio interface applications
The SA9123L is high-performance, up to 24 bits,
192KHz PCM Streaming USB High Speed Compatibility
Audio USB controller. It has an IEC60958
S/PDIF transport stream output. SA9123L Yes
Perfect for one stereo input and one stereo output
Professional digital audio interface application
Supported specifications:
Independent sample rates for each
pair
44.1/ 48/ 88.2/ 96/ 176.4/ 192 KHz sampling rates
16/24 bit resolution
It may be the cheapest in the world. And the 32BIT 384K DSD256 with excellent performance
USB TO digital platform. SA9227
And supports AC3 DTS and DSD256
