Hello everybody!
Hello fellow audio enthusiasts! I'm thrilled to join this community where passion for diy high-end audio unites us all. I have a particular interest in DIY audio projects and am a big fan of Sansui and Decware amplifiers. I'm eager to deepen my understanding, share my experiences, and learn from the wealth of knowledge within this forum. Looking forward to engaging in discussions and exploring the fascinating world of HiFi together.
What to do with Realistic 40-1022?
A friend dug these out of storage and gave them to me. They were never used and look to be perfectly fine in the packaging. I see they were often part of a well known “Minimus 7” bookshelf speaker.
I guess I’m wondering what a nice short path to using them might be? My wife could use some book shelf speakers in her office. But I don’t know where to start in terms of a tweeter or crossover.
Edit: a thread about M7 upgrades directs to these little crossovers. Or there’s this thread about upgrade crossovers.
Audiolab 8000A popping fuses
I've acquired an Audiolab 8000A which is popping its mains fuses.
I've checked the power supply with the rails to the output stage disconnected and all is OK - voltages OK, minor ripple.
Looking in to the power rails the resistance on both channels and rails is the same and showing no shorts or low resistance so I think the output transistors are OK.
With the power connected to the power amp again and the amp powered via a DBT nothing looks untoward - the expected inrush then a steady dim glow.
However, when directly connected to the mains the transformer briefly hums as though under high load and the fuse goes.
The only anomaly I've found is that one of R495/R496 which are 4R7 2W resistors is down to 2R8 when measured out of circuit. That resistor is in series with a 100nF capacitor, which are across the output.
Is that circuit to filter high frequencies to prevent oscillation? Could oscillation be what's causing the high current draw and be due to that filter not working correctly due to the resistor's lower value? Given the amp blows its fuse so quickly it's not that feasible to detect with a scope.
It also looks like some of the output transistors have been changed - perhaps for unsuitable replacements?
Greetings from Central - Near Syracuse NY and looking for help with PCB design!
Hi Folks,
My name is Rich… a few folks know me as the guy who provides support and service for folks with Merlin Music Systems speakers and Joule-Electra tube gear. I’m a EE and have been playing around with electronics since high school and have been into (high end) audio since my early teens (I caught the disease from my dad being raised around AR3A’s, Dynaco gear, Thorens turntables etc). As a EE, my speciality was more in systems/project engineering which is what I did in the defense industry during the 80’s and early 90’s before deciding to go do my own thing in the world of high end audio.
Though (full disclosure) I am a (very small) high-end audio retailer, close to half of my work is taking care of old Joule-Electra gear and Merlin Music Systems speakers and a some other stuff (mostly tube stuff). I knew the owners/designers at both companies well and loved their gear. With these guys not around (Bobby P at Merlin passed in 2015 and Jud Barber at Joule retired and closed his company down in 2013 and has passed on 2 yers ago) I’ve done what I can get help keep that gear going and making music. At times hat has meant being creative and DIYing some fixes for things. 🙂
What do I DIY then??? I do some of my own mods/tweaks to things (don’t really have the time to build complete things from scratch these days) Latest project is trying to learn DIPTrace PCB design SW so I can make a simple replacement circuit board which will allow different/better volume and balance controls in later Joule-Electra preamps (including my own of course). It’s been slow going. Could really use some help with this and DIPTrace’s on discussion forum has not been of any help. Hoping I can find someone here who has some actual circuit board design experience (which I am a total newbie to) who can help (this idiot) out!
Last major project was resurrecting a 25 year old pair of Joule-Electra VZN-160 OTL amps which have sat in storage/unused for close to 20 years (a lot of filter capacitor replacing, some cap reforming, doing some mods to improve serviceability, and then testing testing testing to make sure the amps were reliable and problem free before sending them to a new home.
Thanks for reading my rambling long post…
Cheers
Rich
A circuit without a cathode resistor?
I hope somebody can help me identifying this line stage circuit. I don’t think it’s an anode (or plate) follower, and it is not a common cathode amplifier. What I don’t really understand is the complete lack of a shunting from the cathode to the ground. The common cathode circuit has a resistor with the bypass cap, but here we have the cathode directly connected to the ground... can't find this circuit on books.
Can somebody help me in understanding how it works?
AD_4nXcLCteSRTODrC-Z0xHDiqy2Xg6usMHA3RHpFNe01VQ4pAJLum0CCnOzncJeS9OKs_hgVYEDHVaYUO6Rh4MbYglsRl9z8JLcvvhAQFDPVyWOi7uLjZTp1QLObYsd62woMhFxL57mpA
Neurochrome HP-2 ultra-low distortion headphone amplifier
World, I present to you the All-DIY Neurochrome HP-2 ultra-low distortion headphone amp.
I will be demoing it tomorrow (Sunday Nov. 10, 2019) at the Burning Amp Fest at Ft. Mason. If you're in San Francisco, please stop by for a demo and chat.
Key features of the HP-2:
  • 4-layer PCB fully optimized for performance while being relatively easy to assemble.
  • Output power: 440 mW (32 Ω), 660 mW (50 Ω), 260 mW (300 Ω) at vanishingly low distortion.
  • Inputs: Balanced/differential (XLR) and unbalanced/single-ended (RCA).
  • Alps "Blue Velvet" volume potentiometer.
  • +5 dB and +15 dB gain settings (jumper selectable).
  • Integrated headphone protection circuit, which disconnects your headphones in the case of DC voltage on the output of the amplifier.
  • Integrated output muting circuit ensures that the HP-2 is completely absent of turn-on and turn-off clicks and pops.
  • Optimized on-board RLC power supply filter allowing for stellar performance with the recommended switching power supply.
  • External 28 VDC switching power supply accepting 85 – 264 VAC mains for use world wide.
  • The PCB features elaborate use of planes and copper pours to maximize circuit performance by minimizing supply and ground impedances.
  • On-board EMI/RFI input filter to prevent wifi and switch transients from interfering with the sound reproduction.
  • With the exception of two SOIC-08 surface mounted ICs, the HP-2 is all through-hole construction with socketed ICs and is easy to solder.
  • Bill-of-materials includes a Mouser Electronics Project Link for ease of parts ordering.
  • Gold plated PCB, fully electrically tested by the manufacturer.
  • PCB is designed and manufactured in Canada.
  • Custom designed chassis manufactured in Italy.
Build budget:
  • Cost of parts for the PCB: ~$160 (including power supply)
  • Cost of a full build using my custom chassis: ~$500
Spec. highlights:
  • Output power: 440 mW (32 Ω); 660 mW (50 Ω); 260 mW (300 Ω)
  • THD: < -130 dBc (50 mW, 300 Ω)
  • Multi-tone IMD residual: -144 dBr (AP 32-tone, ref. 100 mW, 300 Ω)
  • Output noise: 1.0 µV RMS (A-wt, 20 Hz - 20 kHz)
  • Dynamic range: 125 dB
  • Gain: +5 dB, +15 dB (jumper selectable)
  • Input sensitivity: 2.90 V, 865 mW (gains +5 dB, +15 dB, respectively; 100 mW, 300 Ω)
You can find the circuit description and full specifications on my website: Neurochrome HP-2.
But, but... What does it sound like? I like it, obviously. Ever since I heard my first precision amp, I've been hooked on the precise (i.e. ultra-low distortion) sound. I prefer that the amp makes as little contribution to the sound as possible, as I believe this allows for experiencing the music the way the artist and recording engineers intended it. The precision of the HP-2 allows it to provide realistic and natural rendition of the source material, with a wide and open sound stage (even in headphones!).
The HP-2 will only be available as a DIY product, i.e. I will not be offering it in a fully assembled option. The PCB features two surface mounted components. They're relatively easy to solder 8-pin SOICs. Should you wish to have me solder those ICs for you, I can do that for a small fee.
In addition to the PCB, I offer a nice aluminum chassis, which has been custom designed for the HP-2. The chassis is a very nice option for DIYers who would like to showcase their builds in the form of a professional-looking product.
I am offering the HP-2 at pre-order prices until they arrive in stock or until the first ten HP-2s have sold (whichever occurs first). You can buy your HP-2 here: Neurochrome HP-2.
Thanks,
Tom
  • HP-2_ Harmonic Spectrum (50 mW, 300 ohm, suppressed fundamental, 256k FFT, 16 averages) - annota.png
  • HP-2_ Multitone Intermodulation Distortion (AP 32-tone, 100 mW, 300 ohm).PNG
CAN (electrolytic) Cap Question - dimension/details
Hi everyone,
I love coming back to this website because of the value of the information given here. People are usually super knowldgeable about this stuff, and that's probably why i've been a member for many, many years. So, here's the questioneroni. Why is it, that NONE of the datasheeets for electrolytic can caps have the SPACING between the screw holes listed? I mean, the distance changes, it's NOT constant, so it's kinda important, wouldn't cha say?
I could go measure the spacing, but practically speaking, if you're designing something in that you don'T have, well, that's what tech drawings are for, right? I'm talking older datasheets, like Sprague stuff from the 60's. Anyway, of you kno why, or if there's a general consensus or standard on this, I'd like to know.
Thank you all
pfeww. I managed to make it through that without adding too much "colour".
Mystery 6SL7GT
Recently bought a batch of 6SL7GT, including National Union, Ken-Rad, RCA and Sylvania.
There also was one tube with no markings on the base, just the stop-sign 6SL7GT on the glass.
My thoughts went first to RCA, but it wasn't like the others in the batch.
Circular top mica, rectangular getter and black plates (probably). Does anyone recognize this structure/construction? All suggestions welcome!
HDMI audio extractor chip with I2S pinout
I'm looking to feed I2S from HDMI audio or specifically the ARC port of newer televisions to a Twisted Pear B3pro. After looking around a while I realized there's nothing out there (that I could find) diy wise that could do it. So I knew there were plenty of audio extractor boxes, most of them were toslink. If I was going to compromise I would use coax spdif out from one of these boxes. I had one of these from Amazon basics that cost $20 and it did the job well feeding my receiver for a few years. I decided to take the cover off and see what was inside
I looked up the chip inside and found out that it is made by this company
https://www.semiconn.com/ep92a3e
The cool thing is that is has I2S output but I could not locate a data sheet to see what and where those pins might be. I've sent an email to that company to see if they'll send me one. If someone knows where to find it please post it.
What's even better is this set of pads labeled JR1 has the right amount of pads for I2S. Could this be I2S? The unit in question is here
https://www.amazon.com/AmazonBasics...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
I don't have the knowledge or tools to try and figure out what JR1 is. Does anyone have a schematic of this unit? I would think it's mass produced under several makers and models.
Any thoughts? Help?
Cyrus 2 Repair Help Needed
Hi Folks. I could really use some help repairing my Cyrus 2, Issue 6 (plastic case).
In particular I need to find a replacement for the MJE243 / MJE253 driver transistor pair. In my case, I contacted something while attempting to check the bias (for the heck of it) that caused MJE253 to become permanently shorted (thus causing the FS1 and FS2 fuses to blow when the Cyrus is powered on).
I can buy a MJE243 / MJE253 pair off of eBay, maybe elsewhere, but unlike the versions with the TO220 package that I have (which apparently can dissipate up to 40 watts at ambient) all the available pairs have a TO126 package where the dissipation capability is far lower. I don’t know whether that matters (or whether there’d be any other difficulties with the TO126 lead pitch, pinout arrangement, etc).
I’ve also read through a number of posts concerning alternative replacements for MJE243 / MJE253, but the only thing I saw that was specific to the Cyrus was a suggestion to use a BD139 / BD140 pair. Again, though, the dissipation values are quite a bit lower than with the pair I have (and, again, I don’t know whether there’d be other difficulties such as the pinout).
Any suggestions would be appreciated since I'm not confident that I could reliably figure it out myself. Just one more thing…
I had an “accident” while taking out the board and bent/banged one of the regulator heat sinks so hard that it drove the transistor through the board, tearing off two of the three solder pads and part of the associated traces. Does anybody know of a repair kit out there with at least appropriately-sized replacement pads and trace sections (the ones I’ve found are tiny - for cell phones and the like)?
Thanks.
Subwoofer controller (Low pass filter)
Hey all, i built a subwoofer controller which has phase and frequency control from 35 to 150hz.
After building and testing it, im hearing too much of high frequency from the subwoofer. The filter should get rid of most high freqeuncy sounds as its a 24db filter using 2 2nd order filters.
Is there something wrong with the design.
How do i fix this?
My presentation of me
Hello all diyer's !
I'm French and I'm delighted to be able to join you to talk about beautiful sound and making it yourself.
My name is Laurent,
I am 40 years old and I have under my belt, for 20 years, manufactured a few pairs of acoustic chambers and subwoofers which I have improved over these few years, I have used very few measuring and recording instruments, preferring to use my ears, that said I come to these places to learn more about the software and how to use them correctly.
To do this, I have a sound card, a microphone and a resistance mount, I just have to download REW and find the calibration, at least I suppose so?
It is not simply for this reason that I wish to join your community but also and simply out of passion and to know you through your know-how and interpersonal skills.
I use a translator in order to understand us and I hope you will accept me that way?
I wish you all happy listening to your respective systems, whether they are completed or still under construction!
Sincerely,
Laurent.
Reactions: DATIR
Commercial Gainclone kit- building instructions
This thread idea started here: http://www.diyaudio.com/forums/showthread.php?postid=1500369#post1500369 and is aimed to provide guidance in building a simple Gainclone amp.
While I'll be using as an example a commercial kit, there is nothing wrong with wiring the circuit point to point, without using printed board.
If commercial forum section is more appropriate for this subject, please move it there.
The basic kit contains printed board, 2 LM3875 chips, 8 resistors, 4 main filter capacitors and 16 diodes and is intended for dual mono application.
Speaker Protection Board
I've designed a simple speaker protection board using the UPC1237 (Unisonic Taiwan is the manufacturer, originally uPC1237 from NEC) that uses mosfets rather than a relay to switch the speaker. The circuit operates from 25V to 75V with some resistor changes (detailed in the write-up), features power up/down muting, DC offset protection and an input to trip the protection on overcurrent (you will need to arrange your own short circuit detection - the board just takes an input for this as a trigger).
There's a presentation with the circuit, BOM and if you want a board, you can buy one off the website.
https://hifisonix.com/projects/hifisonix-speaker-protection-board/
Happy soldering
See here for where to connect the AC detect input in split power supplies: https://www.diyaudio.com/community/threads/speaker-protection-board.377896/post-7283100
JohnAudioTech JAT501 Build Thread
Hi, I ordered a batch of ten JohnAudioTech's JAT501 PCBs from JLCPCB. The Inline double sided version. Made from JohnAudioTech's publicly available JAT501 gerber files.
John, Thank you for your generosity and contributions to the community. Also, much thanks to the anonymous PCB designer. Much appreciated.
Class D amp directly solar powered?
I have a 2x25 Watt class D amp with CS8673 chip.
It can take maximum voltage of 24 Volts.
I have a 60 watt solar panel with maximum open circuit voltage of 22 Volts.
Is it possible to power such an amplifier directly with a solar panel with maybe some filtering capacitor of several thousand uF? Or should filtering be omitted ?
I live in egypt here you have always sun and it never rains.
Anyone tried running a class D amp like this?
Bass chest kick science
When I started getting in diy audio, especially in car diy audio. I was thinking why my powerful subwoofer cand give me a chest kick at all but those very cheap subs from sony, pioneers etc can??
I believe is because of mms! Even if the motor force is high, if the mms is over or at 200gr of a 12" driver, you can't feel the midbass! the cone will not accelerate fast enough because of inertia! A high bl force will reach a high speed cone but won't accelerate fast enough.
I come with this calculation (Bl÷mss) the = needs to be higher than 0.1 for midbass kick feel.(Don't ask me where i found this 😂) 20bl÷200mm=0.1 but even if the equal is 0.1, the mms is too high for a 12, this more calculates if the bl is high enough.
The mms needs to be under 200 for a 12" (150) above 200 for 15" and under 100 for 10" and so on.
If you look at the specs of pa drivers and those cheap *** subs, you can see exactly this(not all of them of course) makes sense.
Basically you need midbass mms with high enough vas to reach 30hz.
Mms is the king.
Reactions: Palmspar
Low cost, high performance headphone amp using OPA1656 and LMH6321
An ultra low distortion moderate power headphone amp was designed for use with a phono/line preamp project.
This is the stand alone amplifier board that was developed.
The goal was to provide an unbalanced headphone amp that would produce essentially unmeasurably low distortion at 2v RMS output, could drive headphones from 15-300 ohms, and would operate using the +/15v supply that was used in the preamp.
Specifications:
+/-15v - SMPS is fine. 0.6A per supply rating.
>90dB power supply rejection over the audio band.
Peak output drive current set at 270mA/channel
0.4W max into 15 ohms.
0.8W max into 30 ohms.
0.15W max into 300 ohms.
Stable into any load capacitance.
Output impedance <0.1ohms.
DC offset <2mV.
AC coupled input (0.47u PP cap, 220K ohm input resistance).
1.5Hz - 1MHz 3dB bandwidth.
Thermally protected.
Protected against shorts.
Fault LED indicating overheating condition.
PC board designed using TI guidelines to act as heatsink, and can accommodate 15ohm and higher loads without shutdown at rated power levels.
Stable into any capacitive load.
6dB gain.
10k volume pot can be added.
TH Distortion plus noise @1kHz, 2v RMS output 80kHz measurement bandwidth: <-114dBc (0.0002%) A weighted. Limited by measurement system.
Not appreciably different at 20kHz, not appreciably different for 30-300 ohm loads.
Basically a realization of the TI app note with simulated/evaluated compensation.
Need some help with a Technics A900s
hi.
i have received my second Technics se-a900s, i bought this one defective, the problem is that it is in protect. i had a hope that it could be bad solder points... so i started troubleshooting yesterday and found many bad solder joints... soldered these but nothing happened, so i went ahead and measured some volts on svi 3205, and on pin 3 i found the fault.. 53.2v..so the left channel is defective.. i have an a800s that looks like it has been through a meat grinder so i am thinking of taking the svi 3205 from this one, but i don't want to put it in without knowing what caused the svi3205 to fail. so what is the next step? are there any other components that could have been damaged?
LED Pilot Light - Wiring Confusion
I want to replace the LED pilot light in one of my guitar amps. The power source in the amp is the 6.3VAC tap on the power transformer. The published specs for the LED I want to use are:
  • operating range 5-14VDC
  • voltage drop 2.8V (typical)
  • @ 20mA
I have seen two different ways to connect this. One has the anode of a IN4002 diode connected to the negative lead of the LED and the resistor of appropriate value connected in line on the positive lead. The other way shows the diode connected across the pos and neg leads of the LED, with the resistor inline on the positive lead.
Advice please.
Fountek repair kits
Hello all of you, audio lovers
HNY and so on
I heve a lot of repair kits for Fountek ribbon tweeters. All of models. I'll be able to send it to worldwide, Video of use process see there
Login to view embedded media By the way - this is my audio youtube channel
ISOBARIC sealed enclosure... Any experiences? Any advantages?
ISOBARIC sealed enclosure... Any experiences ? Any advantages ?
In a project of a quite large 4-ways sealed enclosure, I wonder if going for the isobaric principle for the woofer setion would offer advantages... 🤔
The goal is not to reduce volume, but improve bass extension in frequency response, transient and step response, distortion, by using a tandem of speakers, like this - but larger about the back volume
According to many expert authors, combining two identical speakers in that way offers an equivalence of :
  • Z / 2 (connected in //)
  • VAS / 2
  • QTS unchanged
  • FS unchanged
If the enclosure volume remains the same (the common chamber is not counted) for one sealed speaker, or two isobaric speakers, as a consequence the result is a lowering of the QTC, so a better transient, earlier bass cutoff start but smoother and longer slope, potentially giving a better bass extrension.
Any advice or experience in that field ?
Thank you Guys !
T
Sansui output transformers
Hi everybody, I have a pair of Sansui radios, a SAX100 and a SM12A, both rather obscure but very interesting probably not only because they are single ended 6BQ5 amps. Not much difference between the two, the SAX has a transistor phono input, the other one has a simpler power supply but two AM tuners for early stereo simulcast and a dual magic eye.
Now the problem is that I have found some differences in the output transformers. I was measuring them without much care for the values, just to check they are the same in each radio and found they were not.
The SAX has one transformer with about 240 Ohm DC resistance primary (and about 7H inductance) and the other transformer has about 200KOhm DC resistance and doesn't give an inductance reading (Peak LCR meter) - I get some negative value with a question mark. Secondaries check out, they are all the same, and make sense.
The 12A exhibits the same ailment. One of the outputs has near identical parameters with the first one above (approx 240Ohm DC resistance and 7H primary) whereas the other one has 500KOhm primary DC resistance and reads gibberish for inductance. Secondaries of both replicate almost to the decimal the values of the other two.
What gives?!
Are the two trannies with high DC resistance cooked? Or is the LCR meter out of its depth?
A little bit of investigation revealed the transformers used in these radios are the same part so they should be swappable (my intention for the moment). Externally they look identical, and after a little bit of cleaning I found under the grime the same labels on the transformers (all also have "5.2K" written on the primary side plus terminal labels).
My gut feeling sez the two transformers with "normal" parameters are still good and I plan to use them to restore the 12A (the SAX is worse for wear), but I would like to know if I can recover the other two. Are they dead? I mean do they need a rewind? Not going to throw them away, but would be good to know.
Would be interesting to know how they managed to go high resistance, because I thought they would either go open or short. Not sure how a wire can increase its resistance. There are signs of heat stress, the outputs are right between the trannies, the wax has obviously run out of the coils somewhat and pooled under the casings.
Any comments would be appreciated.
Want more control POTs on ADAU1701?
Hello Folks,
I sometimes feel frustrated by the small number of controls on my FreeDSP Classic SMD A/B. ADAU1701 has only four AUXADC for reading control POTs. Well, the ADAU1452/1466 has six AUXADCs. However, in many cases, ADAU1701 is enough for processing. But the control is not enough...
So I start a small project for expanding AUXADC on ADAU1701. The basic idea is to use an external MUX circuit driven by feeding the POT selection signal from the DSP. Unselected POT keeps holding a last-moment value during the opposite POT reading.
The AUXADC multiplexer circuit:
Multiplexer Circuit Switching Test Result
SigmaStudioPrototyping
DAC Output
It seems possible to implement AUXADC multiplexing. So I will start the board design...
CyberPIt
Reactions: xa488
Psychoacoustic considerations for my OB project
After having settled for the drivers and the basic construction (H-baffle with 2 Peerless SLS-10, naked TB-1320 and Neo3), I am now considering what should into go into the equalization and positioning of my first OB speakers.
Especially two points got my attention:
First, the approach of Dr. Geddes (p. 7 and 9) et al. to broaden the stereo sweet spot by compensating the distance induced SPL loss from the far speaker by an angle induced SPL loss from the near speaker; second, SL´s recent Orion voicing modifications that supposedly improve imaging and perceived tonal balance and that he traces back to our hearing sensibility varying with frequency and listening angle.
As to the first point:
It is usually said that SPL drops with 6dB per double distance. This drop could be accomodated by positioning the speakers so that the distance from the far speaker is twice that from the near speaker, while the listening angle of the near speaker is 60°, which also produces a 6dB drop in SPL due to dipole directivity. This should roughly give equal SPL from both speakers across a wide sweet spot (while, of course, it doesn´t account for timing differences).
In Floyd Toole´s "Sound reproduction", though, I found a compilation of in-room-measurements of omnidirectional sources as well as of speakers with different directivity characteristics that strongly suggest an SPL drop of 3dB per double distance (fig. 4.13, p. 60). I guess this is due to diffuse or reverberant sound contributing to the measured SPL.
So my questions here are: Do you think my outlined approach is gerenally valid? And if so, which of the numbers for SPL loss should be the starting point?
As to the second point: SL argues that in higher frequency ranges we are more sensitive to sound coming from angles around 30° than to sound coming from the front, making harmonics and overtones sound too bright compared to their fundamentals, which in turn not only leads to a perceivedly unbalanced sound but also to compromised imaging because our brain gets incoherent clues for soundstage reconstruction. (Or at least this is what I understood so far.)
My question here ist this: I found plenty of research on the topic of hearing sensitivity varying with listening angle, still SL seems to be the first to draw these conclusions concerning stereo imaging. So I´m asking myself if his reasoning here ist correct, or if the perceived imbalance of the "old" Orion is really due to dipole blooming in the relevant frequency regions that leads to imbalances in total radiated sound power which in turn could be responsible for the noted effects. What do you think?
Thanks in advance for your feedback & input!
DIY Phase plugs for speaker drivers?
Hi, I'm playing with diy phase plugs for small speakers, I was wondering what will they do on very small speakers like 2 inch .
modifying a pair of 2 inch speakers from dust cap to " phase plug " improve the high end ? for such a small cone removing the dust cap that ( I think acts as a cone as well ) will reduce the size of the cone -> reducing the speaker's sensibility ?.
I did this on 3 inch full range drivers, it improved the mid-highs , highs and made it sound better, significantly. ( bass would be a problem because some air will escape the voice coil gap. Tho there is a spider and no magnet vent.
It can be made out of wood pretty easily, I made them from this hard foam rod,
Ignore the shitty encolsure , I had time to waste with this and a passive radiator , sounds better than it looks 🙂 .
- Bruno.
Audison LRX1.2K Overload protection circuit fault finding
Hi all! Before I strip this down and get too deep into diagnosing, I wanted to check here first for any potential insight or "common issues" on what this amp is doing. It is an LRX 1.2K with no previous repairs, visibly fantastic board condition with no signs of vibration damage, condensation residue, etc.
It powers up, SMPS PWM good, class D switching good, idle current at 12v is 5.8A. Seems high but i'm not sure what is normal for these. Most of that is output section. Nothing getting worryingly hot on the thermal imager.
  • The main relays engage, but there is no audio output, and the Overload orange LED is lit solidly. From the manual I gauge that audio is muted during this protection mode, and the amp should self-reset and unmute, which it does not. The muting appears to happen on the detachable preamp board as I have no sine wave at any of the header pins to the main board. There is no load attached to the amp at all. This fault is the same whether or not any RCAs are connected.
  • With the class D driver card removed (DLD.1) the amp hard-protects with all the LEDs illuminated.
  • With the auxiliary supply board removed the amp stays on, 1.3A draw, but of course no class D switching. The orange Overload led is not lit, so I can almost rule out the CPU.1 board being an issue i think.
  • With the CPU.1 board removed obviously nothing happens other than the main relays engaging. Green light is on, orange OL light is not.
I suspect there is an issue with either the DLD.1 board (as I believe the overcurrent sensing may happen here) or the preamp board. There was a previous thread I saw which mentioned the top-left JFET marked GK on the DLD.1 had something to do with overload muting, I did remove it and powered up but there is no change in behaviour. I also changed the TL072C beside it as a stab in the dark, no change. There are no dead-short semiconductor parts or caps on the board and it all looks visibly good.
Although this is what the amp is currently doing, I want to mention that when i powered it up for the very first time, i DID in fact get audio output, and the overload LED was flashing which the manual suggests is "rare" overcurrent, seems to be more of an indicator as it does not mute output. While powered up initially, regardless of whether I had an RCA in or not, there would be slight "wobbling" voltage on the output terminal, a few mV of DC up and down with no obvious rhythm, and then amp would sporadically disengage the main relays with the orange OL led going solid, and then reset and re-engage the relays. Between this time of initial diagnosis and what the amp is doing now, no changes were made to the circuit and nothing was shorted by a probe, all I did was remove and reseat some of the daughter boards, and the change in behaviour kind of slowly progressed to this current state. In its current behaviour with the audio permanently muted and OL led solid, there is no mV bouncing around at the terminals, which suggests that was coming from the preamp board perhaps.
Any past experience you may have will be appreciated before I spend a lot of time on this! Thanks!
Arcam A22 Preamp Section
Hi all. Have an Arcam A22 with two separate problems, maybe three. First two result in protection fault problems.
When I disconnect the preamp from the main board, as stated, protection fault, unless I warm up Z9. Then the power amp runs fine. Connect the preamp, Either by internal switch or RCA cable, and fault returns. Running pre out to separate amp yields a low signal with no volume control. I can however hear clicking through the speakers when turning the volume control in either direction. Using RCA to connect pre to main gives immediate fault whether connecting right or left channel.
Thinking the most likely cause for preamp failure in both channels is the one ic common to both sides. + and -15v are getting into the board, but I haven't trace any further. Any other ideas?
So, as I said, seems like two different problems. Z9 all on its own, and the preamp board. Feel free to suggest something else.
Z9 seems to be a death sentence based on cost and availability. I'm crazy enough to consider grounding pin 9 to disable the fault circuit. Seems like I have a boat anchor if I don't. Any opinions here?
Oh yeah. That other problem. Left side, main speaker output. 9k resistance across output, any and all conditions. All three other speakers measure open circuit. No obvious audible problem.
Help me please!!!
Any benefits to mounting a tweeter above the cabinet?
Bowers & Wilkins mount their tweeter assembly above the cabinet - supposedly it's more acoustically decoupled and cleaner in its solid enclosure. See pic below.
Are there any benefits to mounting a tweeter above the cabinet in a similar way, like in a heavy aluminium tube? The main cabinet for a 2-way could have the mid-bass mounted right at the top so as to be as close to the tweeter as possible.
One benefit would be that you could easily swap tweeters when experimenting.
Parasound P3 adjustment trim pots do what ??
Hi Guys n Gals.
Friend has a late model P3 pre.
He's wondering what and how the trimpots TVR1 TVR2 TVR3 TVR4 should be adjusted.
His balance is of to one side.
Thanks.
PS it seems Parasound have been bought out, When did that happen, and who owns them now ??
Cardioid and Sealed cabinet ala John Kreskovsky
Cardioid OR Monopole (sub)woofer cabinets à la John Kreskovsky
Has anyone completed a woofer system with multiple woofers in dual opposed sealed configuration, but instead utilizing DSP and selectable settings to transform in between sealed and cardioid-like behavior, when preferred?
Reference:
U-frame DIY
NaO U-frame
Gradient woofeer equalization
Newby question: Hybrid bridge rectifier
I hope I drew these schematics correctly and its not a stupid question. Which configuration makes the "best" hybrid bridge rectifier, A, B or C? I have a "hunch" of which I like best, but no science behind it. I found schematics in my stash to be varying.
A: NEG (diode/diode) - POS (tube/tube)
B: NEG (tube/tube) - POS (diode/diode)
C: NEG(tube/diode) - POS (tube/diode)
Kenwood KR-5340 bias
So the service manual for the quad KR-5340 recommends breaking the B- connection and inserting an ammeter to set the bias by measuring the current. I'm wondering what the value would be per each pair of outputs (two pair per channel because it's a quad) when measuring across one of the emitter resistors. Each emitter resistor is 0.47 ohms. So am I looking for 14.1mV and 18.8mV when adjusting VRe1 and VRe2 respectively? Or half that because I'm only measuring across one resistor, i.e. 9.4mV and 7mV?
Experience with FedEx?
I'm fed up with Fed Ex.
I have a package from Madisound... they shipped it FedEx... it was supposed to be here tomorrow or the day after ( 11/13 or 11/24).
Instead, "Surprise!" FedEx announced it was coming early, on Sunday 11/12. It "will be here from 7:30AM to 10:30AM".
No! no! So, I tried to get them to delay it... but after half an hour trying to get with them I gave.
See... it's my wife's Big Birthday this weekend, We got family here for the whole weekend, events planned. So, I accommodated the pendejos at FedEx. We will go out to dinner on Sunday and do brunch at home. At the last minute my wife told me that we should do dinner at home on Sunday instead ( we were gone all day Saturday ).
At 8 AM, package out for delivery, Delivery scheduled before 1o:30 AM.
Sure enough.. on Sunday at 10:30, no package. Still out for delivery.
At 11:00 AM, delivery changed from 10:30 AM TO 1:30 PM.
At 2 PM no package, delivery changed to End Of Day. Still out for delivery.
Now, this is a Big Birthday and FedEx is a bunch of incompetent nincompoops, do they think they own the market?
Anyhow, we're home, it's now 3PM and still no package.
Tomorrow I'm gonna call Madisound and tell them I will NOT deal with them if they insist on using FedEx.
I get lots of packages... Amazon Logistics is by far the best.... then USPS and UPS. DHL comes through, Costco and Fed Ex are by far the worst.
I am so pissed... being forced to stay home for a lousy $200 package because Madisound shipped it "signature required"... with FedEx.
WTF are they thinking?
Do you have the same issues with FedEx?
Marantz Model 9 - Restoration resistor choice
I am recapping a Marantz Model 9. While I was in there I noticed some of carbon composition resistors have drifted over the years. Are there any resistors that must stay carbon composition for best performance? And any positions that would benefit from a specific type like wire wound? I plan on using thin/thick film resistors as long as they have the correct voltage rating and low ppm.
http://zilla.li/Resources/PDF/Marantz_8B_9/Marantz_9_Service_Manual.pdf
Thanks!
Square wave overshoot
Hi there,
I am playing with the amplifier circuit below in LTspice.
It seems quite stable when looking at gain/phase margins. However, when I feed it a square pulse, the result is this:
I don't really know how to interpret this, is it bad? if so, what could be done about it?
Looking forward to your comments, also in general about this circuit.
Designing and building external speakers for 8002D Bluetooth speaker unit
My experiments with speakers and amplifiers located in the subterranean layer of the Hi - Fi world continues. Subterranean in terms of cost.
Here is my latest project, which is proceeding nicely: When the TEA 2025 amplifier stopped working properly, I hit upon the idea of connecting an inexpensive speakers to my existing Whafedale Diamond IV speakers. The results were surprising, while bass was totally lacking, it could be boosted using the music player (Musicolet) equalizer for acceptable levels of musical enjoyment.
I am in the process of building a set of speakers specifically for this little Bluetooth amplifier, with some success. I am getting 70 dB at 1 metre with these connected to large vintage floor standers of 89 dB sensitivity.
I had a few questions though.
Resistor inline vs series notch for tweeter. Sound quality and protection?
Tried idea on VituixCAD to use series notch filter on tweeter for pretty high frequency ~11.5-12.5kHz, Q of ~0.8 to ~1.4. All the frequencies and Q between kinda work and give good results on perceived sound quality, graphs are better too. With that notch filter I can get away only with capacitors in the path between tweeter and amp, no resistors are needed, no additional L-pad. Sensitivity looks more or less the same with "side" filter vs inline resistor. Graphs differ, but nothing out of the ordinary.
Tweeter is dome fabric, 25mm, crossover freq is ~2.4kHz, tweeter Fs is 1500Hz, 8Ohm. The setup that interests me is 3rd order + notch explained above,
In the animated gif there are 3 examples:
"R1" 3rd order and resistor in front - 1 side bypass route
"R2" 4th order and resistor in front - 2 side bypass routes
"R5" 3rd order and series notch after - 2 side bypass routes
The questions are:
1. What is the extra purpose of resistor in line with tweeter except for reducing the sensitivity: General improved sound quality - can it be measured or/and heard? Filtering of some unwanted hissing? Some protection vs amp clipping or some artefacts coming from source such as accidentally disconnected wire, power loss and so on?
2. If it is recommended to do this - can I get away with some "dummy" of 0.1-0.5 Ohm or more is needed?
All 3 variants attached, but the first two are just similar xover, with 3rd or 4th order crossover.
Why the dip at ~550Hz (nearfield)
This is my first attempt at speaker design from scratch (repurposing old BOSE acoustimass drivers). Bringing them together in a TMT arrangement with the satellite FR drivers. Attached is the box design. Attached also are some 1'/15ms gated measurements using a umm-6. Before and after felting the inside (Felt from a vintage westinghouse cabinet). I am seeing some sort of interference at just about 550Hz that the felting did not take care of.
What sort of obvious thing am i missing? (other than that these drivers are way outside of their intended usage?
FS:Yes It Can Drive an F4 (fully built and full kit)
Too many builds and too little time! I have for sale one of MJ’s “Yes It Can Drive an F4” full kits (which is enough to build 2 channels) as organized by our wonderful colleague birdbox as well as two fully built/populated and tested boards. They work wonderfully. For the kits, I have taken the time to provide matched N channel pairs for the differential input stage saving you time.
Each board is for a single channel.
$OLD including shipping in USA for the kit. The kit contains 1 white board and 1 red board and all parts including the appropriate matched transistors.
$OLD including shipping in the USA for the fully built/tested boards, ready to plug and play. Each board has been cleansed of all flux residue.
Paypal preferred.
Best,
Anand.
Jmlab SW-33A repair
Hi all!
Searched for some time, hope this is no dupe!
Got this Jmlab sw-33a (12" focal sw) that needs alot of love!
One transistor blown (visualy), 1 15000uf cap vented and possibly more!
I have not been able to find any schematic or specs on sw element such as impedence, it measuers 6.7ohms and is a real pain to drive as my only amp around tripps when i raise vol, so i wounder is it really this heavy to drive, or is it busted? it is a impressive peice of element, so would not be supprised if it is heavy to drive.
The amp has been tempered with, previous owner probably done a cooling paste replacement and overlooked the plastic washers between heatsink and transistors causing a shortout trough the heatsink, leaving one transistor visualy blown and vented one of the big caps (elna lp5 15000uf/63v).
Starting out like this, pictures of the thing will popup as i work with it.
Denon AVR-5800
I have a Denon AVR-5800 that stopped working several years ago. I took it to a Denon authorized service center who said a digital board went bad and that since the board was no longer made by Denon they could not repair it. For a while I had in my mind the thought of using the preamp inputs and bypassing other components inside to make it into an amplifier. I even posted here about it and got some useful advice: https://www.diyaudio.com/community/threads/using-amp-in-receiver.342695/
Unfortunately I never got around to it so it has been sitting in its box for several years.
As far as I know all the amplifier components are fine. The thing is a beast. It weighs about 50 pounds, was rated as 170 watts/channel, and has a massive toroidal transformer. It seems like a terrible waste to send it to the recycle bin and I am hoping someone here could use it. I can see someone using the transformer in an amp they are building or using both the transformer and amplifier boards to make an amp. Somebody with the right skills might even be able to repair the digital board that failed.
So, I'd like to sell it to someone for any reasonable offer. I am located in the Houston area and it is probably too heavy to ship economically so it needs to be someone local. Does anyone want it or have any ideas of what I can do other than recycle it?
hot solenoids on Teac A-4010s.
I just purchased a Teac A-4010s that was made in 1970. I am in the prosses of going through it and doing what I can to fix some of the issues it has. I am not an experienced tech but I can do simple work. It seems that the two solenoids are running hot. I don't know what too hot is for these units but the front panel get hot to the touch. I can get to the leads on the one and measured 83 vdc across it. I can't find anywhere that list what that voltage should be. I appreciate any help I can get.
For Sale TDA1540 DAC full set
Selling all parts to build a high end TDA1540 DAC, selling due to having too much projects going on!
All boards have been tested and DAC is confirmed working, you just have to wire everything up and build it into the case!
Set contains:
Miro TDA1540 DAC board: PSU decoupling caps changed to Elna Silmic II, opamp sockets have not been populated.
Altera CPLD I2s converter: converts I2s to offset binary, flashed with Miro's firmware and including USB blaster
SPDIF/Toslink receiver board, with Cirrus Logic WM8805 receiver chip
2x CEN FC IV boards: great IV converters, with matched FETs, Audio Note Kaisei capacitors and Rhopoint IV resistors, tested and DC offset in the 0+-3mv region
5x Salas UltraBIB shunt regulator supplies: 3x pos and 2x neg
2x SilentSwitcher 2024 model: -15 0 +15V supplies
2x R-core transformers: with all the necessary taps, including 115V and 230V primaries
1x Hifi2000 3U case, with 10mm thick front panel: new and unused including IEC socket and illuminated power switch
Will add 2x TDA1540 additional DAC chips and unpopulated CEN filter boards
This needs to go to a good home, so asking 500€ for everything, will ship worldwide
Ask if you need some different digital input options, have some XMOS USB boards or Rpi with FifopPi Q7
BF862 based SE Class A Headamp without the HEAT
I was looking for a small portable amp for my DT880-250 headphones. I wanted class A and I wanted longer battery life and low rejected heat. These sound like requirements that are at odds with each other right?
This project started in another thread and is based on the BF862 JFET single ended White follower design suggested by EUVL here. The design has a fairly low bias current of about 50mA, but because it used qnty 8 x BF862 JFETs on the output stage in a singel-ended arrangement with about 12mA in each device, the overall heat dissipation is very low but it is guaranteed to work in pure class A (it has to because of the topology). This amp is very simple to make following this schematic:
I did my layout using a drawing program (MS PowerPoint in this case) and came up with this:
I then made iron on transfers using laser printer and got this on the copper as the etch mask:
Etched in HCl and peroxide (hardware store muriatic acid concrete sidewalk cleaner and hydrogen peroxide (3%) for 20 minutes:
Etched board looks like this:
Soldered it up (I had to switch 1R source resistors for 33R to keep my bias current low, it was pegged at 23mA ea wit 1R):
I had some difficulty getting it to make sound at first and found out that the problem was a bad 6in length of wire from the output terminal to the headphone jack. Took hours to figure that one out after debugging the board components.
Initial tests were done at 12v supply and I boosted that up to 17v to get a little more headroom and keep heat down still. I am using a small DC to DC boost converter (400kHz switcher) and added 2200uF cap to filter it some more. Ripple is about 9mV at 17v but luckily the amp has some decent PSRR and output measures 0.3mV with inputs shorted. It is silent to my ears anyhow. Absolutely no hum or hiss. Cannot tell it is on.
I spend half a day listening and decided it was worthy to be boxed. So using this niftly enclosure. After drilling some holes and adding a 50k stereo pot, and power jack, switch, LED indicator, 3.5mm jacks IN and OUT, the amp is completed:
586398d1482011463-bf862-based-se-class-headamp-without-heat-bf862-ha-build-boxed-10g.jpg
Here is the (messy) inside. I am not one to have neat wiring harnesses as my time is very limited to work on it. The wires work fine and do not seem to pickup noises. All wires are at least twisted:
586399d1482011463-bf862-based-se-class-headamp-without-heat-bf862-ha-build-boxed-internal-11.jpg
Edit: I added a cap multiplier using IRF540 MOSFET with 10mF output ca[ and circuit from Juma's Easy Peasy Cap Mx thread:
586803d1482215824-bf862-based-se-class-headamp-without-heat-bf862-ha-build-boxed-internal-cap-mx-12.jpg
Here is the amp next to DT880's that I will be using them with. I am using a 2200uF 16v electrolytic cap for C2 bypassed with 1uF 230v MKT. I initially used 330uF OSCON but found the bass lacking. With the 2200uF I can hear deep deep bass now. There is a 270R 2W load resistor, so when I plug in the 250R DT880's, overall impedance is about 125R - which I think may help to draw more current out of the amp so it gets more impact with the bass (seems so subjectively).
586400d1482011463-bf862-based-se-class-headamp-without-heat-bf862-ha-build-final-dt880-12.jpg
So in addition to sounding extremely detailed, neutral, and having excellent bass authority, they are absolutely cool. The case is ambient temperature after hours of playing. Also, since I am using a XL6009 switch mode step up regulator, the power supply input is very flexible. For desktop use I have a 12v 3A SMPS wall wart from my external disk drive. For portable use, I will use a 5v USB phone charger battery pack and let the step up take care of getting the 17v rail. I estimate a 10,000mA Li-ion battery pack will last more than 12 hours. That's a lot of pure class A play time for a small battery.
This amp sounds wonderful and I thank EUVL for a great design. It has indeed been tested and works very well. Give it a shot.
Edit: Dec. 22, 2016 - an attempt at a smaller 37mm x 26mm layout to fit in an Altoids tin with two 9v batteries.
Edit: Jan 6, 2017 - portable battery operation using 5v USB charging battery pack. 10,000mAhr cell should last about 15 hrs.
590340d1483735403-bf862-based-se-class-headamp-without-heat-bf862-se-ha-portable-demo-v2.jpg
Sound is still great - using XL6009 DC to DC step up internally for 18v supply to amp (after cap Mx).
Edit: Jan 7, 2017 - Here is a new portable 2 FET design that sounds great - very easy to make. We will have a GB soon so stay tuned!
Schematic and THD prediction:
591187d1483977924-bf862-based-se-class-headamp-without-heat-pocket-class-bf862-zvn5306-ha-v1.png
FFT HD profile (sweet H2 and not much else!):
591189d1483977924-bf862-based-se-class-headamp-without-heat-pocket-class-bf862-zvn5306-ha-v1-fft-1khz.png
Implementation as portable mint tin pocket Class A amp a la CMOY:
591117d1483961316-mosfet-source-follower-headamp-pocket-bf862-zvn4306-ha-smt-tin-case-dtr880.jpg
Internals of above amp:
591116d1483961316-mosfet-source-follower-headamp-pocket-bf862-zvn4306-ha-smt-tin-case.jpg
590981d1483910917-bf862-based-se-class-headamp-without-heat-pocket-bf862-zvn4306-ha-top-side.-caps-mods.jpg
590982d1483910917-bf862-based-se-class-headamp-without-heat-pocket-bf862-zvn4306-ha-smt-side-mods.jpg
Help on single ended 211 question
A very impulsive question 🙂from a layman.
I have a 211 single ended amplifier with a very simple transformer coupled signal circuit as attached that I am rebuilding with replacement capacitors, as it's 30 years old etc.
I also have a small valve output DAC and I have just found a fabulous sounding valve: Sylvania GB5670 that I am using in the DAC output stage.
The thought occurred to me that I might replace the 6c45 driver valve with a 5670 running both triodes in parallel instead (1 per channel). I can easily change the Plate voltage as it comes from a 500V supply taken down with a 10K series resistor.
Is this a crazy silly idea for a 211 driver valve or is it something to genuinely think about?
Appreciate your input/thoughts
Thanks!
Rich
Masonry casting artist; Suggestions for full range driver
I love doing sculptural art and have made a lot of other stuff but Im up to a floor standing speaker
I would like to use a full range decent driver.
Im a fan of punchy sealed bass and cabinet can be up to about 50l
I have heard a lot of PR enclosures that have actually sounded quite good but I dont have the same design limitation as box builders ...its just the group delay can be a bit disconcerting for bottom end.
Am wanting to only have a single driver visible and any bass porting/manifolds/pr will be constructed internally and vent as a downfiring output but the PR or whatever can be vertically mounted into a manifold as well
Considering these parameters; are there any recommendations. I mentioned PR because I saw Hexibase get pretty decent sub out of small drivers that was quite impressive
I have quite a number of ideas but will prob start off with this which is a stylized tusk and stands about 1.5m high to be a balance with the driver receiver being about 200mm
I use a proprietary sustainable masonry material called wood stone(TM) which can easily stop a 50 cal @200mm thick so its a very energy absorbing material and is quite tensile. About 0.6 the weight of concrete.
Ive done translation monitors which were at NAMM (all hand made so Im only a boutique artist kind of guy) so this gives an idea of the material applied
Any help would be amazing
For Sale X-Altra MC/MM Phono EQ Amplifier
I built 2 of these, but my plans changed and they are no longer needed.
$250 USD Each
FS: Iron Pre Balanced kit (2023)
Hi folks! Great partial kit, but unfortunately, I don’t have much time for all my diy building endeavors.
This is the balanced version of the 2023 Iron Pre kit including the JFET transistors. The kit is unbuilt and only opened for inspection. Brand new.
Pics below:
I’ll need to revisit this design in the future most definitely. But for now, I’m going to let it go!
$OLD! inclusive of shipping in the USA. PayPal preferred.
Best,
Anand.
New here from Georgia, USA
Hello everyone!
I have been building amps (guitar and hifi - both tube and solid state), preamps, guitar pedals, midi controllers, and etc. for many years. Mostly not from kits, but some of those too. Have designed some of my own stuff but have only built a couple of things from those designs (primarily unique compression and EQ control). I also build guitars, DMX light controllers, and nearly anything related to music except speakers (although have built cabinets).
Started looking into DIY DSP effects/devices, but honestly am intimidated. ;-) I can program in C++ for Arduino just fine but seems like a whole other level with DSP stuff!
Would love to learn about adaptive EQ, DIY modeling amps/pre-amps (from scratch, not kits) and other more complex audio devices.
Glad I found this place!
P88 preamplifier - moving volume pot
Hello,
For anyone that is familiar with Rod Eliott's P88 preamplifier, I have a question. Is there a problem if I move the volume pot from between the stages to the input directly. I do this because I want to recreate the tone + loudness circuit of a vintage Sony preamp that I love, and that uses a passive Tone module at the input signal. Would there be any disadvantage to moving the volume pot to the input. Thanks !
Ideas for a Two-Way Bookshelf Speaker Build Using Dynaudio Chassis
Hello, I’d like to start my first DIY speaker project. I have two Dynaudio D28AF (8 Ohm) and two Dynaudio 17W75XL (4 Ohm) drivers and would like to design and build a bookshelf speaker with them. It would be great if someone could share ideas for the enclosure and crossover, or perhaps point me to a Dynaudio design plan for these drivers and provide the schematics.
MEH 2-way - Tuned rear wave port feasibility?
Has anyone been able to get a tuned port to work with success in a 2way MEH? I know danley uses them on his 3 way units, but then at the same time Iv been seeing folks on this forum not to happy with ports performance in their designs.
To be clear im not talking about the entry ports for the drivers but using the back phase of the speaker like a a hemholtz resonator to get extra low end, but with without the tube.
Seems like a waste to not use that energy.
What am I missing?
The VeraFi Audio A40 Amp
I have been talking a little bit about this amp on the What’s On the Bench Tonight thread, but thought it’s time to give it its own proper thread. It started as a 25W Class A amp, and now has progressed to 40W - mandatory Class A operation since the topology is SE Class A with a an active push-pull CCS based on the Aksa Lender P-Chan Complementary Aleph (ALPHA Nirvana) output stage developed by Hugh Dean and used here under license to Aspen Amplifiers PLC, Melbourne. The layout is by JPS64 which means this is a state of the art amp in terms of layout symmetry, low impedance traces, thousands of sticking vias, and careful attention to minimizing ground loops and noise immunity.
Some of the notable features that this amp will have includes:
  • Dual Monoblock design with independent power transformers and amp boards
  • Solid State Relays (SSR) for speaker DC protection similar to the RTR SSR designed by jhofland
  • SSR Soft Start with soft mains On/Standby button in front panel similar to the SFP designed by jhofland
  • Custom All-CNC milled and satin bead blasted hard anodized aluminum chassis with thick 5mm walls and massive 40mm heatsink plates. The chassis is a massive amount of aluminum on the order of 25 to 27lbs. Chassis look, shape, HMI and layout is all my own design and the 3D modeling and CAD is by Darko M.
  • Dual analog meters for output power with backlight
  • Premium Viborg copper binding posts
  • Premium gold plated RCA jacks
  • Front panel Mute switch via SSR enable
  • Automatic over temperature safety shutdown with dual thermostatic switches that activate the SSR
  • Maximum output power of 40W into 8ohms and the wonderful ALPHA Nirvana 2nd harmonic dominant distortion profile with relatively low THD of circa 0.005% THD at 2.83Vrms into 8ohms
  • Beautiful classic lines for an enduring timeless visual look
This will be offered through my XSA Labs website and we plan to offer a limited run of 25 first production units at an introductory price of $1599.
We are exploring anodizing color options for the handles and heatsinks. All black is still a major contender.
The internals will be laid out like this with the amp and its PSU mounted together on each heatsink. The floor of the amp will house the dual toroidal power trafos and also a main board let’s the SSR’s for the soft start, the main IEC soft On/Standby, and speaker SSR’s.
Here is a closeup of one channel of the amp and on-board CRC PSU on one PCB assembly. You can see the temperature sensor on the heatsink. Keantoken helped with the construction and assembly of the amp PCBA.
Initial testing of this amp indicates it sounds superb and the latest work is expand the chassis an extra 50mm deep to reduce heatsink temperatures and permit full 50W operation.
You can listen to it here:
Vanguard speakers
XSD speakers
Ibanez TSA15 head retubing and setting the correct bias
Dear Forum,
I have been asked to retube an Ibanez TSA15H tube head amp. Could someone help me how is it done correctly? I received the amp with a set of replacement tubes (2x 6V6 S and 2x ECC83 S)
I've read somewhere that it has fixed bias, so maybe nothing could be done except replacing the tubes.
Thank you for your help in advance!
How stable should DC anode voltages really be?
I test my anode voltages with a DMM set to DC and I see the voltage 'swing' from in my case 183v to 179 or so over maybe 10s or so on a slow fluctuation back and forth. Should this be like this or could it be indicative of a more fundamental fault. Other voltages in the amp don't move like this really.
Sorry if this is a dumb question?
Thanks,
A Digitally Programmable Graphic Eq
I've always wanted to make digitally programmable tube preamp like the Mesa Triaxis. As I gear up to do the high voltage parts of that project I decided to start at the back end and make a 5 band graphic eq that was programmable. The Triaxis cuts some corners and prewires the EQ to a popular curve, then the "dynamic voice" control sets the amount that is applied - I want a real 5 band.
Since the EQ is at line level I'm using AD5293 digital potentiometers. It's mostly surface mount and small parts so a it's little scary if you haven't done it before. Fortunately I've been slowly moving all my projects to more SMD and, frankly, I like it a bit better in some regards. The board works (mostly*) but I haven't set up a good control scheme so the pot shown below is either adjusting one band or the whole "voice" depending on what parts of the code I activate. Most importantly it's pretty transparent and when set "flat" it sounds the same as my normal guitar tone. This proof of concept opens the door to digitally controllable tone stacks and maybe even front-end drive circuits if the gain doesn't cause digital noise to leak in.
* "mostly" because I implemented the zero cross circuit in the data sheet for the AD5293; one of the components in the sub circuit was damaged by heat I think and was clamping the 5v rail to .9v. So I had to rip out the sub circuit and bypass it. Perhaps you can see the 30awg jumper wire. Regardless, the popping from updates to the pots is only noticeable in some circumstances but I'm going to replace the bits and see if I can get it working.
FM 155 module 19202
Sono interessato ad acquistare un modulo 19202 per il mio preamplificatore FM Acoustics 155.
Per favore dimmi dove posso comprarlo?
Il modulo crackato andrebbe bene, ma non so dove trovarlo. Grazie.
:cop: Moderator edit.
I am interested in purchasing a 19202 module for my Acoustics 155 FM preamp.
Please tell me where I can buy it?
The cracked form would be fine, but I don't know where to find it. Thank you.
UNgo
DIY Speakon cable
First time trying to do this.
There are 2 and 4 pole Speakon connectors (even 8).
I will use this cable for my home audio. No bi-amping or bi-wiring. I read that 4 pole is for bi-amping. Does it also mean for bi-wiring?
Would not be future proof to get the 4 pole if in the future I want to bi-wire (not-bi amp) if I get bi-wireable speakers?
Will be using a pro amplifier hence the desire to build a speakon cable.
Art installation sound
I have a sound installation where I will put 24 speakers in a sculpture.
I have a question that might be very simple to all of you regarding power.. a help would be kind as it's not my field.
I will use some Dayton exciters 8ohm / 25W with an amp that is 2x50W @4ohm powered with 18V.
I did a test with 2 speakers and it works well.
But I need 10 speakers so I will use 5 of those little amps.
I will use also 6 x 3W/4ohm speakers with small 2x3W amps that are powered by 5V.
so that's 5 18V powerblacks and 3 5v powerblocks.
I thought I could reduce that and power things in serie.. I asked chat gpt and it said I need for the 18v amps a 40Amp powerblock 😛
First that scared me a little bit thinking it's a lot. But also there's no powerblock doing this.
So how do I calculate the current I need ? because the amp info only says "wide working voltage range of DC4.5-26 V."
I would say for one amp the process is this ? :
2x50 = 100W
P=UI
so I = 100/18 = 5.5A ?
is that right ? I feel 5.5A looks high but what do I know ?
thanks for your advice,
Sylvain
Zenductor
Hi
Is it possible to find out a little more about the Zenductor before the upcoming Burning Amp ?
Eric
Zenductor
(EDIT) @6L6 here, Eric has allowed me to put some links and such in this top post to make things easier to find. Thank you!!
Here is the post with Nelson's article - ZENDUCTOR ARTICLE
zenductor-jpg.1215963
Beautiful pair of amps built by Mike Rothatcher sitting on the optional chassis pans.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,906
Members
7,893,244
Messages
Filter
Forum Statistics
Threads
406,471
Messages
7,893,244
Members
507,906
Latest member
JoseCR
