Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Other Audio Things Audio items not directly related to RJM Audio projects.
Old
JLH-2005 headphone amplifier
Posted 18th May 2015 at 08:15 AM by rjm (RJM Audio Blog)
Updated 27th May 2015 at 01:52 AM by rjm
I was perusing this thread earlier today. Which led me to what I think is the original source, at least as a modern, relatively clean headphone amp version of the original original (by way of ESP).
Some comments from our own Nelson Pass are seemingly relevant.
AC coupled, and simplified to a single supply voltage, the circuit can be run at +5 V operation (USB, etc) with fairly decent performance.
The circuit is optimized for 16 ohm headphones.
Click image for larger version
Name:	JLH2005 LV 23.png
rjm's Avatar
rjm
Views 1510 Comments 1 rjm is offline
Old
A headphone amplifier gain calculator
Posted 2nd May 2015 at 05:30 AM by rjm (RJM Audio Blog)
Updated 2nd May 2015 at 05:33 AM by rjm
You input the headphone sensitivity and impedance, and it spits out what I think is the ideal amplifier gain.
Even if you disagree (personal preference, difference input levels, etc.), the difference will be consistent regardless of headphone as long as the specified parameters are correct.
The gain value setting is tailored to normal line level input and listening fairly loud with the volume control at 9~10 o'clock. The output series resistance is assumed to be zero ohms.
Adjust as desired, and note that 3~6 dB either way will still be a usable. If your amp has a large output series resistance the gain Av should be scaled up as,
(Routput + headphone Z)/(headphone Z)
Name:	gain calculator.png
rjm's Avatar
rjm
Views 828 Comments 0 rjm is offline
Old
Doin' a "Gilmore" : a discrete transistor headphone amplifier
Posted 10th March 2015 at 12:17 AM by rjm (RJM Audio Blog)
Updated 13th March 2015 at 10:42 PM by rjm
Recently I spent some time updating the diamond buffer of Sapphire headphone amp circuit. Later I stumbled on Kevin Gilmore's headphone amp circuit. Well, I'd read it before, but it had slipped my mind.
On seeing the Gilmore circuit again the thought process re. a Sapphire+Gilmore went something as follows,
"Toss out op amp, convert the Gilmore dual-LTP front end to bipolar, bolt the Sapphire3 buffer stage to the back, and substitute in the Sapphire3 current sources. Wrap in a mild feedback loop."
The result is shown attached. The Vbe multiplier is still a simple resistor (R33) ... that may need to be refined to add thermal throttling. The offset servo is not shown, but the action is shown as Vadj. Alternatively a trim pot would be placed between R30 and R32 to provide a small measure of offset adjustment. Most of the open loop gain is controlled by R14,R15 ... it seems to me that some work could still be done in that area. Despite going...
rjm's Avatar
rjm
Views 1151 Comments 0 rjm is offline
Old
Which is better, Sennheiser HD600 or AKG K702?
Posted 25th February 2015 at 01:24 PM by rjm (RJM Audio Blog)
Updated 26th February 2015 at 12:41 AM by rjm
The HD600s.
Ok, so why don’t you like the K702s?
I didn’t say I didn’t like them. Just that I think the HD600s are better.
It’s pretty simple really:
The K702s have a strident, hard upper-midrange "bump" that I find disagreeable. Yes, it makes tracks sound more “live”, but it’s also fatiguing and a bit clinical, and - as many others before have noted - makes the sound overall somewhat thin. In direct comparison the HD600s seem full the point of boominess, but I'm willing to accept that midbass plumpness for the Sennheiser's warmer, luxurious midrange. In imaging, the K702s trend to a wide, distant, airy soundstage while the HD600s run towards a closed in, intimate presentation. In that sense the K702 are more like listening to speakers, and I can certainly see people being attracted to that.
These are both top-shelf headphones at the top of their game, I don't mean to imply that the AKGs are bad. The two...
rjm's Avatar
rjm
Views 1297 Comments 1 rjm is offline
Old
Z-reg II improved simple Zener voltage regulator
Posted 22nd February 2015 at 02:24 AM by rjm (RJM Audio Blog)
Updated 28th February 2015 at 07:17 AM by rjm
I've added an additional RC filter stage (R3, C4 in the schematic below) before the Zener diode, substantially reducing the amount or ripple on the transistor base by cleaning up the voltage applied to the Zener reference. (The original Z-reg is described here.)
Circuit shows C2 with a value of 300 uF. Typically much larger values are used. I kept the filter capacitance to a minimum here to show circuit working with a reasonably high ripple (1 V p-p) on the input. The rectifier diodes used here are of no particular consequence, I just wanted the simulation to generate a realistic sawtooth for the input.
OK, this doesn't do as much as I originally thought. The improvement is mostly below 100 Hz, whereas the ripple is mostly in the 100Hz-1kHz band. There's perhaps 3 dB less output ripple, but that's about it. You can verify this yourself in LTSpice, just cut the wire between C4 and the junction or R1-R3 and rerun the sim.
rjm's Avatar
rjm
Views 1120 Comments 2 rjm is offline
Old
Gustard H10 Headphone Amplifier
Posted 14th February 2015 at 12:47 PM by rjm (RJM Audio Blog)
Updated 12th April 2015 at 02:59 AM by rjm
Technical Specifications:
Signal Input : 2x XLR female , balance
2x RCA, unbalanced
Maximum input level : +21 dBu, impedance 10kΩ
Input impedance : XLR: 10kΩ, RCA: 68kΩ
Input Sensitivity : +6 dBu
Main amplifier gain : +8 dB
Main amplifier gain adjustment range : -4 / +2 / +8 / +14 / +20 dB
Frequency response : 0-55kHz (-0.5dB)
Damping Factor :> 400 @ 50Ω
Dynamic range :> 128dB (A -weighted )
THD + N (1kHz 1W @ 100Ω): <0.00035%
THD + N (1kHz 0.5W @ 32Ω): <0.0007%
Crosstalk :-110db (1kHz)
Each channel has a BB OPA134PA - socketed - for voltage amplification and an eight transistor discrete buffer with 2 ea. 2SA1837. 2SC4793, C546B, C556B. Dual mono layout - more or less ... the circuit board itself is shared and not completely symmetric. There's a pair of NE5532s at back for balanced-unbalanced...
ID:	1577   Click image for larger version
ID:	1578   Click image for larger version
ID:	1579   Click image for larger version
rjm's Avatar
rjm
Views 8551 Comments 10 rjm is offline
Old
Headphone Sensitivity: AKG K702 vs. Sennheiser HD 600
Posted 7th February 2015 at 07:47 AM by rjm (RJM Audio Blog)
Updated 14th February 2015 at 10:13 AM by rjm
I recently obtained a pair of AKG K702 headphones to complement my long-standing reference Sennheiser HD 600s. I figured since I'm building headphone amplifiers it would be a good idea to have a reference grade low impedance model as well as the high impedance HD 600s to use for evaluation.
First though, a note on sensitivity:
K702: 62 ohms, 105 SPL/V
HD600: 300 ohms, 97 dB/mW
Different units. Grrr!
At the same volume position I quickly discovered the HD 600s play slightly louder than the K702s. The datasheet values predict the K702s should be about 3 dB louder, so it seems the sensitivity is off by as much as 6 dB.
In numbers,
K702: 62 ohms, 105 SPL/V ... 93 dB/mW from datasheet, 87~89 dB/mW (99~101 SPL/V) in practice.
HD 600: 300 ohms, 97 dB/mW ... 102 SPL/V.
The K702 requires as much as ten times more power to drive than the HD 600s. The voltage sensitivity is about 3 dB lower than...
rjm's Avatar
rjm
Views 1803 Comments 0 rjm is offline
Old
Refining the Open Loop Diamond Buffer Headphone Driver (RJM Audio Sapphire 3.0)
Posted 31st January 2015 at 01:28 PM by rjm (RJM Audio Blog)
Updated 18th March 2015 at 01:52 AM by rjm (add photo of finished amp)
A couple of years ago I built a standard op amp + diamond buffer headphone amplifier, called the Sapphire.
My original circuit (Sapphire 1.x) was the simple four transistor four resistor diamond buffer of the LH0002. Later small resistors (Sapphire 2.0) were added to the emitters of the driver transistors to boost the output bias current.
In this next go-round (Sapphire 3.0), I've replaced the emitter resistors with current sources. This provides a significant improvement in PSRR, over 20 dB in simulation. The output pair has been reinforced in a Sziklai configuration for lower distortion, and the primary output transistors five-way paralleled for improved thermal stability. The output impedance is 1~2 ohms, limited primarily by the output resistor.
It simulates to <-100 dB harmonics for 0 dB (1 V rms) output into 60 ohms. The total circuit standing current is less than 50 mA per channel.
LTSpice files below. R5,R6 on LTSpice...
Name:	Sapphire3 buffer.png
ID:	1589   Click image for larger version
ID:	1597   Click image for larger version
Name:	Sapphire 3.0f2 sch.png
rjm's Avatar
rjm
Views 2154 Comments 0 rjm is offline
Old
Portable headphone amplifiers
Posted 14th January 2015 at 07:07 AM by rjm (RJM Audio Blog)
Updated 13th February 2015 at 05:11 AM by rjm
The shift of the center of gravity of the high end from component, rack systems to portable continues. Exhibit A
I've also noticed that over the last couple of years the basic blueprint for a portable headphone amplifier as defined by the Sony PHA-1 has now been taken up by all of the major Japanese audio companies.
Sony PHA-1, PHA-2, PHA-3
Denon DA-10
Onkyo DAC-HA200 and TEAC HA-P50 (variants of the same basic unit)
JVC SU-AX7 (report) (seems to be mostly Kenwood DNA)
Audio Technica AT-PHA100
and Fostex hp-p1
For all the above you are looking at a battery powered, slim-cased DAC + headphone amp typically with some sort of guard around the controls. They all feature a good variety of analog and digital inputs, offer switchable gains, and are priced over a range from $200 to nearly $1000.
You are looking at the convenience of having the DAC built in, the small size, and the rechargeable lithium...
rjm's Avatar
rjm
Views 1162 Comments 9 rjm is offline
Old
Windows volume control settings in dB.
Posted 23rd August 2014 at 11:33 AM by rjm (RJM Audio Blog)
Updated 6th July 2016 at 12:34 AM by rjm
I suppose everyone has at one point or another adjusted the volume sliders in Windows. The ones that go from 0-100, and you are never quite sure what whether its a boost, or an attenuation, or what.
Some years ago I measured the outputs and inputs using a fixed amplitude .wav file created in audacity and played back through the Onkyo SE-200PCI. I've taken another look at the worksheet I made and I've noticed that the volume settings correspond to very logical, even steps, namely:
100 0 dB
90 -1 dB
80 -2 dB
70 -3 dB
60 -4.5 dB
50 -6 dB
40 -8 dB
30 -10 dB
20 -14 dB
10 -20 dB
or for the mathematically inclined: 20*log(volume/100)
This scale is the same for both the output master volume and the line input, so its probably maintained throughout the operating system.
So now you know.
** note added much later,
My new soundcard,...
rjm's Avatar
rjm
Views 1266 Comments 1 rjm is offline
Copyright ©1999-2017 diyAudio
