XSD Speaker Flatpack GB
Joined 2003
As promised, the packing is progressing nicely but is a lot of work. You can see how carefully the pieces are packed in foam and strapping and then a nice box and then strapped on the outside.
Folks should be receiving tracking numbers soon.
Yup. It looks just like that. Took a minute to get it pulled in the door. Box doesn't appear to have any damage whatsoever to it.
I guess first order of business is to fish out the bass section parts and decide where to glue and clamp it.
Russellc
Joined 2003
Un boxing, it took a hit somewhere, few things broken loose, all the L shaped corners were loose in box. But, because of all of the protective
padding inside, nothing was damaged. Looks like it must have been dropped on one end. Excellent packing job!
Russellc
Reactions: 1 user
Joined 2003
I have started. By the way, those inexpensive clamps you put a link to seem just fine.
Reactions: 1 user
Joined 2003
I have both bass units assembled. Have been sanding edges of all the parts, then filler, sand smooth.
I figure to attach the front panel next, I think that will be logical order, it will determine that faceplate is properly aligned, then base can be attached, clamped so it is perfectly perpendicular, not "tilted" in either direction.
More sealer and sanding, then prime and paint.
Russellc
Joined 2003
Ready to put wings on. Guide holes for screws on same side all 4 pieces, so wrong side for 2. No big deal, I just drilled a tiny hole all the way through. There is a slight bowing to the wings, so that if top and bottom are flat to the edge of face plate. The bow takes it a little beyond the edge. Careful placing of the long square piece will hold it even once wing is screwed to it
Bubba
Reactions: 1 user
Joined 2003
Are you going to leave screws exposed, or fill and sand?
The long square pieces that the wings screw to will require careful placement. Once I get it positioned at the top, I will put a screw through, then pivot the piece down a screw it as well, at least temporarily. Hopefully this effort will result in the wings edge fitting flush to edge of face plate, all the way down. This assumes the long square piece is straight and if not, I will have to find a method to attach it so it is.
Bubba
