Thanks again Zen Mod, my friend has measured them and it looks like all windings are the same and around 50 ohms or a bit less dc (he just has a primitive analog meter for car repairs).in general, with repeater coils (old name for 600:600 jobbies) it's irrelevant which one you use as secondary and which one as primary
further - if you see one side having more Rdc, that's secondary
if all windings are having same Rdc, irrelevant
sp
good
when you get it, if you have problems with pinout, just buzz for help
all you need is DVM and laptop/PC soundcard output - they're made for headphone load, so useful for noncritical test
and yes, either simple prog for sine generator or file of 400Hz-1Khz
Hi everybody
Is there anything wrong using autoformer for 6 ou 12dB gain with a salas DCB1 ?
Damien
Damien
Hello Damien,
6db is 2x voltage gain or 2x turns ratio, 12db is 4x voltage gain or 4x turns ratio.
The impedance ratio(your question if it works or not is related to this) is equal to its turns ratio squared this meaning that:
-for 6db your output impedance will be 2x2 x input impedance, so output impedance will be 4x input impedance
-for 12db your output impedance will be 4x4 x input impedance, so output impedance will be 16x input impedance
The dcb1 output impedance is ~120r.
With 6db trafo you will have ~480r output impedance and with a 12db trafo you will have ~1920r.
480r is ok but 2k is a bit high.
What is the input impedance of the next stage you wanna drive with the dcb1+autoformer ?
Thanks for this answer.
Next stage could be VFet P-channel, BA3, Pass AB100...depend of the mood...
@Abx74 if you have some spare time I do suggest reading this article https://www.psaudio.com/pauls-posts/output-impedance/
Now you know the output impedance you will get with with your 6db or 12db preamp and you also know the input impedance of those amps you mentioned above.
Read the article in the link and then check if your preamp-amp combo satisfies the condition mentioned in the article.
good praxis, always doubt in Mighty ZM's musings
22R isn't exactly standard value for pots, even if it is for resistors
so, just another Brainfart of MZM, nothing unusual, I did learn from The Best One
(don't tell anyone, but I did catch Pa melting 5 channel amp, according to Iq settings in Service Manual)
yup, 20R
yup, 20R
Mighty Zen,
I run dual mono with my amp, is there any advantage to choose dual mono with a preamp ?
Damien
Damien
always
in case of Iron Pre SE, there are cap multipliers for each channel rails
in case of Iron Pre Bal, fully dual mono, if there is dedicated mains xformer for each channel ...... or dedicated secondaries in case of using one mains xformer, common for bot channels
And what do you think about separated PSU ?
xformer/rectifier bridge/first cap in a box and another cap near the circuit in a second box...
I'm always following Monkey which is most successful in rattling my Cage
Feel free to do the same
(last time I checked Iron Pre , I had all rectification and filtering on board)
this is thread about Iron Pre, not that one
Yeah…just figured you building fancy smancy Iron Pumpkin with tranny in same case was a “goose and gander” example
Didn’t mean to create confusion 😁
yeah, but then, I'm using custom Donuts - having both Static and Magnetic shield
not wound for low flux, just normal proper
smaller Donut 10VA used for relays (and logic/TFT if used)
bigger Donut 20VA used for audio circuit, each channel having separate secondary, so practically dual mono
- What's wrong with the kiss, boy?
