buy any decent 2x100Klin (either Alps or lucky Alps clone or some of those AllIsInMyHead linked to) , shunt wiper to gnd with 33K metalfilm and you're there
OK, dumb again....what's with 33K metal film to ground? I should solder a 33k to wiper and take to ground? besides wire that is already there going to Iron pre board I suppose?
Two wipers, @ 24 hrs per wire, 48 hrs....😀
Russellc
On the subject of "more iron, more better", has anyone tried the IronPre
with an amp with an input transformer (say F6, M2, SissySIT, SIT3, etc)?
Dennis
I'm wrapping up M2X mono blocks and will be trying with Iron (and Waynes)... ZM already give some sort of green nod to Iron+Iron but I can't tell if it was jokester or not! Definitely gonna see for myself. ASAP. Will report back of course. I've been testing the M2Xs with the B1K and it sounds fab on some cheap not to sensitive test speakers I picked up... But I'm holding pronouncements until it's in the main system.
Pick me! 😀
Iron Pre with SissySIT is pretty fabulous, IMHO.
I've got it hooked up to M2 right now. Just moved it from Aleph J, where it is great I might say! Cant wait to complete Sissysit.
I can say that at first, very laid back. Almost subdued for lack of better term. As M2 heats up, better and better. Getting more transparent than at beginning. very nice effect.
As for Zen, he can speak for self, but....he is big on Iron pre/Iron Turtle. Add that to fav First Watt M2,
and I will bet he was not joking.
Russellc
Thanks for the comments! I've only tried the IronPre with an F4 so far (mostly
at 12dB gain) and think it's mighty fine. I guess this weekend I can try an amp
with gain. 🙂
with gain. 🙂
I've always used the ladder pots off ebay. I've wondered about the muse, but dont really know and havent heard one. I think zenmod has something similar/same in signature, blog or somewhere. But if he has been there and this autoformer has his eye, I'm figuring this is best way.
I see a balanced Iron Turtle in both of our futures is short story. But for now this thing is very good sounding to demonstrate principal that "more iron, more better.
Oh, and I wired the one channel to selector pot, see pic
Russellc
just tell me - what's that big black NTC being connected to?
I hope not to selector switch ...... I already see something burned and I'm not sure that I'll take care of that at least for 72 hrs .....
Russellc
old trick for re-dressing linear pot to better-than-factory-made-log
shown on few reputable sites around
point is that linear pots are usually having better tracking low down , so why not
The CL-60 goes to the small white terminal block, then to ground.
As to 33k resistor, here If I were going to impliment on these temporary pots, I would just solder 33k to wiper, along with wire already there and just take it to ground?
Maybe I should add it to volume pot with CL-60,
Hmmmmm.
Russellc
Hmmmmm.
Russellc
read this :Better Volume (and Balance) Controls ESP - A Better Volume Control
edit: correction of 33K value I did mention; that's what I'm using with one Black Beauty 250KLin ( in one of my small boxes), while for 100KLin I'm finding 18K as shunt most convenient
Dennis
general character of gadget itself counts, not what's inside
though, if you ask me , more Iron you have in entire chain, the better ; reason why I'm not using OPT (with sand amps) is that I'm lousy and ignorant for making them and so there is really not dilema - between paying for some or not using them at all
believe me, I'll use them in case that I know how to actually make (design) them, and then I would pay someone to wind them for me
anyway, there are several guys around, having my Iron in Iron Pumpkins and then Cinemag Iron in my amps - completely happy
and some of them are using big ole Tannoys, in boxes designed by me - with that tricky tweet autoformer made aircore big as hat
so, that's one place where I avoided Iron, actually
That's some sweet reading. Right up there with your LIghtspeed doc. Love it.
So in terms of Iron Pre—Wiper -> 33K -> ground? Or wiper -> 33K -> Wiper pad on Iron Pre? Or as Russell was asking is it an additional wiper -> 33K -> ground, leaving the wiper connection to Iron as is? I've been using 50K alps blue velvets... Would like to mess around and see/hear what's what.
if you're going to deal with pot, let's make it pot only work
what's wrong with soldering damn resistor ditto between wiper and CCW pins on pot itself?
Brilliant! That will lower my time frame from 48 hours to 24 hours!😀
Russellc
Agreed!
I am not sure 100% what you want to try, but per ZMs note previously and my review of the article, you'd do this with a linear pot. ZM recommends a 100k linear pot with the 33k (edited to 18k) resistor - that jives with the ratio in the article. I'm sure if you're talking about using the 50k Blue Velvet audio taper with this mod. Still, it would be cool to see what it does. If I misread/misinterpreted ZM's recommendation, the article, or your post - apologies. My brain is full after trying to sort a whole other DIY situation. 😀
I think I'll wait for others to report some results before I try to think again.
as I said - that's altering Linear function pot to be better than factory made Logarithmic function pot
logarithming already logarithm pot is not double dumb, it's triple dumb
So, I did read it correctly. Excellent! 😀
I thought it was 2^9 dumb... or did I get that inverted
I thought it was 2^9 dumb... or did I get that inverted![]()
Ok I'll admit it, I didn't catch that. Now for linear pot search.😕
Russellc
guess with which I did log trick, having same looking pots on desk, several Logs and several Lins
funny 15 mins of tracing what I did wrong with gain stage
I have a 50K linear TKD I picked up for cheap that I can try this with....Understood about Alps log pot!
50K is sorta low in value, because you need no more than , say , 10K to shunt wiper to CCW pin
in fact, it is perfect, if upstream (sources) are having some Cojones
btw. TKD is for Sissies, going for no-brainer
The bell just rang - I think the universe is trying to tell me that I might have a tough time with a pre-amp chassis - it came with wine.
strictly in Science Purpose,care to send some to Mithrandir?
he's transforming it ....... in water!
- What's wrong with the kiss, boy?
