"WHAMMY" Pass DIY headphone amp guide
Looks great.
Where did you add the 100 Ohm resistors for the line out?
Thank you, I simply ran the cabling from the switched contacts of the headphone amp and connected the ground to ground and attached a 100 ohm resistor to the left and right in series so the other end of the resistor would be connected to the RCA centre pin as the left and right are positive. 150 ohm would also work as I've seen that value on some other amps.
Gaz
I took the time this evening to upgrade the wiring to some tour grade Van Damme microphone cable and took a few pics including where to put the 100 ohm resistors for the pre out in case anyone wants to do the same.
6L6
Moderator
Joined 2010
I have a whammy with Toshiba and another with Fairchild (and I've built one with IRF...) and there's no difference in bass.
It's (the whammy) a very neutral design that doesn't editorialize at all. Changing opamps won't make much difference either. If you want more bass, I'd honestly grab a different set of headphones, or (more fun) put a Schiit Loki in front of it and EQ to your taste. :yes:
Joined 2007
One of them out in one minute, cleaning the holes and the new one in...
I really did it and still find that the FQP did more bass for my ears.
Ok, I once ruined a board. Good thing was, I had a few more of them and had to resolder all the rest. Except the opts I made it. Regarding the Toshibas I couldn't bring enough heat in for some legs. So they work as dwarfs in my USSA-5. Probably a more powerful solder station would have saved their legs. Still they are fine.
Or was there another trick?
I use the IRF in my build. I did find that the LM833 op amp gave a tad more bass than the OPA2134. Which reminds me, I have been reading about other op amps and wondered if anyone has tried the OPA2107 in their Whammy? This is a DiFet op amp and apparently are meant to be really good. They are quite pricey though on digykey and mouser.
Joined 2009
I am ashamed as the boy I got the trick from....
you have to put so much solder on the three legs that they are all covered.
Then you heat the chunk with the solder iron in a nearly horizontal position fast and furious and pull the beast out from the other side.
It works fine, I lost none since doing it in this way.
Joined 2009
So I think there is no big difference between the IRF and the FQP.
:mad:
Keyword search shows users meldrew and scranton both had favorable results with OPA2107.
BK
Maybe try hot air? And lots of extra flux and solder.
