Wayne's BA 2018 linestage
I assume there is no way with a simple DVM to test whether the original output TTA004/TTC004 pair are fried?
Assuming the safe option is to just bin them..?
Yes you can test them. Set your DVM to diode test and test the emitter to base junctions just like testing the LED except the junction voltage will be .66 volts when forward biased. Then check the other junction base to collector. Lastly check the emitter to collector to see it's not shorted.
ordered new parts.
LEDs did not come out in a testable condition, so nothing learned (other than to allow parts to stand off the board to enable later cutting of legs if required...)🙄
And apologies I missed the earlier post... about R31 and R26 not being on schematic.
The second board of the stereo pair have different numbers...
R7 (on other board is R38)
R11 (=R32)
R12 (=R33)
R13 (=R31)
R14 (=R26)
Appreciate the help,
thanks,
m
I think, which could get me in trouble, if you swapped and rotated the pnp and npn transistors you would have a forward biased collector-base junction, thus V+ and V- would be across the LED. Minus the junction voltages. For a little while. Not much resistance to impede the current.
  • Thank You
Reactions: BeardyWan
Thought I would share my partially finished Wayne’s build with Academy Audio’s new BIB kit.
Lenny has been VERY helpful explaining what I need and how to hook it up.
I got the optional BOB board so I have fully balanced input and output. He also included a nice mounting bracket to hold the MCU module and the screen.
It works and sounds really nice. I just need to put it in the chassis, add the other 2 xlr inputs, and figure out the best way to add my headphone jack plus a rca inputs/outputs for more versatility.
It sounds really good.
