Ah! The photo in the data sheet has "1 2 3" but the drawing has "1 2 C". So yes, C is 3.
Usually the chassis ground is at the PSU, but that might not work with Silent Switcher... need to see your entire wiring diagram.
Hmm ok let me put down my wiring with the power amp and preamp in a single chassis and how I did the wiring to showcase if this works. As I think I get lot of hum which seems to be ground loop issue
Apart from checking the DC offset being closer to the 0mV on each of the mono boards outputs, what else should I check for the bias any other things on the preamp.
Any pointers guys, sorry I looked around in the thread but could not find instructions on the PDF document as well.
thanks
Twist the pot to make the dc offset at the output zero or as close as you can get it. That’s it.
Thanks Jim
Is this a commercially available supply or of your own design?
It's basically a slightly tweaked version of the supply on the whammy differences being you can't lift the voltage on the output with the LEDs they are simply to provide an idle load and there's also provision for a power LED indicator. Wayne is credited for the original design.
I have made some of my own designs based off this for single rail and another dual rail but with two positive outputs for making PSU boxes for multiple projects.
Is this PS only board available for purchase? If so, details please.
OR, perhaps, a Group Buy may be a possibility?
Many thanks
It will be soon. I first need to get a small batch made for testing before planning on making them available.
Stereo store PCB will look like this, in BLUE, with a couple revisions to the silkscreen to clarify connections.
I’ll post a photo of the PCB as soon as I have one.
New silkscreen -
New silkscreen -
Sorry guys, I picked the wrong setting when I added the product and it screwed up the shipping calculator. I've fixed the error and confirmed it's working. You may need to wait a few hours for the Shopify shipping rate cache to refresh if you're trying again using the same address, but I just checked and it seems to have already refreshed for my test addresses. If you experience any further issues please email contact@diyaudiostore.com. Thanks!
- Wayne's BA 2018 linestage
