Wayne's BA 2018 linestage
Joined 2016
Measurements of Wayne's BA 2018 linestage done with Focusrite 2i2 / REW
Well, in post #837 Wayne showed a measurement of distortion vs. output voltage.
I dug out the pictures from my own measurements, done with a Focusrite 2i2 and REW. My BAF 2018 linestage (see my earlier posts in this thread) was built with Toshiba TTA004B and TTC004B as output transitors, 15R emitter resistors for the outputs, and a WIMA MKP10 1uF cap at the output.
All measurements are with 0.7V RMS input signal, attenuated by the preamp resistive divider circuitry the line stage is built.
So here it goes, 64 mV RMS output:
attachment.php
The next is 390 mV RMS output. Please ignore the hash to the right of the 1kHz fundamental, that's spuriae from the relay-based attenuator's control logic that is feeding through into the signal:
attachment.php
Now, 1.49 V RMS output voltage:
attachment.php
And, 2.63 V RMS output (no attenuation):
attachment.php
Finally, I got some stepped frequency sweeps to show distortion vs. frequency.
First, at 64 mV RMS ouput voltage:
attachment.php
And the second one at 2.63 V RMS output voltage:
attachment.php
For my build of the linestage in the configuration I had at the time, the lower -3dB point was at around 1.5 Hz (due to the output DC blocking / coupling capacitor), and the upper -3dB point was higher than 2.2 MHz (the upper limit of my frequency generator :p).
Hope you find this interesting,
best regards,
Claas
Founder of XSA-Labs
Joined 2012
Thanks for the measurements Chede. I was also using TTA004 and TTC004 outputs during tests presented here. My THD and profiles were similar to your as measured but I had some +/30v rails.
Here was 2Vpp into 52kOhm load with 0.0017% THD and second harmonic dominant signature - nice sounding preamp:
762898d1560517273-yarra-preamplifier-hpa-melbourne-db-buy-wba18-2vpp-52kohm-fft-jpg
Was your load impedance 64ohm? That's headphone amp terrritory more so than line-level preanmp.
Joined 2016
Hi xrk971,
no, load impedance in my case was 100k Ohms. Sorry, had not included all info in my previous thread ... the last number in the naming of my measurements just was the setting of my volume control ;), which sits before the input to the line stage ... it has a constant 50k input impedance, but it's output impedance (what the line stage sees as input impedance varies from about 1k at low volume settings to about 25k at max. volume setting.
Resulting output voltage of the line stage for a signal input of 0.7V RMS into the volume control is noted before each pic.
Rail voltage in my case is +/- 18V dc.
Best regards, Claas
Not as yet. We are waiting patently for them to come up in the Forum Store. Wayne has very kindly redesigned the board for our easier use and sent the info to DIYaudio Store decision maker/manager. We can not but continue to wait!
[edit:
See that I have been beaten by a minute by our esteemed 6L6]
