transistor amp not working after shorting output
Hi.
All caps look good? did you measure them?.
Asking because I had a similar case here with distortion on output , caused by a bad cap in my case.
ts 0.7v between bases of both transistors white wire between collectors is 28v between emitters is 07v
from Base to Base ? one transistor to other?. Have you measured the two pins on each transistors like this ? what voltage you have?.
Hi.
from Base to Base ? one transistor to other?. Have you measured the two pins on each transistors like this ? what voltage you have?. View attachment 1257017
hi, all the things you ask i posted before but in short. i did measure there and you can find voltages in previous posts. btw i dont have way to measure caps on my meter so i am not sure. could you suggest a bad cap from this picture ?
One way would be to measure resistance ( 200 ohm range or so ) on each cap, if you measure a few ohms clear sign it's a bad cap, unless it is in parallel with a small value resistor.
A small LCR tester like this one is cheap and can measure caps, inductors, test transistors , mosfets. very handy. and cheap!.
If both output transistors have 0.7v on Base emitter, problem must be somewhere else.
Even if middle point ( right before the speaker output cap and ground ) is not half of the supply , 55 / 2 = 27.5v It wouldn't sound bad since you don't hit the rails . if im not mistaken.
Input, First transistor wrong resistor values , not biased correctly maybe.
