Everybody does that sooner or later. I've even seen some caps like that in working equipment. Hmmmmm.
Did you check if it survived? It’s not that terrible of a burn.
No I didn’t, I just ordered a 10 pack from eBay ($5.61 w/shipping). So anybody in need of a 22nf WIMA cap can come see me🙂
Yes to both🙂
Also, HS1&2 are can be small extruded aluminum fin type, they barely get warm.
Actually, I didn’t use HS at all for my last pair of SLB’s.
577202B00000G Aavid, Thermal Division of Boyd Corporation | Fans, Thermal Management | DigiKey
R7 and R8 have a secondary purpose of bleeding the charge off the main caps when power is shut off.
Oh Sh*t, I was soldering in some spades and totally smoked C23 by carelessly resting the iron on it. Unfortunately I have no spares 😡
I can send you a couple, if you PM me your address. Wima 22nF, right?
Andy
In post #306 @md_Stryker posted this Mouser BOM.
Mouser Electronics
If you search there's also a recent BOM for the single version.
Mouser Electronics
https://www.diyaudio.com/forums/gro...-mx-class-power-supply-gb-14.html#post5782064
Please do not edit the cart, but sve it to your own before changing anything!
Good day,
May i ask (i know that is has aswered but) because i have them is it wise? To put the NIC 33000uF 35v NRLM333M35V35X50F ? Esr 0,018 and ir 7150mA?
Thank you
Thank you
Probably not as it may cause too high of a ripple current. We would have to run a simulation and see if ripple current is exceeded for the cap. The 15,000uF cap we spec’d was chosen based on 5A draw and staying within ripple current rating. Exceeding it causes heating and shorter cap lifetime.
I'll try tool #1. I have a desoldering station but it isn't helpful. I can't even get the solder to melt in order to suck it up...the heat is just wicked away by the plane that runs through most of the board. I've tried extreme temperatures (max of my iron 850˚F) and solder sucker. I've tried to "flood" the hole and then suck up the solder. Obviously nothing has worked. What would normally take about two minutes I've invested about 30 into...so far.
That’s one of the downfalls of 2mm thick board and 2oz copper planes. Usually I am able to remove the solder by preheating the spot with a jet of hot air from my SMT hot air pencil. Usually 45 seconds of preheat. Then use a wide chisel tip soldering iron to apply the final heat followed by a plunger type solder sucker. If that solder goes liquidus it has to come out under suction.
High quality copper braid like NTE brand with liquid flux dripped onto the wick and the fat chisel tip iron will also usually pull stubborn solder up. I would not drill it. You will break your drill as those only require the slightest lateral pressure to break.
You are working it from the exposed back side I assume? The SMT hot air pencil with large dia tip set to 300C should melt that no problem in a minute.
- Group Buys
- The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
