DN2540 is used as level shifter for Schade - triodizing enhanced part ( positive Ugs)
IRF510 is used as level shifter for depletion parts - negative Ugs
find entire presentation where I explained logic of this biasing ..... I forgot where it is
For me it’s a complete version of the Boo 😁
If anyone is interested to play with their Lu fets I can share the gerbers for r1 here or in a pm.
I have also 4 pcbs of r0 that I can donate. They have the wrong tracks cut, you only need to place some wires to do the correct bridges and some cleaning.
What are those connectors you are using for the Vcc's and the Out? Look almost like some sort of BNC.
Those are rc bullet connectors, very cheap. I use some between the amps and speakers without problems for many years.
Oh boy, both amps are now playing music. It was easier than expected to setup everything.
Thanks ZM
Thanks ZM
I am listening Coleman Hawkins tonight.
At 50mW that go to the speakers at this hour I can say it’s very good. What I noticed is that it does better at low level details compared to the mosfet version.
I mostly don’t like to do this type of comments because every new amp sounds better than the old one … you know how it is.
I am curious to play with the Vds of the LU. I think it can be done while you listen to music 😁
This is the part that implies a lot of fun.
- The marriage
