The BA-3 as preamp build guide
What feet are those? 🫣
Modushop-chassis?
Yes I would swap those too.
Modushop has some normal-good-looking ones, too. A bit cumbersome to attach them, but absolutely faisible.
I have some modest rubber-feet on mine too, and it got considerably warmer when I put the amp into a closet (front and back removed!), so the airflow is influencial!
Modushop-chassis?
We are FAB. We aren’t afraid of a little heat :rofl:
Me not, me am a darn scared sissy! 🫣🔥🧯
Me: 71773582-88FF-4CDF-BD4F-29341E2C7CEF.jpeg
You: E49A92B2-B7D3-42B8-9E09-593D58C1E328.jpeg
The transformers finally made it to destination, next piece of shopping the case but I think I am set there with your advise, since I have a friend coming off the US I was thinking about getting the volume pot if I can find a better deal there but still need you to advise value (50k or 100k), brand and which would better fit considering the construction (dual mono, I-select board and Sigma22 PSUs).
Which of these would fit the bill, Shunt 25K stereo? https://khozmo.com/products_dale_shunt.html
Grazie
It's mostly a matter of preference. The price difference between the various models is not huge. The ladder one is a bit more because there are a lot more resistors. The advantage is that there are only ever two resistors involved. The shunt version has that advantage, too, but it has variable impedence, which may or may not be something you want. I've used the series one myself, and been very happy with it.
So the series one in 25K could fit the bill of my build?
Well, this isn't good.
I have been using my 2nd BA-3 preamp for about six months.
I started to notice that the right channel was weaker than the left. Confirmed that on multiple FW amps.
I opened it up and checked the bias/offset settings for both channels.
Bias for both was 48DCV and offset was ~ 0. That's not good. Bias = 1DCV is the goal.
I unplugged and rolled back the trim pots to 0.
Took new readings and got the same results.
If I move both P1's nothing changes with the bias.
The PSU is delivering 24 DCV. + / -.
No parts looks fried, but something must be.
I appreciate any guidance.
Depth wise, 30 or 40cm? Maybe 40 is too much, slight difference in price but lot more footprint and space is always precious both in and outside.
Top cover standard or grilled for better heat dissipation?
Feet wise, those from ModusShot don't look that great, any hint at where to find better ones? I like 'em round and low, maybe half an inch or so height not to rip too much space in height unless you suggest differently.
Next step will be the volume pot and then RCAs, knobs, power switch (which I'd like to be matching the power amp, a round button with LED light)...
Grazie
Giovanni,
Did you see the links concerning feet I posted a few weeks ago?
It’s an italian house and they have plenty…
Yes I saw it, I am actually debating on the depth of the case, either 300mm or 400mm, not much of a price difference but footprint and empty space, my guess is that 2x toroids on the left side, the iSelect on the bottom, 2x Sigma22 in the middle and the BA-3 should have plenty space even within 300mm, maybe I should arrange a quick CAD prototype to find out.
This is the case by the way
Grazie
p.s. suggestion for the feet?
So far, by a quick sketch, it seems 300mm depth won't fit it comfortably, I might have done something wrong but:
  • 2 x toroids 63mm diameter
  • 2 x Sigma22 boards 150 x 89mm
  • 1 x BA-3 board 140 x 70mm
  • 1 x I-Select board 160 x 49mm
Of course matter of laying it all out but I wonder if I should go for the extra 10cm depth case...
Move second Sigma for 90 degres and done!
