Shigaclone MKII Black - The builders Thread
Pictures
Thank you for the fast response, I appreciate it very much.
Here are pictures from all cables and as you can see I have taken away the heat shrink sleaves to check cable separation and continuity and they are just fine.
Playing
After some rearangements on the board we are good!
Me like! From cold start it is way better than my PS1 cd player with Salas shunts. Better resolution, 3 D stage, bass whatever you want to compare it is way better and still, my PS1 cd player wipes the floor with many good cd players already.
Now it is on repeat for some days and then I will start making it betterb if that is possible but appearantly it is doable according to this thread.
Hi Tibi,
All new connectors and cables did not change anything so I am committing to changing IC's. I bought the pictured IC's when I originally purchased shiga because I was not sure of my soldering skills. I ended up waiting and getting the soldering experience but looks like I still will need. Do these IC's look right for replacement. Thanks!
best regards,
Steve
Hello Tibi,
First of all I feel sorry for you for the loss of your good friend. Please keep him in good memory!
The transformer you send me recently acts wierd. Refurring to your picture (see attachtsment) I have to use other wires to make it work. I have to connect the two 220Vac and use brown and black for current to make it work. Doing so the PSU lights up. Did not dare to connect it to the board. I used my old transformer and wired it as shown on the picture and everything works fine, but the backlight of the LCD stays dark. What is wrong?
Robert
PSU
I have a question about the LDO regulator for the PSU.
I see that it is surgested LT1086 but I have 1085 at home so the question is are they comparable??
Seem that the only difference is the amount of drop out voltage where 1086 have 1.2 volt drop out while 1085 have 1.3 volt drop out.
Hi Tibi,
I need help in how to test LC78601 oscillator. I have a basic understanding of VCO's/PLL's. I see pins 3-7 are PLL circuit, pin 11 is test mode TMOD and pin50 FSX is test output [7.35kHz test mode or low output normal]. 60/61 are external clock. I don't know where to go from there. Do I need to analyze PLL or just look for a VCO output. Which pins? Or am I just looking for a signal at its destination from oscillator? If this inquiry is beyond this forum I apologize. Thanks for any help.
regards,
Steve
Robert,
Please check primary continuity between wires and secondary as well. These are factory tested transformers and when properly used are 100% working proof. Maybe one primary wire was broken due some stress.You may check up to where the connection is done with CuEm wire winding start.
Tibi
Reference voltage is same 1,25V on both LT1085 and LT1086. You may use 1085 instead 1086. Please keep drop out voltage above 3V for good regulation.
Tibi
Hi Steve,
You may check if LC78601 oscillator still work by connecting your scope on pin 60 or over capacitor C58. If you see a deformed square signal (due oscilloscope input capacitance) at 16,9344MHz, than LC78601 may still work and you need to proceed replacing LA9242. LA6541 may work up to 12V, so this is not be replaced.
Tibi
