http://www.bcae1.com/temp/ausettingbias.swf
Turn the bias pot in the good channel slowly just until you see an increase like in the demo above.
Do the same for the distorted channel.
The amp has to be clamped to the heatsink when doing this.
Perry,
What do I use to open the attachment you sent? I cant open it.
it starts downloading and then i try to open it and it says to try to seach the web for a program
Yes. I just need to know that the bias is functioning. That may help guide further troubleshooting if you don't have a scope.
Ok I got the voltage to 2.12vdc with both adjusted. It seems like the one on the bad channel isn't as responsive as the one on the good channel.
- General Interest
- Car Audio
- Rockford 500a2
