Rockford 500a2
You'll have to isolate the FETs to test individually. You can do this by lifting the gate leg or sliding the 10 ohm gate resistors off of the pads. Do not apply power with the gates out of the circuit.
As a side note, we need to try defeating the protection circuit on the 'bad' channel when we get past this problem.
I clamped it back into the heatsink to play it safe.
The good channel is good again! The bad one is still bad. I did notice that when I was playing audio on the good channel the voltage went up across the resistors to 2.4* vdc and on the distorted channel it was only around 2.14 vdc
