Rockford 500a2
Probably. It's possible that the drive circuit was damaged.
In this amp and similar amps, expect the replace the gate resistors, the 20 ohm driver resistors and the MMBTA06 and MMBTA56 driver transistors.
If the 0.1 ohm source resistors are out of tolerance, you may have protection circuit damage.
